74HC594DB,112
74HC594DB,112
    NEXPERIA(安世)
    SSOP16_208MIL
    带输出寄存器的8位移位寄存器 SSOP16_208MIL 2~6V
74HC594DB,112 数据手册
74HC594; 74HCT594 8-bit shift register with output register Rev. 4 — 25 February 2016 Product data sheet 1. General description The 74HC594; 74HCT594 is an 8-bit serial-in/serial or parallel-out shift register with a storage register. Separate clock and reset inputs are provided on both shift and storage registers. The device features a serial input (DS) and a serial output (Q7S) to enable cascading. Data is shifted on the LOW-to-HIGH transitions of the SHCP input, and the data in the shift register is transferred to the storage register on a LOW-to-HIGH transition of the STCP input. If both clocks are connected together, the shift register will always be one clock pulse ahead of the storage register. A LOW level on one of the two register reset pins (SHR and STR) will clear the corresponding register. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits        Synchronous serial input and output Complies with JEDEC standard No.7A 8-bit parallel output Shift and storage registers have independent direct clear and clocks Independent clocks for shift and storage registers 100 MHz (typical) Input levels:  For 74HC594: CMOS level  For 74HCT594: TTL level  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Applications  Serial-to parallel data conversion  Remote control holding register 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 4. Ordering information Table 1. Ordering information Type number Package 74HC594D Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74HCT594D 74HC594DB 74HCT594DB 5. Functional diagram  '6  6+&3 67$*(6+,)75(*,67(5  6+5   67&3  675 %,76725$*(5(*,67(5         4 4 4 4 4 4 4 4 Fig 1. 46 PEF Functional diagram 6+&3 67&3 675    '6 6+5 Fig 2. Logic symbol 74HC_HCT594 Product data sheet 46 6+5 5    & 5 65*  4  4  4  4   4   4   4  4   67&3  6+&3 '6  & '  '      675  PEF 4 4 4 4 4 4 4 4 46 PEF Fig 3. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 2 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 67$*(672 67$*( '6 ' ' 4 67$*( 4 ' 46 4 ))6+ ))6+ &3 &3 5 5 6+&3 6+5 ' ' 4 ))67 4 ))67 &3 &3 5 5 67&3 675 4 Fig 4. 4 4 4 4 4 4 4 PEF Logic diagram 6+&3 '6 67&3 6+5 675 4 4 4 4 46 PEF Fig 5. Timing diagram 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 3 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 6. Pinning information 6.1 Pinning +& +&7 4   9&& 4   4 4   '6 4   675 4   67&3 4   6+&3 4  *1'  +& +&7 4  4   9&&  4 4   '6 4   675 4   67&3 4   6+&3 4   6+5 *1'   6+5  46  DDI DDI Fig 6. 46 Pin configuration SO16 Fig 7. Pin configuration SSOP16 6.2 Pin description Table 2. Pin description Symbol Pin Description Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7 15, 1, 2, 3, 4, 5, 6, 7 parallel data output GND 8 ground (0 V) Q7S 9 serial data output SHR 10 shift register reset (active LOW) SHCP 11 shift register clock input STCP 12 storage register clock input STR 13 storage register reset (active LOW) DS 14 serial data input VCC 16 supply voltage 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 4 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 7. Functional description Table 3. Function table[1] Function Input SHR STR SHCP STCP DS Clear shift register L X X X X Clear storage register X L X X X Load DS into shift register stage 0, advance previous stage data to the next stage H X  X H or L Transfer shift register data to storage register and outputs Qn X H X  X Shift register one count pulse ahead of storage register H H   X [1] H = HIGH voltage level; L = LOW voltage level;  = LOW-to-HIGH transition; X = don’t care. 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7.0 V - 20 mA - 20 mA Serial data output Q7S - 25 mA Parallel data output - 35 mA - 50 mA input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current VO = 0.5 V to VCC + 0.5 V IIK ICC supply current Serial data output Q7S Parallel data output - 70 mA IGND ground current Serial data output Q7S - 50 mA Parallel data output - 70 mA 65 +150 C - 500 mW storage temperature Tstg total power dissipation Ptot Tamb = 40 C to +125 C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO16 packages: above 70 C the value of Ptot derates linearly with 8 mW/K. For SSOP16 packages: above 60 C the value of Ptot derates linearly with 5.5 mW/K. 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 5 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 9. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC594 Min Typ 74HCT594 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 - +125 40 - +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V Unit 10. Static characteristics Table 6. Static characteristics type 74HC594 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V Tamb = 25 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - V IO = 6.0 mA; VCC = 4.5 V 3.98 4.32 - V IO = 7.8 mA; VCC = 6.0 V 5.48 5.81 - V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 V VI = VIH or VIL Serial data output Q7S Parallel data outputs VOL LOW-level output voltage VI = VIH or VIL Serial data output Q7S Parallel data outputs IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 A Ci input capacitance - 3.5 - pF 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 6 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register Table 6. Static characteristics type 74HC594 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 - - VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = 4.0 mA; VCC = 4.5 V 3.84 - - V IO = 5.2 mA; VCC = 6.0 V 5.34 - - V IO = 6.0 mA; VCC = 4.5 V 3.84 - - V IO = 7.8 mA; VCC = 6.0 V 5.34 - - V IO = 4.0 mA; VCC = 4.5 V - - 0.33 V IO = 5.2 mA; VCC = 6.0 V - - 0.33 V IO = 6.0 mA; VCC = 4.5 V - - 0.33 V IO = 7.8 mA; VCC = 6.0 V - - 0.33 V Tamb = 40 C to +85 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage V VI = VIH or VIL Serial data output Q7S Parallel data outputs VOL LOW-level output voltage VI = VIH or VIL Serial data output Q7S Parallel data outputs II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 80 A VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = 4.0 mA; VCC = 4.5 V 3.7 - - V IO = 5.2 mA; VCC = 6.0 V 5.2 - - V IO = 6.0 mA; VCC = 4.5 V 3.7 - - V IO = 7.8 mA; VCC = 6.0 V 5.2 - - V Tamb = 40 C to +125 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VI = VIH or VIL Serial data output Q7S Parallel data outputs 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 7 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register Table 6. Static characteristics type 74HC594 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VOL LOW-level output voltage VI = VIH or VIL IO = 4.0 mA; VCC = 4.5 V - - 0.4 V IO = 5.2 mA; VCC = 6.0 V - - 0.4 V IO = 6.0 mA; VCC = 4.5 V - - 0.4 V Serial data output Q7S Parallel data outputs IO = 7.8 mA; VCC = 6.0 V - - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 160 A Conditions Min Typ Max Unit Table 7. Static characteristics type 74HCT594 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 25 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 V VOH HIGH-level output voltage VI = VIH or VIL 3.98 4.32 - V 3.98 4.32 - V - 0.15 0.26 V IO = 6.0 mA; VCC = 4.5 V - 0.16 0.26 V Serial data output Q7S IO = 4.0 mA; VCC = 4.5 V Parallel data outputs IO = 6.0 mA; VCC = 4.5 V VOL LOW-level output voltage VI = VIH or VIL Serial data output Q7S IO = 4.0 mA; VCC = 4.5 V Parallel data outputs II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 A ICC additional supply current per input pin; VI = VCC  2.1 V and other inputs at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V pins SHR, SHCP, STCP, STR - 150 540 A pin DS - 25 90 A - 3.5 - pF Ci input capacitance 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 8 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register Table 7. Static characteristics type 74HCT594 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 4.5 V to 5.5 V 2.0 - - V - - 0.8 V 3.84 - - V 3.84 - - V - - 0.33 V IO = 6.0 mA; VCC = 4.5 V - - 0.33 V Tamb = 40 C to +85 C VIH HIGH-level input voltage VIL LOW-level input voltage VCC = 4.5 V to 5.5 V VOH HIGH-level output voltage VI = VIH or VIL Serial data output Q7S IO = 4.0 mA; VCC = 4.5 V Parallel data outputs IO = 6.0 mA; VCC = 4.5 V VOL LOW-level output voltage VI = VIH or VIL Serial data output IO = 4.0 mA; VCC = 4.5 V Parallel data outputs II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 80 A ICC additional supply current per input pin; VI = VCC  2.1 V and other inputs at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V pins SHR, SHCP, STCP, STR - - 675 A pin DS - - 112.5 A Tamb = 40 C to +125 C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL 3.7 - - V 3.7 - - V - - 0.4 V IO = 6.0 mA; VCC = 4.5 V - - 0.4 V Serial data output Q7S IO = 4.0 mA; VCC = 4.5 V Parallel data outputs IO = 6.0 mA; VCC = 4.5 V VOL LOW-level output voltage VI = VIH or VIL Serial data output Q7S IO = 4.0 mA; VCC = 4.5 V Parallel data outputs II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 160 A ICC additional supply current per input pin; VI = VCC  2.1 V and other inputs at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V pins SHR, SHCP, STCP, STR - - 735 A pin DS - - 122.5 A 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 9 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 11. Dynamic characteristics Table 8. Dynamic characteristics type 74HC594 GND = 0 V; tr = tf = 6 ns; CL = 50 pF; see Figure 14. Symbol tpd Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 44 150 - 185 - 225 ns VCC = 4.5 V - 16 30 - 37 - 45 ns VCC = 5.0 V; CL = 15 pF - 13 - - - - - ns VCC = 6.0 V - 14 26 - 31 - 38 ns VCC = 2.0 V - 44 150 - 185 - 225 ns VCC = 4.5 V - 16 30 - 37 - 45 ns propagation SHCP to Q7S; see Figure 8 delay VCC = 2.0 V [1] STCP to Qn; see Figure 9 tPHL VCC = 5.0 V; CL = 15 pF - 13 - - - - - ns VCC = 6.0 V - 14 26 - 31 - 38 ns - 39 150 - 185 - 225 ns - 14 30 - 37 - 45 ns - 11 - - - - - ns - 12 26 - 31 - 38 ns VCC = 2.0 V - 39 125 - 155 - 185 ns VCC = 4.5 V - 14 25 - 31 - 37 ns VCC = 5.0 V; CL = 15 pF - 11 - - - - - ns VCC = 6.0 V - 12 21 - 26 - 31 ns - 19 75 - 95 - 110 ns - 7 15 - 19 - 22 ns - 6 13 - 16 - 19 ns VCC = 2.0 V - 14 60 - 75 - 90 ns VCC = 4.5 V - 5 12 - 15 - 18 ns VCC = 6.0 V - 4 10 - 13 - 15 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V - 14 60 - 75 - 90 ns VCC = 4.5 V - 5 12 - 15 - 18 ns VCC = 6.0 V - 4 10 - 13 - 15 ns HIGH to SHR to Q7S; see Figure 12 LOW VCC = 2.0 V propagation VCC = 4.5 V delay VCC = 5.0 V; CL = 15 pF VCC = 6.0 V STR to Qn; see Figure 13 tTHL HIGH to Q7S; see Figure 8 LOW output VCC = 2.0 V transition VCC = 4.5 V time VCC = 6.0 V Qn tTLH LOW to HIGH output transition time Q7S; see Figure 8 Qn 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 10 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register Table 8. Dynamic characteristics type 74HC594 …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; see Figure 14. Symbol tW Parameter pulse width 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 80 10 - 100 - 120 - ns VCC = 4.5 V 16 4 - 20 - 24 - ns VCC = 6.0 V 14 3 - 17 - 20 - ns VCC = 2.0 V 80 10 - 100 - 120 - ns VCC = 4.5 V 16 4 - 20 - 24 - ns VCC = 6.0 V 14 3 - 17 - 20 - ns VCC = 2.0 V 80 14 - 100 - 120 - ns VCC = 4.5 V 16 5 - 20 - 24 - ns VCC = 6.0 V 14 4 - 17 - 20 - ns SHCP (HIGH or LOW); see Figure 8 STCP (HIGH or LOW); see Figure 9 SHR and STR (HIGH or LOW); see Figure 12 and Figure 13 tsu set-up time DS to SHCP; see Figure 10 VCC = 2.0 V 100 10 - 125 - 150 - ns VCC = 4.5 V 20 4 - 25 - 30 - ns VCC = 6.0 V 17 3 - 21 - 26 - ns VCC = 2.0 V 100 14 - 125 - 150 - ns VCC = 4.5 V 20 5 - 25 - 30 - ns VCC = 6.0 V 17 4 - 21 - 26 - ns VCC = 2.0 V 100 17 - 125 - 150 - ns VCC = 4.5 V 20 6 - 25 - 30 - ns VCC = 6.0 V 17 5 - 21 - 26 - ns VCC = 2.0 V 25 8 - 30 - 35 - ns VCC = 4.5 V 5 3 - 6 - 7 - ns VCC = 6.0 V 4 2 - 5 - 6 - ns VCC = 2.0 V 50 14 - 65 - 75 - ns VCC = 4.5 V 10 5 - 13 - 15 - ns VCC = 6.0 V 9 4 - 11 - 13 - ns SHR to STCP; see Figure 11 SHCP to STCP; see Figure 9 th trec hold time recovery time 74HC_HCT594 Product data sheet DS to SHCP; see Figure 10 SHR to SHCP and STR to STCP; see Figure 12 and Figure 13 All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 11 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register Table 8. Dynamic characteristics type 74HC594 …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; see Figure 14. Symbol fmax Parameter maximum frequency 25 C Conditions Min Typ Max Min Max Min Max VCC = 2.0 V 6.0 30 - 4.8 - 4.0 - MHz VCC = 4.5 V 30 92 - 24 - 20 - MHz - 100 - - - - - MHz 35 109 - 28 - 24 - MHz - 84 - - - - - pF SHCP or STCP; see Figure 8 and Figure 9 VCC = 5.0 V; CL = 15 pF VCC = 6.0 V [2] power VI = GND to VCC; dissipation VCC = 5 V; fi = 1 MHz capacitance CPD 40 C to +85 C 40 C to +125 C Unit [1] tpd is the same as tPHL and tPLH. [2] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. Table 9. Dynamic characteristics type 74HCT594 GND = 0 V; VCC = 4.5 V; tr = tf = 6 ns; CL = 50 pF; see Figure 14. Symbol Parameter 25 C Conditions Min tpd tPHL tTHL tTLH propagation SHCP to Q7S; see Figure 8 delay VCC = 5.0 V; CL = 15 pF Max Min Max Min Max - 18 32 - 40 - 48 ns 15 - - - - - ns STCP to Qn; see Figure 9 - 18 32 - 40 - 48 ns VCC = 5.0 V; CL = 15 pF - 15 - - - - - ns HIGH to Q7S; see Figure 8 LOW output VCC = 4.5 V transition Qn time VCC = 4.5 V LOW to Q7S; see Figure 8 HIGH output VCC = 4.5 V transition Qn time VCC = 4.5 V Product data sheet Typ - HIGH to SHR to Q7S; see Figure 12 LOW VCC = 5.0 V; CL = 15 pF propagation STR to Qn; see Figure 13 delay VCC = 5.0 V; CL = 15 pF 74HC_HCT594 [1] 40 C to +85 C 40 C to +125 C Unit - 17 30 - 38 - 45 ns - 14 - - - - - ns - 17 30 - 38 - 45 ns - 14 - - - - - ns - 7 15 - 19 - 22 ns - 5 12 - 15 - 18 ns - 7 15 - 19 - 22 ns - 5 12 - 15 - 18 ns All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 12 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register Table 9. Dynamic characteristics type 74HCT594 …continued GND = 0 V; VCC = 4.5 V; tr = tf = 6 ns; CL = 50 pF; see Figure 14. Symbol Parameter tW pulse width tsu set-up time 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max SHCP (HIGH or LOW); see Figure 8 16 4 - 20 - 24 - ns STCP (HIGH or LOW); see Figure 9 16 4 - 20 - 24 - ns SHR and STR (HIGH or LOW); see Figure 12 and Figure 13 16 6 - 20 - 24 - ns DS to SHCP; see Figure 10 20 4 - 25 - 30 - ns SHR to STCP; see Figure 11 20 6 - 25 - 30 - ns SHCP to STCP; see Figure 9 20 7 - 25 - 30 - ns th hold time DS to SHCP; see Figure 10 5 3 - 6 - 7 - ns trec recovery time SHR to SHCP and STR to STCP; see Figure 12 and Figure 13 10 5 - 13 - 15 - ns fmax maximum frequency SHCP or STCP; see Figure 8 and Figure 9 30 92 - 24 - 20 - MHz - 100 - - - - - MHz - 89 - - - - - pF VCC = 5.0 V; CL = 15 pF power VI = GND to VCC  1.5 V; dissipation VCC = 5 V; fi = 1 MHz capacitance CPD [2] [1] tpd is the same as tPHL and tPLH. [2] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 13 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 12. Waveforms IPD[ 6+&3LQSXW 90 W: W3/+ 46RXWSXW W3+/ 90 W7/+ W7+/ DDH Measurement points are given in Table 10. tPLH and tPHL are the same as tpd. tTLH = LOW to HIGH output transition time; tTHL = HIGH to LOW output transition time. Fig 8. The shift clock (SHCP) to output (Q7S) propagation delays, the shift clock pulse width, the maximum shift clock frequency, and output transition times 6+&3LQSXW 90 WVX IPD[ 90 67&3LQSXW W: W3+/ W3/+ 4QRXWSXWV 90 POD Measurement points are given in Table 10. tPLH and tPHL are the same as tpd. Fig 9. The storage clock (STCP) to output (Qn), propagation delays, the storage clock pulse width, the maximum storage clock pulse frequency and the shift clock to storage clock set-up time 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 14 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 90 6+&3LQSXW W VX W VX WK WK 90 '6LQSXW 90 4RXWSXW DDH Measurement points are given in Table 10. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig 10. The data set-up time and hold times for DS input to SHCP 6+5LQSXW 90 WVX 67&3LQSXW 4QRXWSXWV 90 90 PEF Measurement points are given in Table 10. Fig 11. The set-up time shift reset (SHR) to storage clock (STCP) 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 15 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 90 6+5LQSXW W: WUHF 90 6+&3LQSXW W3+/ 90 46RXWSXW PEF Measurement points are given in Table 10. tPLH and tPHL are the same as tpd. Fig 12. The shift reset (SHR) pulse width, the shift reset to output (Q7S) propagation delay and the shift reset to shift clock (SHCP) recovery time 90 675LQSXW W: WUHF 90 67&3LQSXW W3+/ 90 4QRXWSXWV PEF Measurement points are given in Table 10. tPLH and tPHL are the same as tpd. Fig 13. The storage reset (STR) pulse width, the storage reset to output (Qn) propagation delay and the storage reset to storage clock (STCP) recovery time Table 10. Measurement points Type Input Output VM VM 74HC594 0.5  VCC 0.5  VCC 74HCT594 1.3 V 1.3 V 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 16 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Test data is given in Table 11. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistance S1 = Test selection switch Fig 14. Test circuit for measuring switching times Table 11. Test data Type Input VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC594 VCC 6 ns 15 pF, 50 pF 1 k open GND VCC 74HCT594 3V 6 ns 15 pF, 50 pF 1 k open GND VCC 74HC_HCT594 Product data sheet Load S1 position All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 17 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 13. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 15. Package outline SOT109-1 (SO16) 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 18 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   GHWDLO; Z 0 ES H   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 16. Package outline SOT338-1 (SSOP16) 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 19 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 14. Abbreviations Table 12. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-Power Schottky Transistor-Transistor Logic MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT594 v.4 20160225 Product data sheet - 74HC_HCT594 v.3 Modifications: 74HC_HCT594 v.3 Modifications: • Type numbers 74HC594N and 74HCT594N (SOT38-4) removed. 20061220 Product data sheet - 74HC_HCT594_CNV v.2 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Table 1 “Ordering information” updated. 74HC_HCT594_CNV v.2 19970908 74HC_HCT594 Product data sheet Product specification - All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 74HC_HCT594_CNV v.1 © Nexperia B.V. 2017. All rights reserved 20 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT594 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 21 of 23 74HC594; 74HCT594 Nexperia 8-bit shift register with output register Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT594 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 25 February 2016 © Nexperia B.V. 2017. All rights reserved 22 of 23 Nexperia 74HC594; 74HCT594 8-bit shift register with output register 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . 10 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 18 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 20 Legal information. . . . . . . . . . . . . . . . . . . . . . . 21 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 21 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Contact information. . . . . . . . . . . . . . . . . . . . . 22 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 25 February 2016 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HCT594D 74HC594D 74HC594DB 74HC594N 74HCT594DB 74HC594D,112 74HC594DB,112 74HC594DB,118 74HC594D,118 74HC594N,112 74HCT594D,112 74HCT594DB,112 74HCT594DB,118 74HCT594D,118 74HCT594D-Q100,118 74HC594D-Q100,118
74HC594DB,112
物料型号:74HC/HCT594 器件简介:74HC/HCT594 是 Nexperia 公司生产的 8 位串行输入、并行输出移位寄存器。
引脚分配:8 个数据输入端、3 个输出使能端、1 个存储寄存器时钟输入端、1 个移位寄存器时钟输入端、1 个主时钟输入端、1 个清除输入端、1 个串行数据输入端和 8 个并行数据输出端。
参数特性:工作电压范围为 2V 至 6V,工作温度范围为 -40°C 至 +85°C,封装类型包括 SOIC、TSSOP、PDIP 等。
功能详解:具有串行数据输入、并行数据输出、存储寄存器和移位寄存器功能,支持主时钟控制和清除功能。
应用信息:广泛应用于 LED 驱动、数据存储、信号分配等领域。
封装信息:提供 SOIC、TSSOP、PDIP 等多种封装形式。
74HC594DB,112 价格&库存
很抱歉,暂时无法提供与“74HC594DB,112”相匹配的价格&库存,您可以联系我们找货
74HC594DB,112
    • 1+5.34600
    • 10+4.32000
    • 30+3.81240
    • 100+3.30480
    • 500+3.00240
    • 1092+2.85120
