CBTD3861PW,118
CBTD3861PW,118
    NEXPERIA(安世)
    TSSOP24_7.8X4.4MM
    带输出使能的10位电平移位总线开关 TSSOP24_7.8X4.4MM 4.5~5.5V
CBTD3861PW,118 数据手册
CBTD3861 10-bit level shifting bus switch with output enable Rev. 3 — 6 March 2019 Product data sheet 1. General description The CBTD3861 provides ten bits of high-speed TTL-compatible bus switching. The low ON resistance of the switch allows connections to be made with minimal propagation delay. The CBTD3861 device is organized as one 10-bit bus switches with one output enable (OE) input. When OE is LOW, the switch is on and port A is connected to the B port. When OE is HIGH, each switch is disabled. The CBTD3861 is characterized for operation from -40 °C to +85 °C. 2. Features and benefits • • • • • Designed to be used in 5 V to 3.3 V level shifting applications with internal diode 5 Ω switch connection between two ports TTL-compatible control input levels Latch-up protection exceeds 100 mA per JESD78 ESD protection: • HBM JESD22-A114F exceeds 2000 V • CDM JESD22-C101C exceeds 1000 V 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version CBTD3861PW -40 °C to +85 °C TSSOP24 plastic thin shrink small outline package; 24 leads; body width 4.4 mm SOT355-1 CBTD3861BQ -40 °C to +85 °C DHVQFN24 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 24 terminals; body 3.5 x 5.5 x 0.85 mm 4. Functional diagram A1 A10 OE Fig. 1. Logic diagram 2 22 11 13 B1 B10 23 001aam471 SOT815-1 CBTD3861 Nexperia 10-bit level shifting bus switch with output enable 5. Pinning information 5.1. Pinning 1 n.c. terminal 1 index area 24 VCC CBTD3861 CBTD3861 24 VCC A1 2 23 OE A2 3 22 B1 A3 4 21 B2 A4 5 20 B3 A5 6 19 B4 A6 7 18 B5 A7 8 17 B6 A8 9 16 B7 A9 10 15 B8 A10 11 14 B9 GND 12 13 B10 22 B1 A3 4 21 B2 A4 5 20 B3 A5 6 19 B4 A6 7 18 B5 A7 8 17 B6 A8 9 16 B7 GND(1) A9 10 15 B8 A10 11 14 B9 001aam479 Transparent top view (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. 001aam477 Fig. 2. 23 OE 3 B10 13 1 2 A2 GND 12 n.c. A1 Pin configuration for TSSOP24 (SOT355-1) Fig. 3. Pin configuration for DHVQFN24 (SOT815-1) 5.2. Pin description Table 2. Pin description Symbol Pin Description n.c. 1 not connected A1 to A10 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 data input/output (A port) GND 12 ground (0 V) B1 to B10 22, 21, 20, 19, 18, 17, 16, 15, 14, 13 data input/output (B port) OE 23 output enable input (active LOW) VCC 24 positive supply voltage 6. Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. Input Input/output OE An, Bn L An = Bn H Z CBTD3861 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 2 / 12 CBTD3861 Nexperia 10-bit level shifting bus switch with output enable 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Tamb = -40 °C to +85 °C, unless otherwise specified. Symbol Parameter VCC supply voltage VI input voltage IO output current IIK input clamping current Tstg storage temperature [1] Conditions Min Max Unit -0.5 +7.0 V -0.5 +7.0 V VO < 0 V - ±128 mA VI/O = 0 V -50 - mA -65 +150 °C [1] The input and output negative-voltage ratings may be exceeded if the input and output clamp-current ratings are observed. 8. Recommended operating conditions Table 5. Operating conditions All unused control inputs of the device must be held at VCC or GND to ensure proper device operation. Symbol Parameter VCC Conditions Min Typ Max Unit supply voltage 4.5 - 5.5 V VIH HIGH-state input voltage 2.0 - - V VIL LOW-state input voltage - - 0.8 V Tamb ambient temperature -40 - +85 °C operating in free air 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = -40 °C to +85 °C Min Typ[1] Max Unit VIK input clamping voltage VCC = 4.5 V; II = -18 mA - - -1.2 V II input leakage current VCC = 5.5 V; VI = GND or 5.5 V - - ±1 μA ICC supply current VCC = 5.5 V; IO = 0 mA; VI = VCC or GND - - 1.5 mA ΔICC additional supply current per input pin; VCC = 5.5 V; one input at 3.4 V, other inputs at VCC or GND - - 2.5 mA Vpass pass voltage see Fig. 4 to Fig. 8 - - - V CI input capacitance control pins; VI = 3 V or 0 V - 2.5 - pF Cio(off) off-state input/output capacitance port off; VI = 3 V or 0 V; OE = VCC - 4.0 - pF RON ON resistance VCC = 4.5 V; VI = 0 V; II = 64 mA [3] - 5 7 Ω VCC = 4.5 V; VI = 0 V; II = 30 mA [3] - 5 7 Ω VCC = 4.5 V; VI = 2.4 V; II = -15 mA [3] - 17 50 Ω [1] [2] [3] [2] All typical values are at VCC = 5 V, Tamb = 25 °C. This is the increase in supply current for each input that is at the specified TTL voltage level rather than VCC or GND. Measured by the voltage drop between the An and the Bn terminals at the indicated current through the switch. ON resistance is determined by the lowest voltage of the two (An or Bn) terminals. CBTD3861 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 3 / 12 CBTD3861 Nexperia 10-bit level shifting bus switch with output enable 9.1. Typical pass voltage graphs 001aak834 3.6 001aak835 3.6 Vpass (V) Vpass (V) (1) 3.2 (1) 3.2 (2) (2) (3) 2.8 2.8 (4) (3) (4) 2.4 2.0 4.4 2.4 4.8 5.2 VCC (V) 2.0 4.4 5.6 Tamb = 85 °C (typical) (1) ISW = 100 μA (2) ISW = 6 mA (3) ISW =12 mA (4) ISW = 24 mA Fig. 4. 4.8 5.2 Fig. 5. 001aak836 3.6 Vpass (V) Pass voltage versus supply voltage 001aak837 3.6 Vpass (V) (1) 3.2 (1) 3.2 (2) (2) (3) 2.8 (4) 4.8 5.2 VCC (V) 2.0 4.4 5.6 4.8 5.2 VCC (V) 5.6 Tamb = 0 °C (typical) (1) ISW = 100 μA (2) ISW = 6 mA (3) ISW =12 mA (4) ISW = 24 mA Pass voltage versus supply voltage Product data sheet (4) 2.4 Tamb = 25 °C (typical) (1) ISW = 100 μA (2) ISW = 6 mA (3) ISW =12 mA (4) ISW = 24 mA CBTD3861 (3) 2.8 2.4 Fig. 6. 5.6 Tamb = 70 °C (typical) (1) ISW = 100 μA (2) ISW = 6 mA (3) ISW =12 mA (4) ISW = 24 mA Pass voltage versus supply voltage 2.0 4.4 VCC (V) Fig. 7. Pass voltage versus supply voltage All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 4 / 12 CBTD3861 Nexperia 10-bit level shifting bus switch with output enable 001aak838 3.6 Vpass (V) 3.2 (1) (2) 2.8 (3) (4) 2.4 2.0 4.4 4.8 5.2 VCC (V) 5.6 Tamb = -40 °C (typical) (1) ISW = 100 μA (2) ISW = 6 mA (3) ISW =12 mA (4) ISW = 24 mA Fig. 8. Pass voltage versus supply voltage 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 11. Symbol Parameter Conditions tpd An, Bn to Bn, An; see Fig. 9 propagation delay Tamb = -40 °C to +85 °C enable time OE to An or Bn; see Fig. 10 disable time OE to An or Bn; see Fig. 10 [2] Max - - 0.25 ns 1.8 4.3 10.0 ns 1.0 3.0 6.0 ns [2] VCC = 5.0 V ± 0.5 V [1] Typ [2] VCC = 5.0 V ± 0.5 V tdis Min [1][2] VCC = 5.0 V ± 0.5 V ten Unit The propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified load capacitance, when driven by an ideal voltage source (zero output impedance). tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. CBTD3861 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 5 / 12 CBTD3861 Nexperia 10-bit level shifting bus switch with output enable 10.1. Waveforms and test circuit VI VM An, Bn input GND tPHL tPLH VOH VM Bn, An output VOL 001aam475 Measurement points are given in Table 8. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 9. The data input (An, Bn) to output (Bn, An) propagation delay times VI VM OE input GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL 3.5 V VM VX VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled 001aam476 Measurement points are given in Table 8. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 10. Enable and disable times Table 8. Measurement points Supply voltage Input VCC VI VCC = 5.0 V ± 0.5 V GND to 3.0 V CBTD3861 Product data sheet Output VM VM VX VY 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 6 / 12 CBTD3861 Nexperia 10-bit level shifting bus switch with output enable VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. All input pulses are supplied by generators having the following characteristics: PRR ≤ 10 MHz; Zo = 50 Ω. The outputs are measured one at a time with one transition per measurement. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 11. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VI VCC = 5.0 V ± 0.5 V GND to 3.0 V CBTD3861 Product data sheet Load VEXT tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH ≤ 2.5 ns 50 pF 500 Ω open 7.0 V open All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 7 / 12 CBTD3861 Nexperia 10-bit level shifting bus switch with output enable 11. Package outline TSSOP24: plastic thin shrink small outline package; 24 leads; body width 4.4 mm D SOT355-1 E A X c HE y v M A Z 13 24 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 12 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 7.9 7.7 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT355-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig. 12. Package outline SOT355-1 (TSSOP24) CBTD3861 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 8 / 12 CBTD3861 Nexperia 10-bit level shifting bus switch with output enable DHVQFN24: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 24 terminals; body 3.5 x 5.5 x 0.85 mm D B SOT815-1 A A E A1 c detail X terminal 1 index area C e1 terminal 1 index area e 2 y1 C v M C A B w M C b 11 y L 12 1 e2 Eh 24 13 23 14 X Dh 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 e2 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 5.6 5.4 4.25 3.95 3.6 3.4 2.25 1.95 0.5 4.5 1.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT815-1 --- --- --- EUROPEAN PROJECTION ISSUE DATE 03-04-29 Fig. 13. Package outline SOT815-1 (DHVQFN24) CBTD3861 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 9 / 12 CBTD3861 Nexperia 10-bit level shifting bus switch with output enable 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model ESD ElectroStatic Discharge HBM Human Body Model PRR Pulse Rate Repetition TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes CBTD3861 v.3 20190306 Product data sheet - CBTD3861 v.2 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number CBTD3861DK (SOT556-1) removed. CBTD3861 v.2 20111121 Modifications: • CBTD3861 v.1 20100819 CBTD3861 Product data sheet Product data sheet - CBTD3861 v.1 - - Legal pages updated. Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 10 / 12 CBTD3861 Nexperia 10-bit level shifting bus switch with output enable 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal CBTD3861 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 11 / 12 CBTD3861 Nexperia 10-bit level shifting bus switch with output enable Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................1 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 2 6. Functional description................................................. 2 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................3 9. Static characteristics....................................................3 9.1. Typical pass voltage graphs........................................ 4 10. Dynamic characteristics............................................ 5 10.1. Waveforms and test circuit........................................ 6 11. Package outline.......................................................... 8 12. Abbreviations............................................................ 10 13. Revision history........................................................10 14. Legal information......................................................11 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 6 March 2019 CBTD3861 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 6 March 2019 © Nexperia B.V. 2019. All rights reserved 12 / 12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: CBTD3861BQ,118 CBTD3861PW,118
CBTD3861PW,118 价格&库存
很抱歉,暂时无法提供与“CBTD3861PW,118”相匹配的价格&库存,您可以联系我们找货
