MMFTN3019E
N-Channel Field Effect Transistor
Applications
• Interfacing, switching
Features
• Low on-resistance
• Fast switching speed
• Low voltage drive makes this device ideal
for portable equipment
• Drive circuits can be simple
• Parallel use is easy
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Drain-Source Voltage
Gate-Source Voltage
M
E
Drain Current - Continuous
Drain Current - Pulsed
Total Power Dissipation
Channel temperature
S
Storage Temperature Range
1)
2)
PW ≤ 10 µs, Duty cycle ≤ 1 %
With each pin mounted on the recommended lands
Drain
Gate
Source
E
T
Symbol
VDSS
VGSS
ID
IDP
H
C
Value
Unit
30
V
± 20
V
± 100
1)
± 400
2)
mA
Ptot
150
mW
Tch
150
O
Tstg
- 55 to + 150
O
C
C
SEMTECH ELECTRONICS LTD.
Subsidiary of Sino-Tech International (BVI) Limited
Dated: 09/12/2011 Rev:02
MMFTN3019E
Characteristics at Ta = 25 OC
Parameter
Symbol
Min.
Typ.
Max.
Unit
Drain-Source Breakdown Voltage
at ID = 10 µA
V(BR)DSS
30
V
Zero Gate Voltage Drain Current
at VDS = 30 V
IDSS
1
µA
Gate-source Leakage
at VGS = ± 20 V
IGSS
±1
µA
Gate-Source Threshold Voltage
at VDS = 3 V, ID = 100 µA
VGS(th)
0.8
1.5
V
Static Drain-Source On-Resistance
at VGS = 4 V, ID = 10 mA
at VGS = 2.5 V, ID = 1 mA
RDS(on)
8
13
Ω
|yfs|
ms
13
pF
9
pF
4
pF
15
ns
Forward transfer admittance
at VDS = 3 V, ID = 10 mA
Input Capacitance
at VDS = 5 V, f = 1 MHz
E
T
H
C
Ciss
Coss
Crss
Turn-On delayTime
at VDD = 5 V, ID = 10 mA, VGS = 5 V, RL = 500 Ω, RG = 10 Ω
td(on)
Turn-Off Delay Time
td(off)
80
ns
Rise Time
tr
35
ns
Turn-off delay time
tf
80
ns
Output Capacitance
Reverse Transfer Capacitance
M
E
S
MMFTN3019E
M
E
S
E
T
H
C
很抱歉,暂时无法提供与“MMFTN3019E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.08910
- 4000+0.07080
- 国内价格
- 20+0.16600
- 200+0.12842
- 600+0.10746
- 4000+0.09483
- 8000+0.08392
- 20000+0.07809
- 国内价格
- 1+0.10500
- 100+0.09800
- 300+0.09100
- 500+0.08400
- 2000+0.08050
- 5000+0.07840
