74LVC157A-Q100
Quad 2-input multiplexer
Rev. 2 — 2 May 2013
Product data sheet
1. General description
The 74LVC157A-Q100 is a quad 2-input multiplexer which select four bits of data from two
sources under the control of a common select input (S). The four outputs present the
selected data in the true (non-inverted) form. The enable input (E) is active LOW. When
pin E is HIGH, all of the outputs (1Y to 4Y) are forced LOW regardless of all the other
input conditions. Moving the data from two groups of registers to four common output
buses is a common use of the 74LVC157A-Q100. The state of the common data select
input (S) determines the particular register from which the data comes. It can also be used
as function generator.
It is useful for implementing highly irregular logic by generating any 4 of the 16 different
functions of two variables with one variable common.
The device is the logic implementation of a 4-pole, 2-position switch, where the position of
the switch is determined by the logic levels applied to pin S.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these
devices as translators in mixed 3.3 V and 5 V applications.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
5 V tolerant inputs for interfacing with 5 V logic
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low power consumption
Direct interface with TTL levels
Complies with JEDEC standard:
JESD8-7A (1.65 V to 1.95 V)
JESD8-5A (2.3 V to 2.7 V)
JESD8-C/JESD36 (2.7 V to 3.6 V)
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
74LVC157A-Q100
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC157AD-Q100
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74LVC157ADB-Q100
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
74LVC157APW-Q100 40 C to +125 C
TSSOP16
plastic thin shrink small outline package; 16 leads; SOT403-1
body width 4.4 mm
74LVC157ABQ-Q100 40 C to +125 C
DHVQFN16 plastic dual In-line compatible thermal enhanced
very thin quad flat package; no leads; 16
terminals; body 2.5 3.5 0.85 mm
SOT763-1
4. Functional diagram
1
15
2
2
3
5
6
11
10
14
EN
1
3
13
G1
MUX
4
1
5
1I0 1I1 2I0 2I1 3I0 3I1 4I0 4I1
1
S
11
15
E
10
1Y
2Y
3Y
4Y
4
7
9
12
7
6
9
14
12
13
mna482
mna481
Fig 1.
Fig 3.
Logic symbol
Fig 2.
2
1I0
3
1I1
5
2I0
6
2I1
11
3I0
10
3I1
14
4I0
13
4I1
SELECTOR
IEC logic symbol
MULTIPLEXER
OUTPUTS
1Y
4
2Y
7
3Y
9
4Y 12
S
E
1
15
mna483
Functional diagram
74LVC157A_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Rev. 2 — 2 May 2013
Nexperia B.V. 2017. All rights reserved
2 of 17
74LVC157A-Q100
Nexperia
S
E
1I1
1Y
1I0
2I1
2Y
2I0
3I1
3Y
3I0
4I1
4Y
4I0
Fig 4.
mna484
Logic diagram
5. Pinning information
5.1 Pinning
/9&$4
WHUPLQDO
LQGH[DUHD
9&&
/9&$4
9&&
*1'
*1'
*1'
6
6
DDD
7UDQVSDUHQWWRSYLHZ
DDD
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 5.
Pin configuration for SO16 and (T)SSOP16
74LVC157A_Q100
Product data sheet
Fig 6.
Pin configuration for DHVQFN16
Rev. 2 — 2 May 2013
3 of 17
74LVC157A-Q100
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
S
1
common data select input
1I0
2
data input from source 0
1I1
3
data input from source 1
1Y
4
multiplexer output
2I0
5
2I1
6
2Y
7
multiplexer output
GND
8
ground (0 V)
3Y
9
multiplexer output
3I1
10
3I0
11
4Y
12
multiplexer output
4I1
13
4I0
14
E
15
enable input (active LOW)
VCC
16
supply voltage
6. Functional description
Table 3.
Function table[1]
Input
Output
E
S
nI0
nI1
nY
H
X
X
X
L
L
L
L
X
L
L
L
H
X
H
L
H
X
L
L
L
H
X
H
H
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care
74LVC157A_Q100
Product data sheet
Rev. 2 — 2 May 2013
4 of 17
74LVC157A-Q100
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0
[1]
VO > VCC or VO < 0
[2]
Min
Max
Unit
0.5
+6.5
V
50
mA
0.5
+6.5
V
50
mA
0.5
VCC + 0.5
V
VO
output voltage
IO
output current
50
mA
ICC
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
500
mW
total power dissipation
Ptot
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
[1]
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
[2]
The output voltage ratings may be exceeded if the output current ratings are observed.
[3]
For SO16 packages: above 70 C the value of PD derates linearly with 8 mW/K.
For (T)SSOP16 packages: above 60 C the value of PD derates linearly with 5.5 mW/K.
For DHVQFN16 packages: above 60 C the value of PD derates linearly with 4.5 mW/K.
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
supply voltage
Conditions
functional
Min
Typ
Max
Unit
1.65
3.6
V
1.2
V
V
VI
input voltage
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+125
C
t/V
input transition rise and fall
rate
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 3.6 V
ns/V
74LVC157A_Q100
Product data sheet
Rev. 2 — 2 May 2013
5 of 17
74LVC157A-Q100
Nexperia
9. Static characteristics
Table 6.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
40 C to +85 C
Conditions
Min
HIGH-level
input voltage
VIH
LOW-level
input voltage
VIL
VOH
HIGH-level
output
voltage
LOW-level
output
voltage
VOL
Typ[1]
40 C to +125 C
Max
Min
Unit
Max
VCC = 1.2 V
1.08
1.08
V
VCC = 1.65 V to 1.95 V
0.65 VCC -
0.65 VCC -
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
2.0
2.0
V
0.12
V
VCC = 1.2 V
0.12
0.35 VCC -
0.35 VCC V
0.7
0.7
V
0.8
0.8
V
IO = 100 A;
VCC = 1.65 V to 3.6 V
VCC 0.2
VCC 0.3
V
IO = 4 mA; VCC = 1.65 V
1.2
1.05
V
VI = VIH or VIL
IO = 8 mA; VCC = 2.3 V
1.8
1.65
V
IO = 12 mA; VCC = 2.7 V
2.2
2.05
V
IO = 18 mA; VCC = 3.0 V
2.4
2.25
V
IO = 24 mA; VCC = 3.0 V
2.2
2.0
V
IO = 100 A;
0.2
0.3
V
0.45
0.65
V
VI = VIH or VIL
0.6
0.8
V
0.4
0.6
V
0.55
0.8
V
0.1
5
A
II
input leakage VCC = 3.6 V; VI = 5.5 V or GND current
ICC
supply
current
VCC = 3.6 V; VI = VCC or GND;
IO = 0 A
0.1
10
40
A
ICC
additional
supply
current
per input pin;
VCC = 2.7 V to 3.6 V;
VI = VCC 0.6 V; IO = 0 A
5
500
5000
A
CI
input
capacitance
VCC = 0 V to 3.6 V;
VI = GND to VCC
5.0
pF
[1]
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C.
74LVC157A_Q100
Product data sheet
Rev. 2 — 2 May 2013
6 of 17
74LVC157A-Q100
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 9.
Symbol Parameter
propagation delay
tpd
40 C to +85 C
Conditions
Min
Max
Min
Max
16
ns
1.0
4.8
10.2
1.0
11.8
ns
1.5
2.8
5.8
1.5
6.7
ns
VCC = 2.7 V
1.0
2.9
5.9
1.0
7.5
ns
VCC = 3.0 V to 3.6 V
1.0
2.5
5.2
1.0
6.5
ns
17
ns
nI0, nI1 to nY; see Figure 8
[2]
VCC = 1.2 V
E to nY; see Figure 7
[2]
VCC = 1.2 V
0.5
4.8
12.8
0.5
14.7
ns
1.5
2.8
7.2
1.5
8.3
ns
VCC = 2.7 V
1.0
2.9
7.8
1.0
10.0
ns
1.0
2.6
6.5
1.0
8.5
ns
16
ns
1.0
5.1
12.4
1.0
14.3
ns
1.5
3.0
7.0
1.5
8.1
ns
VCC = 2.7 V
1.0
3.1
7.3
1.0
9.5
ns
1.0
2.7
6.3
1.0
8.0
ns
1.0
1.5
ns
S to nY; see Figure 8
[2]
VCC = 1.2 V
tsk(o)
CPD
[1]
output skew time
power dissipation
capacitance
40 C to +125 C Unit
Typ[1]
[3]
per input; VI = GND to VCC
[4]
9.4
pF
12.8
pF
15.9
pF
Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
[4]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in V
N = number of inputs switching
(CL VCC2 fo) = sum of outputs
74LVC157A_Q100
Product data sheet
Rev. 2 — 2 May 2013
7 of 17
74LVC157A-Q100
Nexperia
11. Waveforms
VCC
VM
E input
GND
t PHL
t PLH
VOH
VM
nY output
mna485
VOL
VM = 1.5 V at VCC 2.7 V; VM = 0.5 VCC at VCC < 2.7 V.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 7.
Enable input (E) to output (nY) propagation delays
VI
nI0, nI1, S
VM
input
GND
t PHL
t PLH
VOH
VM
nY output
mna486
VOL
Fig 8.
Data inputs (nI0, nI1) and common data select input (S) to output (nY) propagation delays
74LVC157A_Q100
Product data sheet
Rev. 2 — 2 May 2013
8 of 17
74LVC157A-Q100
Nexperia
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
VM
VM
10 %
0V
tW
VCC
PULSE
GENERATOR
VI
VO
DUT
RT
CL
RL
001aaf615
Test data is given in Table 8. Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig 9.
Table 8.
Test circuit for measuring switching times
Test data
Supply voltage
Input
Load
VI
tr, tf
CL
RL
1.2 V
VCC
2 ns
30 pF
1 k
1.65 V to 1.95 V
VCC
2 ns
30 pF
1 k
2.3 V to 2.7 V
VCC
2 ns
30 pF
500
2.7 V
2.7 V
2.5 ns
50 pF
500
3.0 V to 3.6 V
2.7 V
2.5 ns
50 pF
500
74LVC157A_Q100
Product data sheet
Rev. 2 — 2 May 2013
9 of 17
74LVC157A-Q100
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
detail X
w M
bp
2.5
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.16
0.15
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 10. Package outline SOT109-1 (SO16)
74LVC157A_Q100
Product data sheet
Rev. 2 — 2 May 2013
10 of 17
74LVC157A-Q100
Nexperia
SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm
D
SOT338-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
8
1
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
6.4
6.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
1.00
0.55
8o
o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT338-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig 11. Package outline SOT338-1 (SSOP16)
74LVC157A_Q100
Product data sheet
Rev. 2 — 2 May 2013
11 of 17
74LVC157A-Q100
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
E
D
A
X
c
y
HE
v M A
Z
9
16
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
8
e
detail X
w M
bp
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 12. Package outline SOT403-1 (TSSOP16)
74LVC157A_Q100
Product data sheet
Rev. 2 — 2 May 2013
12 of 17
74LVC157A-Q100
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
7
y
y1 C
v M C A B
w M C
b
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
mm
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
c
D (1)
Dh
E (1)
Eh
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 13. Package outline SOT763-1 (DHVQFN16)
74LVC157A_Q100
Product data sheet
Rev. 2 — 2 May 2013
13 of 17
74LVC157A-Q100
Nexperia
13. Abbreviations
Table 9.
Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
MIL
Military
14. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC157A_Q100 v.2
20130502
Product data sheet
74LVC157A_Q100 v.1
Modifications:
74LVC157A_Q100 v.1
74LVC157A_Q100
Product data sheet
74LVC157ADB-Q100 added.
20120807
Product data sheet
Rev. 2 — 2 May 2013
14 of 17
74LVC157A-Q100
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74LVC157A_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Rev. 2 — 2 May 2013
15 of 17
74LVC157A-Q100
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LVC157A_Q100
Product data sheet
Rev. 2 — 2 May 2013
16 of 17
Nexperia
74LVC157A-Q100
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Contact information. . . . . . . . . . . . . . . . . . . . . 16
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Date of release: 02 May 2013
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC157ADB-Q100J 74LVC157AD-Q100J 74LVC157APW-Q100J 74LVC157ABQ-Q100X
