74HC257-Q100; 74HCT257-Q100
Quad 2-input multiplexer; 3-state
Rev. 1 — 27 July 2015
Product data sheet
1. General description
The 74HC257-Q100; 74HCT257-Q100 is a quad 2-input multiplexer with 3-state outputs.
Inputs include clamp diodes. It enables the use of current limiting resistors to interface
inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Non-inverting data path
3-state outputs interface directly with system bus
Complies with JEDEC standard no. 7A
Input levels:
For 74HC257: CMOS level
For 74HCT257: TTL level
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
3. Ordering information
Table 1.
Type number
74HC257D-Q100
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
40 C to +125 C
TSSOP16 plastic thin shrink small outline package; 16 leads; SOT403-1
body width 4.4 mm
74HCT257D-Q100
74HC257PW-Q100
74HCT257PW-Q100
Nexperia
4. Functional diagram
2(
6
(1
DDG
Logic symbol
Fig 2.
6
2(
Fig 3.
PJD
Fig 1.
08;
IEC logic symbol
6(/(&725
67$7(08/7,3/(;(52873876
PJU
Functional diagram
74HC_HCT257_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 16
Nexperia
2(
6
Fig 4.
DDG
Logic diagram
5. Pinning information
5.1 Pinning
+&4
+&74
6
9&&
2(
*1'
DDD
Fig 5.
Pin configuration SO16 and TSSOP16
74HC_HCT257_Q100
Product data sheet
3 of 16
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
S
1
common data select input
1I0 to 4I0
2, 5, 11, 14
data input from source 0
1I1 to 4I1
3, 6, 10, 13
data input from source 1
1Y to 4Y
4, 7, 9, 12
3-state multiplexer output
GND
8
ground (0 V)
OE
15
3-state output enable input (active LOW)
VCC
16
supply voltage
6. Functional description
6.1 Function table
Table 3.
Function table[1]
Control
Input
Output
OE
S
nl0
nl1
nY
H
X
X
X
Z
L
H
X
L
L
L
H
X
H
H
L
L
L
X
L
L
L
H
X
H
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
IO
output current
VO = 0.5 V to VCC + 0.5 V
ICC
supply current
IGND
ground current
Tstg
storage temperature
total power dissipation
Ptot
Conditions
Min
Max
Unit
0.5
+7
V
[1]
mA
[1]
mA
35
mA
+70
mA
70
mA
65
+150
C
SO16 package
[2]
500
mW
TSSOP16 package
[3]
500
mW
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO16 packages: above 70 C, Ptot derates linearly with 8 mW/K.
[3]
For TSSOP16 packages: above 60 C, Ptot derates linearly with 5.5 mW/K.
74HC_HCT257_Q100
Product data sheet
4 of 16
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
2.0
5.0
6.0
V
74HC257-Q100
VCC
supply voltage
VI
input voltage
VCC
V
VO
output voltage
VCC
V
t/V
input transition rise and fall VCC = 2.0 V
rates
VCC = 4.5 V
625
ns
1.67
139
ns
VCC = 6.0 V
83
ns
40
+125
C
4.5
5.0
5.5
V
ambient temperature
Tamb
74HCT257-Q100
VCC
supply voltage
VI
input voltage
VCC
V
VO
output voltage
VCC
V
t/V
input transition rise and fall VCC = 4.5 V
rates
1.67
139
ns
Tamb
ambient temperature
40
+125
C
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 C
Conditions
40 C to
+85 C
40 C to
+125 C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
V
74HC257-Q100
VIH
VIL
VOH
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
74HC_HCT257_Q100
Product data sheet
VCC = 2.0 V
0.8
0.5
0.5
0.5
VCC = 4.5 V
2.1
1.35
1.35
1.35 V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 6.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 7.8 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
VI = VIH or VIL
5 of 16
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
VOL
LOW-level
output voltage
25 C
Conditions
40 C to
+85 C
40 C to
+125 C
Unit
Min
Typ
Max
Min
Max
Min
Max
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
0.16
0.26
0.33
0.4
V
VI = VIH or VIL
II
input leakage current VI = VCC or GND; VCC = 6.0 V
0.1
1.0
1.0 A
IOZ
OFF-state
output current
VI = VIH or VIL;
VO = VCC or GND;
VCC = 6.0 V
0.5
5.0
10.0 A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
A
Ci
input capacitance
3.5
pF
74HCT257-Q100
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = 20 A
4.4
4.5
4.4
4.4
V
IO = 6 mA
3.98
4.32
3.84
3.7
V
LOW-level
output voltage
IO = 20 A
0.33
0.4
V
IO = 6.0 mA
0.15
0.26
0.33
0.4
V
VOL
II
input leakage current VI = VCC or GND; VCC = 5.5 V
0.1
1.0
1.0 A
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 5.5 V;
VO = VCC or GND per input
pin; other inputs at VCC or
GND; IO = 0 A
0.5
5.0
10
A
ICC
supply current
VCC = 5.5 V
8.0
80
160
A
ICC
additional supply
current
VI = VCC 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A
CI
input capacitance
74HC_HCT257_Q100
Product data sheet
per input pin; nI0, nI1 inputs
40
144
180
196
A
per input pin; OE input
135
486
608
662
A
per input pin; S input
70
252
315
343
A
3.5
pF
6 of 16
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); For test circuit, see Figure 8.
Symbol Parameter
25 C
Conditions
40 C to
+85 C
40 C to Unit
+125 C
Typ
Max
Max
Max
VCC = 2.0 V
36
110
140
165
ns
VCC = 4.5 V
13
22
28
33
ns
VCC = 5.0 V; CL = 15 pF
11
ns
VCC = 6.0 V
10
19
24
28
ns
74HC257-Q100
tpd
propagation
delay
nl0 to nY or nl1 to nY; see Figure 6
[1]
S to nY; see Figure 6
VCC = 2.0 V
47
150
190
225
ns
VCC = 4.5 V
17
30
38
45
ns
14
ns
14
26
33
38
ns
VCC = 2.0 V
33
150
190
225
ns
VCC = 4.5 V
12
30
38
45
ns
10
26
33
38
ns
VCC = 2.0 V
41
150
190
225
ns
VCC = 4.5 V
15
30
38
45
ns
12
26
33
38
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
4
10
13
15
ns
45
pF
VCC = 4.5 V
16
30
38
45
ns
13
ns
44
53
ns
VCC = 6.0 V
ten
enable time
OE to nY; see Figure 7
[2]
VCC = 6.0 V
tdis
disable time
[3]
VCC = 6.0 V
tt
transition time
[4]
see Figure 6
VCC = 6.0 V
CPD
power dissipation per multiplexer; VI = GND to VCC
capacitance
[5]
74HCT257-Q100
tpd
propagation
delay
[1]
VCC = 4.5 V
17
ns
ten
enable time
OE to nY; VCC = 4.5 V; see Figure 7
[2]
15
30
38
45
ns
tdis
disable time
[3]
16
30
38
45
ns
VCC = 4.5 V; see Figure 6
[4]
5
12
15
18
ns
tt
transition time
74HC_HCT257_Q100
Product data sheet
7 of 16
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
power dissipation per multiplexer; VI = GND to VCC 1.5 V
capacitance
CPD
[1]
40 C to
+85 C
40 C to Unit
+125 C
Typ
Max
Max
Max
45
[5]
pF
tpd is the same as tPHL, tPLH.
[2]
ten is the same as tPZH, tPZL.
[3]
tdis is the same as tPHZ, tPLZ.
[4]
tt is the same as tTHL, tTLH.
[5]
25 C
Conditions
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
11. Waveforms
9,
LQSXW
6Q,Q,
90
90
*1'
W 3+/
W 3/+
92+
RXWSXW
Q<
90
90
92/
W 7+/
W 7/+
DDG
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6.
Propagation delays input (S, nI0, nI1) to output (nY) and output (nY) transition times
74HC_HCT257_Q100
Product data sheet
8 of 16
Nexperia
WU
9,
WI
2(LQSXW
90
*1'
W3/=
RXWSXW
W3=/
9&&
/2:WR2))
2))WR/2:
90
92/
W3+=
RXWSXW
92+
W3=+
+,*+WR2))
2))WR+,*+
*1'
90
RXWSXWV
HQDEOHG
RXWSXWV
HQDEOHG
RXWSXWV
GLVDEOHG
DDF
Fig 7.
Table 8.
3-state output enable and disable times
Measurement points
Type
Input
Output
VM
VM
74HC257-Q100
0.5VCC
0.5VCC
74HCT257-Q100
1.3 V
1.3 V
74HC_HCT257_Q100
Product data sheet
9 of 16
Nexperia
9,
W:
QHJDWLYH
SXOVH
90
9
WI
WU
WU
WI
9,
SRVLWLYH
SXOVH
9
90
90
90
W:
9&&
9&&
9,
92
5/
6
RSHQ
'87
57
DDG
Measurement points are given in Table 8 and test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistor.
Fig 8.
Table 9.
Test circuit for measuring switching times
Test data
Type
Input
Load
Switch position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
VCC
6 ns
50 pF
1 k
open
GND
VCC
74HCT257-Q100 3 V
6 ns
50 pF
1 k
open
GND
VCC
74HC257-Q100
74HC_HCT257_Q100
Product data sheet
10 of 16
Nexperia
12. Package outline
62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
Z 0
ES
GHWDLO;
PP
VFDOH
',0(16,216LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
PP
LQFKHV
ș
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPLQFKPD[LPXPSHUVLGHDUHQRWLQFOXGHG
Fig 9.
5()(5(1&(6
287/,1(
9(56,21
627
06
-(,7$
(8523($1
352-(&7,21
,668('$7(
Package outline SOT109-1 (SO16)
74HC_HCT257_Q100
Product data sheet
11 of 16
Nexperia
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWHV
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Fig 10. Package outline SOT403-1 (TSSOP16)
74HC_HCT257_Q100
Product data sheet
12 of 16
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
MIL
Military
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74HC_HCT257_Q100 v.1
20150727
Product data sheet
74HC_HCT257_Q100
Product data sheet
13 of 16
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74HC_HCT257_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
14 of 16
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC_HCT257_Q100
Product data sheet
15 of 16
Nexperia
17. Contents
1
2
3
4
5
5.1
5.2
6
6.1
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 4
Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 27 July 2015
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC257PW-Q100J 74HC257D-Q100J 74HCT257PW-Q100J 74HCT257D-Q100J
