CBT3306GM,125
CBT3306GM,125
    NEXPERIA(安世)
    XQFN8_1.6X1.6MM
    双总线开关 XQFN8_1.6X1.6MM 4.5~5.5V
CBT3306GM,125 数据手册
CBT3306 Dual bus switch Rev. 8 — 6 March 2019 Product data sheet 1. General description The CBT3306 dual FET bus switch features independent line switches. Each switch is disabled when the associated output enable (nOE) input is HIGH. The CBT3306 is characterized for operation from -40 °C to +85 °C. 2. Features and benefits • • • • • 5 Ω switch connection between two ports TTL-compatible input levels Multiple package options Latch-up protection exceeds 100 mA per JESD78B ESD protection: • HBM JESD22-A114F exceeds 2000 V • CDM JESD22-C101D exceeds 1000 V 3. Ordering information Table 1. Ordering information Type number Package Name Description Version CBT3306PW TSSOP8 plastic thin shrink small outline package; 8 leads; body width 4.4 mm SOT530-1 CBT3306GT XSON8 plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm SOT833-1 CBT3306GM XQFN8 plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6 x 1.6 x 0.5 mm SOT902-2 4. Marking Table 2. Marking codes Type number Marking code CBT3306PW 3306 CBT3306GT F06 CBT3306GM F06 CBT3306 Nexperia Dual bus switch 5. Functional diagram 1A 1OE 2A 2OE 2 3 1B 1 5 6 2B 7 002aab985 Fig. 1. Logic diagram 6. Pinning information 6.1. Pinning CBT3306 1OE 1 8 VCC 1A 2 7 2OE 1B 3 6 2B GND 4 5 2A 1OE 1 1A 1B 8 CBT3306 VCC terminal 1 index area 7 2OE 2 6 2B 3 5 2A 1 8 VCC 1A 2 7 2OE 1B 3 6 2B GND 4 5 2A 001aal337 Transparent top view 001aak304 Fig. 2. Pin configuration for TSSOP8 (SOT530-1) GND 1OE 4 CBT3306 Fig. 3. Pin configuration for SOT833-1 (XSON8) 001aal338 Transparent top view Fig. 4. Pin configuration for SOT902-2 (XQFN8) 6.2. Pin description Table 3. Pin description Symbol Pin Description 1OE, 2OE 1, 7 output enable input 1A, 2A 2, 5 data input/output (A port) 1B, 2B 3, 6 data input/output (B port) GND 4 ground (0 V) VCC 8 positive supply voltage CBT3306 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 2 / 12 CBT3306 Nexperia Dual bus switch 7. Functional description Table 4. Function selection H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. Input Input/output nOE nA, nB L nA = nB H Z 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Tamb = -40 °C to +85 °C, unless otherwise specified. Symbol Parameter VCC supply voltage VI input voltage IO output current IIK input clamping current Tstg storage temperature [1] Conditions [1] VI/O = 0 V Min Max Unit -0.5 +7.0 V -0.5 +7.0 V - 128 mA -50 - mA -65 +150 °C The input and output negative-voltage ratings may be exceeded if the input and output clamp-current ratings are observed. 9. Recommended operating conditions Table 6. Operating conditions All unused control inputs of the device must be held at VCC or GND to ensure proper device operation. Symbol Parameter VCC Min Typ Max Unit supply voltage 4.5 - 5.5 V VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V Tamb ambient temperature -40 - +85 °C CBT3306 Product data sheet Conditions operating in free air All information provided in this document is subject to legal disclaimers. Rev. 8 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 3 / 12 CBT3306 Nexperia Dual bus switch 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C Unit Min Typ[1] Max VIK input clamping voltage VCC = 4.5 V; II = -18 mA - - -1.2 V II input leakage current VCC = 5.5 V; VI = GND or 5.5 V - - ±1 μA ICC supply current VCC = 5.5 V; IO = 0 mA; VI = VCC or GND - - 3 μA Vpass pass voltage output HIGH; VI = VCC = 5.0 V; IO = -100 μA 3.6 3.9 4.2 V ΔICC additional supply current per input pin; VCC = 5.5 V; one input at 3.4 V, other inputs at VCC or GND - - 2.5 mA CI input capacitance control pin; VI = 3 V or 0 V - 3.15 - pF Cio(off) off-state input/output capacitance port off; VI = 3 V or 0 V; nOE = VCC - 6.45 - pF RON ON resistance VCC = 4.5 V; VI = 0 V; II = 64 mA [3] - 3.4 5 Ω VCC = 4.5 V; VI = 0 V; II = 30 mA [3] - 3.4 5 Ω VCC = 4.5 V; VI = 2.4 V; II = 15 mA [3] - 6.8 15 Ω [1] [2] [3] [2] All typical values are measured at VCC = 5 V, Tamb = 25 °C. This is the increase in supply current for each input that is at the specified TTL voltage level rather than VCC or GND. Measured by the voltage drop between the nA and the nB terminals at the indicated current through the switch. ON resistance is determined by the lowest voltage of the two (nA, nB) terminals. 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 7. Symbol Parameter Conditions -40 °C to +85 °C tpd propagation delay nA, nB to nB, nA; see Fig. 5 Unit Min Typ Max - - 0.25 ns [2] 1.0 - 5.0 ns [2] 1.0 - 5.0 ns [1][2] VCC = 5.0 V ± 0.5 V ten enable time nOE to nA, nB; see Fig. 6 VCC = 5.0 V ± 0.5 V tdis disable time nOE to nA, nB; see Fig. 6 VCC = 5.0 V ± 0.5 V [1] [2] The propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified load capacitance, when driven by an ideal voltage source (zero output impedance). tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. CBT3306 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 4 / 12 CBT3306 Nexperia Dual bus switch 11.1. Waveforms and test circuit VI nA, nB input VM GND tPHL tPLH VOH nB, nA output VM VOL 001aak305 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 5. The data input (nA, nB) to output (nB, nA) propagation delay times VI VM nOE input VM GND tPZL tPLZ output LOW to OFF OFF to LOW 3.5 V VM VX VOL tPZH tPHZ output HIGH to OFF OFF to HIGH VOH VY VM GND outputs enabled outputs disabled outputs enabled 001aak298 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. Enable and disable times Table 9. Measurement points Supply voltage Input VCC VI VCC = 5.0 V ± 0.5 V GND to 3.0 V CBT3306 Product data sheet Output VM VM VX VY 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V All information provided in this document is subject to legal disclaimers. Rev. 8 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 5 / 12 CBT3306 Nexperia Dual bus switch VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 10. All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz; Zo = 50 Ω. The outputs are measured one at a time with one transition per measurement. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 7. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VI VCC = 5.0 V ± 0.5 V GND to 3.0 V CBT3306 Product data sheet Load VEXT tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH ≤ 2.5 ns 50 pF 500 Ω open 7.0 V open All information provided in this document is subject to legal disclaimers. Rev. 8 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 6 / 12 CBT3306 Nexperia Dual bus switch 12. Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 4.4 mm SOT530-1 E D A X c y HE v M A Z 8 5 A2 (A3) A1 pin 1 index A θ Lp L detail X 1 4 e w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(2) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.05 0.95 0.85 0.25 0.30 0.19 0.20 0.13 3.1 2.9 4.5 4.3 0.65 6.5 6.3 0.94 0.7 0.5 0.1 0.1 0.1 0.70 0.35 8° 0° Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT530-1 Fig. 8. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 00-02-24 03-02-18 MO-153 Package outline SOT530-1 (TSSOP8) CBT3306 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 7 / 12 CBT3306 Nexperia Dual bus switch XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm 1 2 SOT833-1 b 4 3 4× (2) L L1 e 8 7 6 e1 5 e1 e1 8× A (2) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max A1 max b D E e e1 L L1 mm 0.5 0.04 0.25 0.17 2.0 1.9 1.05 0.95 0.6 0.5 0.35 0.27 0.40 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT833-1 --- MO-252 --- EUROPEAN PROJECTION ISSUE DATE 07-11-14 07-12-07 Package outline SOT833-1 (XSON8) CBT3306 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 8 / 12 CBT3306 Nexperia Dual bus switch XQFN8: plastic, extremely thin quad flat package; no leads; 8 terminals; body 1.6 x 1.6 x 0.5 mm SOT902-2 X D B A terminal 1 index area E A A1 detail X e v w b 4 3 C C A B C y1 C y 5 e1 terminal 1 index area 2 6 L 1 7 k 8 L2 L k metal area not for soldering L3 L1 0 1 Dimensions Unit(1) mm max nom min 2 mm scale A 0.5 A1 b D E e e1 0.05 0.25 1.65 1.65 0.20 1.60 1.60 0.55 0.00 0.15 1.55 1.55 0.5 k 0.2 L L1 L2 L3 0.35 0.15 0.25 0.35 0.30 0.10 0.20 0.30 0.25 0.05 0.15 0.25 v 0.1 w y y1 0.05 0.05 0.05 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT902-2 --- MO-255 --- sot902-2_po European projection Issue date 16-07-14 16-11-08 Fig. 10. Package outline SOT902-2 (XQFN8) CBT3306 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 9 / 12 CBT3306 Nexperia Dual bus switch 13. Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model ESD ElectroStatic Discharge FET Field Effect Transistor HBM Human Body Model PRR Pulse Rate Repetition TTL Transistor-Transistor Logic 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes CBT3306 v.8 20190306 Product data sheet - CBT3306 v.7 Modifications: • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number CBT3306D (SOT96-1) removed. Fig. 10: Package outline drawing SOT902-2 (XQFN8) updated. CBT3306 v.7 20120501 Modifications: • CBT3306 v.6 20111122 Modifications: • CBT3306 v.5 20100325 CBT3306 v.4 Product data sheet - CBT3306 v.6 For type number CBT3306GM the sot code has changed to SOT902-2. - CBT3306 v.5 Product data sheet - CBT3306 v.4 20100218 Product data sheet - CBT3306 v.3 CBT3306 v.3 20091014 Product data sheet - CBT3306 v.2 CBT3306 v.2 20051117 Product data sheet - CBT3306 v.1 CBT3306 v.1 20011108 Product data - - CBT3306 Product data sheet Product data sheet Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 8 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 10 / 12 CBT3306 Nexperia Dual bus switch 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal CBT3306 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 8 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 11 / 12 CBT3306 Nexperia Dual bus switch Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Marking.......................................................................... 1 5. Functional diagram.......................................................2 6. Pinning information......................................................2 6.1. Pinning.........................................................................2 6.2. Pin description............................................................. 2 7. Functional description................................................. 3 8. Limiting values............................................................. 3 9. Recommended operating conditions..........................3 10. Static characteristics..................................................4 11. Dynamic characteristics.............................................4 11.1. Waveforms and test circuit........................................ 5 12. Package outline.......................................................... 7 13. Abbreviations............................................................ 10 14. Revision history........................................................10 15. Legal information......................................................11 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 6 March 2019 CBT3306 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 12 / 12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: CBT3306D,112 CBT3306D,118 CBT3306PW,118 CBT3306GM,125 CBT3306GT,115
CBT3306GM,125 价格&库存
很抱歉,暂时无法提供与“CBT3306GM,125”相匹配的价格&库存,您可以联系我们找货
