74HC238DB,112
74HC238DB,112
    NEXPERIA(安世)
    SSOP16_208MIL
    3到8线解码器/多路分解器 SSOP16_208MIL 2~6V
74HC238DB,112 数据手册
74HC238; 74HCT238 3-to-8 line decoder/demultiplexer Rev. 5 — 13 June 2018 1 Product data sheet General description The 74HC238; 74HCT238 decodes three binary weighted address inputs (A0, A1 and A2) to eight mutually exclusive outputs (Y0 to Y7). The device features three enable inputs (E1 and E2 and E3). Every output will be LOW unless E1 and E2 are LOW and E3 is HIGH. This multiple enable function allows easy parallel expansion to a 1-of-32 (5 to 32 lines) decoder with just four '238 ICs and one inverter. The '238 can be used as an eight output demultiplexer by using one of the active LOW enable inputs as the data input and the remaining enable inputs as strobes. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2 Features and benefits • • • • • • • Demultiplexing capability Multiple input enable for easy expansion Ideal for memory chip select decoding Active HIGH mutually exclusive outputs Multiple package options Complies with JEDEC standard no. 7A Input levels: – For 74HC238: CMOS level – For 74HCT238: TTL level • ESD protection: – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V • Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3 Ordering information Table 1. Ordering information Type number 74HC238D Package Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 -40 °C to +125 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HCT238D 74HC238DB 74HCT238DB 74HC238PW 74HCT238PW 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer Type number 74HC238BQ Package Temperature range Name -40 °C to +125 °C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5 x 3.5 x 0.85 mm 74HCT238BQ 4 Description Version SOT763-1 Functional diagram 15 A0 1 A1 2 A2 3 E1 E2 E3 3 TO 8 DECODER 15 Y0 14 Y1 13 Y2 ENABLE 12 EXITING 11 Y3 10 Y5 9 Y6 7 Y7 Y4 4 14 A0 A1 A2 3 3 TO 8 DECODER E1 12 11 10 Y1 Y2 Y3 Y4 Y5 Y6 Y7 4 5 6 001aag753 001aag752 Figure 1.  Logic symbol ENABLE EXITING 7 E3 6 2 9 E2 5 13 1 Y0 Figure 2.  Functional diagram Y0 E1 Y1 E2 Y2 E3 Y3 Y4 Y5 A0 Y6 A1 Y7 A2 001aag754 Figure 3.  Logic diagram 74HC_HCT238 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer 5 Pinning information 5.1 Pinning 1 A0 terminal 1 index area A1 2 15 Y0 A2 3 14 Y1 E1 4 13 Y2 E2 5 12 Y3 E3 6 11 Y4 Y7 7 10 Y5 GND 8 9 14 Y1 E1 4 13 Y2 E2 5 12 Y3 E3 6 Y7 7 GND(1) 11 Y4 10 Y5 9 16 VCC 15 Y0 3 8 1 2 A2 Y6 A0 A1 GND 74HC238 74HCT238 16 VCC 74HC238 74HCT238 001aag756 Transparent top view (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad.However, if it is soldered, the solder land should remain floating or be connected to GND. Y6 001aag755 Figure 4.  Pin configuration SO16 and (T)SSOP16 Figure 5.  Pin configuration DHVQFN16 5.2 Pin description Table 2. Pin description Symbol Pin Description A0, A1, A2 1, 2, 3 address input E1 4 enable input (active LOW) E2 5 enable input (active LOW) E3 6 enable input (active HIGH) Y0, Y1, Y2, Y3, Y4, Y5, Y6, Y7 15, 14, 13, 12, 11, 10, 9, 7 output (active HIGH) GND 8 ground (0 V) VCC 16 supply voltage 74HC_HCT238 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer 6 Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care. Inputs Outputs E1 E2 E3 A0 A1 A2 Y0 Y1 Y2 Y3 Y4 Y5 Y6 Y7 H X X X X X L L L L L L L L X H X X X X L L L L L L L L X X L X X X L L L L L L L L L L H L L L H L L L L L L L L L H H L L L H L L L L L L L L H L H L L L H L L L L L L L H H H L L L L H L L L L L L H L L H L L L L H L L L L L H H L H L L L L L H L L L L H L H H L L L L L L H L L L H H H H L L L L L L L H 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions Min Max Unit -0.5 +7 V VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA [1] - ±20 mA - ±25 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V IO output current -0.5 V < VO < VCC + 0.5 V ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C - 500 mW Ptot total power dissipation SO16, (T)SSOP16 and DHVQFN16 packages [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO16 package: above 70 °C the value of Ptot derates linearly at 8 mW/K. For SSOP16 and TSSOP16 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K. For DHVQFN16 package: above 60 °C the value of Ptot derates linearly at 4.5 mW/K. 74HC_HCT238 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer 8 Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74HC238 74HCT238 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 - +125 -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V HIGH-level VI = VIH or VIL output voltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V 74HC238 VIH VIL VOH VOL II HIGH-level input voltage LOW-level input voltage LOW-level VI = VIH or VIL output voltage IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1.0 - ±1.0 μA input leakage current 74HC_HCT238 Product data sheet VI = VCC or GND; VCC = 6.0 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - - - - - pF 74HCT238 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V IO = -4.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 μA IO = 4.0 mA - 0 0.1 - 0.1 - 0.1 V - 0.16 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; VCC = 5.5 V; IO = 0 A - - 8.0 - 80 - 160 μA ΔICC additional per input pin; supply current VI = VCC - 2.1 V; IO = 0 A; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V An inputs - 70 252 - 315 - 343 μA E1, E2 inputs - 40 144 - 180 - 196 μA E3 input - 145 522 - 653 - 711 μA - 3.5 - - - - - pF CI input capacitance 74HC_HCT238 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer 10 Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; test circuit see Figure 8. Symbol Parameter Conditions 25 °C -40 °C to +125 °C Min Typ Max Max (85 °C) Max Unit (125 °C) VCC = 2.0 V - 47 150 190 225 ns VCC = 4.5 V - 17 30 38 45 ns VCC = 5.0 V; CL = 15 pF - 14 - - - ns - 14 26 33 38 ns VCC = 2.0 V - 52 160 200 240 ns VCC = 4.5 V - 19 32 40 48 ns VCC = 5.0 V; CL = 15 pF - 16 - - - ns - 15 27 34 41 ns VCC = 2.0 V - 50 155 195 235 ns VCC = 4.5 V - 18 31 39 47 ns VCC = 5.0 V; CL = 15 pF - 17 - - - ns - 14 26 33 40 ns VCC = 2.0 V - 19 75 95 110 ns VCC = 4.5 V - 7 15 19 22 ns - 6 13 16 19 ns - 72 - - - pF 74HC238 tpd propagation delay An to Yn; see Figure 6 [1] VCC = 6.0 V E3 to Yn; see Figure 6 [1] VCC = 6.0 V En to Yn or see Figure 7 [1] VCC = 6.0 V tt transition time see Figure 6 and Figure 7 [2] VCC = 6.0 V CPD power dissipation capacitance 74HC_HCT238 Product data sheet per package; VI = GND to VCC [3] All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer Symbol Parameter Conditions 25 °C -40 °C to +125 °C Min Typ Max Max (85 °C) Max Unit (125 °C) - 19 35 44 53 ns - 18 - - - ns - 20 37 46 56 ns - 20 - - - ns - 20 35 44 53 ns 74HCT238 tpd [1] propagation delay An to Yn; see Figure 6 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF [1] E3 to Yn; see Figure 6 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF [1] En to Yn or see Figure 7 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF tt transition time VCC = 4.5 V; see Figure 6 and Figure 7 [2] CPD power dissipation capacitance per package; VI = GND to VCC - 1.5 V [3] - 21 - - - ns - 7 15 19 22 ns - 76 - - - pF [1] tpd is the same as tPHL and tPLH. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD x VCC x fi x N + ∑ (CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑ (CL x VCC x fo) = sum of outputs. 10.1 Waveforms and test circuit An, E3 input VM tPHL VY Yn output tTHL tPLH VM VX tTLH 001aag757 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6.  Input (An, E3) to output (Yn) propagation delays and output transition times 74HC_HCT238 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer E1, E2 input VM tPHL VY Yn output tTHL tPLH VM VX tTLH 001aag758 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 7.  Input (E1, E2) to output (Yn) propagation delays and output transition times Table 8. Measurement points Input Output VM VM VX VY 74HC238 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT238 1.3 V 1.3 V 0.1VCC 0.9VCC Type 74HC_HCT238 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI VCC VO DUT RT RL S1 open CL 001aad983 Test data is given in Table 9. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch Figure 8.  Test circuit for measuring switching times Table 9. Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH 74HC238 VCC 6 ns 15 pF, 50 pF 1 kΩ open 74HCT238 3V 6 ns 15 pF, 50 pF 1 kΩ open 74HC_HCT238 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer 11 Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 9.  Package outline SOT109-1 (SO16) 74HC_HCT238 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 10.  Package outline SOT338-1 (SSOP16) 74HC_HCT238 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Figure 11.  Package outline SOT403-1 (TSSOP16) 74HC_HCT238 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm B D A A E A1 c detail X terminal 1 index area terminal 1 index area C e1 e b 2 y y1 C v M C A B w M C 7 L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Figure 12.  Package outline SOT763-1 (DHVQFN16) 74HC_HCT238 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer 12 Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT238 v.5 20180613 Product data sheet - Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. • Figure 3: typo corrected. 74HC_HCT238 v.4 20160127 Modifications: • Type numbers 74HC238N and 74HCT238N (SOT38-4) removed. 74HC_HCT238 v.3 20070716 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. • Added type number 74HC238BQ and 74HCT238BQ (DHVQFN16 package) 74HC_HCT238_CNV v.2 19970828 74HC_HCT238 Product data sheet Product data sheet Product data sheet Product specification - - All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 74HC_HCT238 v.4 74HC_HCT238 v.3 74HC_HCT238_CNV v.2 - © Nexperia B.V. 2018. All rights reserved. 15 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74HC_HCT238 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 16 / 18 74HC238; 74HCT238 Nexperia 3-to-8 line decoder/demultiplexer Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74HC_HCT238 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 13 June 2018 © Nexperia B.V. 2018. All rights reserved. 17 / 18 Nexperia 74HC238; 74HCT238 3-to-8 line decoder/demultiplexer Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 5 Static characteristics .......................................... 5 Dynamic characteristics .....................................7 Waveforms and test circuit ................................ 8 Package outline .................................................11 Abbreviations .................................................... 15 Revision history ................................................ 15 Legal information .............................................. 16 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 13 June 2018 Document identifier: 74HC_HCT238 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC238BQ,115 74HC238D,652 74HC238DB,112 74HC238DB,118 74HC238D,653 74HC238N,652 74HC238PW,112 74HC238PW,118 74HCT238BQ,115 74HCT238D,652 74HCT238DB,112 74HCT238DB,118 74HCT238D,653 74HCT238N,652 74HCT238PW,112 74HCT238PW,118
74HC238DB,112 价格&库存
很抱歉,暂时无法提供与“74HC238DB,112”相匹配的价格&库存,您可以联系我们找货
