CBT3251
1-of-8 FET multiplexer/demultiplexer
Rev. 3 — 16 March 2016
Product data sheet
1. General description
The CBT3251 is a 1-of-8 high-speed TTL-compatible FET multiplexer/demultiplexer. The
low ON-resistance of the switch allows inputs to be connected to outputs without adding
propagation delay or generating additional ground bounce noise.
When output enable (OE) is LOW, the CBT3251 is enabled. S0, S1 and S2 select one of
the Bn outputs for the A input data.
The CBT3251 is characterized for operation from 40 C to +85 C.
2. Features and benefits
5 switch connection between two ports
TTL-compatible input levels
Minimal propagation delay through the switch
Latch-up protection exceeds 100 mA per JEDEC standard JESD78 class II level A
ESD protection:
HBM JESD22-A114E exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101C exceeds 1000 V
Multiple package options
Specified from 40 C to +85 C
3. Ordering information
Table 1.
Type number
Temperature range
Package
Name
Description
Version
CBT3251D
40 C to +85 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
CBT3251DB
40 C to +85 C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
CBT3251PW
40 C to +85 C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
CBT3251
Nexperia
4. Functional diagram
2(
6
6
6
Fig 1.
DDE
Logic diagram
CBT3251
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
CBT3251
Nexperia
5. Pinning information
5.1 Pinning
&%7
9&&
QF
6
2(
*1'
&%7
6
6
9&&
QF
6
2(
6
*1'
DDE
Fig 2.
6
DDE
Pin configuration SOT109-1 (SO16)
Fig 3.
Pin configuration SOT338-1 (SSOP16) and
SOT403-1 (TSSOP16)
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
B1, B2, B3, B4, B5, B6, B7, B8
1, 2, 3, 4, 12, 13, 14, 15
B outputs/inputs
A
5
A input/output
n.c.
6
not connected
OE
7
output enable (active LOW)
S2, S1, S0
9, 10, 11
select control input
GND
8
ground (0 V)
VCC
16
positive supply voltage
CBT3251
Product data sheet
3 of 14
CBT3251
Nexperia
6. Functional description
Table 3.
Function selection
H = HIGH voltage level; L = LOW voltage level; X = Don’t care.
Inputs
Switch
OE
S2
S1
S0
L
L
L
L
A to B1
L
L
L
H
A to B2
L
L
H
L
A to B3
L
L
H
H
A to B4
L
H
L
L
A to B5
L
H
L
H
A to B6
L
H
H
L
A to B7
L
H
H
H
A to B8
H
X
X
X
switch off
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter
Conditions
supply voltage
VCC
[1]
VI
input voltage
ISW
switch current
continuous current through each switch
IIK
input clamping current
VI < 0 V
Tstg
storage temperature
Ptot
total power dissipation
Min
Max
Unit
0.5
+7.0
V
0.5
+7.0
V
128
mA
50
mA
65
+150
C
Tamb = 40 C to +85 C
SO16 package
[2]
500
mW
SSOP16 package
[3]
500
mW
TSSOP16 package
[3]
500
mW
[1]
The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed.
[2]
For SO16 package: Ptot derates linearly with 8 mW/K above 70 C.
[3]
For SSOP16 and TSSOP16 package: Ptot derates linearly with 5.5 mW/K above 70 C.
8. Recommended operating conditions
Table 5.
Operating conditions
All unused control inputs of the device must be held at VCC or GND to ensure proper device operation.
Symbol
Parameter
VCC
VIH
Min
Max
Unit
supply voltage
4.5
5.5
V
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
Tamb
ambient temperature
40
+85
C
CBT3251
Product data sheet
Conditions
operating in free-air
4 of 14
CBT3251
Nexperia
9. Static characteristics
Table 6.
Tamb = 40 C to +85 C.
Symbol
Parameter
Conditions
VIK
input clamping voltage
VCC = 4.5 V; II = 18 mA
Min
Typ
Max
Unit
1.2
V
Vpass
pass voltage
VI = VCC = 5.0 V; IO = 100 A
3.6
3.9
4.2
V
II
input leakage current
VCC = 5.5 V; VI = GND or 5.5 V
1
A
ICC
supply current
VCC = 5.5 V; IO = 0 mA;
VI = VCC or GND
3
A
ICC
additional supply current
per input; VCC = 5.5 V; one input at
3.4 V, other inputs at VCC or GND
[3]
2.5
mA
CI
input capacitance
control pins; VI = 3 V or 0 V
[1]
3.5
pF
A port; VO = 3 V or 0 V; OE = VCC
[1]
17.5
pF
B port; VO = 3 V or 0 V; OE = VCC
[1]
4.0
pF
VCC = 4 V
[4]
5
Cio(off)
RON
off-state input/output capacitance
ON resistance
VI = 2.4 V; II = 15 mA
VCC = 4.5 V
[1]
[1]
[2]
[4]
VI = 0 V; II = 64 mA
[1]
5
7
VI = 0 V; II = 30 mA
[1]
5
7
[1]
10
15
Typical value is measured at VCC = 5 V; Tamb = 25 C.
[2]
Typical value is measured at VCC = 4 V; Tamb = 25 C.
[3]
This is the increase in supply current for each input that is at the specified TTL voltage level rather than VCC or GND.
[4]
Measured by the voltage drop between the A and the Bn terminals at the indicated current through the switch. The lowest voltage of the
two (A or Bn) terminals determines the ON resistance.
10. Dynamic characteristics
Table 7.
Tamb = 40 C to +85 C; VCC = 4.5 V to 5.5 V; for test circuit, see Figure 6.
Symbol
Parameter
propagation delay
tpd
enable time
ten
disable time
tdis
Conditions
Min
Max
Unit
A to Bn or Bn to A; see Figure 4
[1][2]
0.25
ns
Sn to A; see Figure 4
[1][2]
1.5
5.5
ns
OE to A or Bn; see Figure 5
[2]
1.5
5.6
ns
Sn to Bn; see Figure 5
[2]
1.6
5.8
ns
[2]
1.9
6.4
ns
[2]
2.3
6.2
ns
[1]
This parameter is warranted but not production tested. The propagation delay is based on the RC time constant of the typical ON
resistance of the switch and a load capacitance, when driven by an ideal voltage source (zero output impedance).
[2]
tPLH and tPHL are the same as tpd.
tPZL and tPZH are the same as ten.
tPLZ and tPHZ are the same as tdis.
CBT3251
Product data sheet
5 of 14
CBT3251
Nexperia
11. AC waveforms
9,
LQSXW
90
90
9
W3+/
W3/+
92+
90
RXWSXW
90
92/
DDL
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 4.
The input (A; Bn) to output (Bn; A) or input (Sn) to output (A) propagation delay times
9,
90
2(6QLQSXW
90
*1'
W3=/
W3/=
9&&
RXWSXW
/2:WR2))
2))WR/2:
90
9;
92/
W3=+
W3+=
92+
RXWSXW
+,*+WR2))
2))WR+,*+
9<
90
*1'
VZLWFK
HQDEOHG
VZLWFK
GLVDEOHG
VZLWFK
HQDEOHG
DDQ
Fig 5.
Table 8.
Enable and disable times
Measurement points
Supply voltage
Input
VCC
VI
VM
VM
VX
VY
4.5 V to 5.5 V
GND to 3.0 V
1.5 V
1.5 V
VOL + 0.3 V
VOH 0.3 V
CBT3251
Product data sheet
Output
6 of 14
CBT3251
Nexperia
12. Test information
9,
W:
QHJDWLYH
SXOVH
90
9
WI
WU
WU
WI
9,
SRVLWLYH
SXOVH
9
90
90
90
W:
9(;7
9&&
9,
5/
92
'87
57
5/
DDH
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 6.
Table 9.
Test circuit for measuring switching times
Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
4.5 V to 5.5 V
GND to 3.0 V
2.5 ns
50 pF
500
open
7.0 V
open
CBT3251
Product data sheet
Load
VEXT
7 of 14
CBT3251
Nexperia
13. Package outline
62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
Z 0
ES
GHWDLO;
PP
VFDOH
',0(16,216LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
PP
LQFKHV
ș
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPLQFKPD[LPXPSHUVLGHDUHQRWLQFOXGHG
Fig 7.
5()(5(1&(6
287/,1(
9(56,21
627
06
-(,7$
(8523($1
352-(&7,21
,668('$7(
Package outline SOT109-1 (SO16)
CBT3251
Product data sheet
8 of 14
CBT3251
Nexperia
6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
GHWDLO;
Z 0
ES
H
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
Fig 8.
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Package outline SOT338-1 (SSOP16)
CBT3251
Product data sheet
9 of 14
CBT3251
Nexperia
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWHV
3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
Fig 9.
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Package outline SOT403-1 (TSSOP16)
CBT3251
Product data sheet
10 of 14
CBT3251
Nexperia
14. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
15. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
CBT3251 v.3
20160316
Product data sheet
CBT3251 v.2
CBT3251 v.1
Modifications:
CBT3251 v.2
Modifications:
CBT3251 v.1
CBT3251
Product data sheet
Type number CBT3251DS removed
20130916
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Table 6 pass voltage modified.
20051221
Product data sheet
11 of 14
CBT3251
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
CBT3251
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
12 of 14
CBT3251
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
CBT3251
Product data sheet
13 of 14
Nexperia
CBT3251
18. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
AC waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . 12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 13
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Date of release: 16 March 2016
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
CBT3251D,112 CBT3251DB,112 CBT3251DB,118 CBT3251DS,112 CBT3251DS,118 CBT3251D,118
CBT3251PW,112 CBT3251PW,118
