74LVC1G18GW-Q100H
74LVC1G18GW-Q100H
    NEXPERIA(安世)
    SOT-363
    1/2非反相多路分解器,带3态取消选择输出 SOT363-6 1.65~5.5V
74LVC1G18GW-Q100H 数据手册
74LVC1G18-Q100 1-of-2 non-inverting demultiplexer with 3-state deselected output Rev. 2 — 9 December 2016 Product data sheet 1. General description The 74LVC1G18-Q100 is a 1-of-2 non-inverting demultiplexer with a 3-state output. The device buffers the data on input pin A. It is passed to either output 1Y or 2Y, depending on whether the state of the select input (pin S) is LOW or HIGH. Input can be driven from either 3.3 V or 5 V devices. These features allow the use of these devices in a mixed 3.3 V and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide supply voltage range from 1.65 V to 5.5 V  5 V tolerant input/output for interfacing with 5 V logic  High noise immunity  Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8B/JESD36 (2.7 V to 3.6 V)  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  24 mA output drive (VCC = 3.0 V)  CMOS low power consumption  Latch-up performance exceeds 250 mA  Direct interface with TTL levels  SOT363 and SOT457 package 74LVC1G18-Q100 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G18GW-Q100 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 40 C to +125 C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 74LVC1G18GV-Q100 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G18GW-Q100 VW 74LVC1G18GV-Q100 V18 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram <  6  $  <  PQE Fig 1. Logic symbol 6. Pinning information 6.1 Pinning /9&*4 6   < *1'   9&& $   < DDD Fig 2. Pin configuration 74LVC1G18_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 14 74LVC1G18-Q100 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output 6.2 Pin description Table 3. Pin description Symbol Pin Description S 1 data select GND 2 ground (0 V) A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 7. Functional description Table 4. Function table[1] Input Output S A 1Y 2Y L L L Z L H H Z H L Z L H H Z H [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current output voltage VO Conditions Min Max Unit 0.5 +6.5 V 50 - 0.5 +6.5 V - 50 mA Active mode [1][2] 0.5 VCC + 0.5 V Power-down mode [1][2] 0.5 +6.5 V VI < 0 V [1] VO > VCC or VO < 0 V mA IO output current - 50 mA ICC supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 300 mW total power dissipation Ptot VO = 0 V to VCC Tamb = 40 C to +125 C [3] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For SC-74 and SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. 74LVC1G18_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 14 74LVC1G18-Q100 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature t/V input transition rise and fall rate Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC VO VCC = 0 V; Power-down mode 0 - 5.5 VO 40 - +125 C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V Min Typ[1] Max 0.65  VCC - - V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Unit Tamb = 40 C to +85 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V VOL LOW-level output voltage VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 1.2 - - V IO = 8 mA; VCC = 2.3 V 1.9 - - V IO = 12 mA; VCC = 2.7 V 2.2 - - V IO = 24 mA; VCC = 3.0 V 2.3 - - V IO = 32 mA; VCC = 4.5 V 3.8 - - V - - 0.1 V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V 74LVC1G18_Q100 Product data sheet 0.35  VCC V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 14 74LVC1G18-Q100 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output Table 7. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Min Typ[1] Max VCC = 0 V to 5.5 V; VI = 5.5 V or GND - 0.1 1 A OFF-state output current VCC = 3.6 V; VI = VIH or VIL; VO = 5.5 V or GND - 0.1 2 A IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - 0.1 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - 0.1 4 A ICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A - 5 500 A CI input capacitance VCC = 3.3 V; VI = GND to VCC - 2.5 - pF Symbol Parameter Conditions II input leakage current IOZ Unit Tamb = 40 C to +125 C HIGH-level input voltage VIH LOW-level input voltage VIL VOH HIGH-level output voltage 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 0.95 - - V IO = 8 mA; VCC = 2.3 V 1.7 - - V IO = 12 mA; VCC = 2.7 V 1.9 - - V IO = 24 mA; VCC = 3.0 V 2.0 - - V IO = 32 mA; VCC = 4.5 V 3.4 - - V IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V LOW-level output voltage VOL 0.35  VCC V VCC = 1.65 V to 1.95 V VI = VIH or VIL II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND - - 1 A IOZ OFF-state output current VCC = 3.6 V; VI = VIH or VIL; VO = 5.5 V or GND - - 2 A IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - - 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - - 4 A ICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A - - 500 A [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 C. 74LVC1G18_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 14 74LVC1G18-Q100 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit, see Figure 5. Symbol Parameter 40 C to +85 C Conditions enable time ten Max Min Max VCC = 1.65 V to 1.95 V 1.0 5.1 10.0 1.0 12.5 ns VCC = 2.3 V to 2.7 V 1.0 3.2 5.5 0.5 6.9 ns VCC = 2.7 V 1.0 3.2 5.4 0.5 6.8 ns VCC = 3.0 V to 3.6 V 1.0 3.0 5.0 0.5 6.3 ns VCC = 4.5 V to 5.5 V 1.0 2.3 3.8 0.5 4.8 ns VCC = 1.65 V to 1.95 V 1.0 5.8 11.0 1.0 13.8 ns S to nY; see Figure 3 [2] [3] VCC = 2.3 V to 2.7 V 1.0 3.6 6.2 0.5 7.8 ns VCC = 2.7 V 1.0 3.6 6.0 0.5 7.5 ns VCC = 3.0 V to 3.6 V 1.0 3.1 5.2 0.5 6.5 ns 1.0 2.4 3.6 0.5 4.5 ns VCC = 1.65 V to 1.95 V 1.0 4.8 9.0 1.0 11.3 ns VCC = 2.3 V to 2.7 V 1.0 2.7 5.3 0.5 6.6 ns VCC = 2.7 V 1.0 3.5 5.2 0.5 6.5 ns VCC = 3.0 V to 3.6 V 1.0 3.3 4.9 0.5 6.1 ns VCC = 4.5 V to 5.5 V 0.5 2.2 3.3 0.5 4.1 ns - 28.8 - - - pF VCC = 4.5 V to 5.5 V disable time tdis power dissipation capacitance CPD S to nY; see Figure 3 VI = GND to VCC; VCC = 3.3 V [4] [5] [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL [3] ten is the same as tPZH and tPZL [4] tdis is the same as tPLZ and tPHZ [5] Unit Min propagation delay A to nY; see Figure 3 tpd 40 C to +125 C Typ[1] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74LVC1G18_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 6 of 14 74LVC1G18-Q100 Nexperia 1-of-2 non-inverting demultiplexer with 3-state deselected output 12. AC waveforms 9, 90 $LQSXW  90 *1' W3+/ W3/+ 92+ Q
74LVC1G18GW-Q100H 价格&库存
很抱歉,暂时无法提供与“74LVC1G18GW-Q100H”相匹配的价格&库存,您可以联系我们找货
74LVC1G18GW-Q100H
    74LVC1G18GW-Q100H
      • 5+1.63610
      • 50+1.29276
      • 150+1.14556
      • 500+0.96196
      库存:492
      74LVC1G18GW-Q100H
        • 5+1.83300
        • 50+1.44840
        • 150+1.28350
        • 500+1.07780
        库存:500
        74LVC1G18GW-Q100H
