74HCT251D-Q100J
74HCT251D-Q100J
    NEXPERIA(安世)
    SOIC16_150MIL
    8输入多路复用器;三态 SOIC16_150MIL 4.5~5.5V
74HCT251D-Q100J 数据手册
74HC251-Q100; 74HCT251-Q100 8-input multiplexer; 3-state Rev. 2 — 15 July 2019 Product data sheet 1. General description The 74HC251-Q100; 74HCT251-Q100 is an 8-bit multiplexer with eight binary inputs (I0 to I7), three select inputs (S0 to S2) and an output enable input (OE). The select inputs select one of the eight binary inputs and route it to the complementary outputs (Y and Y). A HIGH on OE causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C Input levels: • For 74HC251-Q100: CMOS level • For 74HCT251-Q100: TTL level Low-power dissipation Non-inverting data path Specified in compliance with JEDEC standard no. 7A ESD protection: • MIL-STD-883, method 3015 exceeds 2000 V • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) Multiple package options 3. Ordering information Table 1. Ordering information Type number Package 74HC251D-Q100 Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 -40 °C to +125 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HCT251D-Q100 74HC251DB-Q100 74HCT251DB-Q100 74HC251PW-Q100 74HCT251PW-Q100 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state 4. Functional diagram 4 3 I0 7 Fig. 1. 3 2 1 15 14 13 12 I0 I1 I2 I3 I4 I5 I6 I7 OE S0 S1 S2 11 10 9 Y 6 15 I3 14 I4 13 I5 I6 7 OE aaa-008235 Y 5 Fig. 2. I7 MULTIPLEXER Y Logic symbol 12 S2 9 5 I2 S1 10 Y I1 1 S0 11 4 2 6 aaa-008236 Functional diagram I7 I6 I5 I4 Y I3 I2 Y I1 I0 S2 Fig. 3. S1 S0 OE aaa-008237 Logic diagram 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 2 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state 5. Pinning information 5.1. Pinning 74HC251-Q100 74HCT251-Q100 I3 1 16 VCC I2 2 15 I4 I1 3 14 I5 I0 4 13 I6 Y 5 12 I7 Y 6 11 S0 OE 7 74HC251-Q100 74HCT251-Q100 I3 1 9 15 I4 I1 3 14 I5 I0 4 13 I6 Y 5 12 I7 OE 11 S0 7 10 S1 GND 8 9 S2 S2 aaa-008243 aaa-008242 Fig. 4. 2 Y 6 10 S1 GND 8 16 VCC I2 Fig. 5. Pin configuration SOT109-1 (SO16) Pin configuration SOT338-1 (SSOP16) and SOT403-1 (TSSOP16) 5.2. Pin description Table 2. Pin description Symbol Pin Description I0, I1, I2, I3, I4, I5, I6, I7 4, 3, 2, 1, 15, 14, 13, 12 data inputs Y 5 multiplexer output Y 6 complementary multiplexer output OE 7 output enable input (active LOW) GND 8 ground (0 V) S0, S1, S2 11, 10, 9 common data select inputs VCC 16 supply voltage 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 3 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Input Output OE S2 S1 S0 I0 I1 I2 I3 I4 I5 I6 I7 Y Y H X X X X X X X X X X X Z Z L L L L L X X X X X X X H L L L L L H X X X X X X X L H L L L H X L X X X X X X H L L L L H X H X X X X X X L H L L H L X X L X X X X X H L L L H L X X H X X X X X L H L L H H X X X L X X X X H L L L H H X X X H X X X X L H L H L L X X X X L X X X H L L H L L X X X X H X X X L H L H L H X X X X X L X X H L L H L H X X X X X H X X L H L H H L X X X X X X L X H L L H H L X X X X X X H X L H L H H H X X X X X X X L H L L H H H X X X X X X X H L H 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V - ±20 mA IO output current VO = -0.5 V to (VCC + 0.5 V) - ±25 mA ICC supply current - +50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [3] Tamb = -40 °C to +125 °C [1][2][3] For SOT109-1 (SO16) packages: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT338-1 (SSOP16) packages: Ptot derates linearly with 8.5 mW/K above 91 °C. For SOT403-1 (TSSOP16) packages: Ptot derates linearly with 8.5 mW/K above 91 °C. 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 4 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC251-Q100 74HCT251-Q100 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V -40 °C to +125 °C Unit 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC251-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage 74HC_HCT251_Q100 Product data sheet VI = VIH or VIL VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 5 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Min Typ Max Min Max Min Max Unit II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1.0 - ±1.0 IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - ±0.5 - ±5.0 - ±10.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - CI input capacitance - 3.5 - 160 μA μA pF 74HCT251-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V IO = -4 mA 3.98 4.32 - 3.84 - 3.7 - V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 μA - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.15 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1.0 - ±1.0 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - ±0.5 - ±5.0 - ±10 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 μA ΔICC additional supply current VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A per input pin; In inputs - 100 360 - 450 - 490 μA per input pin; OE input - 150 540 - 675 - 735 μA per input pin; Sn input - 150 540 - 675 - 735 μA - 3.5 - CI input capacitance 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 pF © Nexperia B.V. 2019. All rights reserved 6 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Fig. 9. Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 50 170 - 215 - 255 ns VCC = 4.5 V - 18 34 - 43 - 51 ns VCC = 5 V; CL = 15 pF - 15 - - - - - ns - 14 29 - 37 - 43 ns VCC = 2.0 V - 55 175 - 220 - 265 ns VCC = 4.5 V - 20 35 - 44 - 53 ns VCC = 5 V; CL = 15 pF - 17 - - - - - ns - 16 30 - 37 - 45 ns VCC = 2.0 V - 66 205 - 255 - 310 ns VCC = 4.5 V - 24 41 - 51 - 62 ns VCC = 5 V; CL = 15 pF - 20 - - - - - ns - 19 35 - 43 - 53 ns VCC = 2.0 V - 69 205 - 255 - 310 ns VCC = 4.5 V - 25 41 - 51 - 62 ns VCC = 5 V; CL = 15 pF - 21 - - - - - ns - 20 35 - 43 - 53 ns VCC = 2.0 V - 36 140 - 175 - 210 ns VCC = 4.5 V - 13 28 - 35 - 42 ns VCC = 6.0 V - 10 24 - 30 - 36 ns VCC = 2.0 V - 39 140 - 170 - 210 ns VCC = 4.5 V - 14 28 - 35 - 42 ns VCC = 6.0 V - 11 24 - 30 - 36 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns - 44 - - - - - pF 74HC251-Q100 tpd propagation delay In to Y; see Fig. 6 [1] VCC = 6.0 V In to Y; see Fig. 6 [1] VCC = 6.0 V Sn to Y; see Fig. 7 [1] VCC = 6.0 V Sn to Y; see Fig. 7 [1] VCC = 6.0 V ten tdis tt CPD enable time disable time OE to Y, Y; see Fig. 8 OE to Y, Y; see Fig. 8 transition time Y, Y; see Fig. 6 power dissipation capacitance 74HC_HCT251_Q100 Product data sheet [2] [3] [4] CL = 50 pF; f = 1 MHz; VI = GND to VCC [5] All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 7 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 4.5 V - 22 35 - 44 - 53 ns VCC = 5 V; CL = 15 pF - 19 - - - - - ns VCC = 4.5 V - 22 35 - 44 - 53 ns VCC = 5 V; CL = 15 pF - 19 - - - - - ns VCC = 4.5 V - 24 44 - 55 - 66 ns VCC = 5 V; CL = 15 pF - 20 - - - - - ns VCC = 4.5 V - 25 44 - 55 - 66 ns VCC = 5 V; CL = 15 pF - 21 - - - - - ns - 13 28 - 35 - 42 ns - 13 - - - - - ns VCC = 4.5 V - 14 28 - 35 - 42 ns VCC = 5 V; CL = 15 pF - 18 - - - - - ns - 7 15 - 19 - 22 ns - 46 - - - - - pF 74HCT251-Q100 tpd propagation delay In to Y; see Fig. 6 In to Y; see Fig. 6 Sn to Y; see Fig. 7 Sn to Y; see Fig. 7 ten enable time OE to Y, Y; see Fig. 8 [1] [1] [1] [1] [2] VCC = 4.5 V VCC = 5 V; CL = 15 pF tdis disable time OE to Y, Y; see Fig. 8 tt transition time Y, Y; see Fig. 6 CPD power dissipation capacitance [3] [4] VCC = 4.5 V [1] [2] [3] [4] [5] CL = 50 pF; f = 1 MHz; VI = GND to VCC [5] tpd is the same as tPLH and tPHL. ten is the same as tPZH and tPZL. tdis is the same as tPLZ and tPHZ. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑(CL × VCC × fo) = sum of outputs. 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 8 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state 10.1. Waveforms and test circuit VI In input VM VM GND tPHL VOH tPLH 90 % 90 % VM Y output VM 10 % VOL 10 % tTLH tTHL tPLH VOH Y output VOL 90 % VM tPHL 90 % VM 10 % 10 % tTLH tTHL aaa-004588 Measurement points are given in Table 8. VOLand VOH are typical voltage output levels that occur with the output load. Fig. 6. Propagation delay input (In) to output (Y,Y) and the output (Y,Y) transition time VI Sn, OE input VM VM GND tPHL VOH tPLH 90 % VM Y output 10 % VOL 90 % VM 10 % tTLH tTHL tPLH VOH Y output VOL 90 % VM tPHL 90 % VM 10 % 10 % tTLH tTHL aaa-008241 Measurement points are given in Table 8. VOLand VOH are typical voltage output levels that occur with the output load. Fig. 7. Propagation delay input (Sn,OE) to output (Y,Y) 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 9 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state VI OE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM 10% VOL tPHZ VOH tPZH 90% output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs disabled outputs enabled 001aae307 Measurement points are given in Table 8. VOLand VOH are typical voltage output levels that occur with the output load. Fig. 8. Enable and disable times Table 8. Measurement points Type Input Output VM VM 74HC251-Q100 0.5VCC 0.5VCC 74HCT251-Q100 1.3 V 1.3 V 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 10 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RT RL S1 open CL 001aad983 Test data is given in Table 9. Definitions test circuit: RT= Termination resistance should be equal to output impedance Zo of the pulse generator. CL= Load capacitance including jig and probe capacitance. RL= Load resistance. S1 = Test selection switch. Fig. 9. Test circuit for measuring switching times Table 9. Test data Type Input Load VI tr, tf CL 74HC251-Q100 VCC 6 ns 74HCT251-Q100 3V 6 ns 74HC_HCT251_Q100 Product data sheet S1 position RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 15 pF, 50 pF 1 kΩ open GND VCC 15 pF, 50 pF 1 kΩ open GND VCC All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 11 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state 11. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 10. Package outline SOT109-1 (SO16) 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 12 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 11. Package outline SOT338-1 (SSOP16) 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 13 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 12. Package outline SOT403-1 (TSSOP16) 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 14 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT251_Q100 v.2 20190715 Product data sheet - Modifications: • • • • 74HC_HCT251_Q100 v.1 74HC_HCT251_Q100 Product data sheet 74HC_HCT251_Q100 v.1 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74HC251DB-Q100 and 74HCT251DB (SOT338-1) added. Table 4: Derating values for Ptot total power dissipation have changed. 20130812 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 - © Nexperia B.V. 2019. All rights reserved 15 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 14. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 16 / 17 74HC251-Q100; 74HCT251-Q100 Nexperia 8-input multiplexer; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................5 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 7 10.1. Waveforms and test circuit........................................ 9 11. Package outline........................................................ 12 12. Abbreviations............................................................ 15 13. Revision history........................................................15 14. Legal information......................................................16 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 July 2019 74HC_HCT251_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 15 July 2019 © Nexperia B.V. 2019. All rights reserved 17 / 17 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC251PW-Q100J 74HC251D-Q100J 74HC251D/AUJ 74HC251DB-Q100J 74HCT251D-Q100J 74HCT251PWQ100J 74HCT251DB-Q100J 74HC138D-Q100HL
74HCT251D-Q100J 价格&库存
很抱歉,暂时无法提供与“74HCT251D-Q100J”相匹配的价格&库存,您可以联系我们找货
