贴片自恢复保险丝
(0805, 0.05A)
Model
型号
SMD0805P005TF
Vmax
V
16.0
Imax
A
100
Ih
It Pd
A
A
W
0.05 0.15 0.5
Time to trip
Resistance
Current(A) Time(s) Rmin(Ω) R1max(Ω)
0.25
1.50
2.000
10.000
产品电气特性参数 Performance specification (25℃)
符号
Sign
说明
RLPTC 在 25℃环境温度下
的最大 工作电流
RLPTC 在 25℃环境温度下
It
启动保护的最小电流
Vmax RLPTC 的最大工作电压
RLPTC 在阻断状态下所承
Vmaxi
受的最大电压
Definition
Hold current-maximum current at which the device will not
trip at 25℃
Trip current-minimum current at which the device will
always trip at 25℃
Maximum voltage at which the device will not trip
Maximum voltage device can withstand without damage at it
rated current
Maximum fault current device can withstand without damage
Imax RLPTC 能承受的最大电流
at rated voltage
RLPTC 工作前的初始最小
Minimum device resistance at 25℃ prior to tripping
Rmin
阻值
RLPTC 工作前的初始最大
Maximum device resistance at 25℃ prior to tripping
Rmax
阻值
Figure图示
The Figure of RLPTC
Lead 导线尺寸
Lead diameter
Ih
很抱歉,暂时无法提供与“SMD0805P005TF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.40209
- 100+0.31714
- 300+0.27467
- 1000+0.24286
- 5000+0.21280
- 10000+0.19997
- 国内价格
- 5+0.30739
- 20+0.28043
- 100+0.25346
- 500+0.22650
- 1000+0.21391
- 2000+0.20493
- 国内价格
- 1+0.33705
- 500+0.22470
- 2500+0.19581
- 5000+0.17762
