74HC153; 74HCT153
Dual 4-input multiplexer
Rev. 8 — 13 August 2019
Product data sheet
1. General description
The 74HC153; 74HCT153 is a dual 4-input multiplexer. The device features independent enable
inputs (nE) and common data select inputs (S0 and S1). For each multiplexer, the select inputs
select one of the four binary inputs and routes it to the multiplexer output (nY). A HIGH on E forces
the corresponding multiplexer outputs LOW. Inputs include clamp diodes. This enables the use of
current limiting resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Input levels:
• For 74HC153: CMOS level
• For 74HCT153: TTL level
Non-inverting outputs
Separate enable input for each output
Common select inputs
Complies with JEDEC standard no. 7A
Permits multiplexing from n lines to 1 line
Enable line provided for cascading (n lines to 1 line)
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C.
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC153D
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
-40 °C to +125 °C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
SOT403-1
74HCT153D
74HC153DB
74HCT153DB
74HC153PW
74HCT153PW
74HC153; 74HCT153
Nexperia
4. Functional diagram
1
1I1
5
13
14
1I0 1I1 1I2 1I3 2I0 2I1 2I2 2I3
S0
10
2
S1
11
1
1E
12
15
2E
14
Fig. 1.
4
3
10
11
12
2Y
7
9
S1
2
2I0
2I1
9
2I3
15
001aal843
Fig. 2.
1I3
2Y
MUX
2I2
2E
Logic symbol
1E
1I2
1I1
1I0
S0
S1
001aal844
Functional diagram
2I3
1Y
Fig. 3.
S0
13
1Y
7
1I3
3
5
1Y
MUX
1I2
4
6
2E
1I0
6
2I2
2I1
2Y
2I0
2E
001aal845
Logic diagram
74HC_HCT153
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 15
74HC153; 74HCT153
Nexperia
5. Pinning information
5.1. Pinning
74HC153
74HCT153
1E
1
16 VCC
S1
2
15 2E
1I3
3
14 S0
1I2
4
13 2I3
1I1
5
12 2I2
74HC153
74HCT153
1E 1
16 VCC
15 2E
1l3 3
14 S0
1l2 4
13 2l3
1l1 5
12 2l2
11 2l1
1I0
6
11 2I1
1l0 6
1Y
7
10 2I0
1Y 7
10 2l0
GND 8
9 2Y
GND
8
9
2Y
aaa-008464
aaa-008463
Fig. 4.
S1 2
Fig. 5.
Pin configuration SOT109-1 (SO16)
Pin configuration SOT338-1 (SSOP16) and
SOT403-1 (TSSOP16)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1E, 2E
1, 15
output enable inputs (active LOW)
S0, S1
14, 2
data select inputs
1I0, 1I1, 1I2, 1I3
6, 5, 4, 3
data inputs source 1
1Y
7
multiplexer output source 1
GND
8
ground (0 V)
2Y
9
multiplexer output source 2
2I0, 2I1, 2I2, 2I3
10, 11, 12, 13
data inputs source 2
VCC
16
supply voltage
74HC_HCT153
Product data sheet
3 / 15
74HC153; 74HCT153
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
select Inputs
output enable output
data inputs
S0
S1
nI0
nI1
nI2
nI3
nE
nY
X
X
X
X
X
X
H
L
L
L
L
X
X
X
L
L
L
L
H
X
X
X
L
H
H
L
X
L
X
X
L
L
H
L
X
H
X
X
L
H
L
H
X
X
L
X
L
L
L
H
X
X
H
X
L
H
H
H
X
X
X
L
L
L
H
H
X
X
X
H
L
H
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Min
Max
-0.5
+7
V
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
[1]
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
IO
output current
-0.5 V < VO < VCC + 0.5 V
±25
mA
ICC
IGND
supply current
50
mA
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[2]
Conditions
[2]
Unit
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT109-1 (SO16) packages: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT338-1 (SSOP16) packages: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT403-1 (TSSOP16) packages: Ptot derates linearly with 8.5 mW/K above 91 °C.
74HC_HCT153
Product data sheet
4 / 15
74HC153; 74HCT153
Nexperia
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC153
74HCT153
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C -40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
VI = VIH or VIL
HIGH-level
output voltage
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
74HC153
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
VI = VIH or VIL
LOW-level
output voltage
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
±0.1
±1
±1
μA
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
μA
CI
input
capacitance
3.5
pF
74HC_HCT153
Product data sheet
VI = VCC or GND; VCC = 6.0 V
5 / 15
74HC153; 74HCT153
Nexperia
Symbol Parameter
Conditions
25 °C
Min
Typ
Max
Min
Max
Min
Max
74HCT153
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
VI = VIH or VIL; VCC = 4.5 V
HIGH-level
output voltage
IO = -20 μA
4.4
4.5
4.4
4.4
V
3.98
4.32
3.84
3.7
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
±0.1
±1
±1
μA
8
80
160
μA
1In, 2In
45
162
203
221
μA
nE
60
216
270
294
μA
Sn
135
486
608
662
μA
3.5
pF
IO = -4.0 mA
VOL
LOW-level
output voltage
II
input leakage
current
ICC
VCC = 5.5 V
ΔICC
per input pin;
additional
supply current VI = VCC - 2.1 V; IO = 0 A;
other inputs at VCC or GND;
CI
input
capacitance
74HC_HCT153
Product data sheet
VI = VCC or GND; VCC = 5.5 V
6 / 15
74HC153; 74HCT153
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit, see Fig. 8; unless otherwise specified
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min Typ Max
-40 °C to +125 °C
Min
Max
Min
Max
Unit
74HC153
tpd
propagation
delay
1In to nY, 2In to nY;
see Fig. 6
[1]
VCC = 2.0 V
47
145
180
220
ns
VCC = 4.5 V
17
29
36
44
ns
VCC = 5.0 V; CL = 15 pF
14
ns
VCC = 6.0 V
14
25
31
38
ns
VCC = 2.0 V
50
150
190
225
ns
VCC = 4.5 V
18
30
38
45
ns
15
ns
VCC = 6.0 V
14
26
33
38
ns
VCC = 2.0 V
33
100
125
150
ns
VCC = 4.5 V
12
30
ns
10
ns
10
17
21
26
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
30
pF
Sn to nY; see Fig. 7
nE to nY; see Fig. 7
VCC = 6.0 V
tt
CPD
transition time see Fig. 6
power
dissipation
capacitance
74HC_HCT153
Product data sheet
[2]
per package;
VI = GND to VCC
[3]
7 / 15
74HC153; 74HCT153
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min Typ Max
-40 °C to +125 °C
Min
Max
Min
Max
Unit
74HCT153
HIGH to LOW 1In to nY, 2In to nY;
see Fig. 6
propagation
delay
VCC = 4.5 V
tPHL
[1]
19
34
43
51
ns
16
ns
13
24
30
36
ns
16
ns
VCC = 4.5 V
43
51
ns
17
ns
VCC = 4.5 V
14
27
34
41
ns
11
ns
7
15
19
22
ns
30
pF
LOW to HIGH 1In to nY, 2In to nY;
see Fig. 6
propagation
delay
VCC = 4.5 V
tPLH
[1]
tpd
propagation
delay
[1]
[1]
tt
[2]
VCC = 4.5 V
CPD
[1]
[2]
[3]
power
dissipation
capacitance
per package;
VI = GND to VCC - 1.5 V
[3]
tpd is the same as tPHL and tPLH.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD x VCC x fi x N + ∑(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL x VCC x fo) = sum of outputs.
VI
VM
1In, 2ln input
VM
GND
tPHL
VOH
VY
nY output
tPLH
VM
VM
VX
VOL
tTHL
tTLH
aaa-008465
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 6.
Waveforms showing the input (1In, 2In) to output (1Y, 2Y) propagation delays and output transition times
74HC_HCT153
Product data sheet
8 / 15
74HC153; 74HCT153
Nexperia
VI
VM
Sn, nE input
VM
GND
tPHL
VOH
VY
tPLH
VM
nY output
VM
VX
VOL
tTHL
tTLH
aaa-008466
Fig. 7.
Waveforms showing the input (Sn, nE) to output (nY) propagation delays
Table 8. Measurement points
Input
Type
Output
VM
VM
VX
VY
74HC153
0.5VCC
0.5VCC
0.1VCC
0.9VCC
74HCT153
1.3 V
1.3 V
0.1VCC
0.9VCC
VI
negative
pulse
VM
VI
GND
VM
10 %
GND
positive
pulse
tW
90 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VO
RT
CL
001aah768
Test data is given in Table 9.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
Fig. 8.
Test circuit for measuring switching times
Table 9. Test data
Type
Load
Input
Test
VI
tr, tf
CL
74HC153
VCC
6.0 ns
15 pF, 50 pF
tPLH, tPHL
74HCT153
3.0 V
6.0 ns
15 pF, 50 pF
tPLH, tPHL
74HC_HCT153
Product data sheet
9 / 15
74HC153; 74HCT153
Nexperia
11. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig. 9.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT109-1 (SO16)
74HC_HCT153
Product data sheet
10 / 15
74HC153; 74HCT153
Nexperia
SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm
D
SOT338-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
8
1
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
6.4
6.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
1.00
0.55
8o
0o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT338-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig. 10. Package outline SOT338-1 (SSOP16)
74HC_HCT153
Product data sheet
11 / 15
74HC153; 74HCT153
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 11. Package outline SOT403-1 (TSSOP16)
74HC_HCT153
Product data sheet
12 / 15
74HC153; 74HCT153
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT153 v.8
20190813
Product data sheet
74HC_HCT153 v.7
Modifications:
74HC_HCT153 v.7
20181010
Modifications:
Type numbers 74HC153DB and 74HCT153DB (SOT338-1/SSOP16) added.
Table 4: Derating values for Ptot total power dissipation updated.
Product data sheet
74HC_HCT153 v.6
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type numbers 74HC153DB and 74HCT153DB (SOT338-1/SSOP16) removed.
74HC_HCT153 v.6
20160511
Modifications:
74HC_HCT153 v.5
20140123
Modifications:
74HC_HCT153 v.4
20131128
Product data sheet
74HC_HCT153 v.3
74HC_HCT153 v.3
20130722
Product data sheet
74HC_HCT153_CNV v.2
74HC_HCT153_CNV v.2
19970827
Product specification
74HC_HCT153
Product data sheet
Product data sheet
74HC_HCT153 v.5
Type numbers 74HC153N and 74HCT153N (SOT38-4) removed.
Product data sheet
74HC_HCT153 v.4
Table 1 and Section 11: all references to 14 pin packages removed.
13 / 15
74HC153; 74HCT153
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT153
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
14 / 15
74HC153; 74HCT153
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................5
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 7
11. Package outline........................................................ 10
12. Abbreviations............................................................ 13
13. Revision history........................................................13
14. Legal information......................................................14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 13 August 2019
74HC_HCT153
Product data sheet
15 / 15
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC153D,652 74HC153DB,112 74HC153DB,118 74HC153D,653 74HC153N,652 74HC153PW,112
74HC153PW,118 74HCT153D,652 74HCT153DB,112 74HCT153DB,118 74HCT153D,653 74HCT153N,652
74HCT153PW,112 74HCT153PW,118
