DATA SHEET
THIN FILM CHIP RESISTORS
High precision - high stability
RT series
0.05% TO 1%, TC 10 TO 50
sizes 0402/0603/0805/1206/
1210/2010/2512
Product specification – Oct 21, 2009 V.4
RoHS compliant
2
Chip Resistor Surface Mount
RT
10
0402 to 2512 (RoHS Compliant)
SERIES
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC
This specification describes
RT0402 to RT2512 high precision high stability chip resistors with
lead-free terminations made by
thin film process.
Both part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
APPLICATIONS
Converters
Printer equipment
Server board
Telecom
Consumer
FEATURES
Halogen Free Epoxy
RoHS compliant
Products with lead free
terminations meet RoHS
requirements
Pb-glass contained in electrodes,
resistor element and glass are
exempted by RoHS
Reducing environmentally
hazardous wastes
High component and equipment
reliability
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED)
RT XXXX F X X XX XXXX L
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0402 / 0603 / 0805 / 1206 / 1210 / 2010 / 2512
(2) TOLERANCE
W = ±0.05%
B = ±0.1%
C = ±0.25%
D = ±0.5%
F = ±1%
(3) PACKAGING TYPE
R = Paper/PE taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
B = 10 ppm/°C
C = 15 ppm/°C
D = 25 ppm/°C
E = 50 ppm/°C
(5) TAPING REEL
07 = 7 inch dia. Reel
10 = 10 inch dia. Reel
13 = 13 inch dia. Reel
(6) RESISTANCE VALUE
Saving of PCB space
There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need
to mention the last zero after R/K/M, e.g.1K2, not 1K20.
None forbidden-materials used
in products/production
Detailed resistance rules show in table of “Resistance rule of global part number”.
(7) DEFAULT CODE
Letter L is system default code for order only (Note)
number
Resistance code rule
Example
XRXX
(1 to 9.76 Ω)
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XMXX
(1 to 9.76 MΩ)
1M = 1,000,000 Ω
9M76= 9,760,000 Ω
ORDERING EXAMPLE
The ordering code of a RT0603 chip
resistor, TC 50 value 56 X with
±0.5% tolerance, supplied in 7-inch
tape reel is: RT0603DRE0756RL.
NOTE
1. All our RSMD products meet RoHS
compliant and Halogen Free. "LFP" of
the internal 2D reel label mentions
"Lead Free Process"
2. On customized label, "LFP" or specific
symbol can be printed
www.yageo.com
Oct 21, 2009 V.4
RT
SERIES
3
10
PHYCOMP BRAND ordering codes
Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp
brand products. For matching traditional types with size codes, please refer to “Comparison table of traditional
types and sizes”.
GLOBAL PART NUMBER (PREFERRED )
For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2.
12NC
CODE
2390
X
XX
(1)
(2)
(3)
X
(4)
START TCR (2) PACKING CODE TOL. (4)
WITH (1) (ppm/°C) BY SIZE (inch) (3) (%)
2390
XXXX
(5)
RESISTANCE
RANGE
The remaining 4 digits
7 = ±15
27 = 10'' reel 6 = ±0.5 represent the resistance
value with the last digit
6 = ±25
47 = 13'' reel 5 = ±0.25
indicating the multiplier
4 = ±50 0603: 04 = 7'' reel 4 = ±0.1 as shown in the table of
24 = 10'' reel 3 = ±0.05 “Last digit of 12NC”.
8 = ±10 0402: 07 = 7'' reel
7 = ±1
44 = 13'' reel
L
(6)
DEFAULT
CODE
(NOTE)
Letter L is
system
default
code for
order only
types and sizes
X
X
TF
X
(1)
(2)
START SIZE
WITH CODE
TF
(4)
(3)
TCR
TOL.
(ppm/°C) (%)
3 = 0402 4 = ±10 0 = ±1
2 = 0603 3 = ±15 1 = ±0.5
1 = 0805 1 = ±25 2 = ±0.25
0402: 10Ω ≤ R < 121KΩ
0 = 1206 2 = ±50 3 = ±0.1
0603: 5.1 Ω ≤ R ≤ 681 KΩ
5 = 1210
21 = 10'' reel
0805: 5.1Ω ≤ R ≤ 1.5 MΩ
7 = 2010
41 = 13'' reel
1206: 5.1Ω ≤ R ≤ 1.5 MΩ
6 = 2512
0805: 01 = 7'' reel
1206: 11 = 7'' reel
1210: 5.1Ω ≤ R ≤ 1.5 MΩ
31 = 10'' reel
2010: 10Ω ≤ R ≤ 1 MΩ
51 = 13'' reel
2512: 10Ω ≤ R ≤ 1 MΩ
1210: 12 = 7'' reel
4 = ±0.05
Example:
TF321 = RT0402, TC50, ±0.5% tolerance
Resistance decade (3)
Last digit
1 to 9.76 X
10 to 97.6 X
8
2010: 15 = 7'' reel
100 to 976 X
1
2512: 18 = 7'' reel
1 to 9.76 kX
2
Exceptions to above packing code definitions:
10 to 97.6 kX
3
0805 TC50 with 1%, supplied in 13" reel, the packing code is 02.
100 to 976 kX
4
0603 TC50 with 1%, supplied in 13" reel, the packing code is 03.
1 to 9.76 MX
5
2512 TC15, in 7" reel, the packing code is 35.
10 to 97.6 MX
6
32 = 10'' reel
52 = 13'' reel
2010 TC15, in 7" reel, the packing code is 31.
ORDERING EXAMPLE
The ordering code of a TF221 resistor, TC50, value 56 X, with ±0.5%
tolerance, supplied in tape of 5,000 units per reel is: 239040465609L or
RT0603DRE0756RL.
Example:
1X
33 kX
10 MX
9
1008 or 108
3303 or 333
1006 or 106
NOTE
1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process"
2. On customized label, "LFP" or specific symbol can be printed
www.yageo.com
Oct 21, 2009 V.4
RT
4
10
SERIES
MARKING
RT0805 / RT1206 / RT1210 / RT2010 / RT2512
Either resistance in E-24 or E-96: 4 digits
00
YNSC004
Fig. 1 Value = 10 kΩ
First three digits for significant figure and 4th digit for number of zeros
RT0603
E-24 series: 3 digits
ynsc015
Fig. 2 Value = 12 kΩ
First two digits for significant figure and 3rd digit for number of zeros
E-96 series: 3 digits for 0603±1% EIA-96 marking method
Fig. 3 Value = 12.4 kΩ
RT0402 / RESISTANCE VALUE IS NOT IN E-24 / E96 SERIES
ynsc007
No marking
Fig. 4
For further marking information, please see special data sheet “Chip resistors marking”.
CONSTRUCTION
The resistors are constructed out of a high-grade ceramic
body. Internal metal electrodes are added at each end and
connected by a resistive layer. The resistive layer is adjusted
to give the approximate required resistance and laser cutting
of this resistive layer that achieves tolerance trims the value.
The resistive layer is covered with a protective coat and
printed with the resistance value. Finally, the two external
terminations (matte tin) are added. See fig. 5.
OUTLINES
For dimension see Table 1
marking layer
protective coat
resistive layer
inner electrode
H
termination (Ni / matte tin)
ceramic substrate
I2
DIMENSION
I1
Table 1 For outlines see fig. 5
TYPE
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
RT0402 1.00 ±0.10 0.50 ±0.05 0.30 ±0.05 0.20 ±0.10
RT0603 1.60 ±0.10 0.80 ±0.10 0.45 ±0.10 0.25 ±0.15
RT0805 2.00 ±0.10 1.25 ±0.10 0.50 ±0.10 0.35 ±0.20
RT1206 3.10 ±0.10 1.60 ±0.10 0.55 ±0.10 0.45 ±0.20
0.25 ±0.10
W
0.25 ±0.15
0.35 ±0.20
0.40 ±0.20
RT1210 3.10 ±0.10 2.60 ±0.15 0.55 ±0.10 0.50 ±0.20 0.50 ±0.20
RT2010 5.00 ±0.10 2.50 ±0.15 0.55 ±0.10 0.60 ±0.20 0.50 ±0.20
RT2512 6.35 ±0.10 3.20 ±0.15 0.55 ±0.10 0.60 ±0.20 0.50 ±0.20
YNSC064
L
Fig. 5 Chip resistor outlines
www.yageo.com
Oct 21, 2009 V.4
RT
5
10
SERIES
ELECTRICAL CHARACTERISTICS
Table 2
TYPE
RT0402
RT0603
Operating
Temperature
Range
–55 °C to +125 °C
–55 °C to +125 °C
Power
Rating
1/16W
Max. Max.
Dielectric
T.C.R.
Work Overload Withstand
(ppm/°C)
(1)
Vol.
Vol.
Vol.
50V
1/10W 75V
100V
150V
75V
100V
±0.05%
±0.1%
±0.25%
±0.5%
±1.0%
±50
10~121k
10~121k
10~121k
10~121k
±25
10~121k
10~121k
10~121k
±15
10~100k
10~100k
±10
10~100k
10~100k
±50
10~681k 5.1~681k 5.1~681k 5.1~681k
±25
1k~47k
10~681k
10~681k
10~681k
±15
1k~47k
10~100k
10~100k
±10
1k~47k
10~100k
10~100k
±50
RT0805
–55 °C to +125 °C
1/8W
150V
300V
200V
RT1210
RT2010
RT2512
–55 °C to +125 °C
–55 °C to +125 °C
–55 °C to +125 °C
–55 °C to +125 °C
1/4W
1/4W
1/2W
3/4W
200V
200V
200V
200V
400V
400V
400V
400V
300V
400V
400V
400V
--- 10~1.5M 5.1~1.5M 5.1~1.5M 5.1~1.5M
±25
100~100k 10~1.5M 10~1.5M 10~1.5M
±15
100~100k
10~100k
10~100k
±10
100~100k
10~100k
10~100k
±50
RT1206
Resistance Range (E-24/E-96 series)(2) & Tolerance
±25
±15
100~100k
10~100k
10~100k
±10
100~100k
10~100k
10~100k
±50
10~1M
5.1~1M
5.1~1M
5.1~1M
±25
100~100k
10~1M
10~1M
10~1M
±15
100~100k
10~100k
10~100k
±10
100~100k
10~100k
10~100k
±50
10~1M
10~1M
10~1M
10~1M
±25
100~100k
10~1M
10~1M
10~1M
±15
100~100k
10~100k
10~100k
±10
100~100k
10~100k
10~100k
±50
10~1M
10~1M
10~1M
10~1M
±25
100~100k
10~1M
10~1M
10~1M
±15
100~100k
10~100k
10~100k
±10
100~100k
10~100k
10~100k
NOTE
1. The maximum working voltage that may be continuously applied to the resistor element, see “IEC publication 60115-8”
2. Value of E-192 series is on request
www.yageo.com
Oct 21, 2009 V.4
RT
6
10
SERIES
FOOTPRINT AND SOLDERING PROFILES
For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
REEL DIMENSION
RT0402
RT0603
RT0805
RT1206
RT1210
RT2010
RT2512
7" (178 mm)
10,000
5,000
5,000
5,000
5,000
10" (254 mm)
20,000
10,000
10,000
10,000
10,000
13" (330 mm)
50,000
20,000
20,000
20,000
20,000
7" (178 mm)
4,000
4,000
Paper/PE taping reel (R)
Embossed taping reel (K)
NOTE
1. For Paper/Embossed tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”
FUNCTIONAL DESCRIPTION
POWER RATING
Each type rated power at 70°C:
RT0402=1/16 W, RT0603=1/10 W, RT0805=1/8 W,
RT1206=1/4 W, RT1210=1/4 W, RT2010=1/2 W,
RT2512=3/4 W.
RATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V=√(P X R)
or max. working voltage whichever is less
Where
handbook, halfpage
MLB206_1
P
(%Prated )
100
50
70
100 125
o
Tamb ( C)
Fig. 6 Maximum dissipation (P) in percentage of rated power as a
function of the operating ambient temperature (Tamb)
V=Continuous rated DC or
AC (rms) working voltage (V)
P=Rated power (W)
R=Resistance value (X)
www.yageo.com
Oct 21, 2009 V.4
RT
SERIES
7
10
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Temperature
Coefficient of
Resistance
(T.C.R.)
IEC 60115-1 4.8
At +25/–55 °C and +25/+125 °C
Refer to table 2
Formula:
R2–R1
T.C.R= ------------------------- ×106 (ppm/°C)
R1(t2–t1)
Where
t1=+25 °C or specified room temperature
t2=–55 °C or +125 °C test temperature
R1=resistance at reference temperature in ohms
R2=resistance at test temperature in ohms
Life/Endurance
IEC 60115-1 4.25.1
At 70±5 °C for 1,000 hours, RCWV applied for
1.5 hours on, 0.5 hour off, still air required
±(0.5%+0.05 Ω)
High
Temperature
Exposure/
Endurance at
Upper Category
Temperature
IEC 60068-2-2
1,000 hours at 155±5 °C, unpowered
±(0.5%+0.05 Ω)
Moisture
Resistance
MIL-STD-202G Method-106G
Each temperature / humidity cycle is defined at 8
hours, 3 cycles / 24 hours for 10d. with 25 °C /
65 °C 95% R.H, without steps 7a & 7b,
unpowered
±(0.5%+0.05 Ω)
Parts mounted on test-boards, without
condensation on parts
Measurement at 24±2 hours after
test conclusion
Thermal Shock
MIL-STD-202G Method-107G
-55/+125 °C
Number of cycles required is 300. Devices
unmounted
±(0.5%+0.05 Ω) for 10 KΩ to
10 MΩ
±(0.5%+0.05 Ω) for others
Maximum transfer time is 20 seconds. Dwell time
is 15 minutes. Air – Air
Humidity
(steady state)
IEC 60115-1 4.37
Steady state for 1000 hours at 40 °C / 95% R.H.
±(0.5%+0.05 Ω)
RCWV applied for 1.5 hours on and
0.5 hour off
www.yageo.com
Oct 21, 2009 V.4
RT
SERIES
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Short Time Overload
IEC60115-1 4.13
2.5 times of rated voltage or maximum
overload voltage whichever is less for 5 sec at
room temperature
±(0.5%+0.05 Ω)
Chips mounted on a 90mm glass epoxy resin
PCB (FR4)
±(0.25%+0.05 Ω)
Board Flex/
Bending
IEC 60068-2-21
8
10
No visible damage
No visible damage
Bending: see table 6 for each size
Bending time: 60±5 seconds
Low Temperature
Operation
IEC 60068-2-1
The resistor shall be subjected to a DC rated
voltage for 1.5 h-on, 0.5 h-off, at -55±3 °C
This constitutes shall be repeated for 96 hours
±(0.5%+0.05 Ω)
No visible damage
However the applied voltage shall not exceed
the maximum operating voltage
Insulation Resistance
IEC 60115-1 4.6
Rated continuous overload voltage (RCOV)
for 1 minute
≥10 GΩ
Details see below table 5
Dielectric Withstand
Voltage
Solderability
- Wetting
IEC 60115-1 4.7
Maximum voltage (Vrms) applied for 1 minute
No breakdown or flashover
IPC/JEDEC J-STD-002B test B
Electrical Test not required
Magnification 50X
SMD conditions:
Well tinned (≥95%
covered)
No visible damage
1st step: method B, aging 4 hours at 155°C
dry heat
2nd step: leadfree solder bath at 245±3°C
Dipping time: 3±0.5 seconds
- Leaching
- Resistance to
Soldering Heat
IPC/JEDEC J-STD-002B test D
Leadfree solder, 260 °C, 30 seconds
immersion time
No visible damage
IEC 60068-2-58
Condition B, no pre-heat of samples.
Leadfree solder, 260 °C, 10 seconds
immersion time
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
±(0.5%+0.05 Ω)
No visible damage
www.yageo.com
Oct 21, 2009 V.4
RT
SERIES
9
10
Table 5 Criteria of rated continued working voltage and overload voltage
TYPE
Voltage (DC/unit: V); (AC/ unit: Vrms)
RT0402
RT0603
RT0805
RT1206
RT1210
RT2010
RT2512
100
100
300
500
500
500
500
Table 6 Bending for sizes 0402 to 2512
TYPE
Specification (mm)
RT0402
RT0603
RT0805
RT1206
RT1210
RT2010
RT2512
5
3
3
2
2
2
2
www.yageo.com
Oct 21, 2009 V.4
RT
SERIES
10
10
REVISION HISTORY
REVISION DATE
Version 4
CHANGE NOTIFICATION
Oct 21, 2009 -
DESCRIPTION
- Test Items and methods updated
- Test requirements upgraded
Version 3
Jul 11, 2008
- Change to dual brand datasheet that describe RT0402 to RT2512 with
RoHS compliant
- Description of "Halogen Free Epoxy" added
- Define global part number
- Modify electrical characteristic
Version 2
Dec 26, 2005 -
- New datasheet for thin film high precision - high stability chip resistors sizes
of 0201/0402/0603/0805/1206/1210/2010/2512, 1%, 0.5%, 0.25%, 0.1%,
0.05%, TC25/50 with lead-free terminations
- Replace the 0402 to 1210 parts of pdf files: TFx10_1_1, TFx11_.5_2,
TFx12_.25_2, TFx13_.1_3, TFx14_.05_1, TFx20_1_2, TFx21_.5_2,
TFx22_.25_2, TFx23_.1_2, TFx24_.05_1, and combine into a document.
- Test method and procedure updated
- PE tape added (paper tape will be replaced by PE tape)
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any
product change will be announced by PCN.”
www.yageo.com
Oct 21, 2009 V.4
