CBT3245AD-Q100J
CBT3245AD-Q100J
    NEXPERIA(安世)
    SOIC20_300MIL
    八进制总线开关 SOIC20_300MIL 4~5.5V
CBT3245AD-Q100J 数据手册
CBT3245A-Q100 Octal bus switch Rev. 2 — 30 April 2019 Product data sheet 1. General description The CBT3245A-Q100 provides eight bits of high-speed TTL-compatible bus switching. The low ON resistance of the switch allows connections to be made with minimal propagation delay. The CBT3245A-Q100 is organized as one 8-bit bus switches with one output enable (OE) input. When OE is LOW, the switch is on and port A is connected to the B port. When OE is HIGH, each switch is disabled. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 3) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 3) • Specified from -40 °C to +85 °C 5 Ω switch connection between two ports TTL-compatible control input levels Multiple package options Latch-up protection exceeds 500 mA per JESD78 ESD protection: • MIL-STD-883, method 3015 exceeds 2000 V • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115B exceeds 150 V (C = 200 pF, R = 0 Ω 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version -40 °C to +85 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 CBT3245APW-Q100 -40 °C to +85 °C TSSOP20 plastic thin shrink small outline package; 20 leads; SOT360-1 body width 4.4 mm CBT3245ABQ-Q100 -40 °C to +85 °C DHVQFN20 plastic dual-in-line compatible thermal enhanced SOT764-1 very thin quad flat package; no leads; 20 terminals; body 2.5 x 4.5 x 0.85 mm CBT3245AD-Q100 CBT3245A-Q100 Nexperia Octal bus switch 4. Functional diagram A1 A8 OE Fig. 1. 2 18 9 11 B1 B8 19 001aao117 Logic diagram 5. Pinning information 5.1. Pinning 1 n.c. terminal 1 index area 1 20 VCC A1 2 19 OE A2 3 18 B1 A3 4 17 B2 A4 5 16 B3 A5 6 15 B4 A6 7 14 B5 A7 8 13 B6 A8 9 12 B7 GND 10 19 OE A2 3 18 B1 A3 4 17 B2 A4 5 16 B3 A5 6 15 B4 A6 7 A7 8 A8 9 14 B5 GND(1) 13 B6 12 B7 aaa-001833 Transparent top view (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. 11 B8 aaa-001831 Fig. 2. 2 B8 11 n.c. A1 GND 10 CBT3245A 20 VCC CBT3245A Pin configuration for SOT163-1 (SO20) and SOT360-1 (TSSOP20) Fig. 3. Pin configuration for SOT764-1 (DHVQFN20) 5.2. Pin description Table 2. Pin description Symbol Pin Description n.c. 1 not connected A1 to A8 2, 3, 4, 5, 6, 7, 8, 9 data input/output (A port) GND 10 ground (0 V) B1 to B8 18, 17, 16, 15, 14, 13, 12, 11 data input/output (B port) OE 19 output enable input (active LOW) VCC 20 positive supply voltage CBT3245A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 April 2019 © Nexperia B.V. 2019. All rights reserved 2 / 12 CBT3245A-Q100 Nexperia Octal bus switch 6. Functional description Table 3. Functional description H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. Input Input/output OE An, Bn L An = Bn H Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Tamb = -40 °C to +85 °C, unless otherwise specified. Symbol Parameter VCC supply voltage VI input voltage IOK output clamping current VO output voltage IO output current IIK input clamping current Tstg storage temperature [1] Conditions Min Max Unit -0.5 +7.0 V [1] -0.5 +7.0 V -50 - [1] -0.5 +7.0 V VO < 0 V - ±128 mA VI < 0 V -50 - mA -65 +150 °C VO < 0 V mA The input and output negative-voltage ratings may be exceeded if the input and output clamp-current ratings are observed. 8. Recommended operating conditions Table 5. Recommended operating conditions All unused control inputs of the device must be held at VCC or GND to ensure proper device operation. Symbol Parameter VCC VIH Min Typ Max Unit supply voltage 4.0 - 5.5 V HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V Tamb ambient temperature -40 - +85 °C CBT3245A_Q100 Product data sheet Conditions operating in free air All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 April 2019 © Nexperia B.V. 2019. All rights reserved 3 / 12 CBT3245A-Q100 Nexperia Octal bus switch 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = -40 °C to +85 °C Unit Min Typ[1] Max - -1.2 V VIK input clamping voltage VCC = 4.5 V; II = -18 mA - II input leakage current VCC = 5.5 V; VI = GND or 5.5 V - - ±5 μA ICC supply current VCC = 5.5 V; IO = 0 mA; VI = VCC or GND - 1 3 μA ΔICC additional supply current per input pin; VCC = 5.5 V; one input at [2] 3.4 V, other inputs at VCC or GND - - 3.5 mA CI input capacitance control pins; VI = 3 V or 0 V - 3.2 - pF Cio(off) off-state input/output capacitance port off; VI = 3 V or 0 V; OE = VCC - 6.6 - pF RON ON resistance VCC = 4.5 V; VI = 0 V; II = 64 mA [3] - 5 7 Ω VCC = 4.5 V; VI = 0 V; II = 30 mA [3] - 5 7 Ω VCC = 4.5 V; VI = 2.4 V; II = -15 mA [3] - 10 15 Ω [1] [2] [3] All typical values are measured at VCC = 5 V and Tamb = 25 °C. This is the increase in supply current for each input that is at the specified TTL voltage level rather than VCC or GND. Measured by the voltage drop between the An and the Bn terminals at the indicated current through the switch. ON resistance is determined by the lowest voltage of the two (An or Bn) terminals. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 6. Symbol tpd Parameter propagation delay Conditions An, Bn to Bn, An; see Fig. 4 Tamb = -40 °C to +85 °C enable time OE to An or Bn; see Fig. 5 tdis disable time OE to An or Bn; see Fig. 5 0.25 ns 1.0 5.9 ns 1.0 6.0 ns [2] VCC = 5.0 V ± 0.5 V [2] [2] VCC = 5.0 V ± 0.5 V [1] Max [1][2] VCC = 5.0 V ± 0.5 V ten Unit Min The propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified load capacitance, when driven by an ideal voltage source (zero output impedance). tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. CBT3245A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 April 2019 © Nexperia B.V. 2019. All rights reserved 4 / 12 CBT3245A-Q100 Nexperia Octal bus switch 10.1. Waveforms and test circuit VI VM An, Bn input GND tPHL tPLH VOH VM Bn, An output VOL 001aam475 Measurement points are given in Table 8. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 4. The data input (An, Bn) to output (Bn, An) propagation delay times VI VM OE input GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL 3.5 V VM VX VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled 001aam476 Measurement points are given in Table 8. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 5. Enable and disable times Table 8. Measurement points Supply voltage Input VCC VI VCC = 5.0 V ± 0.5 V GND to 3.0 V CBT3245A_Q100 Product data sheet Output VM VM VX VY 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 April 2019 © Nexperia B.V. 2019. All rights reserved 5 / 12 CBT3245A-Q100 Nexperia Octal bus switch VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz; Zo = 50 Ω. The outputs are measured one at a time with one transition per measurement. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 6. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VI VCC = 5.0 V ± 0.5 V GND to 3.0 V CBT3245A_Q100 Product data sheet Load VEXT tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH ≤ 2.5 ns 50 pF 500 Ω open 7.0 V open All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 April 2019 © Nexperia B.V. 2019. All rights reserved 6 / 12 CBT3245A-Q100 Nexperia Octal bus switch 11. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 inches 0.1 0.012 0.096 0.004 0.089 0.043 0.039 0.01 0.01 Z (1) 0.9 0.4 0.035 0.004 0.016 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 7. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT163-1 (SO20) CBT3245A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 April 2019 © Nexperia B.V. 2019. All rights reserved 7 / 12 CBT3245A-Q100 Nexperia Octal bus switch TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm D SOT360-1 E A X c HE y v M A Z 11 20 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 10 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 Fig. 8. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Package outline SOT360-1 (TSSOP20) CBT3245A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 April 2019 © Nexperia B.V. 2019. All rights reserved 8 / 12 CBT3245A-Q100 Nexperia Octal bus switch DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5 x 4.5 x 0.85 mm B D SOT764-1 A A A1 E c detail X terminal 1 index area terminal 1 index area e1 C e b 2 9 v w C A B C y1 C y L 1 10 Eh e 20 11 19 12 X Dh 0 2.5 5 mm scale Dimensions (mm are the original dimensions) Unit mm A(1) A1 b max 1.00 0.05 0.30 nom 0.90 0.02 0.25 min 0.80 0.00 0.18 c D(1) Dh E(1) Eh e e1 L v 0.2 4.6 4.5 4.4 3.15 3.00 2.85 2.6 2.5 2.4 1.15 1.00 0.85 0.5 3.5 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT764-1 --- MO-241 --- Fig. 9. sot764-1_po European projection Issue date 03-01-27 14-12-12 Package outline SOT764-1 (DHVQFN20) CBT3245A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 April 2019 © Nexperia B.V. 2019. All rights reserved 9 / 12 CBT3245A-Q100 Nexperia Octal bus switch 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model ESD ElectroStatic Discharge DUT Device Under Test HBM Human Body Model MIL Military MM Machine Model PRR Pulse Rate Repetition TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes CBT3245A_Q100 v.2 20190430 Product data sheet - CBT3245A_Q100 v.1 Modifications: • • • CBT3245A_Q100 v.1 CBT3245A_Q100 Product data sheet The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Package outline drawing SOT764-1 updated. 20130320 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 April 2019 - © Nexperia B.V. 2019. All rights reserved 10 / 12 CBT3245A-Q100 Nexperia Octal bus switch equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 14. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or CBT3245A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 April 2019 © Nexperia B.V. 2019. All rights reserved 11 / 12 CBT3245A-Q100 Nexperia Octal bus switch Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 2 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................3 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 4 10.1. Waveforms and test circuit........................................ 5 11. Package outline.......................................................... 7 12. Abbreviations............................................................ 10 13. Revision history........................................................10 14. Legal information......................................................11 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 April 2019 CBT3245A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 April 2019 © Nexperia B.V. 2019. All rights reserved 12 / 12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: CBT3245AD-Q100J CBT3245ABQ-Q100X CBT3245APW-Q100J
CBT3245AD-Q100J 价格&库存
很抱歉,暂时无法提供与“CBT3245AD-Q100J”相匹配的价格&库存,您可以联系我们找货
