74HC138-Q100; 74HCT138-Q100
3-to-8 line decoder/demultiplexer; inverting
Rev. 3 — 26 March 2018
1
Product data sheet
General description
The 74HC138-Q100; 74HCT138-Q100 decodes three binary weighted address inputs
(A0, A1 and A2) to eight mutually exclusive outputs (Y0 to Y7). The device features three
enable inputs (E1, E2 and E3). Every output will be HIGH unless E1 and E2 are LOW
and E3 is HIGH. This multiple enable function allows easy parallel expansion to a 1-of-32
(5 to 32 lines) decoder with just four '138 ICs and one inverter. The '138 can be used
as an eight output demultiplexer by using one of the active LOW enable inputs as the
data input and the remaining enable inputs as strobes. Inputs include clamp diodes. This
enables the use of current limiting resistors to interface inputs to voltages in excess of
VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2
Features and benefits
• Automotive product qualification in accordance with AEC-Q100 (Grade 1)
– Specified from -40 °C to +85 °C and from -40 °C to +125 °C
• Complies with JEDEC standard no. 7A
• Input levels:
– For 74HC138-Q100: CMOS level
– For 74HCT138-Q100: TTL level
• Demultiplexing capability
• Multiple input enable for easy expansion
• Ideal for memory chip select decoding
• Active LOW mutually exclusive outputs
• ESD protection:
– MIL-STD-883, method 3015 exceeds 2000 V
– HBM JESD22-A114F exceeds 2000 V
– MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
• Multiple package options
Nexperia
3
Ordering information
Table 1. Ordering information
Type number
Package
74HC138D-Q100
Temperature range Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
SOT403-1
-40 °C to +125 °C
DHVQFN16 plastic dual in-line compatible thermal enhanced SOT763-1
very thin quad flat package; no leads;
16 terminals; body 2.5 × 3.5 × 0.85 mm
74HCT138D-Q100
74HC138PW-Q100
74HCT138PW-Q100
74HC138BQ-Q100
74HCT138BQ-Q100
4
Functional diagram
Y0
15
1
A0
Y1
14
2
A1
Y2
13
3
A2
Y3
12
Y4
11
Y5
10
3-to-8
DECODER
ENABLE
EXITING
1
A0
Y0
15
2
A1
Y1
14
3
A2
Y2
13
Y6
9
Y3
12
Y7
7
E1
Y4
11
E2
Y5
10
E3
Y6
9
Y7
7
4
5
6
4
E1
5
E2
6
E3
mna370
Figure 1. Logic symbol
mna372
Figure 2. Functional diagram
Y7
A2
Y6
A1
Y5
A0
Y4
E1
Y3
E2
Y2
E3
Y1
Y0
001aae059
Figure 3. Logic diagram
74HC_HCT138_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2018. All rights reserved.
2 / 17
Nexperia
5
Pinning information
5.1 Pinning
1
A0
terminal 1
index area
A1
2
15 Y0
A2
3
14 Y1
E1
4
13 Y2
E2
5
12 Y3
E3
6
11 Y4
Y7
7
10 Y5
GND
8
9
74HC138
74HCT138
Y6
A0
1
16 VCC
A1
2
15 Y0
A2
3
14 Y1
E1
4
13 Y2
E2
5
12 Y3
E3
6
11 Y4
Y7
7
10 Y5
GND
8
9
Y6
aaa-028343
aaa-028342
A2
3
14 Y1
E1
4
13 Y2
E2
5
12 Y3
E3
6
11 Y4
Y7
7
10 Y5
9
16 VCC
15 Y0
8
1
2
Y6
A0
A1
GND
74HC138
74HCT138
16 VCC
74HC138
74HCT138
aaa-028344
Transparent top view
(1) This is not a supply pin. The
substrate is attached to this pad using
conductive die attach material. There is
no electrical or mechanical requirement
to solder this pad.However, if it is
soldered, the solder land should remain
floating or be connected to GND.
Figure 4. Pin configuration SOT109-1 Figure 5. Pin configuration SOT403-1 Figure 6. Pin configuration SOT763-1
(SO16)
(TSSOP16)
(DHVQFN16)
5.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
A0, A1, A2
1, 2, 3
address input
E1, E2
4, 5
enable input (active LOW)
E3
6
enable input (active HIGH)
Y0, Y1, Y2, Y3, Y4, Y5, Y6, Y7
15, 14, 13, 12, 11, 10, 9, 7
output (active LOW)
GND
8
ground (0 V)
VCC
16
supply voltage
74HC_HCT138_Q100
Product data sheet
3 / 17
Nexperia
6
Functional description
Table 3. Function table
Control
[1]
Input
Output
E1
E2
E3
A2
A1
A0
Y7
Y6
Y5
Y4
Y3
Y2
Y1
Y0
H
X
X
X
X
X
H
H
H
H
H
H
H
H
X
H
X
X
X
L
L
L
H
L
L
L
H
H
H
H
H
H
H
L
L
L
H
H
H
H
H
H
H
L
H
L
H
L
H
H
H
H
H
L
H
H
L
H
H
H
H
H
H
L
H
H
H
H
L
L
H
H
H
L
H
H
H
H
H
L
H
H
H
L
H
H
H
H
H
H
H
L
H
L
H
H
H
H
H
H
H
H
H
L
H
H
H
H
H
H
H
[1] H = HIGH voltage level;
L = LOW voltage level;
X = don’t care.
7
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+7
V
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
VO = -0.5 V to (VCC + 0.5 V)
±25
mA
ICC
quiescent supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
500
mW
Ptot
[1]
total power dissipation
[1] For SO16 package: Ptot derates linearly with 8 mW/K above 70 °C.
For TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 °C.
For DHVQFN16 packages: Ptot derates linearly with 4.5 mW/K above 60 °C.
74HC_HCT138_Q100
Product data sheet
4 / 17
Nexperia
8
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC138-Q100
74HCT138-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9
Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C
to +125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
74HC138-Q100
VIH
VIL
VOH
VOL
HIGH-level
VCC = 2.0 V
input voltage
VCC = 4.5 V
1.5
1.2
1.5
1.5
V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
LOW-level
VCC = 2.0 V
input voltage
VCC = 4.5 V
0.8
0.5
0.5
0.5
V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
HIGHlevel output
voltage
LOW-level
output
voltage
74HC_HCT138_Q100
Product data sheet
VI = VIH or VIL
VI = VIH or VIL
5 / 17
Nexperia
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C
to +125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
II
input leakage VI = VCC or GND; VCC = 6.0 V
current
±0.1
±1.0
±1.0
μA
ICC
supply
current
8.0
80
160
μA
CI
input
capacitance
3.5
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
pF
74HCT138-Q100
VIH
HIGH-level
VCC = 4.5 V to 5.5 V
input voltage
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGHlevel output
voltage
VI = VIH or VIL; VCC = 4.5 V
IO = -20 μA
4.4
4.5
4.4
4.4
V
IO = -4 mA
3.98
4.32
3.84
3.7
V
LOW-level
output
voltage
IO = 20 μA
0.1
0.1
V
IO = 4.0 mA
0.15
0.26
0.33
0.4
V
VOL
II
input leakage VI = VCC or GND; VCC = 5.5 V
current
±0.1
±1.0
±1.0
μA
ICC
supply
current
VCC = 5.5 V
8.0
80
160
μA
ΔICC
additional
supply
current
VI = VCC - 2.1 V;
other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; IO = 0 A
per input pin; An inputs
150
540
675
735
μA
per input pin; En inputs
125
450
562.5
612.5
μA
per input pin; E3 input
100
360
450
490
μA
3.5
pF
CI
input
capacitance
74HC_HCT138_Q100
Product data sheet
6 / 17
Nexperia
10 Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 9.
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C
to +125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
41
150
190
225
ns
VCC = 4.5 V
15
30
38
45
ns
VCC = 5 V; CL = 15 pF
12
ns
12
26
33
38
ns
VCC = 2.0 V
47
150
190
225
ns
VCC = 4.5 V
17
45
ns
14
ns
14
26
33
38
ns
VCC = 2.0 V
47
150
190
225
ns
VCC = 4.5 V
17
45
ns
14
ns
14
26
33
38
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
6
13
16
19
ns
67
pF
74HC138-Q100
tpd
propagation
delay
[1]
An to Yn; see Figure 7
VCC = 6.0 V
[1]
E3 to Yn; see Figure 7
VCC = 6.0 V
[1]
En to Yn; see Figure 8
VCC = 6.0 V
tt
transition
time
[2]
Yn; see Figure 7
and Figure 8
VCC = 6.0 V
CPD
power
dissipation
capacitance
74HC_HCT138_Q100
Product data sheet
CL = 50 pF; f = 1 MHz;
VI = GND to VCC
[3]
7 / 17
Nexperia
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C
to +125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
44
53
ns
17
ns
18
40
50
60
ns
19
ns
19
40
50
60
ns
19
ns
7
15
19
22
ns
67
pF
74HCT138-Q100
tpd
propagation
delay
[1]
VCC = 4.5 V
[1]
VCC = 4.5 V
[1]
VCC = 4.5 V
tt
transition
time
[2]
Yn; see Figure 7
and Figure 8
VCC = 4.5 V
CPD
power
dissipation
capacitance
[3]
VI = GND to VCC - 1.5 V
[1] tpd is the same as tPLH and tPHL.
[2] tt is the same as tTHL and tTLH.
[3] CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of outputs.
74HC_HCT138_Q100
Product data sheet
8 / 17
Nexperia
10.1 Waveforms and test circuit
VCC
An, E3
input
VM
GND
tPHL
tPLH
VOH
Yn
output
VM
VOL
tTHL
tTLH
mna373
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Figure 7. Propagation delay input (An) and enable input (E3) to output (Yn) and transition time output (Yn)
VCC
E1, E2
VM
input
GND
tPHL
tPLH
VOH
Yn
output
VM
VOL
tTHL
tTLH
mna374
Figure 8. Propagation delay enable input (En) to output (Yn) and transition time output (Yn)
Table 8. Measurement points
Type
Input
Output
VM
VM
74HC138-Q100
0.5VCC
0.5VCC
74HCT138-Q100
1.3 V
1.3 V
74HC_HCT138_Q100
Product data sheet
9 / 17
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VCC
VO
RL
RT
S1
open
CL
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Figure 9. Test circuit for measuring switching times
Table 9. Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74HC138-Q100
VCC
6 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HCT138-Q100
3V
6 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HC_HCT138_Q100
Product data sheet
10 / 17
Nexperia
11 Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Figure 10. Package outline SOT109-1 (SO16)
74HC_HCT138_Q100
Product data sheet
11 / 17
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Figure 11. Package outline SOT403-1 (TSSOP16)
74HC_HCT138_Q100
Product data sheet
12 / 17
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
y
y1 C
v M C A B
w M C
7
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Figure 12. Package outline SOT763-1 (DHVQFN16)
74HC_HCT138_Q100
Product data sheet
13 / 17
Nexperia
12 Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
13 Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT138_Q100 v.3
20180326
Product data sheet
74HC_HCT138_Q100 v.2
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
20150126
Modifications:
• Section 9: OFF-state output current removed because device has no 3-state outputs.
• Section 10: Power dissipation capacitance condition for 74HCT138 is corrected.
74HC_HCT138_Q100 v.1
20120716
74HC_HCT138_Q100
Product data sheet
Product data sheet
Product data sheet
14 / 17
Nexperia
14 Legal information
14.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
74HC_HCT138_Q100
Product data sheet
15 / 17
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
74HC_HCT138_Q100
Product data sheet
14.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
16 / 17
Nexperia
Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
11
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 2
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 3
Functional description ........................................4
Limiting values .................................................... 4
Recommended operating conditions ................ 5
Static characteristics .......................................... 5
Dynamic characteristics .....................................7
Waveforms and test circuit ................................ 9
Package outline .................................................11
Abbreviations .................................................... 14
Revision history ................................................ 14
Legal information .............................................. 15
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 26 March 2018
Document identifier: 74HC_HCT138_Q100
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HCT138D-Q100,118 74HC138BQ-Q100,115 74HCT138BQ-Q100,11 74HC138PW-Q100,118 74HCT138PWQ100,11 74HC138D-Q100,118
