CBT3253ADS,118
CBT3253ADS,118
    NEXPERIA(安世)
    SSOP-16
    Dual 1-of-4 FET multiplexer/demultiplexer
CBT3253ADS,118 数据手册
CBT3253A Dual 1-of-4 FET multiplexer/demultiplexer Rev. 5 — 9 May 2017 1 Product data sheet General description The CBT3253A is a dual 1-of-4 high-speed TTL-compatible FET multiplexer/ demultiplexer. The low ON-resistance of the switch allows inputs to be connected to outputs without adding propagation delay or generating additional ground bounce noise. When the output enable input (nOE) is LOW, the 1-of-4 multiplexer/demultiplexer is enabled. The data path is selected by the select control inputs (S0, S1). When nOE is HIGH, the 1-of-4 multiplexer/demultiplexer is disabled. The switch terminals are in the high impedance OFF-state, independent of S0 and S1. The CBT3253A is characterized for operation from -40 °C to +85 °C. 2 Features and benefits • • • • • 5 Ω switch connection between two ports TTL-compatible input levels Minimal propagation delay through the switch Latch-up protection exceeds 100 mA per JEDEC standard JESD78 class II level A ESD protection: – HBM JESD22-A114E exceeds 2000 V – MM JESD22-A115-A exceeds 200 V – CDM JESD22-C101C exceeds 1000 V • Multiple package options • Specified from -40 °C to +85 °C 3 Ordering information Table 1. Ordering information Type number Temperature range Package Name Description Version CBT3253AD -40 °C to +85 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 CBT3253ADB -40 °C to +85 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 CBT3253ADS -40 °C to +85 °C SSOP16 plastic shrink small outline package; 16 leads; body width 3.9 mm; lead pitch 0.635 mm SOT519-1 CBT3253APW -40 °C to +85 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 [1] Also known as QSOP16. [1] CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer 4 Functional diagram 1A 7 6 5 4 3 2A 9 10 11 12 13 S0 S1 1OE 2OE 1B1 1B2 1B3 1B4 2B1 2B2 2B3 2B4 14 2 1 15 aaa-015421 Figure 1. Logic diagram CBT3253A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer 5 Pinning information 5.1 Pinning CBT3253A 1OE 1 16 VCC S1 2 15 2OE 1B4 3 14 S0 1B3 4 13 2B4 1B2 5 12 2B3 1B1 6 11 2B2 1A 7 GND 8 CBT3253A 10 2B1 9 2A 1OE 1 16 VCC S1 2 15 2OE 1B4 3 14 S0 1B3 4 13 2B4 1B2 5 12 2B3 1B1 6 11 2B2 1A 7 10 2B1 GND 8 9 2A 002aab827 002aab824 Figure 2. Pin configuration SOT109-1 (SO16) and SOT519-1 (SSOP16) Figure 3. Pin configuration SOT338-1 (SSOP16) and SOT403-1 (TSSOP16) 5.2 Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE 1, 15 output enable (active LOW) S1, S0 2, 14 select control input 1B4, 1B3, 1B2, 1B1 3, 4, 5, 6 1B outputs/inputs 1A 7 1A input/output GND 8 ground (0 V) 2A 9 2A input/output 2B1, 2B2, 2B3, 2B4 10, 11, 12, 13 2B outputs/inputs VCC 16 positive supply voltage CBT3253A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer 6 Functional description Table 3. Function selection [1] Inputs Switch 1OE 2OE S1 S0 X H X X disconnect 2A to 2Bn H X X X disconnect 1A to 1Bn L L L L 1A to 1B1 and 2A to 2B1 L L L H 1A to 1B2 and 2A to 2B2 L L H L 1A to 1B3 and 2A to 2B3 L L H H 1A to 1B4 and 2A to 2B4 [1] H = HIGH voltage level; L = LOW voltage level; X = Don’t care. 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions supply voltage [1] VI input voltage ISW switch current continuous current through each switch IIK input clamping current VI < 0 V Tstg storage temperature Ptot total power dissipation [1] [2] [3] Min Max Unit -0.5 +7.0 V -0.5 +7.0 V - 128 mA -50 - mA -65 +150 °C Tamb = -40 °C to +85 °C SO16 package [2] - 500 mW SSOP16 package [3] - 500 mW TSSOP16 package [3] - 500 mW Min Max Unit The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. For SO16 package: Ptot derates linearly with 8 mW/K above 70 °C. For SSOP16 and TSSOP16 package: Ptot derates linearly with 5.5 mW/K above 70 °C. 8 Recommended operating conditions Table 5. Operating conditions All unused control inputs of the device must be held at VCC or GND to ensure proper device operation. Symbol Parameter Conditions VCC supply voltage 4.5 5.5 V VIH HIGH-level input voltage 2.0 - V VIL LOW-level input voltage - 0.8 V Tamb ambient temperature -40 +85 °C CBT3253A Product data sheet operating in free-air All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer 9 Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Tamb = -40 °C to +85 °C. Symbol Parameter Conditions VIK input clamping voltage VCC = 4.5 V; II = -18 mA Vpass pass voltage II ICC Min Typ [1] Max Unit - - -1.2 V VI = VCC = 5.0 V; IO = -100 μA 3.6 3.9 4.2 V input leakage current VCC = 5.5 V; VI = GND or 5.5 V - - ±1 μA supply current VCC = 5.5 V; IO = 0 mA;VI = VCC or GND - - 3 μA - - 2.5 mA [2] ΔICC additional supply current per input; VCC = 5.5 V; one input at 3.4 V, other inputs at VCC or GND CI input capacitance control pins; VI = 3 V or 0 V - 4.5 - pF Cio(off) off-state input/output capacitance A port; VO = 3 V or 0 V; nOE = VCC - 11.4 - pF B port; VO = 3 V or 0 V; nOE = VCC - 3.8 - pF Cio(on) on-state input/output capacitance A port and B port - 18.6 - pF RON ON resistance VCC = 4.5 V VI = 0 V; II = 64 mA - 5 7 Ω VI = 0 V; II = 30 mA - 5 7 Ω VI = 2.4 V; II = -15 mA - 10 15 Ω [1] [2] [3] [3] All typical values are measured at VCC = 5 V; Tamb = 25 °C. This is the increase in supply current for each input that is at the specified TTL voltage level rather than VCC or GND. Measured by the voltage drop between the A and the B terminals at the indicated current through the switch. The lowest voltage of the two (A or B) terminals determines the ON resistance. 10 Dynamic characteristics Table 7. Dynamic characteristics Tamb = -40 °C to +85 °C; VCC = 4.5 V to 5.5 V; for test circuit, see Figure 6. Symbol Parameter tpd propagation delay ten enable time tdis [1] [2] [3] [4] disable time Conditions Min Max Sn to nA; see Figure 4 [1] [2] Unit 1.2 6.2 ns nA to nBn or nBn to nA; see Figure 4 [1] [2] - 0.25 ns Sn to nBn; see Figure 5 [3] 1.3 6.3 ns nOE to nA or nBn; see Figure 5 [3] 1.4 6.4 ns Sn to nBn; see Figure 5 [4] 1.1 7.2 ns nOE to nA or nBn; see Figure 5 [4] 1.0 7 ns This parameter is warranted but not production tested. The propagation delay is based on the RC time constant of the typical ON resistance of the switch and a load capacitance, when driven by an ideal voltage source (zero output impedance). tPLH and tPHL are the same as tpd. tPZL and tPZH are the same as ten. tPLZ and tPHZ are the same as tdis. CBT3253A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer 10.1 Waveforms and test circuit VI VM input VM 0V tPHL tPLH VOH VM output VM VOL 001aai367 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 4. The input (nA; nBn) to output (nBn; nA) or input (Sn) to output (nA) propagation delay times VI VM nOE, Sn input VM GND tPZL tPLZ output LOW-to-OFF OFF-to-LOW VCC VM VX VOL tPZH tPHZ VOH output HIGH-to-OFF OFF-to-HIGH VY VM GND switch enabled switch disabled switch enabled 001aal212 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 5. Enable and disable times Table 8. Measurement points Supply voltage Input VCC VI VM VM VX VY 4.5 V to 5.5 V GND to 3.0 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V CBT3253A Product data sheet Output All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 6. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 4.5 V to 5.5 V GND to 3.0 V ≤ 2.5 ns 50 pF 500 Ω open 7.0 V open CBT3253A Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer 11 Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 7. Package outline SOT109-1 (SO16) CBT3253A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 8. Package outline SOT338-1 (SSOP16) CBT3253A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer SSOP16: plastic shrink small outline package; 16 leads; body width 3.9 mm; lead pitch 0.635 mm D E A SOT519-1 X c y HE v M A Z 9 16 A2 A (A 3 ) A1 θ Lp L 8 1 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp v w y Z (1) θ mm 1.73 0.25 0.10 1.55 1.40 0.25 0.31 0.20 0.25 0.18 5.0 4.8 4.0 3.8 0.635 6.2 5.8 1 0.89 0.41 0.2 0.18 0.09 0.18 0.05 8o 0o Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-05-04 03-02-18 SOT519-1 Figure 9. Package outline SOT519-1 (SSOP16) CBT3253A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Figure 10. Package outline SOT403-1 (TSSOP16) CBT3253A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer 12 Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes CBT3253A v.5 20170509 - CBT3253A v.4 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. CBT3253A v.4 20141031 Modifications: • • • • CBT3253A v.3 20130924 Modifications: Section 9 values for pass voltage modified. CBT3253A v.2 20070208 CBT3253A v.1 20051024 CBT3253A Product data sheet Product data sheet Product data sheet - CBT3253A v.3 Section 1: text changed to align with the function of the device. Figure 1: schematic changed.. Section 6: switch description changed to align with the function of the device. Table 7: typo corrected, the conditions for enable and disable times are swapped. Product data sheet - CBT3253A v.2 Product data sheet - CBT3253A v.1 Product data sheet - - All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical CBT3253A Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer CBT3253A Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 May 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 15 CBT3253A Nexperia Dual 1-of-4 FET multiplexer/demultiplexer Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 5 Dynamic characteristics .....................................5 Waveforms and test circuit ................................ 6 Package outline ...................................................8 Abbreviations .................................................... 12 Revision history ................................................ 12 Legal information .............................................. 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 9 May 2017 Document identifier: CBT3253A Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: CBT3253AD,112 CBT3253ADB,112 CBT3253ADB,118 CBT3253ADS,112 CBT3253ADS,118 CBT3253AD,118 CBT3253APW,112 CBT3253APW,118
CBT3253ADS,118 价格&库存
很抱歉,暂时无法提供与“CBT3253ADS,118”相匹配的价格&库存,您可以联系我们找货
