BRIGHT LED ELECTRONICS CORP.
Specification for Approval
● DEVICE NUMBER: BL-HB337A-AV-TRB
PAGE
DATE
2016.03.03
1
2
3
4
5
1.0 1.0 1.0 1.0 1.0
6
SAMPLES
ATTACHED AREA
7
CONTENTS
1.0 1.0
Initial Released
FOR CUSTOMER’S APPROVAL STAMP OR SIGNATURE
APPROVED
PURCHASE
MANUFACTURE
佰鴻工業股份有限公司
新北市板橋區和平路 19 號 3 樓
3F., No.19, He Ping Road,
Ban Qiao Dist., New Taipei City,
Taiwan
Tel: +886-2-29591090
ISSUED
QUALITY
ENGINEERING
APPROVED
PREPARED
張
占
任
2016.03.03
2016.03.03
2016.03.03
孝 嚴
旭
穎
BL-HB337A-AV-TRB
● Features:
1. Emitted Color : Super Blue
●Package Dimensions:
2. Lens Appearance : Water Clear
3. Mono-color type.
4. 1.0x0.5x0.4mm(0402) standard package
5. Suitable for all SMT assembly methods.
0.05
refold solder process.
0.16±0.03
6. Compatible with infrared and vapor phase
7. Compatible with automatic placement
equipment.
8. This product doesn’t contain restriction
Substance, comply ROHS standard.
● Applications:
1. Automotive: Dashboards, stop lamps,
NOTES:
1.All dimensions are in millimeters .
2.Tolerance is ± 0.10mm unless otherwise specified.
3.Specifications are subject to change without notice.
turn signals.
2. Backlighting: LCDs, Key pads advertising.
3. Status indicators : Comsumer & industrial
electronics.
4. General use.
● Absolute Maximum Ratings(Ta=25℃)
Parameter
Symbol
Rating
Unit
Power Dissipation
Pd
70
mW
Forward Current
IF
mA
Peak Forward Current *1
IFP
100
mA
Reverse Voltage
VR
5
V
Operating Temperature
Topr
-40℃~85℃
Storage Temperature
Tstg
-40℃~85℃
Soldering Temperature
Tsol
See Page 6
*1 Condition for IFp is pulse of 1/10 duty and 0.1msec width.
Ver.1.0 Page 1 of 7
BL-HB337A-AV-TRB
● Electrical and optical characteristics(Ta=25℃)
Parameter
Symbol
Condition
Min.
Typ.
Max.
Unit
Forward Voltage
Vf
IF=5mA
2.8
3.2
V
Luminous Intensity
Iv
IF=5mA
12.3
mcd
Reverse Current
IR
VR=5V
1
µA
Peak Wave Length
λp
IF=5mA
460
nm
Dominant Wave Length
λd
IF=5mA
465
470
nm
Spectral Line Half-width
Δλ
IF=5mA
30
nm
Viewing Angle
2θ1/2
IF=5mA
120
deg
● Typical Electro-Optical Characteristics Curves
Fig.2 Forward current derating curve
vs. ambient temperature
Fig.1 Relative intensity vs. wavelength
1.0
50
Forward current (mA)
Relative radiant intensity
40
0.5
30
460
Wavelength (nm)
100
2.5
30
1
2
3
4
(Normalized @ 20mA)
Relative luminous intensity
40
2.0
1.5
1.0
0.5
5
-20
Forward voltage(V)
60
Ambient
A
temperature Ta( C)
Fig.6 Radiation diagram
Fig.5 Relative luminous intensity vs. forward current
10
RELATIVE RADIANT INTENSITY
Relative luminous intensity (@20mA)
80
60
3.0
50
40
Fig.4 Relative luminous intensity vs.
ambient temperature
Fig.3 Forward current vs. forward voltage
Ambient temperature Ta( C)
1.5
1.0
0.5
40
50
40
1.0
0.9
50
0.8
60
70
0.7
80
90
0.5
0.3
0.1
0.2
0.4
0.6
Ver.1.0 Page 2 of 7
BL-HB337A-AV-TRB
● Tapping and packaging specifications(Units: mm)
Quantity:3000PCS
CATHODE
8.0±0.3
ANODE
USER DIRECTION OF FEED
●Package Method:(unit:mm) Vacuum
12 bag/box
3000 pcs/reel
200
Bar Code Label
245
220
220
Aluminum Foil Bag
185
645
6 box/carton
210
470
Ver.1.0 Page 3 of 7
BL-HB337A-AV-TRB
● Bin Limits
I n t e n s i t y Bi n L i mi ts ( A t 5 mA )
B IN CO D E
Mi n . ( mc d )
Ma x . ( mc d )
L
18.5
28
M
N
28
42
42
63
P
63
94
To ler a n c e fo r e ac h B in l i m it is ± 1 5 % .
Co l o r Bi n L i mi ts ( At 5 mA )
B IN CO D E
Mi n . ( n m)
Ma x . ( n m)
3
460
465
4
465
470
5
470
475
To ler a n c e fo r e ac h B in l i m it is ± 1 n m.
V F Bi n L i mi ts ( A t 5 mA )
B IN CO D E
Mi n . ( v)
Ma x . ( v)
E
2.4
2.6
F
2.6
2.8
G
2.8
3.0
H
3.0
3.2
To ler a n c e fo r e ac h B in l i m it is ± 0 . 0 5V.
● B IN: x
x
x
V F BI N C O D E
C ol or BI N C O D E
In t e n s i t y B I N C O D E
Ver.1.0 Page 4 of 7
BL-HB337A-AV-TRB
● Reliability Test
Classification
Test Item
Reference Standard
MIL-STD-750D:1026
Operation Life MIL-STD-883D:1005
JIS-C-7021 :B-1
High
Temperature MIL-STD-202F:103B
High Humidity JIS-C-7021 :B-11
Endurance
Storage
Test
High
MIL-STD-883:1008
Temperature
JIS-C-7021 :B-10
Storage
Low
Temperature JIS-C-7021 :B-11
Storage
MIL-STD-202F:107D
Temperature MIL-STD-750D:1051
Cycling
MIL-STD-883D:1010
JIS-C-7021 :A-2
MIL-STD-202F:107D(1980)
Environmental
Thermal Shock MIL-STD-750D:1051(1995)
Test
MIL-STD-883D:1011(1991)
Test Conditions
Ta: Under room temperature
Test time:1,000hrs
IF=Product Recommended IF
Ta:85±5℃
RH:90%-95%
Test time:240hrs
Ta:100±5℃
Test time:1,000hrs
Result
0/32
0/32
0/32
Ta: -40±5℃
Test time=1,000hrs
0/32
Ta:-35±5℃~25±5℃~85±5℃~25±5℃
30min 5min 30min
5min
0/32
Ta:-40±5℃ ~+85±5℃
10min
10 min
Time: 20min/cycle 10cycle
0/32
Wetting
balance
MIL-STD-883:2003
MIL-STD-202F:208D
MIL-STD-883D:2003
Ta:230±5℃
Time:5±0.5s
0/32
Solder
Resistance
MIL-STD-202F:210A
MIL-STD-883D:1011
JIS-C-7021 :A-1
Ta:260±10℃
Time:10±1s
0/32
● Judgment criteria of failure for the reliability
Measuring items
Forward voltage
Reverse current
Luminous intensity
Symbol
VF ( V)
IR(uA)
Iv ( mcd )
Measuring conditions
IF=5mA
VR=5V
IF=5mA
Judgement criteria for failure
Initial Level*1.1
Over U*2
Initial Level*0.7
Note: 1.U means the upper limit of specified characteristics.
2.Measurment shall be taken between 2 hours and after the test pieces have been returned to
normal ambient conditions after completion of each test.
Ver.1.0 Page 5 of 7
BL-HB337A-AV-TRB
●IR-Reflow Soldering
260℃ Max.
10sec.Max.
Above255℃
30sec.Max.
3℃/sec.Max.
6℃/sec.Max.
Above 217℃
60~150sec.
Pre-heating
150~200℃
60~120sec.
1.
Avoid any external stress applied to the resin while the LEDs are at
high temperature, especially during soldering .
2.
Avoid rapid cooling or any excess vibration during temperature ramp-down process
3.
Although the soldering condition is recommended above,
soldering at the lowest possible temperature is feasible for the LEDs
● IRON
Soldering
350℃ Within 3 sec.,One time only.
Ver.1.0 Page 6 of 7
BL-HB337A-AV-TRB
● Notes for designing:
Care must be taken to provide the current limiting resistor in the circuit so as to drive the BRIGHT
LEDs within the rated figures. Also, caution should be taken not to overload BRIGHT LEDs with
instantaneous voltage at the turning ON and OFF of the circuit.
When using the pulse drive care must be taken to keep the average current within the rated figures.
Also, the circuit should be designed so as be subjected to reverse voltage when turning off the
BRIGHT LEDs.
● Storage:
In order to avoid the absorption of moisture, it is recommended to solder BRIGHT LEDs as soon as
possible after unpacking the sealed envelope.
If the envelope is still packed, to store it in the environment as following:
(1) Temperature : 5℃-30℃(41℉)Humidity : RH 60﹪Max.
(2) After this bag is opened, devices that will be applied to infrared reflow, vapor-phase reflow, or
equivalent soldering process must be:
a. Completed within 168 hours.
b. Stored at less than 30% RH.
(3) Devices require baking before mounting, if:
(2) a or (2) b is not met.
(4) If baking is required, devices must be baked under below conditions:
48 hours at 60℃±3℃.
● Package and Label of Products:
(1) Package: Products are packed in one bag of 3000 pcs (one taping reel) and a label is attached
on each bag.
(2) Label:
B
Part No
Quantity
BIN.
Sealing Date
x
xx
xx
xx
x
xx
xx
Year Month
Year Cycle
Manufacture Location
Ver.1.0 Page 7 of 7
很抱歉,暂时无法提供与“BL-HB337A-AV-TRB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.21082
- 200+0.16298
- 600+0.13641
- 3000+0.12755
- 国内价格
- 1+0.58740
- 200+0.19690
- 1500+0.12210
- 3000+0.09724
- 国内价格
- 20+0.19130
- 200+0.14788
