1N4148
Silicon Epitaxial Planar Switching Diode
Max. 0.5
Applications
Max. 0.45
Min. 27.5
Max. 1.9
Black
Cathode Band
Black
Part No.
Black
"ST" Brand
This diode is also available in MiniMELF case
Min. 27.5
Max. 1.9
• High-speed switching
Black
Cathode Band
XXX
Black
Part No.
Max. 3.9
ST
XXX
Max. 2.9
with the type designation LL4148
Min. 27.5
Min. 27.5
Glass Case DO-34
Dimensions in mm
Glass Case DO-35
Dimensions in mm
Absolute Maximum Ratings (Ta = 25
Parameter
Symbol
Value
Unit
Peak Reverse Voltage
VRM
100
V
Reverse Voltage
VR
75
V
IF(AV)
200
mA
IFSM
0.5
1
4
A
Ptot
500
mW
Tj
- 65 to + 200
Tstg
- 65 to + 200
Symbol
Max.
Unit
RθJL
350
/W
Average Rectified Forward Current
Non-repetitive Peak Forward Surge Current
at t = 1 s
at t = 1 ms
at t = 1 μs
Power Dissipation
Operating Junction Temperature Range
Storage Temperature Range
Thermal Characteristics
Parameter
Thermal Resistance - Junction to Lead 1)
1)
Valid provided that leads at a distance of 8 mm from case are kept at ambient temperature.
1/3
Dated: 04/05/2023 Rev: 05
1N4148
Characteristics at Ta = 25
Parameter
Reverse Breakdown Voltage
at IR = 100 µA
at IR = 5 µA
Forward Voltage
at IF = 10 mA
Leakage Current
at VR = 20 V
at VR = 75 V
at VR = 20 V, Tj = 150
Capacitance
at VR = 0, f = 1 MHz
Voltage Rise when Switching ON
tested with 50 mA Forward Pulses
tp = 0.1 s, Rise Time < 30 ns, fp = 5 to 100 KHz
Reverse Recovery Time
at IF = 10 mA, Irr = 1 mA, VR = 6 V, RL = 100 Ω
Rectification Efficiency 1)
at f = 100 MHz, VRF = 2 V
Symbol
Min.
Max.
Unit
V(BR)R
V(BR)R
100
75
V
V
VF
1
V
IR
IR
IR
25
5
50
nA
µA
µA
Ctot
4
pF
Vfr
2.5
V
trr
4
ns
ηV
0.45
Vo
2nF
5K
VRF =2V
60
1)
Rectification Efficiency Measurem ent Circuit
2/3
1N4148
Electrical Characteristics Curve
Fig 1. Power Derating Curve
IF, Forward Current (mA)
Fig 2. Forward Characteristic Curve
VF, Forward voltage(V)
Fig 4. Junction Capacitance
Tj, Junction Temperature (
Cj, Junction Capacitance (pF)
IR, Reverse Current (nA)
Fig 3. Reverse Characteristic Curve
VR, Reverse Voltage(V)
3/3
很抱歉,暂时无法提供与“1N4148”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.03390
- 100+0.03164
- 300+0.02938
- 500+0.02712
- 2000+0.02599
- 5000+0.02531
- 国内价格
- 1000+0.02362
- 5000+0.02312
