74HC137
3-to-8 line decoder, demultiplexer with address latches;
inverting
Rev. 4 — 23 December 2015
Product data sheet
1. General description
The 74HC137 is a high-speed Si-gate CMOS device and is pin compatible with low power
Schottky TTL (LSTTL). The 74HC137 is specified in compliance with JEDEC
standard no. 7A.
The 74HC137 is a 3-to-8 line decoder, demultiplexer with latches at the three address
inputs (An). The 74HC137 essentially combines the 3-to-8 decoder function with a 3-bit
storage latch. When the latch is enabled (LE = LOW), the 74HC137 acts as a 3-to-8 active
LOW decoder. When the latch enable (LE) goes from LOW-to-HIGH, the last data present
at the inputs before this transition, is stored in the latches. Further address changes are
ignored as long as LE remains HIGH.
The output enable input (E1 and E2) controls the state of the outputs independent of the
address inputs or latch operation. All outputs are HIGH unless E1 is LOW and E2 is HIGH.
The 74HC137 is ideally suited for implementing non-overlapping decoders in 3-state
systems and strobed (stored address) applications in bus oriented systems.
2. Features and benefits
Combines 3-to-8 decoder with 3-bit latch
Multiple input enable for easy expansion or independent controls
Active LOW mutually exclusive outputs
Low-power dissipation
Complies with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Specified from 40 C to +80 C and from 40 C to +125 C.
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74HC137D
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74HC137DB
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
74HC137
Nexperia
3-to-8 line decoder, demultiplexer with address latches; inverting
4. Functional diagram
很抱歉,暂时无法提供与“74HC137D,652”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 390+8.21507390+1.05908
- 500+7.39339500+0.95315
- 1000+6.818301000+0.87901
- 10000+6.0785410000+0.78364
- 100000+5.09304100000+0.65659
