CBTD3384
10-bit level shifting bus switch with 5-bit output enables
Rev. 9 — 6 March 2019
Product data sheet
1. General description
The CBTD3384 provides ten bits of high-speed TTL-compatible bus switching. The low ON
resistance of the switch allows connections to be made with minimal propagation delay.
The CBTD3384 device is organized as two 5-bit bus switches with two separate output enable
(1OE, 2OE) inputs. When nOE is LOW, the switch is on and port A is connected to the B port.
When nOE is HIGH, each switch is disabled.
2. Features and benefits
Designed to be used in 5 V to 3.3 V level shifting applications with internal diode
5 Ω switch connection between two ports
TTL-compatible control input levels
Latch-up protection exceeds 100 mA per JESD78
ESD protection:
• HBM JESD22-A114E exceeds 2000 V
• CDM JESD22-C101C exceeds 1000 V
Specified from -40 °C to +85 °C
3. Ordering information
Table 1. Ordering information
Type number Package
Temperature range Name
Description
CBTD3384D
-40 °C to +85 °C
SO24
plastic small outline package; 24 leads; body width 7.5 mm SOT137-1
CBTD3384DB
-40 °C to +85 °C
SSOP24
plastic shrink small outline package; 24 leads;
body width 5.3 mm
SOT340-1
TSSOP24
plastic thin shrink small outline package; 24 leads;
body width 4.4 mm
SOT355-1
CBTD3384PW -40 °C to +85 °C
Version
CBTD3384
Nexperia
4. Functional diagram
1A1
1A5
1OE
2A1
2A5
2OE
Fig. 1.
3
2
11
10
1B1
1B5
1
14
15
22
23
2B1
2B5
13
001aak877
Logic diagram
5. Pinning information
5.1. Pinning
CBTD3384
CBTD3384
1OE
1
1OE
1
24 VCC
1B1
2
24 VCC
23 2B5
1B1
2
23 2B5
1A1
3
22 2A5
1A1
3
22 2A5
1A2
4
21 2A4
1A2
4
21 2A4
1B2
5
20 2B4
1B2
5
20 2B4
1B3
6
19 2B3
1B3
6
19 2B3
1A3
7
18 2A3
1A3
7
18 2A3
1A4
8
17 2A2
1A4
8
17 2A2
1B4
9
16 2B2
1B4
9
16 2B2
1B5 10
15 2B1
1B5 10
15 2B1
1A5 11
14 2A1
1A5 11
14 2A1
GND 12
13 2OE
GND 12
13 2OE
001aan060
Fig. 2.
Pin configuration for SO24 (SOT137-1)
CBTD3384
Product data sheet
001aan061
Fig. 3.
Pin configuration for SSOP24 (SOT340-1) and
TSSOP24 (SOT355-1)
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 13
CBTD3384
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1OE, 2OE
1, 13
output enable input (active LOW)
1A1 to 1A5
3, 4, 7, 8, 11
data input/output (A port)
2A1 to 2A5
14, 17, 18, 21, 22
1B1 to 1B5
2, 5, 6, 9, 10
data input/output (B port)
2B1 to 2B5
15, 16, 19, 20, 23
GND
12
ground (0 V)
VCC
24
positive supply voltage
6. Functional description
Table 3. Function selection
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
Input
Input/output
1OE
2OE
1An, 1Bn
2An, 2Bn
L
L
1An = 1Bn
2An = 2Bn
L
H
1An = 1Bn
Z
H
L
Z
2An = 2Bn
H
H
Z
Z
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Tamb = -40 °C to +85 °C, unless otherwise specified.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
IO
output current
VO < 0 V
IIK
input clamping current
VI/O = 0 V
Tstg
storage temperature
[1]
Conditions
[1]
Min
Max
Unit
-0.5
+7.0
V
-0.5
+7.0
V
±128
mA
-50
mA
-65
+150
°C
The input and output negative-voltage ratings may be exceeded if the input and output clamp-current ratings are observed.
8. Recommended operating conditions
Table 5. Operating conditions
All unused control inputs of the device must be held at VCC or GND to ensure proper device operation.
Symbol
Parameter
VCC
Min
Typ
Max
Unit
supply voltage
4.5
5.5
V
VIH
HIGH-level input voltage
2.0
V
VIL
LOW-level input voltage
0.8
V
Tamb
ambient temperature
-40
+85
°C
CBTD3384
Product data sheet
Conditions
operating in free air
3 / 13
CBTD3384
Nexperia
9. Static characteristics
Table 6. Static characteristics
Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Unit
Min
Typ[1]
Max
-1.2
V
VIK
input clamping voltage
VCC = 4.5 V; II = -18 mA
II
input leakage current
VCC = 5.5 V; VI = GND or 5.5 V
±1
μA
ICC
supply current
VCC = 5.5 V; IO = 0 mA;
VI = VCC or GND
1.5
mA
ΔICC
additional supply current
per input pin; VCC = 5.5 V; one input
at 3.4 V, other inputs at VCC or GND
2.5
mA
Vpass
pass voltage
see Fig. 4 to Fig. 8
V
CI
input capacitance
control pins; VI = 3 V or 0 V
3.2
pF
Cio(off)
off-state input/output
capacitance
port off; VI = 3 V or 0 V; nOE = VCC
6.0
pF
RON
ON resistance
VCC = 4.5 V; VI = 0 V; II = 64 mA
[3]
5
7
Ω
VCC = 4.5 V; VI = 0 V; II = 30 mA
[3]
5
7
Ω
VCC = 4.5 V; VI = 2.4 V; II = -15 mA
[3]
17
50
Ω
[1]
[2]
[3]
[2]
All typical values are at VCC = 5 V, Tamb = 25 °C.
This is the increase in supply current for each input that is at the specified TTL voltage level rather than VCC or GND.
Measured by the voltage drop between the nAn and the nBn terminals at the indicated current through the switch. ON resistance is
determined by the lowest voltage of the two (nAn or nBn) terminals.
9.1. Typical pass voltage graphs
001aak834
3.6
001aak835
3.6
Vpass
(V)
Vpass
(V)
(1)
3.2
(1)
3.2
(2)
(2)
(3)
2.8
2.8
(4)
(3)
(4)
2.4
2.0
4.4
2.4
4.8
5.2
VCC (V)
2.0
4.4
5.6
Tamb = 85 °C (typical)
(1) ISW = 100 μA
(2) ISW = 6 mA
(3) ISW =12 mA
(4) ISW = 24 mA
Fig. 4.
Product data sheet
5.2
VCC (V)
5.6
Tamb = 70 °C (typical)
(1) ISW = 100 μA
(2) ISW = 6 mA
(3) ISW =12 mA
(4) ISW = 24 mA
Pass voltage versus supply voltage
CBTD3384
4.8
Fig. 5.
4 / 13
CBTD3384
Nexperia
001aak836
3.6
Vpass
(V)
001aak837
3.6
Vpass
(V)
(1)
3.2
(1)
3.2
(2)
(2)
(3)
2.8
(4)
2.4
2.0
4.4
(4)
2.4
4.8
5.2
VCC (V)
2.0
4.4
5.6
Tamb = 25 °C (typical)
(1) ISW = 100 μA
(2) ISW = 6 mA
(3) ISW =12 mA
(4) ISW = 24 mA
Fig. 6.
(3)
2.8
4.8
5.2
VCC (V)
5.6
Tamb = 0 °C (typical)
(1) ISW = 100 μA
(2) ISW = 6 mA
(3) ISW =12 mA
(4) ISW = 24 mA
Fig. 7.
001aak838
3.6
Vpass
(V)
3.2
(1)
(2)
2.8
(3)
(4)
2.4
2.0
4.4
4.8
5.2
VCC (V)
5.6
Tamb = -40 °C (typical)
(1) ISW = 100 μA
(2) ISW = 6 mA
(3) ISW =12 mA
(4) ISW = 24 mA
Fig. 8.
Pass voltage versus supply voltage;
CBTD3384
Product data sheet
5 / 13
CBTD3384
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 11.
Symbol Parameter
Conditions
tpd
propagation delay
nAn, nBn to nBn, nAn; see Fig. 9
ten
enable time
nOE to nAn or nBn; see Fig. 10
Min
Typ
Max
0.25
ns
1.2
4.3
7.0
ns
1.7
3.0
5.3
ns
[1][2]
VCC = 5.0 V ± 0.5 V
[2]
VCC = 5.0 V ± 0.5 V
tdis
disable time
[2]
VCC = 5.0 V ± 0.5 V
[1]
[2]
Unit
The propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified load capacitance,
when driven by an ideal voltage source (zero output impedance).
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
10.1. Waveforms and test circuit
VI
nAn, nBn,
input
VM
GND
tPHL
tPLH
VOH
nBn, nAn,
output
VM
VOL
001aan063
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 9.
The data input (nAn, nBn) to output (nBn, nAn) propagation delay times
VI
VM
nOE input
VM
GND
tPZL
tPLZ
output
LOW to OFF
OFF to LOW
3.5 V
VM
VX
VOL
tPZH
tPHZ
output
HIGH to OFF
OFF to HIGH
VOH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
001aak298
Fig. 10. Enable and disable times
CBTD3384
Product data sheet
6 / 13
CBTD3384
Nexperia
Table 8. Measurement points
Supply voltage
Input
VCC
Output
VI
VCC = 5.0 V ± 0.5 V GND to 3.0 V
VM
VM
VX
VY
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz; Zo = 50 Ω.
The outputs are measured one at a time with one transition per measurement.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 11. Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VI
CBTD3384
Product data sheet
Load
VEXT
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
≤ 2.5 ns
50 pF
500 Ω
open
7.0 V
open
7 / 13
CBTD3384
Nexperia
11. Package outline
SO24: plastic small outline package; 24 leads; body width 7.5 mm
SOT137-1
D
E
A
X
c
HE
y
v M A
Z
24
13
Q
A2
A
(A 3 )
A1
pin 1 index
θ
Lp
L
1
12
e
detail X
w M
bp
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
15.6
15.2
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.019 0.013
0.014 0.009
0.61
0.60
0.30
0.29
0.05
0.419
0.043 0.043
0.055
0.394
0.016 0.039
inches
0.1
0.012 0.096
0.004 0.089
0.01
0.01
0.01
Z
(1)
0.9
0.4
0.035
0.004
0.016
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT137-1
075E05
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 12. Package outline SOT137-1 (SO24)
CBTD3384
Product data sheet
8 / 13
CBTD3384
Nexperia
SSOP24: plastic shrink small outline package; 24 leads; body width 5.3 mm
D
SOT340-1
E
A
X
c
HE
y
v M A
Z
24
13
Q
A2
pin 1 index
A
(A 3 )
A1
θ
Lp
L
1
12
bp
e
detail X
w M
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
8.4
8.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
0.8
0.4
8o
0o
Note
1. Plastic or metal protrusions of 0.2 mm maximum per side are not included.
OUTLINE
VERSION
SOT340-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig. 13. Package outline SOT340-1 (SSOP24)
CBTD3384
Product data sheet
9 / 13
CBTD3384
Nexperia
TSSOP24: plastic thin shrink small outline package; 24 leads; body width 4.4 mm
D
SOT355-1
E
A
X
c
HE
y
v M A
Z
13
24
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
12
e
detail X
w M
bp
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
7.9
7.7
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT355-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig. 14. Package outline SOT355-1 (TSSOP24)
CBTD3384
Product data sheet
10 / 13
CBTD3384
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CDM
Charged Device Model
ESD
ElectroStatic Discharge
HBM
Human Body Model
PRR
Pulse Rate Repetition
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
CBTD3384 v.9
20190306
Product data sheet
CBT3384 v.8
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number CBTD3384DK (SOT556-1) removed.
CBTD3384 v.8
20121212
Modifications:
CBTD3384 v.7
20121119
Modifications:
CBTD3384 v.6
20111121
Modifications:
CBTD3384 v.5
20101119
Product data sheet
CBTD3384 v.4
20011220
Product specification
CBTD3384 v.3
20000830
CBTD3384 v.2
CBTD3384 v.2
20000830
CBTD3384
Product data sheet
Product data sheet
CBT3384 v.7
CBT3384 v.6
CBTD3384 v.5
CBTD3384 v.4
Table 1: changed +125 °C into +85 °C (errata).
Product data sheet
Table 1: changed +85 °C into +125 °C (errata).
Product data sheet
Legal pages updated.
CBTD3384 v.3
11 / 13
CBTD3384
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
CBTD3384
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
12 / 13
CBTD3384
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................2
5.1. Pinning.........................................................................2
5.2. Pin description............................................................. 3
6. Functional description................................................. 3
7. Limiting values............................................................. 3
8. Recommended operating conditions..........................3
9. Static characteristics....................................................4
9.1. Typical pass voltage graphs........................................ 4
10. Dynamic characteristics............................................ 6
10.1. Waveforms and test circuit........................................ 6
11. Package outline.......................................................... 8
12. Abbreviations............................................................ 11
13. Revision history........................................................11
14. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 6 March 2019
CBTD3384
Product data sheet
13 / 13
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
CBTD3384D,112 CBTD3384DB,112 CBTD3384DB,118 CBTD3384DK,118 CBTD3384D,118 CBTD3384PW,112
CBTD3384PW,118
