74HCT139DB-Q100J
74HCT139DB-Q100J
    NEXPERIA(安世)
    SSOP16_208MIL
    双2对4线解码器/多路分解器 SSOP16_208MIL 4.5~5.5V
74HCT139DB-Q100J 数据手册
74HC139-Q100; 74HCT139-Q100 Dual 2-to-4 line decoder/demultiplexer Rev. 1 — 19 June 2014 Product data sheet 1. General description The 74HC139-Q100; 74HCT139-Q100 decodes two binary weighted address inputs (nA0, nA1) to four mutually exclusive outputs (nY0 to nY3). Each decoder features an enable input (nE). When nE is HIGH all outputs are forced HIGH. The enable input can be used as the data input for a 1-to-4 demultiplexer application. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Input levels:  For 74HC139-Q100: CMOS level  For 74HCT139-Q100: TTL level  Demultiplexing capability  2 independent 2-to-4 decoders  Multifunction capability  Suitable for memory decoding, data routing or code conversion  Complies with JEDEC standard no. 7A  Active LOW mutually exclusive outputs  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 74HC139-Q100; 74HCT139-Q100 Nexperia Dual 2-to-4 line decoder/demultiplexer 3. Ordering information Table 1. Ordering information Type number Package 74HC139D-Q100 Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74 HCT139D-Q100 74HC139DB-Q100 74HCT139DB-Q100 74HC139PW-Q100 74HCT139PW-Q100 4. Functional diagram
74HCT139DB-Q100J 价格&库存
很抱歉,暂时无法提供与“74HCT139DB-Q100J”相匹配的价格&库存,您可以联系我们找货
