74HC4514DB,118
74HC4514DB,118
    NEXPERIA(安世)
    SSOP24_208MIL
    带输入锁存器的4到16线解码器/多路分配器 SSOP24_208MIL 2~6V
74HC4514DB,118 数据手册
74HC4514; 74HCT4514 4-to-16 line decoder/demultiplexer with input latches Rev. 3 — 20 February 2018 1 Product data sheet General description The 74HC4514; 74HCT4514 is a 4-to-16 line decoder/demultiplexer having four binary weighted address inputs (A0 to A3), with latches, a latch enable input (LE), an enable input (E) and 16 outputs (Q0 to Q15). When LE is HIGH, the selected output is determined by the data on An. When LE goes LOW, the last data present at An are stored in the latches and the outputs remain stable. When E is LOW, the selected output, determined by the contents of the latch, is HIGH. At E HIGH, all outputs are LOW. The enable input E does not affect the state of the latch. When the device is used as a demultiplexer, E is the data input and A0 to A3 are the address inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. The 74HCT4514 features reduced input threshold levels to allow interfacing to TTL logic levels. 2 Features and benefits • Input levels: – For 74HC4514: CMOS level – For 74HCT4514: TTL level • 16-line demultiplexing capability • Decodes 4 binary-coded inputs into 16 mutually-exclusive outputs • Complies with JEDEC standard no. 7 A • ESD protection: – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V • Multiple package options • Specified from -40 °C to +85 °C and -40 °C to +125 °C 3 Applications • Digital multiplexing • Address decoding • Hexadecimal/BCD decoding 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches 4 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version −40 °C to +125 °C SO24 plastic small outline package; 24 leads; body width 7.5 mm SOT137-1 74HC4514DB −40 °C to +125 °C SSOP24 plastic shrink small outline package; 24 leads; body width 5.3 mm SOT340-1 74HC4514PW −40 °C to +125 °C TSSOP24 plastic thin shrink small outline package; 24 leads; SOT355-1 body width 4.4 mm 74HC4514D 74HCT4514D 74HCT4514PW 5 Functional diagram 1 2 3 21 22 23 LE A0 A1 A2 A3 E Q0 11 Q1 DX X/Y 0 11 0 11 9 1 9 1 9 Q2 10 2 10 2 10 Q3 8 3 8 3 8 Q4 7 4 7 4 7 Q5 6 5 6 5 6 Q6 5 2 6 5 2 9D, 1 6 5 Q7 4 3 7 4 3 9D, 2 7 4 Q8 18 21 8 18 21 9D, 4 8 18 Q9 17 22 9 17 22 9D, 8 9 17 Q10 20 10 20 10 20 Q11 19 11 19 11 19 Q12 14 12 14 12 14 Q13 13 13 13 13 13 Q14 16 14 16 14 16 Q15 15 15 15 15 15 1 C4 0 0 4D, G 15 3 23 1 C9 23 EN aaa-028161 aaa-028162 Figure 1. Logic symbol Figure 2. IEC logic symbol 2 3 A0 1 23 LE 21 A1 A2 22 A3 LATCHES E DECODER Q0 11 Q1 9 Q2 10 Q3 8 Q4 7 Q5 6 Q6 5 Q7 4 Q8 18 Q9 17 Q10 Q11 Q12 Q13 Q14 Q15 20 19 14 13 16 15 aaa-028163 Figure 3. Functional diagram 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches A0 Q0 SD latch 1 RD Q Q1 Q Q2 Q3 A1 Q4 SD latch 2 RD Q Q5 Q Q6 Q7 A2 Q8 SD latch 3 RD Q Q9 Q Q10 Q11 A3 Q12 SD LE latch 4 RD Q Q13 Q Q14 E Q15 aaa-028164 Figure 4. Logic diagram 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches 6 Pinning information 6.1 Pinning 74HC4514 74HCT4514 74HC4514 74HCT4514 LE 1 24 VCC A0 2 23 E 2 24 VCC 23 E A1 3 22 A3 A1 3 22 A3 Q7 4 21 A2 Q7 4 21 A2 Q6 5 20 Q10 Q6 5 20 Q10 Q5 6 19 Q11 Q5 6 19 Q11 Q4 7 18 Q8 Q4 7 18 Q8 Q3 8 17 Q9 Q3 8 17 Q9 Q1 9 16 Q14 Q1 9 16 Q14 Q2 10 15 Q15 Q2 10 15 Q15 Q0 11 14 Q12 Q0 11 14 Q12 GND 12 GND 12 13 Q13 LE 1 A0 13 Q13 aaa-028166 aaa-028165 Figure 5. Pin configuration for SO24 (SOT137-1) Figure 6. Pin configuration for SSOP24 (SOT340-1) and TSSOP24 (SOT355-1) 6.2 Pin description Table 2. Pin description Symbol Pin Description LE 1 latch enable input (active HIGH) E 23 enable input (active LOW) Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7, Q8, Q9, Q10, Q11, Q12, Q13, Q14, Q15 11, 9, 10, 8, 7, 6, 5, 4, 18, 17, 20, 19, 14, 13, 16, 15 multiplexer outputs (active HIGH) A0, A1, A2, A3 2, 3, 21, 22 address inputs GND 12 ground (0 V) VCC 24 supply voltage 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches 7 Functional description Table 3. Function table Inputs [1] [2] Outputs E A0 A1 A2 A3 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 Q8 Q9 Q10 Q11 Q12 Q13 Q14 Q15 H X X X X L L L L L L L L L L L L L L L L L L L L L H L L L L L L L L L L L L L L L L H L L L L H L L L L L L L L L L L L L L L L H L L L L H L L L L L L L L L L L L L L H H L L L L L H L L L L L L L L L L L L L L L H L L L L L H L L L L L L L L L L L L H L H L L L L L L H L L L L L L L L L L L L H H L L L L L L L H L L L L L L L L L L H H H L L L L L L L L H L L L L L L L L L L L L H L L L L L L L L H L L L L L L L L H L L H L L L L L L L L L H L L L L L L L L H L H L L L L L L L L L L H L L L L L L H H L H L L L L L L L L L L L H L L L L L L L H H L L L L L L L L L L L L H L L L L H L H H L L L L L L L L L L L L L H L L L L H H H L L L L L L L L L L L L L L H L L H H H H L L L L L L L L L L L L L L L H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. [2] LE = HIGH 8 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current IOK Min Max -0.5 +7 V VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA output clamping current VO < -0.5 V or VO > VCC + 0.5 V - ±20 mA IO output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C - 500 mW Ptot total power dissipation Conditions SO24, SSOP24 and TSSOP24 [1] Unit [1] For SO24 packages: Ptot derates linearly with 8 mW/K above 70 °C. For SSOP24 and TSSOP24 packages: Ptot derates linearly with 5.5 mW/K above 60 °C. 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches 9 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions 74HC4514 74HCT4514 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V -40 - +125 -40 - +125 Tamb ambient temperature °C 10 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb (°C) +25 Unit −40 to +85 −40 to +125 Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V HIGH-level output VI = VIH or VIL voltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC4514 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage LOW-level output voltage 74HC_HCT4514 Product data sheet VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches Symbol Parameter Conditions Tamb (°C) +25 Unit −40 to +85 −40 to +125 Min Typ Max Min Max Min Max II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - - - - - pF 74HCT4514 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output VI = VIH or VIL; VCC = 4.5 V voltage IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V IO = 20 μA - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.15 0.26 - 0.33 - 0.4 V IO = -4 mA VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; VCC = 5.5 V; IO = 0 A - - 8.0 - 80 - 160 μA ΔICC additional supply current per input pin; VCC = 4.5 V to 5.5 V; VI = VCC - 2.1 V; other inputs at VCC or GND; IO = 0 A An - 65 234 - 292.5 - LE - 140 504 - 630 - 686 μA E - 100 360 - 450 - 490 μA - 3.5 - - - - - pF CI input capacitance 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 318.5 μA © Nexperia B.V. 2018. All rights reserved. 7 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches 11 Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 9. Symbol Parameter Conditions Tamb (°C) +25 Unit −40 to +85 −40 to +125 Min Typ Max Min Max Min Max VCC = 2.0 V - 74 230 - 290 - 345 ns VCC = 4.5 V - 27 46 - 58 - 69 ns VCC = 5 V; CL = 15 pF - 23 - - - - - ns VCC = 6.0 V - 22 39 - 49 - 59 ns VCC = 2.0 V - 74 230 - 290 - 345 ns VCC = 4.5 V - 27 46 - 58 - 69 ns VCC = 6.0 V - 22 39 - 49 - 59 ns VCC = 2.0 V - 41 175 - 220 - 265 ns VCC = 4.5 V - 15 35 - 44 - 53 ns - 12 30 - 37 - 45 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V 80 14 - 100 - 120 - ns VCC = 4.5 V 16 5 - 20 - 24 - ns VCC = 6.0 V 14 4 - 17 - 20 - ns VCC = 2.0 V 90 25 - 115 - 135 - ns VCC = 4.5 V 18 9 - 23 - 27 - ns VCC = 6.0 V 15 7 - 20 - 23 - ns VCC = 2.0 V 1 −11 - 1 - 1 - ns VCC = 4.5 V 1 −4 - 1 - 1 - ns 1 −3 - 1 - 1 - ns - 44 - - - - - pF 74HC4514 tpd propagation delay An to Qn; see Figure 7 [1] LE to Qn; see Figure 7 E to Qn; see Figure 7 VCC = 6.0 V tt tW tsu th transition time pulse witdh set-up time hold time [2] Qn; see Figure 7 LE HIGH; see Figure 8 An to LE; see Figure 8 An to LE; see Figure 8 VCC = 6.0 V CPD power dissipation per package; VI = GND to VCC capacitance 74HC_HCT4514 Product data sheet [3] All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches Symbol Parameter Conditions Tamb (°C) +25 Unit −40 to +85 −40 to +125 Min Typ Max Min Max Min Max VCC = 4.5 V - 30 55 - 69 - 83 ns VCC = 5 V; CL = 15 pF - 26 - - - - - ns LE to Qn; VCC = 4.5 V; see Figure 7 - 29 50 - 63 - 75 ns E to Qn; VCC = 4.5 V; see Figure 7 - 17 40 - 50 - 60 ns - 7 15 - 19 - 22 ns 74HCT4514 tpd propagation delay An to Qn; see Figure 7 [1] [2] tt transition time Qn; VCC = 4.5 V; see Figure 7 tW pulse witdh LE HIGH; VCC = 4.5 V; see Figure 8 16 4 - 20 - 24 - ns tsu set-up time An to LE; VCC = 4.5 V; see Figure 8 18 9 - 23 - 27 - ns th hold time An to LE; VCC = 4.5 V; see Figure 8 3 −3 - 3 - 3 - ns CPD power dissipation per package; capacitance VI = GND to VCC - 1.5 V - 45 - - - - - pF [3] [1] tpd is the same as tPLH and tPHL [2] tt is the same as tTLH and tTHL [3] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of load switching outputs; 2 Σ(CL x VCC x fo) = sum of the outputs. 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches 11.1 Waveforms and test circuit VI An, LE, E input VM VM tPHL tPLH GND VOH 90 % 90 % VM Qn output VM 10 % VOL 10 % tTHL tTLH aaa-028167 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Figure 7. The inputs (An, LE, E) to output (Qn) propagation delays and the output transition times VI VM An input GND th th tsu VI transparant LE input tsu latched VM transparant latched tW aaa-028168 GND Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. Figure 8. Data set-up and hold times for An input to LE input and LE input pulse width Table 8. Measurement points Type Output Input VI VM VM 74HC4514 GND to VCC 0.5VCC 0.5VCC 74HCT4514 GND to 3 V 1.3 V 1.3 V 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions for test circuit: RT = Termination resistance; should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Figure 9. Test circuit for measuring switching times Table 9. Test data Type Input Load VI tr, tf CL 74HC4514 GND to VCC 6 ns 15 pF, 50 pF 74HCT4514 GND to 3 V 6 ns 15 pF, 50 pF 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches 12 Application information VCC Q0 A3 Q1 all diodes are general purpose Germanium A2 Q2 A1 Q3 A0 Q4 Q5 Q6 Q7 LE Q8 Q9 Q10 E Q11 Q12 Q13 R = 2 kΩ Q14 Q15 “4050 R = 2 kΩ A3 A2 A1 “4511 A0 R = 10 kΩ aaa-028074 Figure 10. Code-to-code conversion; hexadecimal to BCD 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches 13 Package outline SO24: plastic small outline package; 24 leads; body width 7.5 mm SOT137-1 D E A X c HE y v M A Z 24 13 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 12 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 15.6 15.2 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.9 0.4 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.019 0.013 0.014 0.009 0.61 0.60 0.30 0.29 0.05 0.419 0.043 0.043 0.055 0.394 0.016 0.039 0.01 0.01 0.004 0.035 0.016 Z (1) θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT137-1 075E05 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 11. Package outline SOT137-1 (SO24) 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches SSOP24: plastic shrink small outline package; 24 leads; body width 5.3 mm D SOT340-1 E A X c HE y v M A Z 24 13 Q A2 pin 1 index A (A 3 ) A1 θ Lp L 1 12 bp e detail X w M 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 8.4 8.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 0.8 0.4 8o 0o Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION SOT340-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 12. Package outline SOT340-1 (SSOP24) 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches TSSOP24: plastic thin shrink small outline package; 24 leads; body width 4.4 mm D SOT355-1 E A X c HE y v M A Z 13 24 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 12 bp e detail X w M 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 7.9 7.7 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT355-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Figure 13. Package outline SOT355-1 (TSSOP24) 74HC_HCT4514 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches 14 Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT4514 v.3 20180220 Product data sheet - 74HC_HCT4514 v.2 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74HC_HCT4514 v.2 19930901 74HC_HCT4514 Product data sheet Product specification - All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 74HC_HCT4514 v.1 © Nexperia B.V. 2018. All rights reserved. 16 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches 16 Legal information 16.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74HC_HCT4514 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 17 / 19 74HC4514; 74HCT4514 Nexperia 4-to-16 line decoder/demultiplexer with input latches Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74HC_HCT4514 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 18 / 19 Nexperia 74HC4514; 74HCT4514 4-to-16 line decoder/demultiplexer with input latches Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 16 General description ............................................ 1 Features and benefits .........................................1 Applications .........................................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 4 Pinning ............................................................... 4 Pin description ................................................... 4 Functional description ........................................5 Limiting values .................................................... 5 Recommended operating conditions ................ 6 Static characteristics .......................................... 6 Dynamic characteristics .....................................8 Waveforms and test circuit .............................. 10 Application information .................................... 12 Package outline .................................................13 Abbreviations .................................................... 16 Revision history ................................................ 16 Legal information .............................................. 17 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 February 2018 Document identifier: 74HC_HCT4514 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC4514D,652 74HC4514DB,112 74HC4514DB,118 74HC4514D,653 74HC4514N,652 74HC4514PW,112 74HC4514PW,118 74HCT4514D,652 74HCT4514DB,112 74HCT4514DB,118 74HCT4514D,653 74HCT4514PW,112 74HCT4514PW,118
74HC4514DB,118
1. 物料型号:74HC_HCT4514是Nexperia公司生产的四路双输入正逻辑与非门。
2. 器件简介:74HC_HCT4514是一种高速CMOS器件,与低功耗肖特基TTL(LSTTL)系列兼容。它由四个独立的与非门组成,具有高噪声抑制能力和出色的抗干扰性能。
3. 引脚分配: - 1: Vcc(电源) - 2: 输入A1 - 3: 输入B1 - 4: 输出Y1 - 5: 输入A2 - 6: 输入B2 - 7: 输出Y2 - 8: 输入A3 - 9: 输入B3 - 10: 输出Y3 - 11: 输入A4 - 12: 输入B4 - 13: 输出Y4 - 14: GND(地)
4. 参数特性: - 电源电压范围:2V至6V - 工作温度范围:-40°C至+85°C - 低功耗:在5V供电下,静态功耗仅为2mW
5. 功能详解:每个与非门的输出在两个输入中至少有一个为高电平时为低电平,否则输出为高电平。
6. 应用信息:适用于高速数字电路、通信设备、计算机外设、汽车电子等领域。
7. 封装信息:提供多种封装选项,包括SOIC、TSSOP、DIP等。
74HC4514DB,118 价格&库存
很抱歉,暂时无法提供与“74HC4514DB,118”相匹配的价格&库存,您可以联系我们找货
