74LVC1G18GV,125
74LVC1G18GV,125
    NEXPERIA(安世)
    TSOP6_2.9X1.5MM
    1/2非反相多路分解器,带3态取消选择输出 TSOP6_2.9X1.5MM 1.65~5.5V
74LVC1G18GV,125 数据手册
74LVC1G18 1-of-2 non-inverting demultiplexer with 3-state deselected output Rev. 3 — 2 December 2016 Product data sheet 1. General description The 74LVC1G18 is a 1-of-2 non-inverting demultiplexer with a 3-state output. The device buffers the data on input pin A and passes it either to output 1Y or 2Y, depending on whether the state of the select input (pin S) is LOW or HIGH. Input can be driven from either 3.3 or 5 V devices. These features allow the use of these devices in a mixed 3.3 and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits            Wide supply voltage range from 1.65 to 5.5 V 5 V tolerant input/output for interfacing with 5 V logic High noise immunity Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8B/JESD36 (2.7 V to 3.6 V) ESD protection:  HBM EIA/JESD22-A114E exceeds 2000 V  MM EIA/JESD22-A115-A exceeds 200 V. 24 mA output drive (VCC = 3.0 V) CMOS low power consumption Latch-up performance exceeds 250 mA Direct interface with TTL levels SOT363 and SOT457 package Specified from 40 to +85 C and 40 to +125 C. 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G18GW 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 74LVC1G18GV 40 C to +125 C SC-74 plastic surface-mounted package (TSOP6); 5 leads SOT457 74LVC1G18 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G18GW VW 74LVC1G18GV V18 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram <  6  $  <  PQE Fig 1. Logic symbol 6. Pinning information 6.1 Pinning /9&* 6   < *1'   9&& $   < DDJ Fig 2. Pin configuration 6.2 Pin description Table 3. Pin description Symbol Pin Description S 1 data select GND 2 ground (0 V) A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 74LVC1G18 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 14 74LVC1G18 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output 7. Functional description Table 4. Function table[1] Input Output S A 1Y 2Y L L L Z L H H Z H L Z L H H Z H [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions Max 0.5 +6.5 50 - 0.5 +6.5 V mA VI < 0 V [1] Unit V mA - 50 Active mode [1][2] 0.5 VCC + 0.5 V Power-down mode [1][2] 0.5 +6.5 V - 50 mA 100 mA VO > VCC or VO < 0 V output voltage VO Min IO output current ICC supply current - IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 300 mW Tamb = 40 C to +125 C total power dissipation Ptot [1] VO = 0 V to VCC [3] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For SC-74 and SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature t/V input transition rise and fall rate 74LVC1G18 Product data sheet Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC VO VCC = 0 V; Power-down mode 0 - 5.5 VO 40 - +125 C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 14 74LVC1G18 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output 10. Static characteristics Table 7. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Unit Tamb = 40 C to +85 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 1.2 - - V IO = 8 mA; VCC = 2.3 V 1.9 - - V IO = 12 mA; VCC = 2.7 V 2.2 - - V IO = 24 mA; VCC = 3.0 V 2.3 - - V IO = 32 mA; VCC = 4.5 V 3.8 - - V IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V VOL LOW-level output voltage 0.35  VCC V VCC = 1.65 V to 1.95 V VI = VIH or VIL II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND - 0.1 1 A IOZ OFF-state output current VCC = 3.6 V; VI = VIH or VIL; VO = 5.5 V or GND - 0.1 2 A IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - 0.1 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - 0.1 4 A ICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A - 5 500 A CI input capacitance VCC = 3.3 V; VI = GND to VCC - 2.5 - pF 74LVC1G18 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 14 74LVC1G18 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output Table 7. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max 0.65  VCC - - V Unit Tamb = 40 C to +125 C HIGH-level input voltage VIH LOW-level input voltage VIL VOH HIGH-level output voltage VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V LOW-level output voltage VOL 0.35  VCC V VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 0.95 - - V IO = 8 mA; VCC = 2.3 V 1.7 - - V IO = 12 mA; VCC = 2.7 V 1.9 - - V IO = 24 mA; VCC = 3.0 V 2.0 - - V IO = 32 mA; VCC = 4.5 V 3.4 - - V - - 0.1 V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V - - 0.80 V II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND IO = 32 mA; VCC = 4.5 V - - 1 A IOZ OFF-state output current VCC = 3.6 V; VI = VIH or VIL; VO = 5.5 V or GND - - 2 A IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - - 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - - 4 A ICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A - - 500 A [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 C. 74LVC1G18 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 14 74LVC1G18 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 5. Symbol Parameter 40 C to +85 C Conditions enable time ten Max Min Max VCC = 1.65 V to 1.95 V 1.0 5.1 10.0 1.0 12.5 ns VCC = 2.3 V to 2.7 V 1.0 3.2 5.5 0.5 6.9 ns VCC = 2.7 V 1.0 3.2 5.4 0.5 6.8 ns VCC = 3.0 V to 3.6 V 1.0 3.0 5.0 0.5 6.3 ns VCC = 4.5 V to 5.5 V 1.0 2.3 3.8 0.5 4.8 ns VCC = 1.65 V to 1.95 V 1.0 5.8 11.0 1.0 13.8 ns S to nY; see Figure 3 [2] [3] VCC = 2.3 V to 2.7 V 1.0 3.6 6.2 0.5 7.8 ns VCC = 2.7 V 1.0 3.6 6.0 0.5 7.5 ns VCC = 3.0 V to 3.6 V 1.0 3.1 5.2 0.5 6.5 ns 1.0 2.4 3.6 0.5 4.5 ns VCC = 1.65 V to 1.95 V 1.0 4.8 9.0 1.0 11.3 ns VCC = 2.3 V to 2.7 V 1.0 2.7 5.3 0.5 6.6 ns VCC = 2.7 V 1.0 3.5 5.2 0.5 6.5 ns VCC = 3.0 V to 3.6 V 1.0 3.3 4.9 0.5 6.1 ns VCC = 4.5 V to 5.5 V 0.5 2.2 3.3 0.5 4.1 ns - 28.8 - - - pF VCC = 4.5 V to 5.5 V disable time tdis power dissipation capacitance CPD S to nY; see Figure 3 VI = GND to VCC; VCC = 3.3 V [4] [5] [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL [3] ten is the same as tPZH and tPZL [4] tdis is the same as tPLZ and tPHZ [5] Unit Min propagation delay A to nY; see Figure 3 tpd 40 C to +125 C Typ[1] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74LVC1G18 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 2 December 2016 © Nexperia B.V. 2017. All rights reserved 6 of 14 74LVC1G18 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output 12. AC waveforms 9, 90 $LQSXW  90 *1' W3+/ W3/+ 92+ Q
74LVC1G18GV,125 价格&库存
很抱歉,暂时无法提供与“74LVC1G18GV,125”相匹配的价格&库存,您可以联系我们找货
74LVC1G18GV,125
  • 1+1.06834
  • 10+0.95345
  • 25+0.80083
  • 100+0.72368
  • 250+0.66750
  • 500+0.64067
  • 1000+0.57190
  • 3000+0.53417
库存:3090
74LVC1G18GV,125
  • 1+1.725731+0.21660
  • 10+1.1773110+0.14777
  • 25+1.0362825+0.13007
  • 100+0.88309100+0.11084
  • 250+0.81006250+0.10168
  • 500+0.76550500+0.09608
  • 1000+0.729011000+0.09150
库存:1044
74LVC1G18GV,125
  • 3000+0.683883000+0.08584
  • 6000+0.661796000+0.08307
  • 9000+0.650749000+0.08168
  • 15000+0.6384815000+0.08014
  • 21000+0.6313121000+0.07924
  • 30000+0.6244230000+0.07838
  • 75000+0.6095975000+0.07651
  • 150000+0.60064150000+0.07539
库存:1044
