SS14
SS14
    MULTICOMP
    SMA(DO-214AC)
    肖特基二极管 单向 VR=28V IF=1A IR=500μA SMA
SS14 数据手册
Power Diodes Controlled Avalanche Features: • • • • • • • For surface mounted application Metal to silicon rectifier, majority carrier conduction Low forward voltage drop Easy pick and place High surge current capability Epitaxial construction High temperature soldering : 250°C / 10 seconds at terminals Mechanical Data Cases Terminals Polarity : Moulded plastic : Solder plated : Indicated by cathode band SMA/DO-214AC Dimensions : Inches (Millimetres) Maximum Ratings and Electrical Characteristics Rating at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20% Type Number SS14 SS16 SS110 Maximum Recurrent Peak Reverse Voltage 40 60 100 Maximum RMS Voltage 28 42 70 Maximum DC Blocking Voltage 40 60 100 Unit V www.element14.com www.farnell.com www.newark.com Page 19/05/12 V1.1 Power Diodes Controlled Avalanche Type Number SS14 SS16 Maximum average forward rectified current at TL (See Figure 1) 1 Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) 30 Maximum Instantaneous forward voltage (Note) at 1 A 0.5 0.75 10 0.8 V 0.05 5 Typical thermal resistance (Note 2) RθJL RθJA Unit A 0.5 Maximum DC reverse current at TA = 25°C at rated DC blocking voltage at TA = 100°C SS110 mA 0.5 28 88 Operating temperature range TJ -65 to +125 Storage temperature range TSTG °C / W -65 to +150 °C -65 to +150 Notes: 1. Pulse test with PW = 300 µ seconds, 1% duty cycle 2. Measured on PC Board with 0.2 × 0.2 inches (5 × 5 mm) copper pad areas Ratings and Characteristic Curves Figure 1 Maximum Forward Current Derating Curve Avarage Forward Current (A) Peak Forward Surge Current (A) Figure 2 Maximum Non-Repetitive Forward Surge Current Lead Temperature (°C) Number of Cycles at 60 Hz www.element14.com www.farnell.com www.newark.com Page 19/05/12 V1.1 Power Diodes Controlled Avalanche Rating and Characteristic Curves Figure 4 Typical Reverse Characteristics Instantaneous Forward Current (mA) Instantaneous Forward Current (A) Figure 3 Typical Forward Characteristics Percent of Rated Peak Reverse Voltage (%) Forward Voltage (V) Junction Capacitance (pF) Figure 5 Typical Junction Capacitance Reverse Voltage (V) Specification Table IF (AV) (A) 1 TC (°C) 105 VRRM (V) VFM maximum (V) IRM maximum (mA) 40 0.5 0.5 60 0.75 100 0.8 Package SS14 DO-214AC (SMA) 0.05 Part Number SS16 SS110 Important Notice : This data sheet and its contents (the "Information") belong to the members of the Premier Farnell group of companies (the "Group") or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group's liability for death or personal injury resulting from its negligence. Multicomp is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com Page 19/05/12 V1.1
很抱歉,暂时无法提供与“SS14”相匹配的价格&库存,您可以联系我们找货
