74HC164; 74HCT164
8-bit serial-in, parallel-out shift register
Rev. 8 — 19 November 2015
Product data sheet
1. General description
The 74HC164; 74HCT164 is an 8-bit serial-in/parallel-out shift register. The device
features two serial data inputs (DSA and DSB), eight parallel data outputs (Q0 to Q7).
Data is entered serially through DSA or DSB and either input can be used as an active
HIGH enable for data entry through the other input. Data is shifted on the LOW-to-HIGH
transitions of the clock (CP) input. A LOW on the master reset input (MR) clears the
register and forces all outputs LOW, independently of other inputs. Inputs include clamp
diodes. This enables the use of current limiting resistors to interface inputs to voltages in
excess of VCC.
2. Features and benefits
Input levels:
For 74HC164: CMOS level
For 74HCT164: TTL level
Gated serial data inputs
Asynchronous master reset
Complies with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V.
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C.
74HC164; 74HCT164
Nexperia
3. Ordering information
Table 1.
Type number
74HC164D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
40 C to +125 C
SSOP14
plastic shrink small outline package; 14 leads; body
width 5.3 mm
SOT337-1
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
40 C to +125 C
DHVQFN14
plastic dual in-line compatible thermal enhanced very SOT762-1
thin quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
74HCT164D
74HC164DB
74HCT164DB
74HC164PW
74HCT164PW
74HC164BQ
74HCT164BQ
4. Functional diagram
65*
5
'6$
'6%
&3
05
4
4
4
4
4
4
4
4
DDF
DDF
Fig 1.
Logic symbol
Fig 2.
'6$
'6%
&3
05
IEC logic symbol
%,76(5,$/ ,13$5$//(/ 287
6+,)75(*,67(5
4 4 4 4 4 4 4 4
DDF
Fig 3.
Logic diagram
74HC_HCT164
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 19
74HC164; 74HCT164
Nexperia
'6$
4
&3
5'
'6%
4
&3
5'
4
&3
5'
4
&3
5'
4
&3
5'
4
&3
5'
4
&3
5'
4
&3
5'
&3
05
4
4
4
4
4
4
4
4
DDF
Fig 4.
Functional diagram
5. Pinning information
5.1 Pinning
WHUPLQDO
LQGH[DUHD
+&7
9&&
'6$
+&7
'6%
4
'6$
9&&
4
4
'6%
4
4
4
4
4
4
4
4
4
4
4
4
05
*1'
&3
*1'
4
*1'
&3
05
DDO
7UDQVSDUHQWWRSYLHZ
DDO
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 5.
Pin configuration SO14, (T)SSOP14
74HC_HCT164
Product data sheet
Fig 6.
Pin configuration DHVQFN14
3 of 19
74HC164; 74HCT164
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
DSA
1
data input
DSB
2
data input
Q0 to Q7
3, 4, 5, 6, 10, 11, 12, 13
output
GND
7
ground (0 V)
CP
8
clock input (LOW-to-HIGH, edge-triggered)
MR
9
master reset input (active LOW)
VCC
14
positive supply voltage
6. Functional description
Table 3.
Function table[1]
Operating
modes
Input
MR
CP
DSA
DSB
Q0
Q1 to Q7
Reset (clear)
L
X
X
X
L
L to L
Shift
H
l
l
L
q0 to q6
H
l
h
L
q0 to q6
H
h
l
L
q0 to q6
H
h
h
H
q0 to q6
[1]
Output
H = HIGH voltage level
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition
L = LOW voltage level
I = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition
q = lower case letters indicate the state of the referenced input one set-up time prior to the LOW-to-HIGH clock transition
= LOW-to-HIGH clock transition
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
0.5
+7
V
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
mA
IO
output current
0.5 V < VO < VCC + 0.5 V
25
mA
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
74HC_HCT164
Product data sheet
4 of 19
74HC164; 74HCT164
Nexperia
Table 4.
Limiting values …continued
Symbol
Ptot
Parameter
Conditions
total power dissipation
Min
Max
Unit
500
mW
[2]
SO14, (T)SSOP14 and DHVQFN14
packages
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 package: Ptot derates linearly with 8 mW/K above 70 C.
For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 C.
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74HC164
Min
Typ
74HCT164
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
t/V
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
74HC164
VIH
VIL
VOH
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
74HC_HCT164
Product data sheet
VI = VIH or VIL
5 of 19
74HC164; 74HCT164
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
VOL
LOW-level
output voltage
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
VI = VIH or VIL
0.16
0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
0.1
1
1
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
A
CI
input
capacitance
3.5
pF
74HCT164
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = 20 A
4.4
4.5
4.4
4.4
V
IO = 4.0 mA
3.98
4.32
3.84
3.7
V
VOL
LOW-level
output voltage
0.1
0.1
V
0.15
0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
0.1
1
1
A
ICC
supply current
VCC = 6.0 V
8
80
160
A
ICC
additional
supply current
per input pin;
VI = VCC 2.1 V; IO = 0 A;
other inputs at VCC or GND;
100
360
450
490
A
CI
input
capacitance
3.5
pF
74HC_HCT164
Product data sheet
6 of 19
74HC164; 74HCT164
Nexperia
10. Dynamic characteristics
Table 7.
GND = 0 V; tr = tf = 6 ns; CL = 50 pF; test circuit see Figure 10; unless otherwise specified
Symbol Parameter
25 C
Conditions
Min
40 C to +85 C
Typ Max
40 C to +125 C Unit
Min
Max
Min
Max
74HC164
tpd
tPHL
propagation
delay
HIGH to LOW
propagation
delay
CP to Qn; see Figure 7
[1]
VCC = 2.0 V
41
170
215
255
ns
VCC = 4.5 V
15
34
43
51
ns
VCC = 5.0 V; CL = 15 pF
12
ns
VCC = 6.0 V
12
29
37
43
ns
VCC = 2.0 V
39
140
175
210
ns
VCC = 4.5 V
14
28
35
42
ns
11
ns
11
24
30
36
ns
MR to Qn; see Figure 8
VCC = 6.0 V
tt
tW
transition time
pulse width
[2]
see Figure 7
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
VCC = 2.0 V
80
14
100
120
ns
VCC = 4.5 V
16
5
ns
VCC = 6.0 V
14
4
17
ns
VCC = 2.0 V
60
17
75
90
ns
VCC = 4.5 V
12
6
15
18
ns
VCC = 6.0 V
10
5
13
15
ns
VCC = 2.0 V
60
17
75
90
ns
VCC = 4.5 V
12
6
15
18
ns
VCC = 6.0 V
10
5
13
15
ns
VCC = 2.0 V
60
8
75
90
ns
VCC = 4.5 V
12
3
15
18
ns
VCC = 6.0 V
10
2
13
15
ns
VCC = 2.0 V
+4
6
4
4
ns
VCC = 4.5 V
+4
2
4
4
ns
VCC = 6.0 V
+4
2
4
4
ns
CP HIGH or LOW;
see Figure 7
MR LOW; see Figure 8
trec
tsu
th
recovery time
set-up time
hold time
74HC_HCT164
Product data sheet
MR to CP; see Figure 8
DSA, and DSB to CP;
see Figure 9
DSA, and DSB to CP;
see Figure 9
7 of 19
74HC164; 74HCT164
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
25 C
Conditions
Min
fmax
maximum
frequency
Min
Max
Min
Max
VCC = 2.0 V
6
23
5
4
MHz
VCC = 4.5 V
30
71
24
MHz
78
MHz
35
85
28
24
MHz
40
pF
VCC = 4.5 V
17
36
45
54
ns
14
ns
VCC = 4.5 V
19
38
48
57
ns
16
ns
7
15
19
22
ns
18
7
23
27
ns
18
10
23
27
ns
16
7
ns
12
6
15
18
ns
+4
2
4
4
ns
27
55
22
18
MHz
61
MHz
VCC = 6.0 V
power
dissipation
capacitance
Typ Max
40 C to +125 C Unit
for Cp, see Figure 7
CPD
40 C to +85 C
per package;
VI = GND to VCC
[3]
[1]
74HCT164
tpd
tPHL
tt
propagation
delay
HIGH to LOW
propagation
delay
transition time
[2]
see Figure 7
VCC = 4.5 V
tW
pulse width
CP HIGH or LOW;
see Figure 7
VCC = 4.5 V
VCC = 4.5 V
trec
recovery time
VCC = 4.5 V
tsu
set-up time
DSA, and DSB to CP;
see Figure 9
VCC = 4.5 V
th
hold time
DSA, and DSB to CP;
see Figure 9
fmax
maximum
frequency
VCC = 4.5 V
VCC = 4.5 V
74HC_HCT164
Product data sheet
8 of 19
74HC164; 74HCT164
Nexperia
Table 7.
Symbol Parameter
25 C
Conditions
Min
CPD
[1]
power
dissipation
capacitance
[3]
per package;
VI = GND to VCC 1.5 V
40 C to +85 C
Typ Max
40
40 C to +125 C Unit
Min
Max
Min
Max
pF
tpd is the same as tPHL and tPLH.
[2]
tt is the same as tTHL and tTLH.
[3]
CPD is used to determine the dynamic power dissipation (PD in W):
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
IPD[
9,
&3LQSXW
90
*1'
W:
W3+/
92+
W3/+
9<
90
4QRXWSXW
9;
92/
W7+/
W7/+
DDO
(1) Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 7.
Waveforms showing the clock (CP) to output (Qn) propagation delays, the clock pulse width, the output
transition times and the maximum clock frequency
Table 8.
Measurement points
Type
Input
Output
VM
VM
VX
VY
74HC164
0.5VCC
0.5VCC
0.1VCC
0.9VCC
74HCT164
1.3 V
1.3 V
0.1VCC
0.9VCC
74HC_HCT164
Product data sheet
9 of 19
74HC164; 74HCT164
Nexperia
9,
90
05LQSXW
*1'
W:
WUHF
9,
&3LQSXW
90
*1'
W3+/
92+
90
4QRXWSXW
92/
DDF
Fig 8.
Waveforms showing the master reset (MR) pulse width, the master reset to output (Qn) propagation
delays and the master reset to clock (CP) removal time
9,
90
&3LQSXW
*1'
W VX
W VX
WK
WK
9,
90
'QLQSXW
*1'
92+
90
4QRXWSXW
92/
DDF
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig 9.
Waveforms showing the data set-up and hold times for Dn inputs
74HC_HCT164
Product data sheet
10 of 19
74HC164; 74HCT164
Nexperia
9,
QHJDWLYH
SXOVH
W:
90
90
*1'
WI
9,
WI
SRVLWLYH
SXOVH
*1'
WU
WU
90
90
W:
9&&
9,
92
'87
57
DDK
Test data is given in Table 9.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
Fig 10. Test circuit for measuring switching times
Table 9.
Test data
Type
Input
Load
Test
VI
tr, tf
CL
74HC164
VCC
6.0 ns
15 pF, 50 pF
tPLH, tPHL
74HCT164
3.0 V
6.0 ns
15 pF, 50 pF
tPLH, tPHL
74HC_HCT164
Product data sheet
11 of 19
74HC164; 74HCT164
Nexperia
11. Package outline
62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
',0(16,216LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
PP
LQFKHV
ș
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPLQFKPD[LPXPSHUVLGHDUHQRWLQFOXGHG
5()(5(1&(6
287/,1(
9(56,21
627
06
-(,7$
(8523($1
352-(&7,21
,668('$7(
Fig 11. Package outline SOT108-1 (SO14)
74HC_HCT164
Product data sheet
12 of 19
74HC164; 74HCT164
Nexperia
6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
GHWDLO;
Z 0
ES
H
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Fig 12. Package outline SOT337-1 (SSOP14)
74HC_HCT164
Product data sheet
13 of 19
74HC164; 74HCT164
Nexperia
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
4
SLQLQGH[
ș
/S
H
GHWDLO;
Z 0
ES
PP
VFDOH
81,7
PD[
ES
F
H
/S
4
Y
Z
ș
PP
R
R
1RWHV
3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
(8523($1
352-(&7,21
,668('$7(
02
Fig 13. Package outline SOT402-1 (TSSOP14)
74HC_HCT164
Product data sheet
14 of 19
74HC164; 74HCT164
Nexperia
'+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV
WHUPLQDOVERG\[[PP
627
F
GHWDLO;
WHUPLQDO
LQGH[DUHD
WHUPLQDO
LQGH[DUHD
H
H
Y
Z
E
(K
H
N
'K
N
PP
VFDOH
'LPHQVLRQVPPDUHWKHRULJLQDOGLPHQVLRQV
8QLW
PD[
QRP
PLQ
PP
E
F
'K
(K
H
H
N
Y
Z
1RWH
2XWOLQH
YHUVLRQ
627
5HIHUHQFHV
-(,7$
VRWBSR
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
02
Fig 14. Package outline SOT762-1 (DHVQFN14)
74HC_HCT164
Product data sheet
15 of 19
74HC164; 74HCT164
Nexperia
12. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT164 v.8
20151119
Product data sheet
74HC_HCT164 v.7
Modifications:
74HC_HCT164 v.7
Modifications:
74HC_HCT164 v.6
Modifications:
Type numbers 74HC164N and 74HCT164N (SOT27-1) removed.
20130613
74HC_HCT164 v.6
74HC_HCT164 v.5
General description updated.
20111212
Product data sheet
Product data sheet
Legal pages updated.
74HC_HCT164 v.5
20101125
Product data sheet
74HC_HCT164 v.4
74HC_HCT164 v.4
20100202
Product data sheet
74HC_HCT164 v.3
74HC_HCT164 v.3
20050404
Product data sheet
74HC_HCT164_ CNV v.2
74HC_HCT164_CNV v.2
19901201
Product specification
74HC_HCT164
Product data sheet
16 of 19
74HC164; 74HCT164
Nexperia
14. Legal information
14.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74HC_HCT164
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
17 of 19
74HC164; 74HCT164
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
14.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
15. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC_HCT164
Product data sheet
18 of 19
Nexperia
74HC164; 74HCT164
16. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
14.1
14.2
14.3
14.4
15
16
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16
Legal information. . . . . . . . . . . . . . . . . . . . . . . 17
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Contact information. . . . . . . . . . . . . . . . . . . . . 18
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Date of release: 19 November 2015
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC164D,652 74HC164DB,112 74HC164DB,118 74HC164D,653 74HC164PW,112 74HC164PW,118
74HCT164BQ,115 74HCT164D,652 74HCT164DB,112 74HCT164DB,118 74HCT164D,653 74HCT164PW,112
74HCT164PW,118 74HC164BQ,115 74HC164D/AUJ
