CBT3245A-Q100
Octal bus switch
Rev. 2 — 30 April 2019
Product data sheet
1. General description
The CBT3245A-Q100 provides eight bits of high-speed TTL-compatible bus switching. The low
ON resistance of the switch allows connections to be made with minimal propagation delay.
The CBT3245A-Q100 is organized as one 8-bit bus switches with one output enable (OE) input.
When OE is LOW, the switch is on and port A is connected to the B port. When OE is HIGH, each
switch is disabled.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 3) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 3)
• Specified from -40 °C to +85 °C
5 Ω switch connection between two ports
TTL-compatible control input levels
Multiple package options
Latch-up protection exceeds 500 mA per JESD78
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115B exceeds 150 V (C = 200 pF, R = 0 Ω
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
-40 °C to +85 °C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
CBT3245APW-Q100 -40 °C to +85 °C
TSSOP20
plastic thin shrink small outline package; 20 leads; SOT360-1
body width 4.4 mm
CBT3245ABQ-Q100 -40 °C to +85 °C
DHVQFN20
plastic dual-in-line compatible thermal enhanced
SOT764-1
very thin quad flat package; no leads; 20 terminals;
body 2.5 x 4.5 x 0.85 mm
CBT3245AD-Q100
CBT3245A-Q100
Nexperia
Octal bus switch
4. Functional diagram
A1
A8
OE
Fig. 1.
2
18
9
11
B1
B8
19
001aao117
Logic diagram
5. Pinning information
5.1. Pinning
1
n.c.
terminal 1
index area
1
20 VCC
A1
2
19 OE
A2
3
18 B1
A3
4
17 B2
A4
5
16 B3
A5
6
15 B4
A6
7
14 B5
A7
8
13 B6
A8
9
12 B7
GND 10
19 OE
A2
3
18 B1
A3
4
17 B2
A4
5
16 B3
A5
6
15 B4
A6
7
A7
8
A8
9
14 B5
GND(1)
13 B6
12 B7
aaa-001833
Transparent top view
(1) This is not a supply pin. The substrate is
attached to this pad using conductive die attach
material. There is no electrical or mechanical
requirement to solder this pad. However, if it is
soldered, the solder land should remain floating or
be connected to GND.
11 B8
aaa-001831
Fig. 2.
2
B8 11
n.c.
A1
GND 10
CBT3245A
20 VCC
CBT3245A
Pin configuration for SOT163-1 (SO20) and
SOT360-1 (TSSOP20)
Fig. 3.
Pin configuration for SOT764-1 (DHVQFN20)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
n.c.
1
not connected
A1 to A8
2, 3, 4, 5, 6, 7, 8, 9
data input/output (A port)
GND
10
ground (0 V)
B1 to B8
18, 17, 16, 15, 14, 13, 12, 11
data input/output (B port)
OE
19
output enable input (active LOW)
VCC
positive supply voltage
CBT3245A_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 12
CBT3245A-Q100
Nexperia
Octal bus switch
6. Functional description
Table 3. Functional description
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
Input
Input/output
OE
An, Bn
L
An = Bn
H
Z
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Tamb = -40 °C to +85 °C, unless otherwise specified.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
IOK
output clamping current
VO
output voltage
IO
output current
IIK
input clamping current
Tstg
storage temperature
[1]
Conditions
Min
Max
Unit
-0.5
+7.0
V
[1]
-0.5
+7.0
V
-50
[1]
-0.5
+7.0
V
VO < 0 V
±128
mA
VI < 0 V
-50
mA
-65
+150
°C
VO < 0 V
mA
The input and output negative-voltage ratings may be exceeded if the input and output clamp-current ratings are observed.
8. Recommended operating conditions
Table 5. Recommended operating conditions
All unused control inputs of the device must be held at VCC or GND to ensure proper device operation.
Symbol
Parameter
VCC
VIH
Min
Typ
Max
Unit
supply voltage
4.0
5.5
V
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
Tamb
ambient temperature
-40
+85
°C
CBT3245A_Q100
Product data sheet
Conditions
operating in free air
3 / 12
CBT3245A-Q100
Nexperia
Octal bus switch
9. Static characteristics
Table 6. Static characteristics
Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Unit
Min
Typ[1]
Max
-1.2
V
VIK
input clamping voltage
VCC = 4.5 V; II = -18 mA
II
input leakage current
VCC = 5.5 V; VI = GND or 5.5 V
±5
μA
ICC
supply current
VCC = 5.5 V; IO = 0 mA;
VI = VCC or GND
1
3
μA
ΔICC
additional supply current
per input pin; VCC = 5.5 V; one input at [2]
3.4 V, other inputs at VCC or GND
3.5
mA
CI
input capacitance
control pins; VI = 3 V or 0 V
3.2
pF
Cio(off)
off-state input/output
capacitance
port off; VI = 3 V or 0 V; OE = VCC
6.6
pF
RON
ON resistance
VCC = 4.5 V; VI = 0 V; II = 64 mA
[3]
5
7
Ω
VCC = 4.5 V; VI = 0 V; II = 30 mA
[3]
5
7
Ω
VCC = 4.5 V; VI = 2.4 V; II = -15 mA
[3]
10
15
Ω
[1]
[2]
[3]
All typical values are measured at VCC = 5 V and Tamb = 25 °C.
This is the increase in supply current for each input that is at the specified TTL voltage level rather than VCC or GND.
Measured by the voltage drop between the An and the Bn terminals at the indicated current through the switch. ON resistance is
determined by the lowest voltage of the two (An or Bn) terminals.
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 6.
Symbol
tpd
Parameter
propagation delay
Conditions
An, Bn to Bn, An; see Fig. 4
enable time
OE to An or Bn; see Fig. 5
tdis
disable time
0.25
ns
1.0
5.9
ns
1.0
6.0
ns
[2]
VCC = 5.0 V ± 0.5 V
[2]
[2]
VCC = 5.0 V ± 0.5 V
[1]
Max
[1][2]
VCC = 5.0 V ± 0.5 V
ten
Unit
Min
The propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified load capacitance,
when driven by an ideal voltage source (zero output impedance).
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
CBT3245A_Q100
Product data sheet
4 / 12
CBT3245A-Q100
Nexperia
Octal bus switch
10.1. Waveforms and test circuit
VI
VM
An, Bn input
GND
tPHL
tPLH
VOH
VM
Bn, An output
VOL
001aam475
Measurement points are given in Table 8.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 4.
The data input (An, Bn) to output (Bn, An) propagation delay times
VI
VM
OE input
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
3.5 V
VM
VX
VOL
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
001aam476
Fig. 5.
Enable and disable times
Table 8. Measurement points
Supply voltage
Input
VCC
VI
VCC = 5.0 V ± 0.5 V GND to 3.0 V
CBT3245A_Q100
Product data sheet
Output
VM
VM
VX
VY
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
5 / 12
CBT3245A-Q100
Nexperia
Octal bus switch
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz; Zo = 50 Ω.
The outputs are measured one at a time with one transition per measurement.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 6.
Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VI
CBT3245A_Q100
Product data sheet
Load
VEXT
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
≤ 2.5 ns
50 pF
500 Ω
open
7.0 V
open
6 / 12
CBT3245A-Q100
Nexperia
Octal bus switch
11. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
y
HE
v M A
Z
Q
A2
A
(A 3 )
A1
pin 1 index
θ
Lp
L
1
10
e
detail X
w M
bp
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
inches
0.1
0.012 0.096
0.004 0.089
0.043
0.039
0.01
0.01
Z
(1)
0.9
0.4
0.035
0.004
0.016
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig. 7.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT163-1 (SO20)
CBT3245A_Q100
Product data sheet
7 / 12
CBT3245A-Q100
Nexperia
Octal bus switch
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
D
SOT360-1
E
A
X
c
HE
y
v M A
Z
11
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
10
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
Fig. 8.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Package outline SOT360-1 (TSSOP20)
CBT3245A_Q100
Product data sheet
8 / 12
CBT3245A-Q100
Nexperia
Octal bus switch
DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
20 terminals; body 2.5 x 4.5 x 0.85 mm
B
D
SOT764-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
e1
C
e
b
2
9
v
w
C A B
C
y1 C
y
L
1
10
Eh
e
19
12
X
Dh
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A(1)
A1
b
max 1.00 0.05 0.30
nom 0.90 0.02 0.25
min 0.80 0.00 0.18
c
D(1)
Dh
E(1)
Eh
e
e1
L
v
0.2
4.6
4.5
4.4
3.15
3.00
2.85
2.6
2.5
2.4
1.15
1.00
0.85
0.5
3.5
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
References
Outline
version
IEC
JEDEC
JEITA
SOT764-1
MO-241
Fig. 9.
sot764-1_po
European
projection
Issue date
03-01-27
14-12-12
Package outline SOT764-1 (DHVQFN20)
CBT3245A_Q100
Product data sheet
9 / 12
CBT3245A-Q100
Nexperia
Octal bus switch
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CDM
Charged Device Model
ESD
ElectroStatic Discharge
DUT
Device Under Test
HBM
Human Body Model
MIL
Military
MM
Machine Model
PRR
Pulse Rate Repetition
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
CBT3245A_Q100 v.2
20190430
Product data sheet
CBT3245A_Q100 v.1
Modifications:
CBT3245A_Q100 v.1
CBT3245A_Q100
Product data sheet
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Package outline drawing SOT764-1 updated.
20130320
Product data sheet
10 / 12
CBT3245A-Q100
Nexperia
Octal bus switch
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
14. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
CBT3245A_Q100
Product data sheet
11 / 12
CBT3245A-Q100
Nexperia
Octal bus switch
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................2
5.1. Pinning.........................................................................2
5.2. Pin description............................................................. 2
6. Functional description................................................. 3
7. Limiting values............................................................. 3
8. Recommended operating conditions..........................3
9. Static characteristics....................................................4
10. Dynamic characteristics............................................ 4
10.1. Waveforms and test circuit........................................ 5
11. Package outline.......................................................... 7
12. Abbreviations............................................................ 10
13. Revision history........................................................10
14. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 30 April 2019
CBT3245A_Q100
Product data sheet
12 / 12
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
CBT3245AD-Q100J CBT3245ABQ-Q100X CBT3245APW-Q100J
