74AHC594; 74AHCT594
8-bit shift register with output register
Rev. 02 — 9 June 2008
Product data sheet
1. General description
The 74AHC594; 74AHCT594 is a high-speed Si-gate CMOS device and is pin compatible
with Low-Power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard
No. 7-A.
The 74AHC594; 74AHCT594 is an 8-bit, non-inverting, serial-in, parallel-out shift register
that feeds an 8-bit D-type storage register. Separate clocks (SHCP and STCP) and direct
overriding clears (SHR and STR) are provided on both the shift and storage registers.
A serial output (Q7S) is provided for cascading purposes.
Both the shift and storage register clocks are positive-edge triggered. If the user wishes to
connect both clocks together, the shift register will always be one count pulse ahead of the
storage register.
2. Features
n
n
n
n
n
n
n
n
n
Balanced propagation delays
All inputs have Schmitt-trigger actions
Inputs accept voltages higher than VCC
Wide supply voltage range from 2.0 V to 5.5 V
8-bit serial-in, parallel-out shift register with storage
Independent direct overriding clears on shift and storage registers
Independent clocks for shift and storage registers
Latch-up performance exceeds 100 mA per JESD78 Class II
Input levels:
u For 74AHC594: CMOS level
u For 74AHCT594: TTL level
n ESD protection:
u HBM EIA/JESD22-A114E exceeds 2000 V
u MM EIA/JESD22-A115-A exceeds 200 V
u CDM EIA/JESD22-C101C exceeds 1000 V
n Multiple package options
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
3. Applications
n Serial-to parallel data conversion
n Remote control holding register
74AHC594; 74AHCT594
Nexperia
4. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74AHC594D
−40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74AHC594DB
−40 °C to +125 °C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
74AHC594PW
−40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
74AHC594BQ
−40 °C to +125 °C
DHVQFN16
plastic dual in-line compatible thermal enhanced very SOT763-1
thin quad flat package; no leads; 16 terminals;
body 2.5 × 3.5 × 0.85 mm
74AHCT594D
−40 °C to +125 °C
SO16
body width 3.9 mm
SOT109-1
74AHCT594DB
−40 °C to +125 °C
SSOP16
body width 5.3 mm
SOT338-1
74AHCT594PW
−40 °C to +125 °C
TSSOP16
body width 4.4 mm
SOT403-1
74AHCT594BQ
−40 °C to +125 °C
DHVQFN16
74AHC594
74AHCT594
5. Functional diagram
DS
SHCP
SHR
14
11
8-STAGE SHIFT REGISTER
10
9
STCP
STR
12
13
8-BIT STORAGE REGISTER
15 1
2
3
4
5
6
7
Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7
Fig 1.
Q7S
mbc320
Functional diagram
74AHC_AHCT594_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 22
74AHC594; 74AHCT594
Nexperia
SHCP STCP
STR
11
12
STCP
Q7S
9
DS
SHR
Fig 2.
C2
10
R1 SRG8
11
Q0
1
Q1
2
Q2
3
Q3
2
4
Q4
3
5
Q5
4
6
Q6
7
Q7
SHCP
DS
C1/
14
1D
15
2D
1
5
6
7
13
9
STR
mbc319
Fig 3.
Q1
Q2
Q3
Q4
Q5
Q6
Q7
Q7S
IEC logic symbol
STAGES 1 TO 6
STAGE 0
D
Q0
mbc322
Logic symbol
DS
R2
12
15
14
10
SHR
13
Q
D
STAGE 7
Q
FFSH0
D
Q7S
Q
FFSH7
CP
CP
R
R
SHCP
SHR
D
D
Q
FFST0
Q
FFST7
CP
CP
R
R
STCP
STR
Q0
Fig 4.
Q1 Q2 Q3 Q4 Q5 Q6
Q7
mbc321
Logic diagram
74AHC_AHCT594_2
Product data sheet
3 of 22
74AHC594; 74AHCT594
Nexperia
6. Pinning information
6.1 Pinning
74AHC594
74AHCT594
Q1
1
16 VCC
Q2
2
15 Q0
Q3
3
14 DS
Q4
4
13 STR
Q5
5
12 STCP
Q6
6
11 SHCP
Q7
7
10 SHR
GND
8
9
Q7S
001aae343
Fig 5.
Pin configuration SO16
terminal 1
index area
1
74AHC594
74AHCT594
16 VCC
Q1
74AHC594
74AHCT594
Q2
2
15 Q0
Q3
3
14 DS
2
16 VCC
15 Q0
Q4
4
13 STR
Q3
3
14 DS
Q5
5
Q4
4
13 STR
Q6
6
Q5
5
12 STCP
Q7
7
Q6
6
11 SHCP
Q7
7
10 SHR
GND
8
Q7S
11 SHCP
10 SHR
9
9
12 STCP
GND(1)
Q7S
Q2
8
1
GND
Q1
001aae345
Transparent top view
001aae344
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as
supply pin or input.
Fig 6.
Pin configuration (T)SSOP16
Fig 7.
Pin configuration DHVQFN16
74AHC_AHCT594_2
Product data sheet
4 of 22
74AHC594; 74AHCT594
Nexperia
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
Q1
1
parallel data output
Q2
2
Q3
3
Q4
4
Q5
5
Q6
6
Q7
7
GND
8
ground (0 V)
Q7S
9
serial data output
SHR
10
shift register reset input (active LOW)
SHCP
11
shift register clock input
STCP
12
storage register clock input
STR
13
storage register reset input (active LOW)
DS
14
serial data input
Q0
15
VCC
16
supply voltage
7. Functional description
Function table[1]
Table 3.
Input
Output
Function
SHCP STCP SHR
STR
DS
Q7S
Qn
X
X
X
X
L
NC
X
X
X
L
X
NC
L
a LOW-state on STR only affects the storage register
X
L
H
X
L
L
empty shift register loaded into storage register
X
H
X
H
Q6S
NC
logic HIGH level shifted into shift register stage 0. Contents of all
shift register stages shifted through, e.g. previous state of stage 6
(internal Q6S) appears on the serial output (Q7S).
X
H
H
X
NC
QnS
contents of shift register stages (internal QnS) are transferred to
the storage register and parallel output stages
H
H
X
Q6S
QnS
contents of shift register shifted through; previous contents of the
shift register is transferred to the storage register and the parallel
output stages
[1]
L
a LOW-state on SHR only affects the shift register
H = HIGH voltage state;
L = LOW voltage state;
↑ = LOW to HIGH transition;
X = don’t care;
NC = no change;
74AHC_AHCT594_2
Product data sheet
5 of 22
74AHC594; 74AHCT594
Nexperia
SHCP
DS
STCP
SHR
STR
Q0
Q1
Q6
Q7
Q7S
mbc323
Fig 8.
Timing diagram
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
VI
Conditions
Min
Max
Unit
supply voltage
−0.5
+7.0
V
input voltage
−0.5
+7.0
V
−20
mA
−20
+20
mA
input clamping current
VI < −0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
VO = −0.5 V to (VCC + 0.5 V)
IIK
IO
output current
−25
+25
mA
ICC
supply current
+75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
500
mW
total power dissipation
Ptot
Tamb = −40 °C to +125 °C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO16 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K.
For (T)SSOP16 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
For DHVQFN16 packages: above 60 °C the value of Ptot derates linearly at 4.5 mW/K.
74AHC_AHCT594_2
Product data sheet
6 of 22
74AHC594; 74AHCT594
Nexperia
9. Recommended operating conditions
Table 5.
Operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
74AHC594
VCC
supply voltage
2.0
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
input transition rise and fall rate
VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
74AHCT594
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
ns/V
10. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
74AHC594
VIH
VIL
VOH
VOL
HIGH-level
input voltage
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
LOW-level
input voltage
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
LOW-level
VI = VIH or VIL
output voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8 mA; VCC = 4.5 V
0.36
0.44
0.55
V
74AHC_AHCT594_2
Product data sheet
7 of 22
74AHC594; 74AHCT594
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
Min
Typ
Max
Min
Max
Min
Max
0.1
1.0
2.0
µA
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
4.0
40
80
µA
CI
input
capacitance
3
10
10
10
pF
VI = VCC or GND
74AHCT594
VIH
HIGH-level
input voltage
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL
output voltage
4.4
4.5
4.4
4.4
V
VOL
3.94
3.80
3.70
V
LOW-level
VI = VIH or VIL
output voltage
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
VCC = 5.5 V
4.0
40
80
µA
∆ICC
additional
per input pin;
supply current VI = VCC − 2.1 V; other pins
at VCC or GND; IO = 0 A;
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
10
10
pF
VI = VCC or GND
11. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 15.
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
5.2
8.5
2.2
9.7
2.2
10.6
ns
7.4
11.5
3.0
13.2
3.0
14.3
ns
CL = 15 pF
3.8
6.3
1.7
7.2
1.7
7.8
ns
CL = 50 pF
4.8
8.0
2.4
9.1
2.4
10.0
ns
74AHC594
tPLH
LOW to HIGH SHCP to Q7S; see Figure 9
propagation
delay
CL = 15 pF
CL = 50 pF
74AHC_AHCT594_2
Product data sheet
8 of 22
74AHC594; 74AHCT594
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
5.1
8.3
2.3
9.5
2.3
10.6
ns
CL = 50 pF
7.3
11.9
3.3
13.6
3.3
14.7
ns
CL = 15 pF
3.5
5.7
1.8
6.5
1.8
7.1
ns
CL = 50 pF
4.8
7.8
2.6
9.0
2.6
9.8
ns
5.5
8.9
2.3
10.2
2.3
11.0
ns
7.4
12.1
3.0
13.9
3.0
15.1
ns
CL = 15 pF
4.1
6.7
1.9
7.6
1.9
8.2
ns
CL = 50 pF
5.4
8.8
2.5
10.1
2.5
11.0
ns
CL = 15 pF
5.5
9.1
2.4
10.4
2.4
11.3
ns
CL = 50 pF
7.3
12.0
3.2
13.8
3.2
15.0
ns
CL = 15 pF
3.7
6.0
1.9
6.9
1.9
7.5
ns
CL = 50 pF
5.2
8.5
2.6
9.7
2.6
10.5
ns
CL = 15 pF
5.7
9.5
2.3
10.8
2.3
11.7
ns
CL = 50 pF
7.5
12.2
3.6
14.0
3.6
15.2
ns
CL = 15 pF
4.1
6.7
2.0
7.6
2.0
8.2
ns
CL = 50 pF
5.4
8.8
2.8
10.1
2.8
11.0
ns
CL = 15 pF
5.8
9.6
2.8
11.0
2.8
12.0
ns
CL = 50 pF
7.7
12.5
3.8
14.4
3.8
15.6
ns
CL = 15 pF
4.1
7.2
2.2
8.2
2.2
8.9
ns
CL = 50 pF
5.4
9.4
3.0
10.7
3.0
11.6
ns
80
125
70
65
MHz
90
170
80
70
MHz
STCP to Qn; see Figure 10
tPHL
HIGH to LOW SHCP to Q7S; see Figure 9
propagation
delay
CL = 15 pF
CL = 50 pF
SHR to Q7S; see Figure 13
STR to Qn; see Figure 14
fmax
maximum
frequency
SHCP or STCP;
see Figure 9 and 10
74AHC_AHCT594_2
Product data sheet
9 of 22
74AHC594; 74AHCT594
Nexperia
Table 7.
Symbol Parameter
tW
pulse width
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
6.0
6.5
7.0
ns
5.5
6.0
6.5
ns
5.0
5.0
5.5
ns
5.0
5.2
5.7
ns
3.5
3.5
4.0
ns
3.0
3.0
3.5
ns
8.0
9.0
9.5
ns
5.0
5.0
5.5
ns
8.0
8.5
9.0
ns
5.0
5.0
5.5
ns
1.5
1.5
2.0
ns
2.0
2.0
2.5
ns
4.2
4.8
5.3
ns
2.9
3.3
3.8
ns
4.6
5.3
5.8
ns
SHCP and STCP HIGH or
LOW; see Figure 9 and 10
SHR and STR HIGH or LOW;
see Figure 13 and 14
tsu
set-up time
DS to SHCP; see Figure 11
SHR to STCP; see Figure 12
SHCP to STCP; see Figure 10
th
trec
hold time
recovery time SHR to SHCP; see Figure 13
STR to STCP; see Figure 14
CPD
power
dissipation
capacitance
3.2
3.7
4.3
ns
55
pF
3.8
6.3
1.7
7.2
1.7
7.8
ns
4.8
8.0
2.2
9.1
2.2
9.9
ns
CL = 15 pF
3.5
5.7
1.8
6.5
1.8
7.1
ns
CL = 50 pF
4.6
7.7
2.6
8.8
2.6
9.6
ns
fi = 1 MHz; VI = GND to VCC
[2]
74AHCT594; VCC = 4.5 V to 5.5 V
tPLH
propagation
CL = 15 pF
delay
CL = 50 pF
74AHC_AHCT594_2
Product data sheet
10 of 22
74AHC594; 74AHCT594
Nexperia
Table 7.
Symbol Parameter
tPHL
25 °C
Conditions
Min
Typ[1]
Max
Min
4.1
6.7
5.4
8.8
CL = 15 pF
3.7
CL = 50 pF
CL = 15 pF
CL = 50 pF
Max
Min
1.8
7.6
1.8
8.3
ns
2.4
10.1
2.4
11.0
ns
6.1
1.9
6.9
1.9
7.2
ns
5.2
8.5
2.6
9.7
2.6
10.5
ns
4.3
7.0
2.4
8.0
2.4
8.7
ns
5.4
8.8
2.7
10.1
2.7
11.0
ns
CL = 15 pF
4.5
7.4
2.3
8.4
2.3
9.2
ns
CL = 50 pF
5.7
9.4
3.1
10.7
3.1
11.7
ns
propagation
CL = 15 pF
delay
CL = 50 pF
Max
fmax
maximum
frequency
SHCP or STCP;
see Figure 9 and 10
90
160
80
70
MHz
tW
pulse width
5.5
6.0
6.5
ns
5.2
5.5
6.0
ns
3.0
3.0
3.5
ns
5.0
5.0
5.5
ns
5.0
5.0
5.5
ns
2.0
2.0
2.5
ns
2.9
3.3
3.8
ns
3.4
3.8
4.3
ns
55
pF
tsu
set-up time
th
hold time
trec
CPD
power
dissipation
capacitance
[2]
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
74AHC_AHCT594_2
Product data sheet
11 of 22
74AHC594; 74AHCT594
Nexperia
12. Waveforms
1/fmax
SHCP input
VM
tW
tPLH
Q7S output
tPHL
VM
tTLH
tTHL
001aae341
Measurement points are given in Table 8.
Fig 9.
Shift register clock pulse width, maximum frequency and input to output propagation delays
SHCP input
VM
tsu
STCP input
1/fmax
VM
tW
tPHL
tPLH
Qn outputs
VM
mla512
Fig 10. Shift register clock to storage register clock set-up time and storage clock pulse width, maximum
74AHC_AHCT594_2
Product data sheet
12 of 22
74AHC594; 74AHCT594
Nexperia
VM
SHCP input
t su
t su
th
th
VM
DS input
VM
Q7 output
001aae342
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig 11. Shift register clock to data input set-up and hold times
STR input
VM
tW
trec
VM
STCP input
tPHL
Qn outputs
VM
mbc325
Fig 12. Storage register reset pulse width, input to output propagation delay and recovery time
74AHC_AHCT594_2
Product data sheet
13 of 22
74AHC594; 74AHCT594
Nexperia
VM
SHR input
tW
trec
VM
SHCP input
tPHL
VM
Q7S output
mbc324
Fig 13. Shift register reset pulse width, input to output propagation delay and recovery time
VM
SHR input
tsu
VM
STCP input
VM
Qn outputs
mbc326
Fig 14. Shift register reset to storage register clock set-up time
Table 8.
Measurement points
Type
Input
Output
VM
VM
74AHC594
0.5 × VCC
0.5 × VCC
74AHCT594
1.5 V
0.5 × VCC
74AHC_AHCT594_2
Product data sheet
14 of 22
74AHC594; 74AHCT594
Nexperia
VI
negative
pulse
tW
90 %
VM
VM
10 %
GND
tr
tf
tr
VI
positive
pulse
GND
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VO
DUT
RT
CL
001aah768
For test data see Table 9.
Definitions for test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
Fig 15. Load circuitry for measuring switching times
Table 9.
Test data
Type
Input
Load
Test
VI
tr, tf
CL
74AHC594
VCC
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHCT594
3.0 V
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHC_AHCT594_2
Product data sheet
15 of 22
74AHC594; 74AHCT594
Nexperia
13. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
detail X
w M
bp
2.5
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.16
0.15
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 16. Package outline SOT109-1 (SO16)
74AHC_AHCT594_2
Product data sheet
16 of 22
74AHC594; 74AHCT594
Nexperia
SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm
D
SOT338-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
8
1
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
6.4
6.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
1.00
0.55
8o
o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT338-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig 17. Package outline SOT338-1 (SSOP16)
74AHC_AHCT594_2
Product data sheet
17 of 22
74AHC594; 74AHCT594
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
E
D
A
X
c
y
HE
v M A
Z
9
16
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
8
e
detail X
w M
bp
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 18. Package outline SOT403-1 (TSSOP16)
74AHC_AHCT594_2
Product data sheet
18 of 22
74AHC594; 74AHCT594
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
7
y
y1 C
v M C A B
w M C
b
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
mm
c
D (1)
Dh
E (1)
Eh
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 19. Package outline SOT763-1 (DHVQFN16)
74AHC_AHCT594_2
Product data sheet
19 of 22
74AHC594; 74AHCT594
Nexperia
14. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
15. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT594_2
20080609
Product data sheet
74AHC_AHCT594_1
Modifications:
74AHC_AHCT594_1
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Table 6: the conditions for input leakage current have been changed.
20060704
Product data sheet
74AHC_AHCT594_2
Product data sheet
20 of 22
74AHC594; 74AHCT594
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
16.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHC_AHCT594_2
Product data sheet
21 of 22
Nexperia
74AHC594; 74AHCT594
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6
Recommended operating conditions. . . . . . . . 7
Static characteristics. . . . . . . . . . . . . . . . . . . . . 7
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 16
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 20
Legal information. . . . . . . . . . . . . . . . . . . . . . . 21
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 21
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Contact information. . . . . . . . . . . . . . . . . . . . . 21
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
Date of release: 09 June 2008
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC594BQ,115 74AHC594D,112 74AHC594DB,112 74AHC594DB,118 74AHC594D,118 74AHC594PW,112
74AHC594PW,118 74AHCT594BQ,115 74AHCT594D,112 74AHCT594DB,112 74AHCT594DB,118
74AHCT594D,118 74AHCT594PW,112 74AHCT594PW,118
