74HC158
Quad 2-input multiplexer; inverting
Rev. 4 — 23 December 2015
Product data sheet
1. General description
The 74HC158 is a high-speed Si-gate CMOS device and is pin compatible with low power
Schottky TTL (LSTTL). The 74HC158 is specified in compliance with JEDEC
standard no. 7A.
The 74HC158 is a quad 2-input multiplexer which select 4 bits of data from two sources
and are controlled by a common data select input (S). The four outputs present the
selected data in the inverted form. The enable input (E) is active LOW.
When E is HIGH, all the outputs (1Y to 4Y) are forced HIGH regardless of all other input
conditions.
Moving the data from two groups of registers to four common output buses is a common
use of the 74HC158. The state of S determines the particular register from which the data
comes. It can also be used as a function generator.
The device is useful for implementing highly irregular logic by generating any four of the
16 different functions of two variables with one variable common.
The 74HC158 is the logic implementation of a 4-pole, 2-position switch, where the
position of the switch is determined by the logic levels applied to S.
The logic equations for the output are:
1Y = E.(1l1.S 1l0.S)
2Y = E.(2l1.S 2l0.S)
3Y = E.(3l1.S 3l0.S)
4Y = E.(4l1.S 4l0.S)
The 74HC158 is identical to the 74HC157 but has inverting outputs.
2. Features and benefits
Low-power dissipation
Inverting data path
Complies with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2 000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from −40° C to +85 °C and −40 °C to +125 °C
74HC158
Nexperia
3. Ordering information
Table 1.
Type number
74HC158D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
4. Functional diagram
2
3
5
6
11 10 14 13
1I0 1I1 2I0 2I1 3I0 3I1 4I0 4I1
1 S
MULTIPLEXER
15 E
OUTPUTS
1Y
4
2Y
7
3Y
9
4Y
12
DDE
Fig 1.
Functional diagram
1
15
1
2
3
5
6
11
10
14
13
15
S
1I0
1I1
2I0
2I1
3I0
3I1
4I0
4I1
1Y
2Y
3Y
4Y
2
4
3
G1
EN
1
5
7
14
74HC158
Product data sheet
12
13
12
11
E
Logic symbol
7
6
9
4
1
9
10
DDE
Fig 2.
MUX
DDE
Fig 3.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
2 of 16
Nexperia B.V. 2017. All rights reserved
74HC158
Nexperia
S
E
1I0
1Y
1I1
2I0
2Y
2I1
3I0
3Y
3I1
4I0
4Y
4I1
DDE
Fig 4.
Logic diagram
5. Pinning information
5.1 Pinning
S
1
16 VCC
1I0
2
15 E
1I1
3
14 4I0
1Y
4
13 4I1
2I0
5
12 4Y
2I1
6
11 3I0
2Y
7
10 3I1
GND
8
9
3Y
DDE
Fig 5.
Pin configuration
74HC158
Product data sheet
3 of 16
74HC158
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
S
1
1I0
2
data input 1 from source 0
1I1
3
data input 1 from source 1
1Y
4
multiplexer output 1
2I0
5
data input 2 from source 0
2I1
6
data input 2 from source 1
2Y
7
multiplexer output 2
GND
8
ground (0 V)
3Y
9
multiplexer output 3
3I1
10
data input 3 from source 1
3I0
11
data input 3 from source 0
4Y
12
multiplexer output 4
4I1
13
data input 4 from source 1
4I0
14
data input 4 from source 0
E
15
enable input (active LOW)
VCC
16
positive supply voltage
6. Functional description
6.1 Function table
Table 3.
Function[1]
Control
Input
Output
E
S
nI0
nl1
nY
H
X
X
X
H
L
L
L
X
H
H
X
L
X
L
H
X
H
L
H
[1]
H = HIGH voltage level;
L = LOW voltage level;
X = don’t care.
74HC158
Product data sheet
4 of 16
74HC158
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
VCC
supply voltage
0.5
+7
V
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
mA
IO
output current
VO = 0.5 V to VCC + 0.5 V
25
mA
ICC
supply current
+50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
Unit
500
mW
Tamb = 40 C to +125 C
[1]
SO16 package
[1]
Max
Above 70 C: Ptot derates linearly with 8 mW/K.
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
supply voltage
VI
VO
Min
Typ
Max
Unit
2.0
5.0
6.0
V
input voltage
VCC
V
output voltage
VCC
V
Tamb
ambient temperature
t/V
input transition rise and
fall rate
74HC158
Product data sheet
Conditions
40
+125
C
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
5 of 16
74HC158
Nexperia
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
HIGH-level input voltage
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
Tamb = 25 C
VIH
VIL
VOH
VOL
LOW-level input voltage
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.8
V
HIGH-level output voltage VI = VIH or VIL
LOW-level output voltage
IO = 20 A; VCC = 2.0 V
1.9
2.0
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
V
IO = 4 mA; VCC = 4.5 V
3.98
4.32
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
V
V
V
V
IO =4 mA; VCC = 4.5 V
0.15
0.26
V
0.16
0.26
V
0.1
A
VI = VIH or VIL
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
ICC
supply current
VI = VCC or GND; IO =0 A; VCC = 6.0 V
8.0
A
CI
input capacitance
3.5
pF
VCC = 2.0 V
1.5
V
Tamb = 40 C to +85 C
VIH
VIL
VOH
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.84
V
5.34
V
74HC158
Product data sheet
6 of 16
74HC158
Nexperia
Table 6.
Static characteristics …continued
Symbol
Parameter
Conditions
VOL
VI = VIH or VIL
Min
Typ
Max
Unit
0.1
V
0.1
V
0.1
V
0.33
V
0.33
V
II
1.0
A
ICC
supply current
80
A
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.7
V
5.2
V
0.1
V
0.1
V
0.1
V
0.4
V
0.4
V
VIH
VIL
VOH
VOL
VI = VIH or VIL
II
1.0
A
ICC
supply current
160
A
74HC158
Product data sheet
7 of 16
74HC158
Nexperia
10. Dynamic characteristics
Table 7.
GND = 0 V; tr = tf = 6 ns; CL = 50 pF; for test circuit see Figure 8.
Symbol
Parameter
Conditions
Min
Typ
Max Unit
VCC = 2.0 V
41
125 ns
VCC = 4.5 V
15
25
ns
VCC = 6.0 V
12
21
ns
VCC =5.0 V; CL = 15 pF
12
ns
VCC = 2.0 V
47
145 ns
VCC = 4.5 V
17
29
ns
VCC = 6.0 V
14
25
ns
14
ns
Tamb = 25 C
tpd
propagation delay
nI0, nI1 to nY; see Figure 6
E to nY; see Figure 7
[1]
[1]
S to nY; see Figure 6
[1]
VCC = 2.0 V
47
145 ns
VCC = 4.5 V
17
29
ns
VCC = 6.0 V
14
25
ns
14
ns
VCC = 2.0 V
19
75
ns
VCC = 4.5 V
7
15
ns
6
13
ns
40
pF
VCC = 2.0 V
155 ns
VCC = 4.5 V
31
ns
VCC = 6.0 V
26
ns
VCC = 2.0 V
180 ns
VCC = 4.5 V
36
ns
VCC = 6.0 V
31
ns
VCC = 2.0 V
180 ns
VCC = 4.5 V
36
ns
VCC = 6.0 V
31
ns
VCC = 2.0 V
95
ns
VCC = 4.5 V
19
ns
VCC = 6.0 V
16
ns
tt
transition time
see Figure 6 and 7
[2]
VCC = 6.0 V
CPD
power dissipation capacitance
per multiplexer; VI = GND to VCC
[3]
[1]
tpd
propagation delay
tt
transition time
74HC158
Product data sheet
see Figure 6 and 7
[1]
[1]
[2]
8 of 16
74HC158
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max Unit
VCC = 2.0 V
190 ns
VCC = 4.5 V
38
ns
32
ns
VCC = 2.0 V
220 ns
VCC = 4.5 V
44
ns
38
ns
VCC = 2.0 V
220 ns
VCC = 4.5 V
44
ns
38
ns
VCC = 2.0 V
110
ns
VCC = 4.5 V
22
ns
VCC = 6.0 V
19
ns
propagation delay
tpd
[1]
VCC = 6.0 V
[1]
VCC = 6.0 V
[1]
VCC = 6.0 V
transition time
tt
[1]
tpd is the same as tPLH and tPHL.
[2]
tt is the same as tTHL and tTLH.
[3]
see Figure 6 and 7
[2]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74HC158
Product data sheet
9 of 16
74HC158
Nexperia
11. Waveforms
nI0, nI1, S
input
VM
tPHL
nY output
tPLH
VM
tTHL
tTLH
DDE
VM = 0.5VCC.
Fig 6.
Waveforms showing the data input (nI0, nI1) to output (nY) propagation delays and the output transition
times
E input
VM
tPHL
nY output
tPLH
VM
tTHL
tTLH
DDE
VM = 0.5VCC.
Fig 7.
Waveforms showing the enable input (E) to output (nY) propagation delays and the output transition
times
74HC158
Product data sheet
10 of 16
74HC158
Nexperia
VI
negative
pulse
VM
VI
GND
VM
10 %
GND
positive
pulse
tW
90 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VO
RT
CL
DDK
Test data is given in Table 8.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig 8.
Table 8.
Test circuit for measuring switching times
Test data
Type
74HC158
74HC158
Product data sheet
Input
Load
VI
tr, tf
CL
VCC
6.0 ns
15 pF, 50 pF
Test
tPLH, tPHL
11 of 16
74HC158
Nexperia
12. Package outline
62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
',0(16,216LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
8o
0o
1RWH
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 9.
5()(5(1&(6
287/,1(
9(56,21
SOT109-1
076E07
MS-012
-(,7$
(8523($1
352-(&7,21
,668('$7(
99-12-27
03-02-19
Package outline SOT109-1 (SO16)
74HC158
Product data sheet
12 of 16
74HC158
Nexperia
13. Abbreviations
Table 9.
Abbreviations
Acronym
Abbreviation
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
14. Revision history
Table 10.
Revision history
Document ID
Release
date
Data sheet status
Change notice
Supersedes
74HC158 v.4
20151223
Product data sheet
74HC158 v.3
Modifications:
74HC158 v.3
Modifications:
Type number 74HC158N (SOT38-4) removed.
20041112
Product data sheet
74HC_HCT158_CNV v.2
The format of this data sheet has been redesigned to comply with the current
presentation and information standard of Philips Semiconductors.
Removed type number 74HCT158.
Inserted family specification.
74HC_HCT158_CNV v.2
19970827
Product specification
74HC_HCT158 v.1
74HC_HCT158 v.1
19901201
74HC158
Product data sheet
13 of 16
74HC158
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74HC158
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
14 of 16
74HC158
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC158
Product data sheet
15 of 16
Nexperia
74HC158
17. Contents
1
2
3
4
5
5.1
5.2
6
6.1
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 4
Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 23 December 2015
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC158D,652 74HC158D,653
