74HC139; 74HCT139
Dual 2-to-4 line decoder/demultiplexer
Rev. 4 — 11 December 2015
Product data sheet
1. General description
The 74HC139; 74HCT139 decodes two binary weighted address inputs (nA0, nA1) to four
mutually exclusive outputs (nY0 to nY3). Each decoder features an enable input (nE).
When nE is HIGH all outputs are forced HIGH. The enable input can be used as the data
input for a 1-to-4 demultiplexer application. Inputs include clamp diodes. This enables the
use of current limiting resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Input levels:
For 74HC139: CMOS level
For 74HCT139: TTL level
Demultiplexing capability
2 independent 2-to-4 decoders
Multifunction capability
Suitable for memory decoding, data routing or code conversion
Complies with JEDEC standard no. 7A
Active LOW mutually exclusive outputs
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
3. Ordering information
Table 1.
Type number
74HC139D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
40 C to +125 C
TSSOP16
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
SOT403-1
74 HCT139D
74HC139DB
74HCT139DB
74HC139PW
74HCT139PW
74HC139; 74HCT139
Nexperia
4. Functional diagram
很抱歉,暂时无法提供与“74HCT139PW,118”相匹配的价格&库存,您可以联系我们找货
