74HCT138PW,112
74HCT138PW,112
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    3到8线解码器/解复用器;反转 TSSOP16_5X4.4MM 4.5~5.5V
74HCT138PW,112 数据手册
74HC138; 74HCT138 3-to-8 line decoder/demultiplexer; inverting Rev. 7 — 26 March 2018 1 Product data sheet General description The 74HC138; 74HCT138 decodes three binary weighted address inputs (A0, A1 and A2) to eight mutually exclusive outputs (Y0 to Y7). The device features three enable inputs (E1, E2 and E3). Every output will be HIGH unless E1 and E2 are LOW and E3 is HIGH. This multiple enable function allows easy parallel expansion to a 1-of-32 (5 to 32 lines) decoder with just four '138 ICs and one inverter. The '138 can be used as an eight output demultiplexer by using one of the active LOW enable inputs as the data input and the remaining enable inputs as strobes. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2 Features and benefits • Complies with JEDEC standard no. 7A • Input levels: – For 74HC138: CMOS level – For 74HCT138: TTL level • Demultiplexing capability • Multiple input enable for easy expansion • Ideal for memory chip select decoding • Active LOW mutually exclusive outputs • ESD protection: – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V • Multiple package options • Specified from -40 °C to +85 °C and from -40 °C to +125 °C 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 3 Ordering information Table 1. Ordering information Type number Package 74HC138D Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 -40 °C to +125 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 -40 °C to +125 °C DHVQFN16 plastic dual in-line compatible thermal enhanced SOT763-1 very thin quad flat package; no leads; 16 terminals; body 2.5 × 3.5 × 0.85 mm 74HCT138D 74HC138DB 74HCT138DB 74HC138PW 74HCT138PW 74HC138BQ 74HCT138BQ 4 Functional diagram Y0 15 1 A0 Y1 14 2 A1 Y2 13 3 A2 Y3 12 Y4 11 Y5 10 3-to-8 DECODER ENABLE EXITING 1 A0 Y0 15 2 A1 Y1 14 3 A2 Y2 13 Y6 9 Y3 12 Y7 7 E1 Y4 11 E2 Y5 10 E3 Y6 9 Y7 7 4 5 6 4 E1 5 E2 6 E3 mna370 Figure 1. Logic symbol 74HC_HCT138 Product data sheet mna372 Figure 2. Functional diagram All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting Y7 A2 Y6 A1 Y5 A0 Y4 E1 Y3 E2 Y2 E3 Y1 Y0 001aae059 Figure 3. Logic diagram 5 Pinning information 5.1 Pinning 1 A0 terminal 1 index area A1 2 15 Y0 A2 3 14 Y1 E1 4 13 Y2 E2 5 12 Y3 E3 6 11 Y4 Y7 7 10 Y5 GND 8 9 aaa-028342 Y6 74HC138 74HCT138 A0 1 16 VCC A1 2 15 Y0 A2 3 14 Y1 E1 4 13 Y2 E2 5 12 Y3 E3 6 11 Y4 Y7 7 10 Y5 GND 8 9 Y6 aaa-028343 A2 3 14 Y1 E1 4 13 Y2 E2 5 12 Y3 E3 6 11 Y4 Y7 7 10 Y5 9 16 VCC 15 Y0 8 1 2 Y6 A0 A1 GND 74HC138 74HCT138 16 VCC 74HC138 74HCT138 aaa-028344 Transparent top view (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad.However, if it is soldered, the solder land should remain floating or be connected to GND. Figure 4. Pin configuration SOT109-1 Figure 5. Pin configuration SOT338-1 Figure 6. Pin configuration SOT763-1 (SO16) (SSOP16) and SOT403-1 (TSSOP16) (DHVQFN16) 74HC_HCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 5.2 Pin description Table 2. Pin description Symbol Pin Description A0, A1, A2 1, 2, 3 address input E1, E2 4, 5 enable input (active LOW) E3 6 enable input (active HIGH) Y0, Y1, Y2, Y3, Y4, Y5, Y6, Y7 15, 14, 13, 12, 11, 10, 9, 7 output (active LOW) GND 8 ground (0 V) VCC 16 supply voltage 6 Functional description Table 3. Function table Control [1] Input Output E1 E2 E3 A2 A1 A0 Y7 Y6 Y5 Y4 Y3 Y2 Y1 Y0 H X X X X X H H H H H H H H X H X X X L L L H L L L H H H H H H H L L L H H H H H H H L H L H L H H H H H L H H L H H H H H H L H H H H L L H H H L H H H H H L H H H L H H H H H H H L H L H H H H H H H H H L H H H H H H H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 74HC_HCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V - ±20 mA IO output current VO = -0.5 V to (VCC + 0.5 V) - ±25 mA ICC quiescent supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C - 500 mW Ptot [1] total power dissipation [1] For SO16 package: Ptot derates linearly with 8 mW/K above 70 °C. For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 °C. For DHVQFN16 packages: Ptot derates linearly with 4.5 mW/K above 60 °C. 8 Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC138 74HCT138 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 74HC_HCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Min Typ Max Min Max Min Max Unit 74HC138 VIH VIL VOH VOL HIGH-level VCC = 2.0 V input voltage VCC = 4.5 V 1.5 1.2 - 1.5 - 1.5 - V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V LOW-level VCC = 2.0 V input voltage VCC = 4.5 V - 0.8 0.5 - 0.5 - 0.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V HIGHlevel output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage VI = VCC or GND; VCC = 6.0 V current - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - 74HC_HCT138 Product data sheet VI = VCC or GND; IO = 0 A; VCC = 6.0 V All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 pF © Nexperia B.V. 2018. All rights reserved. 6 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting Symbol Parameter Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Min Typ Max Min Max Min Max Unit 74HCT138 VIH HIGH-level VCC = 4.5 V to 5.5 V input voltage 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level VCC = 4.5 V to 5.5 V input voltage - 1.2 0.8 - 0.8 - 0.8 V VOH HIGHlevel output voltage VI = VIH or VIL; VCC = 4.5 V IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V IO = -4 mA 3.98 4.32 - 3.84 - 3.7 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 μA - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.15 0.26 - 0.33 - 0.4 V VOL II input leakage VI = VCC or GND; VCC = 5.5 V current - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 μA ΔICC additional supply current VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A per input pin; An inputs - 150 540 - 675 - 735 μA per input pin; En inputs - 125 450 - 562.5 - 612.5 μA per input pin; E3 input - 100 360 - 450 - 490 μA - 3.5 - - - - - pF CI input capacitance 74HC_HCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 10 Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 9. Symbol Parameter Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 41 150 - 190 - 225 ns VCC = 4.5 V - 15 30 - 38 - 45 ns VCC = 5 V; CL = 15 pF - 12 - - - - - ns - 12 26 - 33 - 38 ns VCC = 2.0 V - 47 150 - 190 - 225 ns VCC = 4.5 V - 17 20 - 38 - 45 ns VCC = 5 V; CL = 15 pF - 14 - - - - - ns - 14 26 - 33 - 38 ns VCC = 2.0 V - 47 150 - 190 - 225 ns VCC = 4.5 V - 17 20 - 38 - 45 ns VCC = 5 V; CL = 15 pF - 14 - - - - - ns - 14 26 - 33 - 38 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns - 6 13 - 16 - 19 ns - 67 - - - - - pF 74HC138 tpd propagation delay [1] An to Yn; see Figure 7 VCC = 6.0 V [1] E3 to Yn; see Figure 7 VCC = 6.0 V [1] En to Yn; see Figure 8 VCC = 6.0 V tt transition time [2] Yn; see Figure 7 and Figure 8 VCC = 6.0 V CPD power dissipation capacitance 74HC_HCT138 Product data sheet CL = 50 pF; f = 1 MHz; VI = GND to VCC [3] All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting Symbol Parameter Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Unit Min Typ Max Min Max Min Max - 20 35 - 44 - 53 ns - 17 - - - - - ns - 18 40 - 50 - 60 ns - 19 - - - - - ns - 19 40 - 50 - 60 ns - 19 - - - - - ns - 7 15 - 19 - 22 ns - 67 - - - - - pF 74HCT138 tpd propagation delay [1] An to Yn; see Figure 7 VCC = 4.5 V VCC = 5 V; CL = 15 pF [1] E3 to Yn; see Figure 7 VCC = 4.5 V VCC = 5 V; CL = 15 pF [1] En to Yn; see Figure 8 VCC = 4.5 V VCC = 5 V; CL = 15 pF tt transition time [2] Yn; see Figure 7 and Figure 8 VCC = 4.5 V CPD power dissipation capacitance [3] CL = 50 pF; f = 1 MHz; VI = GND to VCC - 1.5 V [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of outputs. 74HC_HCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 10.1 Waveforms and test circuit VCC An, E3 input VM GND tPHL tPLH VOH Yn output VM VOL tTHL tTLH mna373 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 7. Propagation delay input (An) and enable input (E3) to output (Yn) and transition time output (Yn) VCC E1, E2 VM input GND tPHL tPLH VOH Yn output VM VOL tTHL tTLH mna374 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 8. Propagation delay enable input (En) to output (Yn) and transition time output (Yn) Table 8. Measurement points Type Input Output VM VM 74HC138 0.5VCC 0.5VCC 74HCT138 1.3 V 1.3 V 74HC_HCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RL RT S1 open CL 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Figure 9. Test circuit for measuring switching times Table 9. Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC138 VCC 6 ns 15 pF, 50 pF 1 kΩ open GND VCC 74HCT138 3V 6 ns 15 pF, 50 pF 1 kΩ open GND VCC 74HC_HCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 11 Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 10. Package outline SOT109-1 (SO16) 74HC_HCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 11. Package outline SOT338-1 (SSOP16) 74HC_HCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Figure 12. Package outline SOT403-1 (TSSOP16) 74HC_HCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm B D A A E A1 c detail X terminal 1 index area terminal 1 index area C e1 e b 2 y y1 C v M C A B w M C 7 L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Figure 13. Package outline SOT763-1 (DHVQFN16) 74HC_HCT138 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 12 Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT138 v.7 20180326 Product data sheet - 74HC_HCT138 v.6 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74HC_HCT138 v.6 20151228 Modifications: • Type numbers 74HC138N and 74HCT138N (SOT38-4) removed. 74HC_HCT138 v.5 20150126 Modifications: • Section 9: OFF-state output current removed because device has no 3-state outputs. • Section 10: Power dissipation capacitance condition for 74HCT138 is corrected. 74HC_HCT138 v.4 20120627 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. • SOT38-1 changed to SOT38-4. 74HC_HCT138 v.3 20051223 Modifications: • The format of this data sheet has been redesigned to comply with the new presentation and information standard of Philips Semiconductors. • Section 3, Section 5 and Section 11: Added DHVQFN package information • Section 9: Added from the family specification 74HC_HCT138_CNV v.2 19970827 74HC_HCT138 Product data sheet Product data sheet Product data sheet Product data sheet Product data sheet Product specification - - - - All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 74HC_HCT138 v.5 74HC_HCT138 v.4 74HC_HCT138 v.3 74HC_HCT138_CNV v.2 - © Nexperia B.V. 2018. All rights reserved. 16 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74HC_HCT138 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 17 / 19 74HC138; 74HCT138 Nexperia 3-to-8 line decoder/demultiplexer; inverting Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74HC_HCT138 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 7 — 26 March 2018 © Nexperia B.V. 2018. All rights reserved. 18 / 19 Nexperia 74HC138; 74HCT138 3-to-8 line decoder/demultiplexer; inverting Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 4 Functional description ........................................4 Limiting values .................................................... 5 Recommended operating conditions ................ 5 Static characteristics .......................................... 6 Dynamic characteristics .....................................8 Waveforms and test circuit .............................. 10 Package outline .................................................12 Abbreviations .................................................... 16 Revision history ................................................ 16 Legal information .............................................. 17 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 26 March 2018 Document identifier: 74HC_HCT138 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC138BQ,115 74HC138D,652 74HC138DB,112 74HC138DB,118 74HC138D,653 74HC138PW,112 74HC138PW,118 74HCT138BQ,115 74HCT138D,652 74HCT138DB,112 74HCT138DB,118 74HCT138D,653 74HCT138PW,112 74HCT138PW,118 74HC138D/AUJ
74HCT138PW,112 价格&库存
很抱歉,暂时无法提供与“74HCT138PW,112”相匹配的价格&库存,您可以联系我们找货
