74AHCT594PW-Q100,1
74AHCT594PW-Q100,1
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    带输出寄存器的8位移位寄存器 TSSOP16_5X4.4MM 4.5~5.5V
74AHCT594PW-Q100,1 数据手册
74AHC594-Q100; 74AHCT594-Q100 8-bit shift register with output register Rev. 2 — 4 July 2013 Product data sheet 1. General description The 74AHC594-Q100; 74AHCT594-Q100 is a high-speed Si-gate CMOS device and is pin compatible with Low-Power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard No. 7A. The 74AHC594-Q100; 74AHCT594-Q100 is an 8-bit, non-inverting, serial-in, parallel-out shift register that feeds an 8-bit D-type storage register. Separate clocks (SHCP and STCP) and direct overriding clears (SHR and STR) are provided on both the shift and storage registers. A serial output (Q7S) is provided for cascading purposes. Both the shift and storage register clocks are positive-edge triggered. If the user wishes to connect both clocks together, the shift register is always one count pulse ahead of the storage register. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Balanced propagation delays  All inputs have Schmitt trigger actions  Inputs accept voltages higher than VCC  Wide supply voltage range from 2.0 V to 5.5 V  8-bit serial-in, parallel-out shift register with storage  Independent direct overriding clears on shift and storage registers  Independent clocks for shift and storage registers  Latch-up performance exceeds 100 mA per JESD78 Class II  Input levels:  For 74AHC594-Q100: CMOS level  For 74AHCT594-Q100: TTL level  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 )  Multiple package options 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register 3. Applications  Serial-to parallel data conversion  Remote control holding register 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AHC594D-Q100 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74AHC594DB-Q100 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74AHC594PW-Q100 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74AHC594BQ-Q100 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal enhanced SOT763-1 very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74AHCT594DB-Q100 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74AHCT594PW-Q100 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74AHCT594BQ-Q100 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal enhanced SOT763-1 very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm 74AHC594-Q100 74AHCT594-Q100 74AHCT594D-Q100 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 2 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register 5. Functional diagram 14 DS 11 SHCP 8-STAGE SHIFT REGISTER 10 SHR 9 12 STCP 13 STR 8-BIT STORAGE REGISTER 15 1 2 3 4 5 6 7 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 Fig 1. Q7S mbc320 Functional diagram SHCP STCP STR 11 12 STCP 9 DS SHR Fig 2. Logic symbol 74AHC_AHCT594_Q100 Product data sheet SHR R2 12 10 C2 R1 SRG8 11 15 Q0 1 Q1 2 Q2 3 Q3 2 4 Q4 3 5 Q5 4 6 Q6 7 Q7 14 10 Q7S 13 SHCP DS 14 C1/ 1D 15 2D 1 5 6 7 13 STR 9 mbc319 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 Q7S mbc322 Fig 3. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 3 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register STAGES 1 TO 6 STAGE 0 DS D Q STAGE 7 D Q D FFSH0 Q7S Q FFSH7 CP CP R R SHCP SHR D D Q FFST0 Q FFST7 CP CP R R STCP STR Q0 Fig 4. Q1 Q2 Q3 Q4 Q5 Q6 Q7 mbc321 Logic diagram 6. Pinning information 6.1 Pinning $+&4 $+&74 4   9&& 4   4 4   '6 4   675 4   67&3 4   6+&3 4   6+5 *1'   46 DDD Fig 5. Pin configuration SO16 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 4 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register WHUPLQDO LQGH[DUHD  $+&4 $+&74  9&& 4 $+&4 $+&74 4   4 4   9&& 4   '6 4   4 4   675 4   '6 4   67&3 4   675 4  4   67&3  4   6+&3 4 4   6+5 *1'    46 46  6+&3  6+5 *1'  *1'  DDD 7UDQVSDUHQWWRSYLHZ DDD (1) The die substrate is attached to this pad using conductive die attach material. It cannot be used as supply pin or input. Fig 6. Pin configuration (T)SSOP16 Fig 7. Pin configuration DHVQFN16 6.2 Pin description Table 2. Pin description Symbol Pin Description Q1 1 parallel data output Q2 2 parallel data output Q3 3 parallel data output Q4 4 parallel data output Q5 5 parallel data output Q6 6 parallel data output Q7 7 parallel data output GND 8 ground (0 V) Q7S 9 serial data output SHR 10 shift register reset input (active LOW) SHCP 11 shift register clock input STCP 12 storage register clock input STR 13 storage register reset input (active LOW) DS 14 serial data input Q0 15 parallel data output VCC 16 supply voltage 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 5 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register 7. Functional description Function table[1] Table 3. Input Output Function SHCP STCP SHR STR DS Q7S Qn X X X L NC X L a LOW-state on SHR only affects the shift register X X X L X NC L a LOW-state on STR only affects the storage register X  L H X L L empty shift register loaded into storage register  X H X H Q6S NC logic HIGH level shifted into shift register stage 0. Contents of all shift register stages shifted through, e.g. previous state of stage 6 (internal Q6S) appears on the serial output (Q7S). X  H H X NC QnS contents of shift register stages (internal QnS) are transferred to the storage register and parallel output stages   H H X Q6S QnS contents of shift register shifted through; previous contents of the shift register is transferred to the storage register and the parallel output stages [1] H = HIGH voltage state; L = LOW voltage state;  = LOW to HIGH transition; X = don’t care; NC = no change; SHCP DS STCP SHR STR Q0 Q1 Q6 Q7 Q7S mbc323 Fig 8. Timing diagram 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 6 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage VI input voltage IIK input clamping current VI < 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current VO = 0.5 V to (VCC + 0.5 V) Min Max Unit 0.5 +7.0 V 0.5 +7.0 V 20 - mA 20 +20 mA 25 +25 mA ICC supply current - +75 mA IGND ground current 75 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot Tamb = 40 C to +125 C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO16 packages: above 70 C the value of Ptot derates linearly at 8 mW/K. For (T)SSOP16 packages: above 60 C the value of Ptot derates linearly at 5.5 mW/K. For DHVQFN16 packages: above 60 C the value of Ptot derates linearly at 4.5 mW/K. 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 7 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register 9. Recommended operating conditions Table 5. Operating conditions Symbol Parameter Conditions Min Typ Max Unit 2.0 5.0 5.5 V 74AHC594-Q100 VCC supply voltage VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C t/V input transition rise and fall rate VCC = 3.0 V to 3.6 V - - 100 ns/V VCC = 4.5 V to 5.5 V - - 20 ns/V 74AHCT594-Q100 VCC supply voltage 4.5 5.0 5.5 V VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C t/V input transition rise and fall rate - - 20 ns/V VCC = 4.5 V to 5.5 V 10. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 50 A; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = 50 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = 8.0 mA; VCC = 4.5 V 3.94 - - 3.80 - 3.70 - V LOW-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V 74AHC594-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 8 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions VI = 5.5 V or GND; VCC = 0 V to 5.5 V 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - - 0.1 - 1.0 - 2.0 A II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 A CI input capacitance - 3 10 - 10 - 10 pF VI = VCC or GND 74AHCT594-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL output voltage IO = 50 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 8.0 mA; VCC = 4.5 V VOL 3.94 - - 3.80 - 3.70 - V LOW-level VI = VIH or VIL output voltage IO = 50 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 8 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 A II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 A ICC additional per input pin; supply current VI = VCC  2.1 V; other pins at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3 10 - 10 - 10 pF VI = VCC or GND 11. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 15. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max - 5.2 8.5 2.2 9.7 2.2 10.6 ns - 7.4 11.5 3.0 13.2 3.0 14.3 ns CL = 15 pF - 3.8 6.3 1.7 7.2 1.7 7.8 ns CL = 50 pF - 4.8 8.0 2.4 9.1 2.4 10.0 ns 74AHC594-Q100 tPLH LOW to HIGH SHCP to Q7S; see Figure 9 propagation VCC = 3.0 V to 3.6 V delay CL = 15 pF CL = 50 pF VCC = 4.5 V to 5.5 V 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 9 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 15. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max CL = 15 pF - 5.1 8.3 2.3 9.5 2.3 10.6 ns CL = 50 pF - 7.3 11.9 3.3 13.6 3.3 14.7 ns CL = 15 pF - 3.5 5.7 1.8 6.5 1.8 7.1 ns CL = 50 pF - 4.8 7.8 2.6 9.0 2.6 9.8 ns STCP to Qn; see Figure 10 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V tPHL HIGH to LOW SHCP to Q7S; see Figure 9 propagation VCC = 3.0 V to 3.6 V delay CL = 15 pF - 5.5 8.9 2.3 10.2 2.3 11.0 ns - 7.4 12.1 3.0 13.9 3.0 15.1 ns CL = 15 pF - 4.1 6.7 1.9 7.6 1.9 8.2 ns CL = 50 pF - 5.4 8.8 2.5 10.1 2.5 11.0 ns CL = 15 pF - 5.5 9.1 2.4 10.4 2.4 11.3 ns CL = 50 pF - 7.3 12.0 3.2 13.8 3.2 15.0 ns CL = 15 pF - 3.7 6.0 1.9 6.9 1.9 7.5 ns CL = 50 pF - 5.2 8.5 2.6 9.7 2.6 10.5 ns CL = 15 pF - 5.7 9.5 2.3 10.8 2.3 11.7 ns CL = 50 pF - 7.5 12.2 3.6 14.0 3.6 15.2 ns CL = 15 pF - 4.1 6.7 2.0 7.6 2.0 8.2 ns CL = 50 pF - 5.4 8.8 2.8 10.1 2.8 11.0 ns CL = 15 pF - 5.8 9.6 2.8 11.0 2.8 12.0 ns CL = 50 pF - 7.7 12.5 3.8 14.4 3.8 15.6 ns CL = 50 pF VCC = 4.5 V to 5.5 V STCP to Qn; see Figure 10 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V SHR to Q7S; see Figure 13 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V STR to Qn; see Figure 14 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V fmax maximum frequency 74AHC_AHCT594_Q100 Product data sheet CL = 15 pF - 4.1 7.2 2.2 8.2 2.2 8.9 ns CL = 50 pF - 5.4 9.4 3.0 10.7 3.0 11.6 ns VCC = 3.0 V to 3.6 V 80 125 - 70 - 65 - MHz VCC = 4.5 V to 5.5 V 90 170 - 80 - 70 - MHz SHCP or STCP; see Figure 9 and Figure 10 All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 10 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 15. Symbol Parameter tW pulse width 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max VCC = 3.0 V to 3.6 V 6.0 - - 6.5 - 7.0 - ns VCC = 4.5 V to 5.5 V 5.5 - - 6.0 - 6.5 - ns VCC = 3.0 V to 3.6 V 5.0 - - 5.0 - 5.5 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.2 - 5.7 - ns VCC = 3.0 V to 3.6 V 3.5 - - 3.5 - 4.0 - ns VCC = 4.5 V to 5.5 V 3.0 - - 3.0 - 3.5 - ns VCC = 3.0 V to 3.6 V 8.0 - - 9.0 - 9.5 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.5 - ns VCC = 3.0 V to 3.6 V 8.0 - - 8.5 - 9.0 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.5 - ns VCC = 3.0 V to 3.6 V 1.5 - - 1.5 - 2.0 - ns VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.5 - ns VCC = 3.0 V to 3.6 V 4.2 - - 4.8 - 5.3 - ns VCC = 4.5 V to 5.5 V 2.9 - - 3.3 - 3.8 - ns VCC = 3.0 V to 3.6 V 4.6 - - 5.3 - 5.8 - ns VCC = 4.5 V to 5.5 V 3.2 - - 3.7 - 4.3 - ns - 55 - - - - - pF - 3.8 6.3 1.7 7.2 1.7 7.8 ns - 4.8 8.0 2.2 9.1 2.2 9.9 ns CL = 15 pF - 3.5 5.7 1.8 6.5 1.8 7.1 ns CL = 50 pF - 4.6 7.7 2.6 8.8 2.6 9.6 ns SHCP and STCP HIGH or LOW; see Figure 9 and Figure 10 SHR and STR HIGH or LOW; see Figure 13 and Figure 14 tsu set-up time DS to SHCP; see Figure 11 SHR to STCP; see Figure 12 SHCP to STCP; see Figure 10 th trec hold time DS to SHCP; see Figure 11 recovery time SHR to SHCP; see Figure 13 STR to STCP; see Figure 14 CPD power dissipation capacitance fi = 1 MHz; VI = GND to VCC [2] 74AHCT594-Q100; VCC = 4.5 V to 5.5 V tPLH LOW to HIGH SHCP to Q7S; see Figure 9 propagation CL = 15 pF delay CL = 50 pF STCP to Qn; see Figure 10 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 11 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 15. Symbol Parameter 25 C Conditions Min tPHL HIGH to LOW SHCP to Q7S; see Figure 9 propagation CL = 15 pF delay CL = 50 pF Typ[1] 40 C to +85 C 40 C to +125 C Unit Max Min Max Min Max - 4.1 6.7 1.8 7.6 1.8 8.3 ns - 5.4 8.8 2.4 10.1 2.4 11.0 ns CL = 15 pF - 3.7 6.1 1.9 6.9 1.9 7.2 ns CL = 50 pF - 5.2 8.5 2.6 9.7 2.6 10.5 ns CL = 15 pF - 4.3 7.0 2.4 8.0 2.4 8.7 ns CL = 50 pF - 5.4 8.8 2.7 10.1 2.7 11.0 ns CL = 15 pF - 4.5 7.4 2.3 8.4 2.3 9.2 ns CL = 50 pF - 5.7 9.4 3.1 10.7 3.1 11.7 ns STCP to Qn; see Figure 10 SHR to Q7S; see Figure 13 STR to Qn; see Figure 14 fmax maximum frequency SHCP or STCP; see Figure 9 and Figure 10 90 160 - 80 - 70 - MHz tW pulse width SHCP and STCP HIGH or LOW; see Figure 9 and Figure 10 5.5 - - 6.0 - 6.5 - ns SHR and STR HIGH or LOW; see Figure 13 and Figure 14 5.2 - - 5.5 - 6.0 - ns DS to SHCP; see Figure 11 3.0 - - 3.0 - 3.5 - ns SHR to STCP; see Figure 12 5.0 - - 5.0 - 5.5 - ns SHCP to STCP; see Figure 10 5.0 - - 5.0 - 5.5 - ns DS to SHCP; see Figure 11 2.0 - - 2.0 - 2.5 - ns 2.9 - - 3.3 - 3.8 - ns 3.4 - - 3.8 - 4.3 - ns - 55 - - - - - pF tsu set-up time th hold time trec recovery time SHR to SHCP; see Figure 13 STR to STCP; see Figure 14 CPD power dissipation capacitance fi = 1 MHz; VI = GND to VCC [2] [1] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [2] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 12 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register 12. Waveforms 1/fmax SHCP input VM tW tPLH Q7S output tPHL VM tTLH tTHL 001aae341 Measurement points are given in Table 8. Fig 9. Shift register clock pulse width, maximum frequency and input to output propagation delays SHCP input VM tsu 1/fmax VM STCP input tW tPHL tPLH Qn outputs VM mla512 Measurement points are given in Table 8. Fig 10. Shift register clock to storage register clock set-up time and storage clock pulse width, maximum frequency and input to output propagation delays 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 13 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register VM SHCP input t su t su th th VM DS input VM Q7 output 001aae342 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig 11. Shift register clock to data input set-up and hold times STR input VM tW trec VM STCP input tPHL Qn outputs VM mbc325 Measurement points are given in Table 8. Fig 12. Storage register reset pulse width, input to output propagation delay and recovery time 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 14 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register SHR input VM tW trec VM SHCP input tPHL VM Q7S output mbc324 Measurement points are given in Table 8. Fig 13. Shift register reset pulse width, input to output propagation delay and recovery time SHR input VM tsu STCP input Qn outputs VM VM mbc326 Measurement points are given in Table 8. Fig 14. Shift register reset to storage register clock set-up time Table 8. Measurement points Type Input Output VM VM 74AHC594-Q100 0.5  VCC 0.5  VCC 74AHCT594-Q100 1.5 V 0.5  VCC 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 15 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register VI negative pulse tW 90 % VM VM 10 % GND tr tf tr VI positive pulse GND tf 90 % VM VM 10 % tW VCC G VI VO DUT RT CL 001aah768 For test data, see Table 9. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Fig 15. Load circuitry for measuring switching times Table 9. Test data Type Input Load Test VI tr, tf CL 74AHC594-Q100 VCC  3.0 ns 15 pF, 50 pF tPLH, tPHL 74AHCT594-Q100 3.0 V  3.0 ns 15 pF, 50 pF tPLH, tPHL 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 16 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register 13. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 16. Package outline SOT109-1 (SO16) 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 17 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o o 0 Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig 17. Package outline SOT338-1 (SSOP16) 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 18 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 E D A X c y HE v M A Z 9 16 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 8 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 18. Package outline SOT403-1 (TSSOP16) 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 19 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 7 y y1 C v M C A B w M C b L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A(1) max. A1 b 1 0.05 0.00 0.30 0.18 c D (1) Dh E (1) Eh 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 19. Package outline SOT763-1 (DHVQFN16) 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 20 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register 14. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MM Machine Model MIL Military 15. Revision history Table 11. Revision history Document ID Release date 74AHC_AHCT594_Q100 v.2 20130704 Modifications: • Product data sheet Change notice Supersedes Product data sheet - 74AHC_AHCT594_Q100 v.1 74AHC594DB-Q100 and 74AHCT594DB-Q100 added. 74AHC_AHCT594_Q100 v.1 20120712 74AHC_AHCT594_Q100 Data sheet status Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 - © Nexperia B.V. 2017. All rights reserved 21 of 24 74AHC594-Q100; 74AHCT594-Q100 Nexperia 8-bit shift register with output register 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AHC_AHCT594_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 22 of 24 Nexperia 74AHC594-Q100; 74AHCT594-Q100 8-bit shift register with output register No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AHC_AHCT594_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 23 of 24 Nexperia 74AHC594-Q100; 74AHCT594-Q100 8-bit shift register with output register 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 3 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5 Functional description . . . . . . . . . . . . . . . . . . . 6 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 7 Recommended operating conditions. . . . . . . . 8 Static characteristics. . . . . . . . . . . . . . . . . . . . . 8 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 17 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 21 Legal information. . . . . . . . . . . . . . . . . . . . . . . 22 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 22 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Contact information. . . . . . . . . . . . . . . . . . . . . 23 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 04 July 2013 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AHC594D-Q100,118 74AHCT594D-Q100,11 74AHCT594BQ-Q100,1 74AHC594BQ-Q100,11 74AHC594PWQ100,11 74AHCT594PW-Q100,1 74AHC594DB-Q100J 74AHCT594DB-Q100J
74AHCT594PW-Q100,1
物料型号:74AHC_AHCT594 器件简介:74AHC_AHCT594 是一款高速CMOS双4线到16线译码器,具有三个使能输入和三个输出使能。
引脚分配:该芯片共有20个引脚,包括供电、地、输入、输出和使能引脚。
参数特性:工作电压范围为2.0V至5.5V,工作温度范围为-40℃至+125℃。
功能详解:该芯片具有双4线到16线译码器功能,可以用于扩展输入信号。
应用信息:适用于高速数据选择和扩展,例如在通信、计算机和工业控制系统中。
封装信息:有QFN和SOIC两种封装形式,具体引脚图和尺寸信息需参考PDF文档。
74AHCT594PW-Q100,1 价格&库存
很抱歉,暂时无法提供与“74AHCT594PW-Q100,1”相匹配的价格&库存,您可以联系我们找货
74AHCT594PW-Q100,1
  • 2500+1.918532500+0.24057
库存:2148
74AHCT594PW-Q100,1
  • 1+5.076221+0.63652
  • 10+3.5904510+0.45021
  • 25+3.2165725+0.40333
  • 100+2.80136100+0.35127
  • 250+2.60301250+0.32640
  • 500+2.48388500+0.31146
  • 1000+2.419051000+0.30333
库存:2148
