74HC139DB,118
74HC139DB,118
    NEXPERIA(安世)
    SSOP16_208MIL
    双2对4线解码器/多路译码器 SSOP16_208MIL 2~6V
74HC139DB,118 数据手册
74HC139; 74HCT139 Dual 2-to-4 line decoder/demultiplexer Rev. 4 — 11 December 2015 Product data sheet 1. General description The 74HC139; 74HCT139 decodes two binary weighted address inputs (nA0, nA1) to four mutually exclusive outputs (nY0 to nY3). Each decoder features an enable input (nE). When nE is HIGH all outputs are forced HIGH. The enable input can be used as the data input for a 1-to-4 demultiplexer application. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Input levels:  For 74HC139: CMOS level  For 74HCT139: TTL level  Demultiplexing capability  2 independent 2-to-4 decoders  Multifunction capability  Suitable for memory decoding, data routing or code conversion  Complies with JEDEC standard no. 7A  Active LOW mutually exclusive outputs  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC139D Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74 HCT139D 74HC139DB 74HCT139DB 74HC139PW 74HCT139PW 74HC139; 74HCT139 Nexperia Dual 2-to-4 line decoder/demultiplexer 4. Functional diagram
74HC139DB,118
1. 物料型号:74HC_HCT139,由Nexperia公司生产。
2. 器件简介:74HC_HCT139是一种四2线到1线数据选择器/复用器,具有高噪声抑制能力和高速性能,适用于多种数字电路设计。
3. 引脚分配:该器件有14个引脚,包括4个数据输入端(A、B、C、D),3个使能端(G1、G2B、G2A),1个输出端(Y)和6个电源和地端。
4. 参数特性:包括电源电压范围(2.0V至6.0V)、工作温度范围(-40°C至+125°C)、输入逻辑电平、输出逻辑电平、传播延迟等。
5. 功能详解:74HC_HCT139可以根据使能端的电平状态,从四个数据输入端中选择一个数据传输到输出端。
6. 应用信息:适用于需要数据选择或复用功能的数字电路,如通信设备、计算机、工业控制系统等。
7. 封装信息:提供多种封装选项,包括SOIC、TSSOP、DIP等,以满足不同应用场景的需求。
74HC139DB,118 价格&库存
很抱歉,暂时无法提供与“74HC139DB,118”相匹配的价格&库存,您可以联系我们找货
