JWPF CONNECTOR
2.0mm pitch/Disconnectable Crimp style connectors
(Combined use for both wire-to-board and wire-to-wire connections)
4
Specifications ––––––––––––––––––
This JWPF connector can be used for the
place of which especially waterproof is
required.
This is the wire-to-board connector that
is grade 7 ingress protection of JIS C
0920 (IPX7 of IEC 60529).
• Waterproof performance
• Contained seal ring
• Solid rubber seal
• Double-spring construction
• Housing-to-terminal locks
• Inner housing lock
• Header for use specifically with resin coated
("potted") PC board
• Current rating: 3 A AC, DC (AWG #22)
• Voltage rating: 100 V AC, DC
• Temperature range: -55˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 15 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,000 VAC/minute
• Applicable wire: AWG #26 to #22
0.13 to 0.33 mm2
Insulation O.D./ 1.4 to 1.7 mm
• Waterproof grade: Grade 7 ingress protection of JIS C 0920
(IPX7 of IEC 60529 )
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
Standards –––––––––––––––––––––
Recognized E60389
R50326661
PC board layout and Assembly layout
Double-row type
Single-row type
7
+0.1
±0.05
21
16.6
±0.05
4
2.45
±0.05
6
2 ±0.05
3
2.05 ±0.05
2
16.6
21
1.5
φ1±0.05
6
φ1±0.05
φ1.1
1.5
2
+0.1
φ1.1
±0.05
11
2±0.05
Note: 1. The above figure is the figure viewed from the connector mounting side.
2. Tolerances are non-cumulative: ±0.05 mm for all centers.
3. Hole dimension differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should
be larger. The dimensions above should serve as a guideline. Contact JST for details.
1
JWPF CONNECTOR
Contact
Applicable wire
mm2
AWG#
Model No.
SWPR-001T-P025
0.13∼0.33
Insulation O.D
(mm)
Q'ty/reel
1.4∼1.7
8,200
26∼22
Material and Finish
Copper alloy, tin-plated (reflow treatment)
11.7
6
RoHS compliance
4.5
Contact
Applicator
Dies
Crimping
machine Crimp applicator
SWPR-001T-P025 AP-K2N
MKS-L
Crimp applicator with dies
MK/SWPR/T-001-025 APLMK SWPR/T001-025
Housing
(2 circuits)
7
16.5
5.5
Circuits
Model No.
Q'ty/bag
2
02R-JWPF-VSLE-S
03R-JWPF-VSLE-S
04R-JWPF-VSLE-S
06R-JWPF-VSLE-D
08R-JWPF-VSLE-D
1,000
3
2
4
6.7
6
8
Material
PBT, UL94V-0, natural (white)
(3 circuits)
7
16.5
8.7
2
5.5
(4 circuits)
7
16.5
(6 circuits)
2
10.7
5.5
11
16.5
8.7
2
9.5
4
(8 circuits)
11
2
10.7
9.5
4
Note: Housing comes with seal rubber plate.
2
16.5
RoHS compliance
1,000
1,000
1,000
1,000
JWPF CONNECTOR
Shrouded header
(2 circuits)
(3.3)
16.6
8.1
Circuits
Model No.
Q'ty/box
2
B02B-JWPF-SK-R
B03B-JWPF-SK-R
B04B-JWPF-SK-R
B06B-JWPF-SK-R
B08B-JWPF-SK-R
825
3
4
8
525
330
270
2
7
6
650
Material and Finish
1.2
Press pin: Copper alloy, tin-plated (reflow treatment)
Seal ring: Silicon rubber
Seal ring holder: PBT, UL94V-0, yellow
Wafer: Glass-filled PBT, UL94V-0, natural (white)
(3 circuits)
16.6
8.4
16.6
8.4
16.6
12.8
4
16.6
12.5
RoHS compliance This product displays (LF)(SN) on a label.
2
9
(3.3)
1.2
2
(3.3)
11
(4 circuits)
1.2
(6 circuits)
2
9.8
(3.3)
1.2
(8 circuits)
(3.3)
11.8
2
4
1.2
3
很抱歉,暂时无法提供与“SWPR-001T-P025”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.23650
- 4100+0.17710
- 8200+0.11770
- 国内价格
- 20+0.25324
- 820+0.20424
- 3280+0.17711
- 8200+0.14414
- 国内价格
- 1+0.21010
- 500+0.14080
- 4100+0.12210
- 8200+0.11110
