74HC154; 74HCT154
4-to-16 line decoder/demultiplexer
Rev. 7 — 29 February 2016
Product data sheet
1. General description
The 74HC154; 74HCT154 is a 4-to-16 line decoder/demultiplexer. It decodes four binary
weighted address inputs (A0 to A3) to sixteen mutually exclusive outputs (Y0 to Y15). The
device features two input enable (E0 and E1) inputs. A HIGH on either of the input
enables forces the outputs HIGH. The device can be used as a 1-to-16 demultiplexer by
using one of the enable inputs as the multiplexed data input. When the other enable input
is LOW the addressed output will follow the state of the applied data. Inputs include clamp
diodes. This enables the use of current limiting resistors to interface inputs to voltages in
excess of VCC.
2. Features and benefits
16-line demultiplexing capability
Decodes 4 binary-coded inputs into 16 mutually-exclusive outputs
Complies with JEDEC standard no. 7A
Input levels:
For 74HC154: CMOS level
For 74HCT154: TTL level
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
3. Ordering information
Table 1.
Type number
74HC154D
Package
Temperature range Name
Description
Version
40 C to +125 C
SO24
plastic small outline package; 24 leads; body width 7.5 mm SOT137-1
40 C to +125 C
SSOP24
plastic shrink small outline package; 24 leads; body width
5.3 mm
SOT340-1
40 C to +125 C
TSSOP24
plastic thin shrink small outline package; 24 leads; body
width 4.4 mm
SOT355-1
40 C to +125 C
DHVQFN24 plastic dual in-line compatible thermal enhanced very thin
quad flat package; no leads; 24 terminals; body
3.5 5.5 0.85 mm
74HCT154D
74HC154DB
74HCT154DB
74HC154PW
74HCT154PW
74HC154BQ
74HCT154BQ
SOT815-1
74HC154; 74HCT154
Nexperia
4. Functional diagram
'(&2'(5
很抱歉,暂时无法提供与“74HCT154D,653”相匹配的价格&库存,您可以联系我们找货
