HEF4028B
BCD to decimal decoder
Rev. 9 — 23 March 2016
Product data sheet
1. General description
The HEF4028B is a 4-bit BCD to decimal decoder, a 4-bit BCO to octal decoder with
active LOW enable or an 8-output (Y0 to Y7) inverting demultiplexer. The outputs are fully
buffered for best performance.
When used as a BCD to decimal decoder a 1-2-4-8 BCD code applied to inputs A0 to A3
causes the selected output to be HIGH. The other nine outputs will be LOW.
To use the HEF4028B as a BCO to octal decoder, input A3 is an active LOW enable pin
and outputs Y8 and Y9 are not used. A 1-2-4 BCO code applied to inputs A0 to A2 causes
the selected output (Y0 to Y7) to be HIGH. The other seven outputs will be LOW. When
A3 is HIGH outputs (Y0 to Y7) will be forced LOW.
When used as an 8-output (Y0 to Y7) inverting demultiplexer A0 to A2 are used as
address inputs and A3 is the data input. Outputs Y8 and Y9 are not used.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS
(usually ground). Unused inputs must be connected to VDD, VSS, or another input.
2. Features and benefits
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Specified from 40 C to +85 C
Complies with JEDEC standard JESD 13-B
3. Ordering information
Table 1.
All types operate from 40 C to +85 C.
Type number
HEF4028BT
Package
Name
Description
Version
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
HEF4028B
Nexperia
4. Functional diagram
'(&2'(5
很抱歉,暂时无法提供与“HEF4028BT,653”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+1.397002500+0.18070
- 国内价格
- 1+4.71912
- 10+3.88107
- 100+3.49052
- 国内价格 香港价格
- 1+3.688561+0.47785
- 10+2.5756210+0.33367
- 25+2.2926525+0.29701
- 100+1.98587100+0.25727
- 250+1.83905250+0.23825
- 500+1.75061500+0.22679
- 1000+1.678801000+0.21749
- 国内价格 香港价格
- 99+0.8100599+0.10494
