74LVC139BQ,115
74LVC139BQ,115
    NEXPERIA(安世)
    DHVQFN-16-EP(2.5x3.5)
    双2对4线解码器/多路分配器 DHVQFN16_2.5X3.5MM-EP 1.2~3.6V
74LVC139BQ,115 数据手册
74LVC139 Dual 2-to-4 line decoder/demultiplexer Rev. 5 — 19 October 2011 Product data sheet 1. General description The 74LVC139 is a dual 2-to-4 line decoder/demultiplexer. It has two independent decoders, each accepting two binary weighted inputs (nA0 and nA1) and providing four mutually exclusive outputs (nY0 to nY3) that are LOW when selected. Each decoder has an active LOW input (nE). When nE is HIGH, every output is forced HIGH. The enable input can be used as the data input for a 1-to-4 demultiplexer application. 2. Features and benefits           Wide supply voltage range from 1.2 V to 3.6 V Inputs accept voltages up to 5.5 V CMOS low power consumption Direct interface with TTL levels Demultiplexing capability Two independent 2-to-4 decoders Multifunction capability Mutually exclusive outputs Output drive capability 50  transmission lines at 125 C Complies with JEDEC standard:  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A (2.3 V to 2.7 V)  JESD8-C/JESD36 (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-B exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Specified from 40 C to +85 C and from 40 C to +125 C 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC139D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74LVC139DB 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74LVC139PW 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74LVC139BQ 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm SOT763-1 4. Functional diagram 1 1E 1Y0 2 3 1A0 1Y1 1A1 1Y2 1Y3 2Y0 14 13 2A0 2Y1 2A1 2Y2 2Y3 4 2 5 3 6 1 DX 0 0 1 G 3 1 2 0 3 7 5 6 7 2 3 1 X/Y 0 1 1 2 2 EN 3 4 5 6 7 12 11 14 10 13 9 15 DX 0 0 1 G 3 1 2 0 2E 15 4 3 12 11 10 9 14 13 15 X/Y 0 1 2 EN (a) mna779 1 2 3 (b) 12 11 10 9 mna781 a) demultiplexer b) decoder Fig 1. Logic symbol 74LVC139 Product data sheet Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 2 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer 2 1A0 3 1A1 1 1E 14 2A0 DECODER 1Y0 4 1Y1 5 1Y2 6 1Y3 7 2Y0 12 13 2A1 2Y1 11 DECODER 2Y2 10 9 2Y3 15 2E mna780 Fig 3. Functional diagram 5. Pinning information 1E terminal 1 index area 16 VCC 5.1 Pinning 1 16 VCC 1A0 2 15 2E 1A0 2 15 2E 1A1 3 14 2A0 1A1 3 14 2A0 1Y0 4 13 2A1 1Y0 4 1Y1 5 1Y2 6 1Y3 7 1 1E 1Y2 6 11 2Y1 1Y3 7 10 2Y2 GND 8 9 2Y3 GND(1) 12 2Y0 11 2Y1 10 2Y2 9 12 2Y0 2Y3 5 8 1Y1 13 2A1 139 GND 139 001aad031 Transparent top view 001aad029 (1) The die substrate is attached to this pad using conductive die attach material. It can not be used as a supply pin or input. Fig 4. Pin configuration SO16 and (T)SSOP16 Fig 5. Pin configuration DHVQFN14 5.2 Pin description Table 2. Pin description Name Pin Description 1E 1 enable input (active LOW) 2E 15 enable input (active LOW) 1A[0:1] 2, 3 address input 2A[0:1] 14, 13 address input 1Y[0:3] 4, 5, 6, 7 output 74LVC139 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 3 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer Table 2. Pin description …continued Name Pin Description 2Y[0:3] 12, 11, 10, 9 output GND 8 ground (0 V) VCC 16 positive supply voltage 6. Functional description Table 3. Function table[1] Input Output nE nA0 nA1 nY0 nY1 nY2 nY3 H X X H H H H L L L L H H H L H L H L H H L L H H H L H L H H H H H L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 [1] VO > VCC or VO < 0 V [2] Min Max Unit 0.5 +6.5 V 50 - mA 0.5 +6.5 V - 50 mA 0.5 VCC + 0.5 V VO output voltage IO output current - 50 mA ICC supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot VO = 0 V to VCC Tamb = 40 C to +125 C [3] [1] The minimum input voltage ratings may be exceeded if the input current ratings are observed. [2] The output voltage ratings may be exceeded if the output current ratings are observed. [3] For SO16 packages: above 70 C derate linearly with 8 mW/K. For SSOP16 and TSSOP16 packages: above 60 C derate linearly with 5.5 mW/K. For DHVQFN16 packages: above 60 C derate linearly with 4.5 mW/K. 74LVC139 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 4 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VCC supply voltage functional Min Typ Max Unit 1.65 - 3.6 V 1.2 - - V VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature in free air 40 +125 C t/V input transition rise and fall rate VCC = 1.65 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 3.6 V 0 - 10 ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter 40 C to +85 C Conditions Min VIH VIL VOH VOL II HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage Product data sheet 40 C to +125 C Max Min Unit Max VCC = 1.2 V 1.08 - - 1.08 - V VCC = 1.65 V to 1.95 V 0.65  VCC - - 0.65  VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 1.2 V - - 0.12 - 0.12 V VCC = 1.65 V to 1.95 V - - 0.35  VCC - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V IO = 100 A; VCC = 1.65 V to 3.6 V VCC  0.2 - - VCC  0.3 - V IO = 4 mA; VCC = 1.65 V 1.2 - - 1.05 - V IO = 8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = 12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = 18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = 24 mA; VCC = 3.0 V 2.2 - - 2.0 - V IO = 100 A; VCC = 1.65 V to 3.6 V - - 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V VI = VIH or VIL VI = VIH or VIL IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V 0.1 5 - 20 A input leakage VCC = 3.6 V; VI = 5.5 V or GND current 74LVC139 Typ[1] All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 5 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer Table 6. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter 40 C to +85 C Conditions Typ[1] Min 40 C to +125 C Max Min Unit Max ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 10 - 40 A ICC additional supply current per input pin ; VCC = 2.7 V to 3.6 V; VI = VCC  0.6 V; IO = 0 A - 5 500 - 5000 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 5.0 - - - pF [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 8. Symbol Parameter propagation delay tpd 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max - 14 - - - ns VCC = 1.65 V to 1.95 V 0.5 4.7 10.4 0.5 11.3 ns VCC = 2.3 V to 2.7 V 1.0 2.8 5.9 1.0 6.5 ns VCC = 2.7 V 1.0 3.0 6.3 1.0 8.0 ns VCC = 3.0 V to 3.6 V 1.0 2.5 5.3 1.0 7.0 ns - 14 - - - ns VCC = 1.65 V to 1.95 V 1.5 4.5 9.8 1.5 10.7 ns VCC = 2.3 V to 2.7 V 2.1 2.7 5.6 2.1 6.1 ns VCC = 2.7 V 1.0 2.8 5.4 1.0 7.0 ns 1.0 2.4 5.0 1.0 6.5 ns - - 1.0 - 1.5 ns VCC = 1.65 V to 1.95 V - 5.6 - - - pF VCC = 2.3 V to 2.7 V - 11.3 - - - pF VCC = 3.0 V to 3.6 V - 16.4 - - - pF nAn to Yn; see Figure 6 [2] VCC = 1.2 V nE to Yn; see Figure 7 [2] VCC = 1.2 V VCC = 3.0 V to 3.6 V tsk(o) output skew time VCC = 3.0 V to 3.6 V [3] CPD power dissipation capacitance VI = GND to VCC [4] [1] Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively. [2] tpd is the same as tPLH and tPHL. [3] Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in V N = number of inputs switching, 74LVC139 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 6 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer (CL  VCC2  fo) = sum of outputs. 11. Waveforms VI VI VM nAn input GND GND t PHL t PLH tPLH tPHL VOH VOH VM nYn output VM nE input VM nYn output VOL VOL mna782 mna783 VM = 1.5 V at VCC  2.7 V. Fig 6. VM = 1.5 V at VCC  2.7 V. VM = 0.5  VCC at VCC < 2.7 V. VM = 0.5  VCC at VCC < 2.7 V. VOL and VOH are the typical output voltage levels that occur with the output load. VOL and VOH are the typical output voltage levels that occur with the output load. Input (nAn) to output (nYn) propagation delays 74LVC139 Product data sheet Fig 7. Enable input (nE) to output (nYn) propagation delays All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 7 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer tW VI 90 % negative pulse VM VM 10 % 0V tf tr tr tf VI 90 % positive pulse VM VM 10 % 0V tW VCC PULSE GENERATOR VI VO DUT RT CL RL 001aaf615 Test data is given in Table 8. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 8. Table 8. Load circuitry for switching times Test data Supply voltage Input Load VI tr, tf CL RL 1.2 V VCC  2 ns 30 pF 1 k 1.65 V to 1.95 V VCC  2 ns 30 pF 1 k 2.3 V to 2.7 V VCC  2 ns 30 pF 500  2.7 V 2.7 V  2.5 ns 50 pF 500  3.0 V to 3.6 V 2.7 V  2.5 ns 50 pF 500  74LVC139 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 8 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) 74LVC139 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 9 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o o 0 Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig 10. Package outline SOT338-1 (SSOP16) 74LVC139 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 10 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 E D A X c y HE v M A Z 9 16 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 8 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 11. Package outline SOT403-1 (TSSOP16) 74LVC139 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 11 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 7 y y1 C v M C A B w M C b L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A(1) max. A1 b 1 0.05 0.00 0.30 0.18 c D (1) Dh E (1) Eh 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 12. Package outline SOT763-1 (DHVQFN16) 74LVC139 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 12 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer 13. Abbreviations Table 9. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC139 v.5 20111019 Product data sheet - 74LVC139 v.4 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Table 4, Table 5, Table 6, Table 7 and Table 8: values added for lower voltage ranges. 74LVC139 v.4 040315 Product specification - 74LVC139 v.3 74LVC139 v.3 030519 Product specification - 74LVC139 v.2 74LVC139 v.2 980428 Product specification - 74LVC139 v.1 74LVC139 v.1 - - - - 74LVC139 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 13 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 74LVC139 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 14 of 16 74LVC139 Nexperia Dual 2-to-4 line decoder/demultiplexer Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74LVC139 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 19 October 2011 © Nexperia B.V. 2017. All rights reserved 15 of 16 Nexperia 74LVC139 Dual 2-to-4 line decoder/demultiplexer 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 19 October 2011 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC139BQ,115 74LVC139D,112 74LVC139DB,112 74LVC139DB,118 74LVC139D,118 74LVC139PW,112 74LVC139PW,118 74LVC139PW/AUJ
74LVC139BQ,115 价格&库存
很抱歉,暂时无法提供与“74LVC139BQ,115”相匹配的价格&库存,您可以联系我们找货
74LVC139BQ,115
  • 3000+1.281863000+0.16658
  • 6000+1.244886000+0.16178
  • 9000+1.226369000+0.15937
  • 15000+1.2058615000+0.15671
  • 21000+1.1938721000+0.15515
  • 30000+1.1823430000+0.15365
库存:4224
74LVC139BQ,115
  • 1+4.643391+0.60342
  • 3+4.034713+0.52432
  • 10+3.2521110+0.42262
74LVC139BQ,115
  • 1+3.080021+0.40026
  • 10+2.1059210+0.27367
  • 25+1.8753025+0.24370
  • 100+1.61632100+0.21005
  • 250+1.49295250+0.19402
  • 500+1.41858500+0.18435
  • 1000+1.357421000+0.17640
库存:4224
