74HCT153PW,118
74HCT153PW,118
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    双4输入多路复用器 TSSOP16_5X4.4MM 4.5~5.5V
74HCT153PW,118 数据手册
74HC153; 74HCT153 Dual 4-input multiplexer Rev. 8 — 13 August 2019 Product data sheet 1. General description The 74HC153; 74HCT153 is a dual 4-input multiplexer. The device features independent enable inputs (nE) and common data select inputs (S0 and S1). For each multiplexer, the select inputs select one of the four binary inputs and routes it to the multiplexer output (nY). A HIGH on E forces the corresponding multiplexer outputs LOW. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • • • Input levels: • For 74HC153: CMOS level • For 74HCT153: TTL level Non-inverting outputs Separate enable input for each output Common select inputs Complies with JEDEC standard no. 7A Permits multiplexing from n lines to 1 line Enable line provided for cascading (n lines to 1 line) ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C. 3. Ordering information Table 1. Ordering information Type number Package 74HC153D Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 -40 °C to +125 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HCT153D 74HC153DB 74HCT153DB 74HC153PW 74HCT153PW 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer 4. Functional diagram 1 1I1 5 13 14 1I0 1I1 1I2 1I3 2I0 2I1 2I2 2I3 S0 10 2 S1 11 1 1E 12 15 2E 14 Fig. 1. 4 3 10 11 12 2Y 7 9 S1 2 2I0 2I1 9 2I3 15 001aal843 Fig. 2. 1I3 2Y MUX 2I2 2E Logic symbol 1E 1I2 1I1 1I0 S0 S1 001aal844 Functional diagram 2I3 1Y Fig. 3. S0 13 1Y 7 1I3 3 5 1Y MUX 1I2 4 6 2E 1I0 6 2I2 2I1 2Y 2I0 2E 001aal845 Logic diagram 74HC_HCT153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 2 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer 5. Pinning information 5.1. Pinning 74HC153 74HCT153 1E 1 16 VCC S1 2 15 2E 1I3 3 14 S0 1I2 4 13 2I3 1I1 5 12 2I2 74HC153 74HCT153 1E 1 16 VCC 15 2E 1l3 3 14 S0 1l2 4 13 2l3 1l1 5 12 2l2 11 2l1 1I0 6 11 2I1 1l0 6 1Y 7 10 2I0 1Y 7 10 2l0 GND 8 9 2Y GND 8 9 2Y aaa-008464 aaa-008463 Fig. 4. S1 2 Fig. 5. Pin configuration SOT109-1 (SO16) Pin configuration SOT338-1 (SSOP16) and SOT403-1 (TSSOP16) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1E, 2E 1, 15 output enable inputs (active LOW) S0, S1 14, 2 data select inputs 1I0, 1I1, 1I2, 1I3 6, 5, 4, 3 data inputs source 1 1Y 7 multiplexer output source 1 GND 8 ground (0 V) 2Y 9 multiplexer output source 2 2I0, 2I1, 2I2, 2I3 10, 11, 12, 13 data inputs source 2 VCC 16 supply voltage 74HC_HCT153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 3 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care. select Inputs output enable output data inputs S0 S1 nI0 nI1 nI2 nI3 nE nY X X X X X X H L L L L X X X L L L L H X X X L H H L X L X X L L H L X H X X L H L H X X L X L L L H X X H X L H H H X X X L L L H H X X X H L H 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Min Max -0.5 +7 V IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC IGND supply current - 50 mA ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] Conditions [2] Unit The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT109-1 (SO16) packages: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT338-1 (SSOP16) packages: Ptot derates linearly with 8.5 mW/K above 91 °C. For SOT403-1 (TSSOP16) packages: Ptot derates linearly with 8.5 mW/K above 91 °C. 74HC_HCT153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 4 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC153 74HCT153 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V VI = VIH or VIL HIGH-level output voltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V 74HC153 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V VI = VIH or VIL LOW-level output voltage IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1 - ±1 μA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - - - - - pF 74HC_HCT153 Product data sheet VI = VCC or GND; VCC = 6.0 V All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 5 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max 74HCT153 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH VI = VIH or VIL; VCC = 4.5 V HIGH-level output voltage IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V - 0 0.1 - 0.1 - 0.1 V - 0.15 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1 - ±1 μA - - 8 - 80 - 160 μA 1In, 2In - 45 162 - 203 - 221 μA nE - 60 216 - 270 - 294 μA Sn - 135 486 - 608 - 662 μA - 3.5 - - - - - pF IO = -4.0 mA VOL VI = VIH or VIL; VCC = 4.5 V LOW-level output voltage IO = 20 μA; VCC = 4.5 V IO = 5.2 mA; VCC = 6.0 V II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V ΔICC per input pin; additional supply current VI = VCC - 2.1 V; IO = 0 A; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V CI input capacitance 74HC_HCT153 Product data sheet VI = VCC or GND; VCC = 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 6 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit, see Fig. 8; unless otherwise specified Symbol Parameter Conditions 25 °C -40 °C to +85 °C Min Typ Max -40 °C to +125 °C Min Max Min Max Unit 74HC153 tpd propagation delay 1In to nY, 2In to nY; see Fig. 6 [1] VCC = 2.0 V - 47 145 - 180 - 220 ns VCC = 4.5 V - 17 29 - 36 - 44 ns VCC = 5.0 V; CL = 15 pF - 14 - - - - - ns VCC = 6.0 V - 14 25 - 31 - 38 ns VCC = 2.0 V - 50 150 - 190 - 225 ns VCC = 4.5 V - 18 30 - 38 - 45 ns VCC = 5.0 V; CL = 15 pF - 15 - - - - - ns VCC = 6.0 V - 14 26 - 33 - 38 ns VCC = 2.0 V - 33 100 - 125 - 150 ns VCC = 4.5 V - 12 20 - 25 - 30 ns VCC = 5.0 V; CL = 15 pF - 10 - - - - - ns - 10 17 - 21 - 26 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns - 30 - - - - - pF Sn to nY; see Fig. 7 nE to nY; see Fig. 7 VCC = 6.0 V tt CPD transition time see Fig. 6 power dissipation capacitance 74HC_HCT153 Product data sheet [2] per package; VI = GND to VCC [3] All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 7 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer Symbol Parameter Conditions 25 °C -40 °C to +85 °C Min Typ Max -40 °C to +125 °C Min Max Min Max Unit 74HCT153 HIGH to LOW 1In to nY, 2In to nY; see Fig. 6 propagation delay VCC = 4.5 V tPHL [1] - 19 34 - 43 - 51 ns - 16 - - - - - ns - 13 24 - 30 - 36 ns - 16 - - - - - ns VCC = 4.5 V - 20 34 - 43 - 51 ns VCC = 5.0 V; CL = 15 pF - 17 - - - - - ns VCC = 4.5 V - 14 27 - 34 - 41 ns VCC = 5.0 V; CL = 15 pF - 11 - - - - - ns - 7 15 - 19 - 22 ns - 30 - - - - - pF VCC = 5.0 V; CL = 15 pF LOW to HIGH 1In to nY, 2In to nY; see Fig. 6 propagation delay VCC = 4.5 V tPLH [1] VCC = 5.0 V; CL = 15 pF tpd propagation delay Sn to nY; see Fig. 7 [1] nE to nY; see Fig. 7 [1] transition time see Fig. 6 tt [2] VCC = 4.5 V CPD [1] [2] [3] power dissipation capacitance per package; VI = GND to VCC - 1.5 V [3] tpd is the same as tPHL and tPLH. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD x VCC x fi x N + ∑(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑(CL x VCC x fo) = sum of outputs. VI VM 1In, 2ln input VM GND tPHL VOH VY nY output tPLH VM VM VX VOL tTHL tTLH aaa-008465 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Waveforms showing the input (1In, 2In) to output (1Y, 2Y) propagation delays and output transition times 74HC_HCT153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 8 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer VI VM Sn, nE input VM GND tPHL VOH VY tPLH VM nY output VM VX VOL tTHL tTLH aaa-008466 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. Waveforms showing the input (Sn, nE) to output (nY) propagation delays Table 8. Measurement points Input Type Output VM VM VX VY 74HC153 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT153 1.3 V 1.3 V 0.1VCC 0.9VCC VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. Fig. 8. Test circuit for measuring switching times Table 9. Test data Type Load Input Test VI tr, tf CL 74HC153 VCC 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HCT153 3.0 V 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HC_HCT153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 9 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer 11. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) 74HC_HCT153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 10 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 10. Package outline SOT338-1 (SSOP16) 74HC_HCT153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 11 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 11. Package outline SOT403-1 (TSSOP16) 74HC_HCT153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 12 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT153 v.8 20190813 Product data sheet - 74HC_HCT153 v.7 Modifications: • • 74HC_HCT153 v.7 20181010 Modifications: • • • Type numbers 74HC153DB and 74HCT153DB (SOT338-1/SSOP16) added. Table 4: Derating values for Ptot total power dissipation updated. Product data sheet - 74HC_HCT153 v.6 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74HC153DB and 74HCT153DB (SOT338-1/SSOP16) removed. 74HC_HCT153 v.6 20160511 Modifications: • 74HC_HCT153 v.5 20140123 Modifications: • 74HC_HCT153 v.4 20131128 Product data sheet - 74HC_HCT153 v.3 74HC_HCT153 v.3 20130722 Product data sheet - 74HC_HCT153_CNV v.2 74HC_HCT153_CNV v.2 19970827 Product specification - - 74HC_HCT153 Product data sheet Product data sheet - 74HC_HCT153 v.5 Type numbers 74HC153N and 74HCT153N (SOT38-4) removed. Product data sheet - 74HC_HCT153 v.4 Table 1 and Section 11: all references to 14 pin packages removed. All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 13 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT153 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 14 / 15 74HC153; 74HCT153 Nexperia Dual 4-input multiplexer Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................5 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 7 11. Package outline........................................................ 10 12. Abbreviations............................................................ 13 13. Revision history........................................................13 14. Legal information......................................................14 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 13 August 2019 74HC_HCT153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 13 August 2019 © Nexperia B.V. 2019. All rights reserved 15 / 15 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC153D,652 74HC153DB,112 74HC153DB,118 74HC153D,653 74HC153N,652 74HC153PW,112 74HC153PW,118 74HCT153D,652 74HCT153DB,112 74HCT153DB,118 74HCT153D,653 74HCT153N,652 74HCT153PW,112 74HCT153PW,118
74HCT153PW,118 价格&库存
很抱歉,暂时无法提供与“74HCT153PW,118”相匹配的价格&库存,您可以联系我们找货
