74AHC164-Q100;
74AHCT164-Q100
8-bit serial-in/parallel-out shift register
Rev. 1 — 5 July 2013
Product data sheet
1. General description
The 74AHC164-Q100; 74AHCT164-Q100 shift register is a high-speed Si-gate CMOS
device and is pin compatible with Low-power Schottky TTL (LSTTL). It is specified in
compliance with JEDEC standard No. 7A.
The 74AHC164-Q100; 74AHCT164-Q100 input signals are 8-bit serial through one of two
inputs (DSA or DSB). Either input can be used as an active HIGH enable for data entry
through the other input. Both inputs must be connected together or an unused input must
be tied HIGH.
Data shifts one place to the right on each LOW-to-HIGH transition of the clock input (CP).
It enters into output Q0, which is a logical AND of the two data inputs (DSA and DSB).
These data inputs existed one set-up time, prior to the rising clock edge.
A LOW-level on the master reset (MR) input overrides all other inputs and clears the
register asynchronously, forcing all outputs LOW.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Balanced propagation delays
All inputs have Schmitt-trigger actions
Inputs accept voltages higher than VCC
Input levels:
For 74AHC164-Q100: CMOS level
For 74AHCT164-Q100: TTL level
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74AHC164D-Q100
40 C to +125 C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74AHC164PW-Q100
40 C to +125 C
TSSOP14
plastic thin shrink small outline package;
14 leads; body width 4.4 mm
SOT402-1
74AHC164BQ-Q100
40 C to +125 C
DHVQFN14
plastic dual in-line compatible thermal enhanced SOT762-1
very thin quad flat package; no leads;
14 terminals; body 2.5 3 0.85 mm
40 C to +125 C
SO14
body width 3.9 mm
SOT108-1
74AHCT164PW-Q100 40 C to +125 C
TSSOP14
SOT402-1
74AHCT164BQ-Q100 40 C to +125 C
DHVQFN14
74AHC164-Q100
74AHCT164-Q100
74AHCT164D-Q100
4. Functional diagram
DSA
DSB
CP
MR
1
2
8
8-BIT SERIAL−IN/PARALLEL−OUT
SHIFT REGISTER
9
3
4
5
6
10
11
12
13
Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7
001aac425
Fig 1.
Functional diagram
74AHC_AHCT164_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 19
Nexperia
SRG8
8
C1/
9
R
1
2
3
1D
4
DSA
DSB
1
2
CP
8
9
MR
5
3
Q0
4
Q1
6
5
Q2
10
6
Q3
10
Q4
11
11
Q5
12
12
Q6
13
Q7
13
001aac423
Fig 2.
001aac424
Logic symbol
Fig 3.
IEC logic symbol
DSA
D
Q
D
CP
FF1
RD
DSB
Q
D
CP
FF2
RD
Q
D
CP
FF3
RD
Q
D
CP
FF4
RD
Q
D
CP
FF5
RD
Q
D
CP
FF6
RD
Q
D
CP
FF7
RD
Q
CP
FF8
RD
CP
MR
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
001aac616
Fig 4.
Logic diagram
74AHC_AHCT164_Q100
Product data sheet
3 of 19
Nexperia
5. Pinning information
5.1 Pinning
$+&4
$+&74
9&&
'6%
4
4
4
'6$
WHUPLQDO
LQGH[DUHD
'6$
9&&
$+&4
$+&74
'6%
4
4
4
4
4
4
4
4
4
4
05
*1'
&3
*1'
&3
4
4
*1'
4
05
DDD
7UDQVSDUHQWWRSYLHZ
DDD
(1) The die substrate is attached to this pad using
conductive die attach material. It cannot be used as a
supply pin or input.
Fig 5.
Pin configuration SO14 and TSSOP14
Fig 6.
Pin configuration DHVQFN14
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
DSA
1
serial data input A
DSB
2
serial data input B
Q0
3
output 0
Q1
4
output 1
Q2
5
output 2
Q3
6
output 3
GND
7
ground (0 V)
CP
8
clock input (LOW-to-HIGH edge-triggered)
MR
9
master reset input (active LOW)
Q4
10
output 4
Q5
11
output 5
Q6
12
output 6
Q7
13
output 7
VCC
14
supply voltage
74AHC_AHCT164_Q100
Product data sheet
4 of 19
Nexperia
6. Functional description
Table 3.
Function table[1]
Operating mode
Control
Input
Output
MR
CP
DSA
DSB
Q0
Q1 to Q7
Reset (clear)
L
X
X
X
L
L to L
Shift
H
l
l
L
q0 to q6
l
h
L
q0 to q6
h
l
L
q0 to q6
h
h
H
q0 to q6
[1]
H = HIGH voltage level;
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition;
L = LOW voltage level;
l = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition;
= LOW-to-HIGH transition;
X = don’t care;
q = lower case letter indicates the state of the referenced input one set-up time prior to the LOW-to-HIGH transition.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
Conditions
Min
Max
Unit
0.5
+7.0
V
0.5
+7.0
V
mA
mA
25
+25
mA
input clamping current
VI < 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = 0.5 V to (VCC + 0.5 V)
ICC
supply current
+75
mA
IGND
ground current
75
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
500
mW
IIK
Tamb = 40 C to +125 C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 packages: above 70 C the value of Ptot derates linearly at 8 mW/K.
For TSSOP14 packages: above 60 C the value of Ptot derates linearly at 5.5 mW/K.
For DHVQFN14 packages: above 60 C the value of Ptot derates linearly at 4.5 mW/K.
74AHC_AHCT164_Q100
Product data sheet
5 of 19
Nexperia
8. Recommended operating conditions
Table 5.
Operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
2.0
5.0
5.5
V
74AHC164-Q100
VCC
supply voltage
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
t/V
input transition rise and fall rate
VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
74AHCT164-Q100
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
t/V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = 50 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 50 A; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = 50 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = 8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
LOW-level
VI = VIH or VIL
output voltage
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.36
0.44
0.55
V
0.36
0.44
0.55
V
74AHC164-Q100
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
74AHC_AHCT164_Q100
Product data sheet
6 of 19
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 C
Conditions
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
Min
Typ
Max
Min
Max
Min
Max
0.1
1.0
2.0
A
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
4.0
40
80
A
CI
input
capacitance
3
10
pF
74AHCT164-Q100
VIH
HIGH-level
input voltage
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = 50 A
4.4
4.5
4.4
4.4
V
3.94
3.80
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
A
IO = 8.0 mA
VOL
LOW-level
output voltage
IO = 50 A
IO = 8.0 mA
II
input leakage
current
ICC
VCC = 5.5 V
4.0
40
80
A
ICC
additional
per input pin;
supply current VI = VCC 2.1 V; IO = 0 A;
other pins at VCC or GND;
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
pF
74AHC_AHCT164_Q100
Product data sheet
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
7 of 19
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 10.
Symbol Parameter
25 C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
6.5
12.8
1.0
15.0
1.0
16.0
ns
CL = 50 pF
9.3
16.3
1.0
18.5
1.0
20.5
ns
4.5
9.0
1.0
10.5
1.0
11.5
ns
6.4
11.0
1.0
12.5
1.0
14.0
ns
CL = 15 pF
5.3
12.8
1.0
15.0
1.0
16.0
ns
CL = 50 pF
7.6
16.3
1.0
18.5
1.0
20.5
ns
CL = 15 pF
4.0
8.6
1.0
10.0
1.0
11.0
ns
CL = 50 pF
5.8
10.6
1.0
12.0
1.0
13.5
ns
CL = 15 pF
80
125
65
50
MHz
CL = 50 pF
50
75
45
35
MHz
CL = 15 pF
125
175
105
85
MHz
CL = 50 pF
85
115
75
65
MHz
5.0
5.0
5.0
ns
5.0
5.0
5.0
ns
5.0
5.0
5.0
ns
5.0
5.0
5.0
ns
5.0
6.0
6.0
ns
4.5
4.5
4.5
ns
1.5
1.5
1.5
ns
2.0
2.0
2.0
ns
74AHC164-Q100
tpd
propagation
delay
CP to Qn; see Figure 7
[2]
CL = 15 pF
CL = 50 pF
MR to Qn; see Figure 8
[3]
fmax
maximum
frequency
see Figure 7
tW
tWL
tsu
th
pulse width
CP HIGH or LOW;
see Figure 7
pulse width
LOW
MR; see Figure 8
set-up time
DSA, DSB to CP;
see Figure 9
hold time
74AHC_AHCT164_Q100
Product data sheet
DSA, DSB to CP;
see Figure 9
8 of 19
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
trec
CPD
recovery
time
25 C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
2.5
2.5
2.5
ns
2.5
2.5
2.5
ns
48
pF
3.4
9.0
1.0
10.5
1.0
11.5
ns
4.9
11.0
1.0
12.5
1.0
14.0
ns
CL = 15 pF
3.5
8.6
1.0
10.0
1.0
11.0
ns
CL = 50 pF
5.0
10.6
1.0
12.0
1.0
13.5
ns
CL = 15 pF
125
175
105
85
MHz
CL = 50 pF
85
115
75
65
MHz
MR to CP; see Figure 8
power
fi = 1 MHz; VI = GND to VCC
dissipation
capacitance
[4]
74AHCT164-Q100; VCC = 4.5 V to 5.5 V
tpd
propagation
delay
[2]
CL = 15 pF
CL = 50 pF
[3]
fmax
maximum
frequency
see Figure 7
tW
pulse width
CP HIGH or LOW;
see Figure 7
5.0
5.0
5.0
ns
tWL
pulse width
LOW
MR; see Figure 8
5.0
5.0
5.0
ns
tsu
set-up time
DSA, DSB to CP;
see Figure 9
4.5
4.5
4.5
ns
th
hold time
DSA, DSB to CP;
see Figure 9
2.0
2.0
2.0
ns
trec
recovery
time
2.5
2.5
2.5
ns
CPD
power
dissipation
capacitance
51
pF
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
[3]
tpd is the same as tPHL only.
[4]
[4]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
74AHC_AHCT164_Q100
Product data sheet
9 of 19
Nexperia
11. Waveforms
1/fmax
VI
CP input
VM
GND
tW
t PHL
t PLH
VOH
VM
Qn output
001aac426
VOL
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 7.
Clock pulse width, maximum frequency and input to output propagation delays
VI
VM
MR input
GND
t WL
t rec
VI
CP input
VM
GND
t PHL
VOH
VM
Qn output
VOL
001aac446
Fig 8.
Master reset pulse width, recovery time and propagation delays
74AHC_AHCT164_Q100
Product data sheet
10 of 19
Nexperia
VI
VM
CP input
GND
t su
t su
th
th
VI
VM
DSA, DSB input
GND
VOH
VM
Qn output
VOL
001aaf612
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig 9.
Table 8.
Data set-up and hold times
Measurement points
Type
Input
Output
VM
VM
74AHC164-Q100
0.5 VCC
0.5 VCC
74AHCT164-Q100
1.5 V
0.5 VCC
74AHC_AHCT164_Q100
Product data sheet
11 of 19
Nexperia
VI
negative
pulse
tW
90 %
VM
VM
10 %
GND
tr
tf
tr
tf
VI
90 %
positive
pulse
GND
VM
VM
10 %
tW
VCC
G
VI
VO
DUT
RT
CL
001aah768
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
Fig 10. Load circuitry for measuring switching times
Table 9.
Test data
Type
Input
Load
Test
VI
tr, tf
CL
74AHC164-Q100
VCC
3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHCT164-Q100
3.0 V
3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHC_AHCT164_Q100
Product data sheet
12 of 19
Nexperia
12. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 11. Package outline SOT108-1 (SO14)
74AHC_AHCT164_Q100
Product data sheet
13 of 19
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 12. Package outline SOT402-1 (TSSOP14)
74AHC_AHCT164_Q100
Product data sheet
14 of 19
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
0.5
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 13. Package outline SOT762-1 (DHVQFN14)
74AHC_AHCT164_Q100
Product data sheet
15 of 19
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
MIL
Military
TTL
Transistor-Transistor Logic
14. Revision history
Table 11.
Revision history
Document ID
Release date
74AHC_AHCT164_Q100 v.1 20130705
74AHC_AHCT164_Q100
Product data sheet
Data sheet status
Change notice
Supersedes
Product data sheet
16 of 19
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74AHC_AHCT164_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
17 of 19
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHC_AHCT164_Q100
Product data sheet
18 of 19
Nexperia
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 6
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16
Legal information. . . . . . . . . . . . . . . . . . . . . . . 17
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Contact information. . . . . . . . . . . . . . . . . . . . . 18
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Date of release: 05 July 2013
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC164BQ-Q100X 74AHC164PW-Q100J 74AHCT164D-Q100J 74AHC164D-Q100J 74AHCT164BQ-Q100X
74AHCT164PW-Q100J
