74LVC1G19GW-Q100H
74LVC1G19GW-Q100H
    NEXPERIA(安世)
    SOT-363
    1/2解码器/解复用器 SOT363-6 1.65~5.5V
74LVC1G19GW-Q100H 数据手册
74LVC1G19-Q100 1-of-2 decoder/demultiplexer Rev. 2 — 9 December 2016 Product data sheet 1. General description The 74LVC1G19-Q100 is a 1-of-2 decoder/demultiplexer with a common output enable. This device buffers the data on input A and passes it to the outputs 1Y (true) and 2Y (complement) when the enable (E) input signal is LOW. Inputs can be driven from either 3.3 V or 5 V devices. These features allow the use of these devices in a mixed 3.3 V and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide supply voltage range from 1.65 V to 5.5 V  5 V tolerant inputs for interfacing with 5 V logic  High noise immunity  Complies with JEDEC standard:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8B/JESD36 (2.7 V to 3.6 V)  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  24 mA output drive (VCC = 3.0 V)  CMOS low power consumption  Latch-up performance exceeds 250 mA  Direct interface with TTL levels  Inputs accept voltages up to 5 V 74LVC1G19-Q100 Nexperia 1-of-2 decoder/demultiplexer 3. Ordering information Table 1. Ordering information Type number Package 74LVC1G19GW-Q100 Temperature range Name Description Version 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G19GW-Q100 VY [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  $  ( <  <  PQE Fig 1. Logic symbol 6. Pinning information 6.1 Pinning /9&*4 $   < *1'   9&& (   < DDD Fig 2. Pin configuration SOT363 74LVC1G19_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 12 74LVC1G19-Q100 Nexperia 1-of-2 decoder/demultiplexer 6.2 Pin description Table 3. Pin description Symbol Pin Description A 1 data input GND 2 ground (0 V) E 3 enable input (active LOW) 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 7. Functional description Table 4. Function table[1] Input Output E A 1Y 2Y L L L H L H H L H X H H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions Min Max Unit 0.5 +6.5 V 50 - [1] 0.5 +6.5 VI < 0 V mA VI input voltage IOK output clamping current VO > VCC or VO < 0 V - 50 VO output voltage Active mode [1][2] 0.5 VCC + 0.5 V Power-down mode [1][2] 0.5 +6.5 V - 50 mA VO = 0 V to VCC V mA IO output current ICC supply current - 100 mA IGND ground current 100 - mA Ptot total power dissipation - 250 mW Tstg storage temperature 65 +150 C Tamb = 40 C to +125 C [3] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] For SC-88 package: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. 74LVC1G19_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 12 74LVC1G19-Q100 Nexperia 1-of-2 decoder/demultiplexer 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Conditions Tamb ambient temperature t/V input transition rise and fall rate Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V Active mode 0 - VCC V Power-down mode; VCC = 0 V 0 - 5.5 V 40 - +125 C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max 0.65  VCC - - V Unit Tamb = 40 C to +85 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V VOL LOW-level output voltage 74LVC1G19_Q100 Product data sheet 0.35  VCC V VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 1.2 1.54 - V IO = 8 mA; VCC = 2.3 V 1.9 2.15 - V IO = 12 mA; VCC = 2.7 V 2.2 2.50 - V IO = 24 mA; VCC = 3.0 V 2.3 2.62 - V IO = 32 mA; VCC = 4.5 V 3.8 4.11 - V IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.10 V IO = 4 mA; VCC = 1.65 V - 0.07 0.45 V IO = 8 mA; VCC = 2.3 V - 0.12 0.30 V IO = 12 mA; VCC = 2.7 V - 0.17 0.40 V IO = 24 mA; VCC = 3.0 V - 0.33 0.55 V IO = 32 mA; VCC = 4.5 V - 0.39 0.55 V VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 12 74LVC1G19-Q100 Nexperia 1-of-2 decoder/demultiplexer Table 7. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Min Typ[1] Max VI = 5.5 V or GND; VCC = 0 V to 5.5 V - 0.1 1 A power-off leakage current VCC = 0 V; VI or VO = 5.5 V - 0.1 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - 0.1 4 A ICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A - 5 500 A CI input capacitance VCC = 3.3 V; VI = GND to VCC - 2.5 - pF 0.65  VCC - - V 1.7 - - V Symbol Parameter Conditions II input leakage current IOFF Unit Tamb = 40 C to +125 C HIGH-level input voltage VIH VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V LOW-level input voltage VIL VOH HIGH-level output voltage VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7  VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - VCC = 2.7 V to 3.6 V - - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3  VCC V VCC  0.1 - - V IO = 4 mA; VCC = 1.65 V 0.95 - - V IO = 8 mA; VCC = 2.3 V 1.7 - - V IO = 12 mA; VCC = 2.7 V 1.9 - - V IO = 24 mA; VCC = 3.0 V 2.0 - - V LOW-level output voltage IO = 32 mA; VCC = 4.5 V 3.4 - - V IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.10 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V 0.7 V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V VOL 0.35  VCC V VI = VIH or VIL II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 1 A IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - - 2 A ICC supply current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V; IO = 0 A - - 4 A ICC additional supply current per pin; VCC = 2.3 V to 5.5 V; VI = VCC  0.6 V; IO = 0 A - - 500 A [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 C. 74LVC1G19_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 9 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 12 74LVC1G19-Q100 Nexperia 1-of-2 decoder/demultiplexer 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 4. Symbol Parameter 40 C to +85 C Conditions power dissipation capacitance CPD Unit Min Max Min Max VCC = 1.65 V to 1.95 V 1.0 4.0 10.5 1.0 13.1 ns VCC = 2.3 V to 2.7 V 0.5 2.5 6.2 0.5 7.7 ns VCC = 2.7 V 1.0 2.8 6.5 1.0 8.1 ns VCC = 3.0 V to 3.6 V 0.5 2.5 5.2 0.5 6.0 ns VCC = 4.5 V to 5.5 V 0.5 1.8 3.9 0.5 5.0 ns - 18.9 - - - pF [2] propagation delay A, E to nY; see Figure 3 tpd 40 C to +125 C Typ[1] [3] VI = GND to VCC; VCC = 3.3 V [1] Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 12. AC waveforms 9, 90 $(LQSXW 90 *1' W 3+/ W 3/+ 92+ Q
74LVC1G19GW-Q100H
物料型号:74LVC1G19-Q100
器件简介: 74LVC1G19-Q100是一款1-of-2译码器/解多路复用器,具有公共输出使能。当使能(E)输入信号为低电平时,该设备将输入A上的数据缓冲,并将其传递到1Y(真)和2Y(互补)输出。输入可以由3.3V或5V设备驱动,这些特性允许在3.3V和5V混合环境中使用这些设备。该产品已针对部分断电应用进行了完全规格化,使用IOFF电路在断电时禁用输出,以防止通过设备产生有害的反向电流。该产品已通过汽车电子委员会(AEC)标准Q100(1级)认证,适用于汽车应用。
引脚分配: - A1:数据输入 - GND2:地(0V) - E3:使能输入(低电平有效) - 2Y4:数据输出 - Vcc5:供电电压 - 1Y6:数据输出
参数特性: - 汽车产品认证:符合AEC-Q100(1级) - 工作温度范围:-40°C至+85°C和-40°C至+125°C - 宽电源电压范围:1.65V至5.5V - 5V容限输入,可与5V逻辑接口 - 高抗干扰性 - 符合JEDEC标准 - ESD保护:超过2000V HBM
功能详解: 功能表展示了输入E和A与输出1Y和2Y的逻辑关系。当E为低电平时,根据A的高低电平,1Y和2Y将分别输出高或低电平。
应用信息: 该产品适用于汽车应用,并且已通过相关的汽车电子标准认证。
封装信息: - 封装类型:SC-88(塑料表面贴装封装;6个引脚) - 封装版本:SOT363
74LVC1G19GW-Q100H 价格&库存
很抱歉,暂时无法提供与“74LVC1G19GW-Q100H”相匹配的价格&库存,您可以联系我们找货
