74LVC138AD,112
74LVC138AD,112
    NEXPERIA(安世)
    SOIC-16
    3到8线解码器/多路分配器;反转 SOIC16_150MIL 1.2~3.6V
74LVC138AD,112 数据手册
74LVC138A 3-to-8 line decoder/demultiplexer; inverting Rev. 6 — 23 January 2019 Product data sheet 1. General description The 74LVC138A is a 3-to-8 line decoder/demultiplexer. It accepts three binary weighted address inputs (A0, A1 and A2) and, when enabled, provides eight mutually exclusive outputs (Y0 to Y7) that are LOW when selected. There are three enable inputs: two active LOW (E1 and E2) and one active HIGH (E3). Every output will be HIGH unless E1 and E2 are LOW and E3 is HIGH. This multiple enable function allows easy parallel expansion of the device to a 1-of-32 (5 lines to 32 lines) decoder with just four 74LVC138A devices and one inverter. The 74LVC138A can be used as an eight output demultiplexer by using one of the active LOW enable inputs as the data input and the remaining enable inputs as strobes. Unused enable inputs must be permanently tied to their appropriate active HIGH or LOW state. 2. Features and benefits • • • • • • • • • • • • 5 V tolerant inputs for interfacing with 5 V logic Wide supply voltage range from 1.2 V to 3.6 V CMOS low power consumption Direct interface with TTL levels Demultiplexing capability Multiple input enable for easy expansion Ideal for memory chip select decoding Mutually exclusive outputs Output drive capability 50 Ω transmission lines at 125 °C Complies with JEDEC standard: • JESD8-7A (1.65 V to 1.95 V) • JESD8-5A (2.3 V to 2.7 V) • JESD8-C/JESD36 (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-B exceeds 200 V • CDM JESD22-C101E exceeds 1000 V Specified from -40 °C to +85 °C and from -40 °C to +125 °C 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC138AD -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74LVC138ADB -40 °C to +125 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74LVC138APW -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; SOT403-1 body width 4.4 mm 74LVC138ABQ -40 °C to +125 °C DHVQFN16 plastic dual in-line compatible thermal-enhanced very thin quad flat package; no leads; 16 terminals; body 2.5 × 3.5 × 0.85 mm SOT763-1 4. Functional diagram DX 1 1 A0 Y0 15 2 A1 Y1 14 3 A2 Y2 13 4 5 6 Y3 12 E1 Y4 11 E2 Y5 10 E3 Y6 9 Y7 7 0 G 0 7 2 2 3 4 4 & 5 5 6 6 7 X/Y 15 14 1 13 2 12 3 1 2 2 4 3 11 4 10 4 9 5 7 & Fig. 2. EN 6 15 1 Y1 14 2 A1 Y2 13 3 A2 Y3 12 Y4 11 Y5 10 Y6 9 Y7 7 E2 6 E3 7 13 12 11 10 9 7 IEC logic symbol Y0 E1 6 14 (b) A0 5 5 15 mna371 Logic symbol 4 0 1 (a) mna370 Fig. 1. 1 2 3 0 3-to-8 DECODER ENABLE EXITING mna372 Fig. 3. Functional diagram 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 2 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting 5. Pinning information 5.1. Pinning A0 1 16 VCC A1 2 15 Y0 A2 3 14 Y1 E1 4 13 Y2 E2 5 138 74LVC138A A0 1 A1 2 16 VCC 15 Y0 A2 3 14 Y1 E1 4 13 Y2 12 Y3 E2 5 12 Y3 6 11 Y4 10 Y5 E3 6 11 Y4 E3 7 Y7 7 10 Y5 Y7 GND 8 GND 8 Y6 aaa-029538 001aad033 Fig. 4. Y6 Fig. 5. Pin configuration SOT109-1 (SO16) 1 A0 terminal 1 index area Pin configuration SOT338-1 (SSOP16) and SOT403-1 (TSSOP16) 16 VCC 9 9 A1 2 15 Y0 A2 3 14 Y1 E1 4 E2 5 E3 6 Y7 7 138 GND(1) 13 Y2 12 Y3 11 Y4 8 9 GND Y6 10 Y5 001aad035 Transparent top view (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig. 6. Pin configuration SOT763-1 (DHVQFN16) 5.2. Pin description Table 2. Pin description Symbol Pin Description A0, A1, A2 1, 2, 3 address input E1, E2 4, 5 enable input (active LOW) E3 6 enable input (active HIGH) GND 8 ground (0 V) Y0, Y1, Y2, Y3, Y4, Y5, Y6, Y7 15, 14, 13, 12, 11, 10, 9, 7 output VCC 16 supply voltage 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 3 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care Input Output E1 E2 E3 A0 A1 A2 Y0 Y1 Y2 Y3 Y4 Y5 Y6 Y7 H X X X X X H H H H H H H H X H X X X X H H H H H H H H X X L X X X H H H H H H H H L L H L L L L H H H H H H H H L L H L H H H H H H L H L H H L H H H H H H H L H H H L H H H H L L H H H H H L H H H H L H H H H H H L H H L H H H H H H H H L H H H H H H H H H H H L 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 V - ±50 mA -0.5 VCC + 0.5 - ±50 mA 100 mA VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V VO output voltage output HIGH or LOW state IO output current VO = 0 V to VCC ICC supply current - IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [3] VI < 0 V [1] Tamb = -40 °C to +125 °C [2] [3] mA V The minimum input voltage ratings may be exceeded if the input current ratings are observed. The output voltage ratings may be exceeded if the output current ratings are observed. For SO16 packages: above 70 °C the value of PD derates linearly with 8 mW/K. For SSOP16 and TSSOP16 packages: above 60 °C the value of PD derates linearly with 5.5 mW/K. For DHVQFN16 packages: above 60 °C the value of PD derates linearly with 4.5 mW/K. 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 4 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC Conditions supply voltage functional VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate Min Typ Max Unit 1.65 - 3.6 V 1.2 - - V 0 - 5.5 V output HIGH or LOW state 0 - VCC V -40 - +125 °C VCC = 1.65 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 3.6 V 0 - 10 ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage Conditions -40 °C to +85 °C VCC = 1.2 V VCC = 1.65 V to 1.95 V -40 °C to +125 °C Unit Min Typ [1] Max Min Max 1.08 - - 1.08 - V 0.65VCC - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 1.2 V - - 0.12 - 0.12 V VCC = 1.65 V to 1.95 V - - 0.35VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC - 0.2 - - VCC - 0.3 - V IO = -4 mA; VCC = 1.65 V 1.2 - - 1.05 - V IO = -8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = -12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = -18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = -24 mA; VCC = 3.0 V 2.2 - - 2.0 - V IO = 100 μA; VCC = 1.65 V to 3.6 V - - 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V 0.35VCC V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 3.6 V VI = VIH or VIL II input leakage current VCC = 3.6 V; VI = 5.5 V or GND - ±0.1 ±5 - ±20 μA ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 10 - 40 μA 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 5 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Min Typ [1] Max Min Max Unit ΔICC additional supply current per input pin; VCC = 2.7 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - 5 500 - 5000 μA CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 4.0 - - - pF [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 9. Symbol Parameter Conditions tpd An to Yn; see Fig. 7 propagation delay -40 °C to +85 °C Min Typ [1] Max Min Max - 14 - - - ns VCC = 1.65 V to 1.95 V 0.5 5.2 11.5 0.5 12.7 ns VCC = 2.3 V to 2.7 V 1.5 3.0 6.5 1.5 7.3 ns VCC = 2.7 V 1.5 3.2 6.8 1.5 8.5 ns VCC = 3.0 V to 3.6 V 1.0 2.7 5.8 1.0 7.5 ns - 14 - - - ns VCC = 1.65 V to 1.95 V 1.0 5.5 11.4 1.0 12.5 ns VCC = 2.3 V to 2.7 V 1.5 3.2 6.5 1.5 7.1 ns VCC = 2.7 V 1.5 3.3 6.8 1.5 8.5 ns VCC = 3.0 V to 3.6 V 1.0 2.9 5.8 1.0 7.5 ns - 15 - - - ns VCC = 1.65 V to 1.95 V 1.0 5.6 11.5 1.0 12.8 ns VCC = 2.3 V to 2.7 V 1.8 3.3 6.5 1.8 7.3 ns VCC = 2.7 V 1.5 3.4 6.4 1.5 8.0 ns VCC = 3.0 V to 3.6 V 1.0 2.9 5.8 1.0 7.5 ns - - 1.0 - 1.5 ns VCC = 1.65 V to 1.95 V - 9.9 - pF VCC = 2.3 V to 2.7 V - 15.8 - pF VCC = 3.0 V to 3.6 V - 21.1 - pF [2] VCC = 1.2 V E3 to Yn; see Fig. 7 [2] VCC = 1.2 V En to Yn; see Fig. 8 [2] VCC = 1.2 V tsk(o) output skew time CPD power dissipation capacitance [1] [2] [3] [4] -40 °C to +125 °C Unit [3] VI = GND to VCC [4] Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively. tpd is the same as tPLH and tPHL. Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in V N = number of inputs switching 2 ∑(CL × VCC × fo) = sum of outputs 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 6 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting 10.1. Waveforms and test circuit VCC An, E3 input VM GND tPHL tPLH VOH Yn output VM VOL tTHL tTLH mna373 Measurement points are given in Table 8 VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. The inputs An, E3 to outputs Yn propagation delays VCC E1, E2 VM input GND tPHL tPLH VOH Yn output VM VOL tTHL tTLH mna374 Measurement points are given in Table 8 VOL and VOH are typical output voltage levels that occur with the output load. Fig. 8. The inputs En to outputs Yn propagation delays Table 8. Measurement points Supply voltage Input Output VCC VI VM VM 1.2 V VCC 0.5 × VCC 0.5 × VCC 1.65 V to 1.95 V VCC 0.5 × VCC 0.5 × VCC 2.3 V to 2.7 V VCC 0.5 × VCC 0.5 × VCC 2.7 V 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 7 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC PULSE GENERATOR VI VO DUT RT CL RL 001aaf615 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig. 9. Test circuit for measuring switching times Table 9. Test data Supply voltage Input Load VI tr, tf CL RL 1.2 V VCC ≤ 2 ns 30 pF 1 kΩ 1.65 V to 1.95 V VCC ≤ 2 ns 30 pF 1 kΩ 2.3 V to 2.7 V VCC ≤ 2 ns 30 pF 500 Ω 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 8 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting 11. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 10. Package outline SOT109-1 (SO16) 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 9 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 11. Package outline SOT338-1 (SSOP16) 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 10 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 12. Package outline SOT403-1 (TSSOP16) 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 11 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm B D A A E A1 c detail X terminal 1 index area terminal 1 index area C e1 e b 2 7 y y1 C v M C A B w M C L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig. 13. Package outline SOT763-1 (DHVQFN16) 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 12 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC138A v.6 20190123 Product data sheet - Modifications: • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 74LVC138A v.5 20111019 Modifications: • • • 74LVC138A v.5 Product data sheet - 74LVC138A v.4 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Table 4, Table 5, Table 6, Table 7 and Table 9: values added for lower voltage ranges. 74LVC138A v.4 20030506 Product specification - 74LVC138A v.3 74LVC138A v.3 20020312 Product specification - 74LVC138A v.2 74LVC138A v.2 19980428 Product specification - 74LVC138A v.1 74LVC138A v.1 - - - - 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 13 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC138A Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 14 / 15 74LVC138A Nexperia 3-to-8 line decoder/demultiplexer; inverting Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................5 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 7 11. Package outline.......................................................... 9 12. Abbreviations............................................................ 13 13. Revision history........................................................13 14. Legal information......................................................14 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 January 2019 74LVC138A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 23 January 2019 © Nexperia B.V. 2019. All rights reserved 15 / 15 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC138ABQ,115 74LVC138AD,112 74LVC138ADB,112 74LVC138ADB,118 74LVC138AD,118 74LVC138APW,112 74LVC138APW,118 74LVC138APW/AUJ 74LVC138AD/AUJ
74LVC138AD,112 价格&库存
很抱歉,暂时无法提供与“74LVC138AD,112”相匹配的价格&库存,您可以联系我们找货
