LM555
LM555 General-purpose single bipolar timers
Features
Low turn-off time
Maximum operating frequency greater than
500 kHz
Timing from microseconds to hours
Operates in both astable and monostable
modes
Output can source or sink up to 200 mA
Adjustable duty cycle
TTL compatible
Temperature stability of 0.005% per °C
N
DIP8
(Plastic package)
D
SO8
(Plastic micropackage)
Description
The LM555 monolithic timing circuit is a highly
stable controller capable of producing accurate
time delays or oscillation. In the time delay mode
of operation, the time is precisely controlled by
one external resistor and capacitor. For a stable
operation as an oscillator, the free running
frequency and the duty cycle are both accurately
controlled with two external resistors and one
capacitor.
The circuit may be triggered and reset on falling
waveforms, and the output structure can source
or sink up to 200 mA.
Pin connections
(top view)
1
8
2
7
3
6
4
5
1 - GND
2 - Trigger
3 - Output
4 - Reset
http://www.hgsemi.com.cn
1
5 - Control voltage
6 - Threshold
7 - Discharge
8 - VCC
2018 JUN
LM555
1
Schematic diagrams
Figure 1.
Block diagram
VCC+
5kΩ
COMP
THRESHOLD
CONTROL VOLTAGE
DISCHARGE
R
FLIP-FLOP
5kΩ
Q
COMP
OUT
TRIGGER
S
INHIBIT/
RESET
5kΩ
S
RESET
S - 8086
Figure 2.
Schematic diagram
CONTROL
VOLTAGE
OUTPUT
THRESHOLD
COMPARATOR
5
VCC
R2
830W
R1
4.7kW
R4 R8
1kW 5kW
R3
4.7kW
R12
6.8kW
Q21
Q5
Q6
Q7
Q8
Q19
Q9
Q22
Q20
R13
3.9kW
R11
5kW
THRESHOLD
Q1
Q2
Q3
Q11 Q12
TRIGGER
2
Q23
R9
5kW
D2
RESET
4
Q24
Q18
R16
100W
R15
4.7kW
Q17
R5
10kW
R6
100kW
R7
100kW
R10
5kW
1
TRIGGER COMPARATOR
R14
220W
Q15
7
Q14
GND
3
Q13
Q10
Q16
DISCHARGE
D1
R17
4.7kW
Q4
2
FLIP FLOP
2018 JUN
LM555
2
Absolute maximum ratings and operating conditions
Table 1.
Symbol
Parameter
Value
Unit
18
V
±225
mA
VCC
Supply voltage
IOUT
Output current (sink & source)
Rthja
Thermal resistance junction to ambient(1)
DIP8
SO-8
85
125
°C/W
Rthjc
Thermal resistance junction to case (1)
DIP8
SO-8
41
40
°C/W
Human body model (HBM)(2)
(3)
ESD
TLEAD
Tj
Tstg
1000
Machine model (MM)
100
Charged device model (CDM)(4)
1500
Latch-up immunity
200
mA
Lead temperature (soldering 10 seconds)
260
°C
Junction temperature
150
°C
-65 to 150
°C
Storage temperature range
V
1. Short-circuits can cause excessive heating. These values are typical.
2. Human body model: a 100 pF capacitor is charged to the specified voltage, then discharged through a
1.5kΩ resistor between two pins of the device. This is done for all couples of connected pin combinations
while the other pins are floating.
3. Machine model: a 200 pF capacitor is charged to the specified voltage, then discharged directly between
two pins of the device with no external series resistor (internal resistor < 5 Ω). This is done for all couples of
connected pin combinations while the other pins are floating.
4. Charged device model: all pins and the package are charged together to the specified voltage and then
discharged directly to the ground through only one pin. This is done for all pins.
Table 2.
Operating conditions
Symbol
VCC
Vth, Vtrig,
Vcl, Vreset
IOUT
Parameter
Value
Unit
4.5 to 16
V
Maximum input voltage
VCC
V
Output current (sink and source)
±200
mA
0 to 70
°C
Supply voltage
LM555
Operating free air temperature range
Toper
LM555
3
2018 JUN
LM555
3
Electrical characteristics
Table 3.
Tamb = +25° C, VCC = +5 V to +15 V (unless otherwise specified)
LM555
Symbol
Parameter
Unit
Min.
ICC
Typ.
Max.
3
10
2
Timing error (monostable)
(RA = 2kΩ to 100kΩ, C = 0.1μF)
Initial accuracy (1)
Drift with temperature
Drift with supply voltage
0.5
30
0.05
Timing error (astable)
(RA, RB = 1kΩ to 100kΩ, C = 0.1μF, VCC = +15V)
1.5
90
0.15
Supply current (RL = ∝)
Low state
VCC = +5V
VCC = +15V
High state
VCC = +5V
Min.
Typ.
Max.
5
12
3
10
2
6
15
2
100
0.2
1
50
0.1
3
0.5
2.25
150
0.3
mA
ppm/°C
%/V
ppm/°C
%/V
VCL
Control voltage level
VCC = +15V
VCC = +5V
9.6
2.9
10
3.33
10.4
3.8
9
2.6
10
3.33
11
4
V
Vth
Threshold voltage
VCC = +15V
VCC = +5V
9.4
2.7
10
3.33
10.6
4
8.8
2.4
10
3.33
11.2
4.2
V
Ith
Threshold current (2)
0.1
0.25
0.1
0.25
µA
5
1.67
5.2
1.9
5
1.67
5.6
2.2
V
0.5
0.9
0.5
2.0
µA
0.7
1
0.7
1
V
mA
Vtrig
Trigger voltage
VCC = +15V
VCC = +5V
Itrig
Trigger current (Vtrig = 0V)
4.8
1.45
4.5
1.1
Vreset
Reset voltage (3)
Ireset
Reset current
Vreset = +0.4V
Vreset = 0V
0.1
0.4
0.4
1
0.1
0.4
0.4
1.5
VOL
Low level output voltage
VCC = +15V IO(sink) = 10mA
IO(sink) = 50mA
IO(sink) = 100mA
IO(sink) = 200mA
VCC = +5V IO(sink) = 8mA
IO(sink) = 5mA
0.1
0.4
2
2.5
0.1
0.05
0.15
0.5
2.2
0.1
0.4
2
2.5
0.3
0.25
0.25
0.75
2.5
VOH
0.4
High level output voltage
VCC = +15V IO(sink) = 200mA
IO(sink) = 100mA
VCC = +5V IO(sink) = 100mA
13
3
4
12.5
13.3
3.3
0.4
0.25
0.2
12.75
2.75
12.5
13.3
3.3
V
0.4
0.35
V
2018 JUN
LM555
Table 3.
Tamb = +25° C, VCC = +5 V to +15 V (unless otherwise specified) (continued)
LM555
Symbol
Parameter
Unit
Min.
Typ.
Max.
Min.
Typ.
Max.
100
Idis(off)
Discharge pin leakage current
(output high) Vdis = 10V
Vdis(sat)
Discharge pin saturation voltage
(output low) (4)
VCC = +15V, Idis = 15mA
VCC = +5V, Idis = 4.5mA
180
80
480
200
180
80
480
200
Output rise time
Output fall time
100
100
200
200
100
100
300
300
Turn off time (5) (Vreset = VCC)
0.5
tr
tf
toff
nA
mV
ns
0.5
µs
1. Tested at VCC = +5 V and VCC = +15 V.
2. This will determine the maximum value of RA + RB for 15 V operation. The maximum total (RA + RB) is 20 MΩ for +15 V
operation and 3.5 MΩ for +5 V operation.
3. Specified with trigger input high.
4. No protection against excessive pin 7 current is necessary, providing the package dissipation rating is not exceeded.
5. Time measured from a positive pulse (from 0 V to 0.8 x VCC) on the Threshold pin to the transition from high to low on the
output pin. Trigger is tied to threshold.
5
2018 JUN
LM555
Figure 3.
Minimum pulse width required for
triggering
Figure 4.
Supply current versus supply
voltage
Figure 5.
Delay time versus temperature
Figure 6.
Low output voltage versus output
sink current
Figure 7.
sink current
Figure 8.
sink current
6
2018 JUN
LM555
Figure 9.
High output voltage drop versus
output
Figure 10. Delay time versus supply voltage
Figure 11. Propagation delay versus voltage
level of trigger value
7
2018 JUN
LM555
4
Application information
4.1
Monostable operation
In the monostable mode, the timer generates a single pulse. As shown in Figure 12, the
external capacitor is initially held discharged by a transistor inside the timer.
Figure 12. Typical schematics in monostable operation
VCC = 5 to 15V
Reset
R1
8
4
Trigger
7
2
LM555
Output
6
5
3
1
C1
Control Voltage
0.01μF
The circuit triggers on a negative-going input signal when the level reaches 1/3 VCC. Once
triggered, the circuit remains in this state until the set time has elapsed, even if it is triggered
again during this interval. The duration of the output HIGH state is given by t = 1.1 R1C1 and
is easily determined by Figure 14.
Note that because the charge rate and the threshold level of the comparator are both
directly proportional to supply voltage, the timing interval is independent of supply. Applying
a negative pulse simultaneously to the reset terminal (pin 4) and the trigger terminal (pin 2)
during the timing cycle discharges the external capacitor and causes the cycle to start over.
The timing cycle now starts on the positive edge of the reset pulse. During the time the reset
pulse is applied, the output is driven to its LOW state.
When a negative trigger pulse is applied to pin 2, the flip-flop is set, releasing the shortcircuit across the external capacitor and driving the output HIGH. The voltage across the
capacitor increases exponentially with the time constant t = R1C1. When the voltage across
the capacitor equals 2/3 VCC, the comparator resets the flip-flop which then discharges the
capacitor rapidly and drives the output to its LOW state.
Figure 13 shows the actual waveforms generated in this mode of operation.
When Reset is not used, it should be tied high to avoid any possibility of unwanted
triggering.
8
2018 JUN
LM555
Figure 13. Waveforms in monostable operation
t = 0.1 ms / div
INPUT = 2.0V/div
OUTPUT VOLTAGE = 5.0V/div
CAPACITOR VOLTAGE = 2.0V/div
R1 = 9.1kΩ, C1 = 0.01μF, RL = 1kΩ
Figure 14. Pulse duration versus R1C1
0.01
0.001
10
μs
4.2
Ω
10
M
0.1
10
k
R
1=
1.0
Ω
10
0k
Ω
1M
Ω
1k
Ω
C
(μF)
10
100
μs
1.0
ms
10
ms
100
ms
10
s
(t d )
Astable operation
When the circuit is connected as shown in Figure 15 (pins 2 and 6 connected) it triggers
itself and free runs as a multi-vibrator. The external capacitor charges through R1 and R2
and discharges through R2 only. Thus the duty cycle can be set accurately by adjusting the
ratio of these two resistors.
In the astable mode of operation, C1 charges and discharges between 1/3 VCC and 2/3 VCC.
As in the triggered mode, the charge and discharge times and, therefore, frequency are
independent of the supply voltage.
9
2018 JUN
LM555
Figure 15. Typical schematics in astable operation
VCC = 5 to 15V
R1
8
4
Output
3
7
LM555
Control
Voltage
R2
6
5
0.01μF
1
2
C1
Figure 16 shows the actual waveforms generated in this mode of operation.
The charge time (output HIGH) is given by:
t1 = 0.693 (R1 + R2) C1
and the discharge time (output LOW) by:
t2 = 0.693 (R2) C1
Thus the total period T is given by:
T = t1 + t2 = 0.693 (R1 + 2R2) C1
The frequency of oscillation is then:
1
1.44
f = --- = --------------------------------------T
( R1 + 2R2 )C1
It can easily be found from Figure 17.
The duty cycle is given by:
R2
D = ------------------------R1 + 2R2
10
2018 JUN
LM555
Figure 16. Waveforms in astable operation
t = 0.5 ms / div
CAPACITOR VOLTAGE = 1.0V/div
R1 = R2 = 4.8kΩ, C1= 0.1μF, RL = 1kΩ
Figure 17. Free running frequency versus R1, R2 and C1
C
(μF)
10
1.0
R
1
1k
Ω
10
kΩ
0.1
0.01
0.001
0.1
1
R2
1M
10
M
10
11
10
0k
Ω
Ω
Ω
100
1k
10k
f o (Hz)
2018 JUN
LM555
4.3
Pulse width modulator
When the timer is connected in the monostable mode and triggered with a continuous pulse
train, the output pulse width can be modulated by a signal applied to pin 5. Figure 18 shows
the circuit.
Figure 18. Pulse width modulator
VCC
RA
8
4
Trigger
7
2
LM555
6
Modulation
Input
5
3
Output
C
1
4.4
Linear ramp
When the pull-up resistor, RA, in the monostable circuit is replaced by a constant current
source, a linear ramp is generated. Figure 19 shows a circuit configuration that will perform
this function.
Figure 19. Linear ramp
VCC
RE
8
4
Trigger
R1
7
2
LM555
2N4250
or equiv.
6
C
Output
5
3
0.01μF
R2
1
12
2018 JUN
LM555
Figure 20 shows the waveforms generator by the linear ramp.
The time interval is given by:
(2/3 Vcc RE (R1+R2) C
T = ---------------------------------------------------------------- VBE = 0.6V
R1 Vcc - VBE (R1+R2)
Figure 20. Linear ramp
VCC = 5 V
Time:
20 µs/DIV
R1 + 47 kΩ
R2 = 100 kΩ
RE = 2.7 kΩ
C = 0.01 µF
4.5
Top trace: input 3 V/DIV
Middle trace: output 5 V/DIV
Bottom trace: output 5 V/DIV
Bottom trace: capacitor voltage 1 V/DIV
50% duty cycle oscillator
For a 50% duty cycle, the resistors RA and RB can be connected as in Figure 21. The time
period for the output high is the same as for astable operation (see Section 4.2 on page 9):
t1 = 0.693 RA C
For the output low it is
RB – 2RA
t 2 = [(R. RB)/(RA+RB)].C.Ln --------------------------2RB – RA
Thus the frequency of oscillation is:
1 f = ---------------t1 + t2
13
2018 JUN
LM555
Figure 21.
VCC
VCC
RA
51kΩ
4
8
RB
7
2
22kΩ
LM555
Out
6
5
3
1
0.01μF
C
0.01μF
Note that this circuit will not oscillate if RB is greater than 1/2 RA because the junction of RA
and RB cannot bring pin 2 down to 1/3 VCC and trigger the lower comparator.
4.6
Additional information
Adequate power supply bypassing is necessary to protect associated circuitry. The
minimum recommended is 0.1 µF in parallel with 1 µF electrolytic.
14
2018 JUN
很抱歉,暂时无法提供与“LM555M/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.43443
- 100+0.34035
