74CBTLVD3384BQ,118
74CBTLVD3384BQ,118
    NEXPERIA(安世)
    DHVQFN24_5.5X3.5MM_EP
    带5位输出的10位电平移位总线开关启用 DHVQFN24_5.5X3.5MM-EP 3~3.6V
74CBTLVD3384BQ,118 数据手册
74CBTLVD3384 10-bit level-shifting bus switch with 5-bit output enables Rev. 3 — 17 April 2019 Product data sheet 1. General description The 74CBTLVD3384 is a dual 5-pole, single-throw bus switch. The device features two output enable inputs (nOE) that each control five switch channels. The switches are disabled when the associated nOE input is HIGH. Schmitt-trigger action at control inputs makes the circuit tolerant of slower input rise and fall times. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • • • • • Supply voltage range from 3.0 V to 3.6 V High noise immunity Complies with JEDEC standard: • JESD8-B/JESD36 (3.0 V to 3.6 V) ESD protection: • HBM JESD22-A114F exceeds 2000 V • CDM AEC-Q100-011 revision B exceeds 1000 V 5 Ω switch connection between two ports -3 dB bandwidth at 600 MHz Rail to rail switching on data I/O ports CMOS low power consumption Latch-up performance exceeds 250 mA per JESD78B Class I level A IOFF circuitry provides partial Power-down mode operation Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74CBTLVD3384PW -40 °C to +125 °C TSSOP24 plastic thin shrink small outline package; 24 leads; body width 4.4 mm SOT355-1 74CBTLVD3384BQ -40 °C to +125 °C DHVQFN24 plastic dual in-line compatible thermal enhanced SOT815-1 very thin quad flat package; no leads; 24 terminals; body 3.5 × 5.5 × 0.85 mm 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables 4. Functional diagram 1OE 1 1A1 1A2 1A3 1A4 3 4 7 8 1A5 11 1A1 2OE 2 5 6 9 1B1 1B2 1B3 1B4 1B5 2A1 2A2 2A3 2A4 2A5 14 13 17 18 2B1 16 21 2B2 19 2B3 1A5 1OE 22 20 2A5 23 2B4 2B5 2OE 001aam095 Fig. 1. 2 11 10 1B1 10 2A1 15 3 Logic symbol Fig. 2. 1B5 1 14 15 22 23 2B1 2B5 13 001aak877 Logic diagram 5. Pinning information 5.1. Pinning 1 terminal 1 index area 24 VCC 1OE 74CBTLVD3384 74CBTLVD3384 1B1 2 23 2B5 1A1 3 22 2A5 1A2 4 21 2A4 1B2 5 20 2B4 1B3 6 19 2B3 1A3 7 18 2A3 1A4 8 17 2A2 1B4 9 16 2B2 1B5 10 15 2B1 1A5 11 14 2A1 GND 12 Product data sheet 4 21 2A4 1B2 5 20 2B4 1B3 6 19 2B3 1A3 7 18 2A3 1A4 8 17 2A2 1B4 9 16 2B2 GND(1) 15 2B1 1A5 11 14 2A1 001aam101 Transparent top view (1) This is not a supply pin, the substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However if it is soldered the solder land should remain floating or be connected to GND. 13 2OE Pin configuration SOT355-1 (TSSOP24) 74CBTLVD3384 22 2A5 1A2 1B5 10 001aam099 Fig. 3. 23 2B5 3 2OE 13 24 VCC 2 1A1 GND 12 1OE 1 1B1 Fig. 4. Pin configuration SOT815-1 (DHVQFN24) All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 2 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE 1, 13 output enable input (active LOW) 1A1 to 1A5 3, 4, 7, 8, 11 data input/output (A port) 2A1 to 2A5 14, 17, 18, 21, 22 data input/output (A port) 1B1 to 1B5 2, 5, 6, 9, 10 data input/output (B port) 2B1 to 2B5 15, 16, 19, 20, 23 data input/output (B port) GND 12 ground (0 V) VCC 24 positive supply voltage 6. Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. Input Input/output 1OE 2OE 1An, 1Bn 2An, 2Bn L L 1An = 1Bn 2An = 2Bn L H 1An = 1Bn Z H L Z 2An = 2Bn H H Z Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC supply voltage VI input voltage VSW switch voltage enable and disable mode IIK input clamping current VI/O < -0.5 V -50 - mA ISK switch clamping current VI < -0.5 V -50 - mA ISW switch current VSW = 0 V to VCC - ±128 mA ICC supply current - +100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] Tamb = -40 °C to +125 °C -0.5 +4.6 V [1] -0.5 +4.6 V [1] -0.5 [2] VCC + 0.5 V The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. For TSSOP24 packages: Ptot derates linearly with 5.5 mW/K above 60 °C. For DHVQFN24 package: Ptot derates linearly at 4.5 mW/K above 60 °C. 74CBTLVD3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 3 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VSW switch voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate [1] Conditions enable and disable mode VCC = 3.0 V to 3.6 V [1] Min Max Unit 3.0 3.6 V 0 3.6 V 0 VCC V -40 +125 °C 0 200 ns/V Applies to control signal levels. 9. Static characteristics Table 6. Static characteristics At recommended operating conditions voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max VIH HIGH-level input voltage VCC = 3.0 V to 3.6 V 2.0 - - 2.0 - V VIL LOW-level input voltage VCC = 3.0 V to 3.6 V - - 0.9 - 0.9 V II input leakage current pin nOE; VI = GND to VCC; VCC = 3.6 V - - ±1 - ±20 μA Vpass pass voltage VI = VCC; see Fig. 7 to Fig. 11 - - - - - V IS(OFF) OFF-state leakage VCC = 3.6 V; see Fig. 5 current - - ±1 - ±20 μA IS(ON) ON-state leakage current - - ±1 - ±20 μA IOFF power-off leakage VI or VO = 0 V to 3.6 V; VCC = 0 V current - - ±10 - ±50 μA ICC supply current VI = VCC; IO = 0 A; VCC = 3.6 V; VSW = GND or VCC - - 20 - 50 μA VI = GND; IO = 0 A; VCC = 3.6 V; VSW = GND or VCC - - 100 - 150 μA - - 300 - 2000 μA VCC = 3.6 V; see Fig. 6 ΔICC additional supply current pin nOE; VI = VCC - 0.6 V; VSW = GND or VCC; VCC = 3.6 V CI input capacitance pin nOE; VCC = 3.3 V; VI = 0 V to 3.3 V - 0.9 - - - pF CS(OFF) OFF-state capacitance VCC = 3.3 V; VI = 0 V to 3.3 V - 2.5 - - - pF CS(ON) ON-state capacitance VCC = 3.3 V; VI = 0 V to 3.3 V - 9.0 - - - pF [1] [2] [2] All typical values are measured at Tamb = 25 °C. One input at 3 V, other inputs at VCC or GND. 74CBTLVD3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 4 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables 9.1. Test circuits VCC VCC nOE VIH Is A nBn nAn Is A A GND Vl nOE VIL Is VO nAn nBn GND Vl VO 001aam032 001aam033 VI = VCC or GND and VO = GND or VCC. Fig. 5. VI = VCC or GND and VO = open circuit. Test circuit for measuring OFF-state leakage current (one switch) Fig. 6. Test circuit for measuring ON-state leakage current (one switch) 9.2. Typical pass voltage graphs 001aam102 1.90 Vpass (V) 1.85 20 µA 1.90 Vpass (V) 1.85 1.80 100 µA 1.80 001aam103 20 µA 100 µA 1.75 1.75 1.70 1.70 2 mA 1.65 4 mA 2 mA 1.65 4 mA 1.60 1.55 3.0 Fig. 7. 3.2 1.60 3.4 VCC (V) 3.6 Pass voltage versus supply voltage; Tamb = 125 °C (typical) 1.55 3.0 Fig. 8. 001aam104 3.2 3.4 VCC (V) 3.6 Pass voltage versus supply voltage; Tamb = 85 °C (typical) 1.90 Vpass (V) 1.85 20 µA 1.90 Vpass (V) 1.85 1.80 100 µA 1.80 001aam105 20 µA 100 µA 1.75 1.75 1.70 1.70 2 mA 2 mA 4 mA 1.65 1.65 1.60 1.55 3.0 Fig. 9. 1.60 3.2 3.4 VCC (V) Pass voltage versus supply voltage; Tamb = 25 °C (typical) 74CBTLVD3384 Product data sheet 4 mA 3.6 1.55 3.0 3.2 3.4 VCC (V) 3.6 Fig. 10. Pass voltage versus supply voltage; Tamb = 0 °C (typical) All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 5 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables 001aam106 1.90 Vpass (V) 1.85 1.80 20 µA 1.75 100 µA 1.70 1.65 2 mA 4 mA 1.60 1.55 3.0 3.2 3.4 VCC (V) 3.6 Fig. 11. Pass voltage versus supply voltage; Tamb = -40 °C (typical) 9.3. ON resistance Table 7. Resistance RON At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 12. Symbol Parameter RON [1] [2] ON resistance Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max ISW = 64 mA; VI = 0 V - 3.7 7.0 - 10.0 Ω ISW = 24 mA; VI = 0 V - 3.7 7.0 - 10.0 Ω ISW = 15 mA; VI = 1.2 V - 4.7 10.0 - 12.0 Ω VCC = 3.0 V to 3.6 V [2] Typical values are measured at Tamb = 25 °C and nominal VCC. Measured by the voltage drop between the A and B terminals at the indicated current through the switch. ON-state resistance is determined by the lower of the voltages of the two (A or B) terminals. VSW V VCC nOE VIL nAn Vl nBn GND ISW 001aam034 RON = VSW / ISW. Fig. 12. Test circuit for measuring ON resistance (one switch) 74CBTLVD3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 6 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables 10. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; for test circuit see Fig. 15 Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max - - 0.11 - 0.22 ns tpd propagation delay nAn to nBn or nBn to nAn; VCC = 3.0 V to 3.6 V; see Fig. 13 [2][3] ten enable time nOE to nAn or nBn; VCC = 3.0 V to 3.6 V; see Fig. 14 [4] 1.5 2.8 5.0 1.5 6.0 ns tdis disable time nOE to nAn or nBn; VCC = 3.0 V to 3.6 V; see Fig. 14 [5] 0.8 3.2 7.0 0.8 8.0 ns [1] [2] [3] [4] [5] All typical values are measured at Tamb = 25 °C and at nominal VCC. The propagation delay is the calculated RC time constant of the typical on-state resistance of the switch and the load capacitance, when driven by an ideal voltage source (zero output impedance). tpd is the same as tPLH and tPHL. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. 10.1. Waveforms and test circuit VI input VM VM 0V tPHL tPLH VOH VM output VM VOL 001aai367 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 13. The data input (nAn, nBn) to output (nBn, nAn) propagation delay times VI nOE input VM VM GND tPZL tPLZ 1.8 V output LOW to OFF OFF to LOW VM VX VOL tPZH tPHZ VOH VY output HIGH to OFF OFF to HIGH GND VM outputs enabled outputs disabled outputs enabled aaa-000029 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 14. Enable and disable times 74CBTLVD3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 7 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables Table 9. Measurement points Supply voltage Input Output VCC VM VI tr = tf VM VX VY 3.0 V to 3.6 V 0.5VCC VCC ≤ 2.0 ns 0.9 V VOL + 0.15 V VOH - 0.15 V VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 15. Test circuit for measuring switching times Table 10. Test data Supply voltage Load VCC CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 3.0 V to 3.6 V 30 pF 1 kΩ open GND 3.6 V 74CBTLVD3384 Product data sheet VEXT All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 8 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables 10.2. Additional dynamic characteristics Table 11. Additional dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); VI = GND or VCC (unless otherwise specified); tr = tf ≤ 2.5 ns. Symbol Parameter f(-3dB) [1] [2] -3 dB frequency response Conditions Tamb = 25 °C VCC = 3.3 V; RL = 50 Ω; see Fig. 16 [2] Unit Min Typ [1] Max - 575 - MHz Typical values are measured at Tamb = 25 °C and VCC = 3.3 V. fi is biased at 0.5VCC. VCC 0.5 VCC nOE VIL RL nBn fi nAn GND dB aaa-000028 nOE connected to GND; Adjust fi voltage to obtain 0 dBm level at output. Increase fi frequency until dB meter reads -3 dB. Fig. 16. Test circuit for measuring the frequency response when channel is in ON-state 74CBTLVD3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 9 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables 11. Package outline TSSOP24: plastic thin shrink small outline package; 24 leads; body width 4.4 mm D SOT355-1 E A X c HE y v M A Z 13 24 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 12 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 7.9 7.7 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT355-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig. 17. Package outline SOT355-1 (TSSOP24) 74CBTLVD3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 10 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables DHVQFN24: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 24 terminals; body 3.5 x 5.5 x 0.85 mm D B SOT815-1 A A E A1 c detail X terminal 1 index area C e1 terminal 1 index area e 2 y1 C v M C A B w M C b 11 y L 12 1 e2 Eh 24 13 23 14 X Dh 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 e2 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 5.6 5.4 4.25 3.95 3.6 3.4 2.25 1.95 0.5 4.5 1.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT815-1 --- --- --- EUROPEAN PROJECTION ISSUE DATE 03-04-29 Fig. 18. Package outline SOT815-1 (DHVQFN24) 74CBTLVD3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 11 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables 12. Abbreviations Table 12. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model 13. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74CBTLVD3384 v.3 20190417 Product data sheet - Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74CBTLVD3384DK (SOT556-1) removed. 74CBTLVD3384 v.2 20111216 Modifications: • 74CBTLVD3384 v.1 20110719 74CBTLVD3384 Product data sheet 74CBTLVD3384 v.2 Product data sheet - 74CBTLVD3384 v.1 - - Legal pages updated. Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 12 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74CBTLVD3384 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 13 / 14 74CBTLVD3384 Nexperia 10-bit level-shifting bus switch with 5-bit output enables Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................4 9. Static characteristics....................................................4 9.1. Test circuits..................................................................5 9.2. Typical pass voltage graphs........................................ 5 9.3. ON resistance..............................................................6 10. Dynamic characteristics............................................ 7 10.1. Waveforms and test circuit........................................ 7 10.2. Additional dynamic characteristics.............................9 11. Package outline........................................................ 10 12. Abbreviations............................................................ 12 13. Revision history........................................................12 14. Legal information......................................................13 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 April 2019 74CBTLVD3384 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 17 April 2019 © Nexperia B.V. 2019. All rights reserved 14 / 14 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74CBTLVD3384BQ,118 74CBTLVD3384PW,118
74CBTLVD3384BQ,118 价格&库存
很抱歉,暂时无法提供与“74CBTLVD3384BQ,118”相匹配的价格&库存,您可以联系我们找货
