HRM-S DC12V
HRM-S DC12V
    MULTICOMP
    DIP Power Relay 12V-10A;29*12.6*20.8mm
HRM-S DC12V 数据手册
HRM Series PCB Power Relays Features: • SPCO contacts. • Sealed to allow washing after flow soldering. Specifications: Coil Data: Nominal Voltage : 3V dc to 24V dc. Nominal Power consumption : 540mW to 720mW. Contact Data: Contact Arrangement : 1 form C. Contact Material : AgCdo. Contact Rating : Resistive Load : 10A 250V ac / 30V dc. Inductive Load : 5A 240V ad cos|µ = 0.4 5A 30V dc L/R = 7ms. Maximum Switching Voltage : 110V dc / 250V ac. Maximum Switching Current : 10A. Maximum Switching Power : 2500VA, 300W. Contact Resistance (initial) : 100mΩ at 6V dc 1A. Life Expectancy Electrical : 100,000 operations at nominal load TV-5 120V ac. Mechanical : 50,000 operations at cos|µ = 0.4, L/R = 7ms 10,000,000 operations. General Data: Insulation Resistance : Minimum 100MΩ at 500V dc. Dielectric Strength : 1000V ac, 1 minute between open contacts Operate Time : Maximum 15ms. 5000V ac, 1 minute between contacts and coil. Release Time : Maximum 8ms. Temperature Range : -30 to +55°C (720mW). Shock Resistance : 10G. Vibration Resistance : 10 - 55Hz, Amplitude 1.5mm. Weight : 13 grams. -30 to +70°C (540mW). Page 1 31/05/05 V1.0 HRM Series PCB Power Relays Dimensions Dimensions : Millimetres HRM Characteristic Data Timing (Standard Type) Coil Temperature Rise (Standard Type) Time (ms) Temperature Rise (°C) Coil Power (W) Coil Power (W) Page 2 31/05/05 V1.0 HRM Series PCB Power Relays Operating Range Nominal Voltage Multiplying Factory Maximum Switching Power Switching Current (A) Ambient Temperature (°C) Contact Voltage (V) Life Curve Operations (x 10,000) Contact Current (A) Page 3 31/05/05 V1.0 HRM Series PCB Power Relays Coil Data Chart Coil Nominal (V dc) Coil Resistance Ω) ±10% (Ω Operate Voltage (V dc) Release Voltage (V dc) Part Number 5 36 4.0 0.25 HRM-S DC5V 9 115 7.2 0.45 HRM-S DC9V 12 200 9.6 0.6 HRM-S DC12V 24 820 19.2 1.20 HRM-S DC24V Part Number Explanation HRM Type - S DC5V Enclosure Nominal Voltage Enclosure : S = Washable. Nominal Voltage : DC5V = 5V, DC9V = 9V, DC12V = 12V and DC24V = 24V. Page 4 31/05/05 V1.0 HRM Series PCB Power Relays Notes: International Sales Offices: AUSTRALIA – Farnell InOne FINLAND – Farnell InOne NETHERLANDS – Farnell InOne SWITZERLAND – Farnell InOne Tel No: Tel No: Tel No: ++ 61 2 9645 8888 Fax No: ++ 61 2 9644 7898 Fax No: ++ 358 9 345 5411 Fax No: ++ 31 30 241 7333 Tel No: ++ 41 1 204 64 64 Fax No: ++ 41 1 204 64 54 AUSTRIA – Farnell InOne FRANCE – Farnell InOne NEW ZEALAND – Farnell InOne UK – Farnell InOne Tel No: Tel No: Tel No: Tel No: ++ 43 662 2180 680 ++ 358 9 560 7780 ++ 33 474 68 99 99 ++ 31 30 241 7373 ++ 64 9 357 0646 ++ 44 8701 200 200 Fax No: ++ 43 662 2180 670 Fax No: ++ 33 474 68 99 90 Fax No: ++ 64 9 357 0656 Fax No: ++ 44 8701 200 201 BELGIUM – Farnell InOne GERMANY – Farnell InOne NORWAY – Farnell InOne UK – BuckHickman InOne Tel No: Tel No: Tel No: ++ 45 44 53 66 66 ++ 44 8450 510 150 ++ 32 3 475 2810 ++ 49 89 61 39 39 39 Fax No: ++ 32 3 227 3648 Fax No: ++ 49 89 613 59 01 Fax No: ++ 45 44 53 66 02 ++ 44 8450 510 130 BRAZIL – Farnell-Newark InOne HONG KONG – Farnell-Newark InOne Tel No: ++ 852 2268 9888 PORTUGAL – Farnell InOne UK – CPC ++ 55 11 4066 9400 Tel No: ++ 34 93 475 8804 ++ 44 8701 202 530 Fax No: ++ 55 11 4066 9410 Fax No: ++ 852 2268 9899 Fax No: ++ 34 93 474 5288 ++ 44 8701 202 531 CHINA – Farnell-Newark InOne IRELAND – Farnell InOne SINGAPORE – Tel No: Tel No: Tel No: ++86 10 6238 5152 Fax No: ++86 10 6238 5022 Farnell-Newark InOne Tel No: ++ 65 6788 0200 ++ 353 1 830 9277 Fax No: ++ 353 1 830 9016 Fax No: ++ 65 6788 0300 export EXPORT – Farnell InOne Tel No: ++ 44 8701 200 208 Fax No: ++ 44 8701 200 209 For enquiries from all other markets DENMARK – Farnell InOne ITALY – Farnell InOne SPAIN – Farnell InOne Tel No: Tel No: Tel No: ++ 45 44 53 66 44 ++ 39 02 93 995 200 ++ 34 93 475 8805 Fax No: ++ 45 44 53 66 06 Fax No: ++ 39 02 93 995 300 Fax No: ++ 34 93 474 5107 ESTONIA – Farnell InOne MALAYSIA – SWEDEN – Farnell InOne http://www.farnellinone.com Tel No: ++ 358 9 560 7780 Fax No: ++ 358 9 345 5411 Farnell-Newark InOne Tel No: ++ 60 3 7873 8000 Fax No: ++ 60 3 7873 7000 Tel No: ++ 46 8 730 50 00 Fax No: ++ 46 8 83 52 62 http://www.buckhickmaninone.com http://www.cpc.co.uk Disclaimer This data sheet and its contents (the "Information") belong to the Premier Farnell Group (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2004. Page 5 31/05/05 V1.0
HRM-S DC12V 价格&库存
很抱歉,暂时无法提供与“HRM-S DC12V”相匹配的价格&库存,您可以联系我们找货
