74HC251-Q100; 74HCT251-Q100
8-input multiplexer; 3-state
Rev. 2 — 15 July 2019
Product data sheet
1. General description
The 74HC251-Q100; 74HCT251-Q100 is an 8-bit multiplexer with eight binary inputs (I0 to I7),
three select inputs (S0 to S2) and an output enable input (OE). The select inputs select one of the
eight binary inputs and route it to the complementary outputs (Y and Y). A HIGH on OE causes the
outputs to assume a high-impedance OFF-state. Inputs include clamp diodes that enable the use
of current limiting resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Input levels:
• For 74HC251-Q100: CMOS level
• For 74HCT251-Q100: TTL level
Low-power dissipation
Non-inverting data path
Specified in compliance with JEDEC standard no. 7A
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
Multiple package options
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC251D-Q100
Temperature range Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
-40 °C to +125 °C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
SOT403-1
74HCT251D-Q100
74HC251DB-Q100
74HCT251DB-Q100
74HC251PW-Q100
74HCT251PW-Q100
Nexperia
4. Functional diagram
4
3
I0
7
Fig. 1.
3
2
1
15
14
13
12
I0
I1
I2
I3
I4
I5
I6
I7
OE
S0
S1
S2
11
10
9
Y
6
15
I3
14
I4
13
I5
I6
7
OE
aaa-008235
Y
5
Fig. 2.
I7
MULTIPLEXER
Y
Logic symbol
12
S2
9
5
I2
S1
10
Y
I1
1
S0
11
4
2
6
aaa-008236
Functional diagram
I7
I6
I5
I4
Y
I3
I2
Y
I1
I0
S2
Fig. 3.
S1
S0
OE
aaa-008237
Logic diagram
74HC_HCT251_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 17
Nexperia
5. Pinning information
5.1. Pinning
74HC251-Q100
74HCT251-Q100
I3 1
16 VCC
I2 2
15 I4
I1 3
14 I5
I0 4
13 I6
Y 5
12 I7
Y 6
11 S0
OE 7
74HC251-Q100
74HCT251-Q100
I3 1
9
15 I4
I1
3
14 I5
I0
4
13 I6
Y
5
12 I7
OE
11 S0
7
10 S1
GND 8
9
S2
S2
aaa-008243
aaa-008242
Fig. 4.
2
Y 6
10 S1
GND 8
16 VCC
I2
Fig. 5.
Pin configuration SOT109-1 (SO16)
Pin configuration SOT338-1 (SSOP16)
and SOT403-1 (TSSOP16)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
I0, I1, I2, I3, I4, I5, I6, I7
4, 3, 2, 1, 15, 14, 13, 12
data inputs
Y
5
multiplexer output
Y
6
complementary multiplexer output
OE
7
output enable input (active LOW)
GND
8
ground (0 V)
S0, S1, S2
11, 10, 9
common data select inputs
VCC
16
supply voltage
74HC_HCT251_Q100
Product data sheet
3 / 17
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Input
Output
OE
S2
S1
S0
I0
I1
I2
I3
I4
I5
I6
I7
Y
Y
H
X
X
X
X
X
X
X
X
X
X
X
Z
Z
L
L
L
L
L
X
X
X
X
X
X
X
H
L
L
L
L
L
H
X
X
X
X
X
X
X
L
H
L
L
L
H
X
L
X
X
X
X
X
X
H
L
L
L
L
H
X
H
X
X
X
X
X
X
L
H
L
L
H
L
X
X
L
X
X
X
X
X
H
L
L
L
H
L
X
X
H
X
X
X
X
X
L
H
L
L
H
H
X
X
X
L
X
X
X
X
H
L
L
L
H
H
X
X
X
H
X
X
X
X
L
H
L
H
L
L
X
X
X
X
L
X
X
X
H
L
L
H
L
L
X
X
X
X
H
X
X
X
L
H
L
H
L
H
X
X
X
X
X
L
X
X
H
L
L
H
L
H
X
X
X
X
X
H
X
X
L
H
L
H
H
L
X
X
X
X
X
X
L
X
H
L
L
H
H
L
X
X
X
X
X
X
H
X
L
H
L
H
H
H
X
X
X
X
X
X
X
L
H
L
L
H
H
H
X
X
X
X
X
X
X
H
L
H
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+7
V
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
VO = -0.5 V to (VCC + 0.5 V)
±25
mA
ICC
supply current
+50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[2]
[3]
Tamb = -40 °C to +125 °C
[1][2][3]
For SOT109-1 (SO16) packages: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT338-1 (SSOP16) packages: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT403-1 (TSSOP16) packages: Ptot derates linearly with 8.5 mW/K above 91 °C.
74HC_HCT251_Q100
Product data sheet
4 / 17
Nexperia
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC251-Q100
74HCT251-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
-40 °C to
+125 °C
Unit
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
74HC251-Q100
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
74HC_HCT251_Q100
Product data sheet
VI = VIH or VIL
VI = VIH or VIL
5 / 17
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±0.1
±1.0
±1.0
IOZ
OFF-state
output current
VI = VIH or VIL;
VO = VCC or GND; VCC = 6.0 V
±0.5
±5.0
±10.0 μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
CI
input
capacitance
3.5
160
μA
μA
pF
74HCT251-Q100
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = -20 μA
4.4
4.5
4.4
4.4
V
IO = -4 mA
3.98
4.32
3.84
3.7
V
VOL
LOW-level
output voltage
IO = 20 μA
0.1
0.1
V
IO = 4.0 mA
0.15
0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
±0.1
±1.0
±1.0
μA
IOZ
OFF-state
output current
VI = VIH or VIL;
VO = VCC or GND; VCC = 5.5 V
±0.5
±5.0
±10
μA
ICC
supply current
VCC = 5.5 V
8.0
80
160
μA
ΔICC
additional
supply current
VI = VCC - 2.1 V;
other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; IO = 0 A
per input pin; In inputs
100
360
450
490
μA
per input pin; OE input
150
540
675
735
μA
per input pin; Sn input
150
540
675
735
μA
3.5
CI
input
capacitance
74HC_HCT251_Q100
Product data sheet
pF
6 / 17
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Fig. 9.
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
50
170
215
255
ns
VCC = 4.5 V
18
34
43
51
ns
VCC = 5 V; CL = 15 pF
15
ns
14
29
37
43
ns
VCC = 2.0 V
55
175
220
265
ns
VCC = 4.5 V
44
53
ns
17
ns
16
30
37
45
ns
VCC = 2.0 V
66
205
255
310
ns
VCC = 4.5 V
24
41
51
62
ns
ns
19
35
43
53
ns
VCC = 2.0 V
69
205
255
310
ns
VCC = 4.5 V
25
41
51
62
ns
21
ns
43
53
ns
VCC = 2.0 V
36
140
175
210
ns
VCC = 4.5 V
13
28
35
42
ns
VCC = 6.0 V
10
24
30
36
ns
VCC = 2.0 V
39
140
170
210
ns
VCC = 4.5 V
14
28
35
42
ns
VCC = 6.0 V
11
24
30
36
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
44
pF
74HC251-Q100
tpd
propagation
delay
In to Y; see Fig. 6
[1]
VCC = 6.0 V
In to Y; see Fig. 6
[1]
VCC = 6.0 V
Sn to Y; see Fig. 7
[1]
VCC = 6.0 V
Sn to Y; see Fig. 7
[1]
VCC = 6.0 V
ten
tdis
tt
CPD
enable time
disable time
OE to Y, Y; see Fig. 8
transition time Y, Y; see Fig. 6
power
dissipation
capacitance
74HC_HCT251_Q100
Product data sheet
[2]
[3]
[4]
CL = 50 pF; f = 1 MHz;
VI = GND to VCC
[5]
7 / 17
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 4.5 V
22
35
44
53
ns
19
ns
VCC = 4.5 V
22
35
44
53
ns
19
ns
VCC = 4.5 V
24
44
55
66
ns
ns
VCC = 4.5 V
25
44
55
66
ns
21
ns
13
28
35
42
ns
13
ns
VCC = 4.5 V
14
28
35
42
ns
18
ns
7
15
19
22
ns
46
pF
74HCT251-Q100
tpd
propagation
delay
In to Y; see Fig. 6
In to Y; see Fig. 6
Sn to Y; see Fig. 7
Sn to Y; see Fig. 7
ten
enable time
[1]
[1]
[1]
[1]
[2]
VCC = 4.5 V
tdis
disable time
tt
CPD
power
dissipation
capacitance
[3]
[4]
VCC = 4.5 V
[1]
[2]
[3]
[4]
[5]
VI = GND to VCC
[5]
tpd is the same as tPLH and tPHL.
ten is the same as tPZH and tPZL.
tdis is the same as tPLZ and tPHZ.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL × VCC × fo) = sum of outputs.
74HC_HCT251_Q100
Product data sheet
8 / 17
Nexperia
10.1. Waveforms and test circuit
VI
In input
VM
VM
GND
tPHL
VOH
tPLH
90 %
90 %
VM
Y output
VM
10 %
VOL
10 %
tTLH
tTHL
tPLH
VOH
Y output
VOL
90 %
VM
tPHL
90 %
VM
10 %
10 %
tTLH
tTHL
aaa-004588
Measurement points are given in Table 8.
VOLand VOH are typical voltage output levels that occur with the output load.
Fig. 6.
Propagation delay input (In) to output (Y,Y) and the output (Y,Y) transition time
VI
Sn, OE input
VM
VM
GND
tPHL
VOH
tPLH
90 %
VM
Y output
10 %
VOL
90 %
VM
10 %
tTLH
tTHL
tPLH
VOH
Y output
VOL
90 %
VM
tPHL
90 %
VM
10 %
10 %
tTLH
tTHL
aaa-008241
Fig. 7.
Propagation delay input (Sn,OE) to output (Y,Y)
74HC_HCT251_Q100
Product data sheet
9 / 17
Nexperia
VI
OE input
VM
GND
tPLZ
tPZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
10%
VOL
tPHZ
VOH
tPZH
90%
output
HIGH-to-OFF
OFF-to-HIGH
GND
VM
outputs
enabled
outputs
disabled
outputs
enabled
001aae307
Fig. 8.
Enable and disable times
Table 8. Measurement points
Type
Input
Output
VM
VM
74HC251-Q100
0.5VCC
0.5VCC
74HCT251-Q100
1.3 V
1.3 V
74HC_HCT251_Q100
Product data sheet
10 / 17
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VCC
VO
RT
RL
S1
open
CL
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT= Termination resistance should be equal to output impedance Zo of the pulse generator.
CL= Load capacitance including jig and probe capacitance.
RL= Load resistance.
S1 = Test selection switch.
Fig. 9.
Test circuit for measuring switching times
Table 9. Test data
Type
Input
Load
VI
tr, tf
CL
74HC251-Q100
VCC
6 ns
74HCT251-Q100
3V
6 ns
74HC_HCT251_Q100
Product data sheet
S1 position
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
15 pF, 50 pF 1 kΩ
open
GND
VCC
15 pF, 50 pF 1 kΩ
open
GND
VCC
11 / 17
Nexperia
11. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 10. Package outline SOT109-1 (SO16)
74HC_HCT251_Q100
Product data sheet
12 / 17
Nexperia
SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm
D
SOT338-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
8
1
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
6.4
6.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
1.00
0.55
8o
0o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT338-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig. 11. Package outline SOT338-1 (SSOP16)
74HC_HCT251_Q100
Product data sheet
13 / 17
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 12. Package outline SOT403-1 (TSSOP16)
74HC_HCT251_Q100
Product data sheet
14 / 17
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74HC_HCT251_Q100 v.2
20190715
Product data sheet
Modifications:
74HC_HCT251_Q100 v.1
74HC_HCT251_Q100
Product data sheet
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type numbers 74HC251DB-Q100 and 74HCT251DB (SOT338-1) added.
Table 4: Derating values for Ptot total power dissipation have changed.
20130812
Product data sheet
15 / 17
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
14. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC_HCT251_Q100
Product data sheet
16 / 17
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................5
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 7
10.1. Waveforms and test circuit........................................ 9
11. Package outline........................................................ 12
12. Abbreviations............................................................ 15
13. Revision history........................................................15
14. Legal information......................................................16
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 15 July 2019
74HC_HCT251_Q100
Product data sheet
17 / 17
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC251PW-Q100J 74HC251D-Q100J 74HC251D/AUJ 74HC251DB-Q100J 74HCT251D-Q100J 74HCT251PWQ100J 74HCT251DB-Q100J 74HC138D-Q100HL
