74HC237DB,112
74HC237DB,112
    NEXPERIA(安世)
    SSOP16_208MIL
    3到8线解码器,带地址锁存器的多路分解器 SSOP16_208MIL 2~6V
74HC237DB,112 数据手册
74HC237 3-to-8 line decoder, demultiplexer with address latches Rev. 7 — 29 January 2016 Product data sheet 1. General description The 74HC237 is a high-speed Si-gate CMOS device and is pin compatible with low-power Schottky TTL (LSTTL). The 74HC237 is specified in compliance with JEDEC standard no. 7A. The 74HC237 is a 3-to-8 line decoder, demultiplexer with latches at the three address inputs (An). The 74HC237 essentially combines the 3-to-8 decoder function with a 3-bit storage latch. When the latch is enabled (LE = LOW), the 74HC237 acts as a 3-to-8 active LOW decoder. When the latch enable (LE) goes from LOW-to-HIGH, the last data present at the inputs before this transition, is stored in the latches. Further address changes are ignored as long as LE remains HIGH. The output enable input (E1 and E2) controls the state of the outputs independent of the address inputs or latch operation. All outputs are HIGH unless E1 is LOW and E2 is HIGH. The 74HC237 is ideally suited for implementing non-overlapping decoders in 3-state systems and strobes (stored address) applications in bus-oriented systems. 2. Features and benefits      Combines 3-to-8 decoder with 3-bit latch Multiple input enable for easy expansion or independent controls Active HIGH mutually exclusive outputs Low-power dissipation ESD protection:  HBM JESD22-A114F exceeds 2 000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC237D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HC237DB 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74HC237 Nexperia 3-to-8 line decoder, demultiplexer with address latches 4. Functional diagram  /(
74HC237DB,112
物料型号:74HC237 器件简介:74HC237 是 Nexperia 公司生产的一款八输入多路选择器/解码器。
引脚分配:1-G1, 2-A0, 3-A1, 4-A2, 5-Y0, 6-Y1, 7-Y2, 8-Y3, 9-G2B, 10-Y4, 11-Y5, 12-Y6, 13-Y7, 14-Vcc, 15-GND 参数特性:工作电压范围 2V 至 6V,工作温度范围 -40°C 至 +85°C,封装类型 SOIC。
功能详解:74HC237 能够根据输入的地址和使能信号选择一个输出。
应用信息:广泛应用于数字逻辑电路、数据选择和解码等领域。
封装信息:SOIC 封装,具有较小的占用空间和良好的热性能。
74HC237DB,112 价格&库存
很抱歉,暂时无法提供与“74HC237DB,112”相匹配的价格&库存,您可以联系我们找货
