JWPF CONNECTOR
2.0mm pitch/Disconnectable Crimp style Wire-to-wire connectors (waterproot type)
Specifications –––––––––––––––––––
• Current rating: 3 A AC, DC (AWG #22)
• Voltage rating: 100 V AC, DC
• Temperature range: -55˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 15 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,000 VAC/minute
• Applicable wire: AWG #26 to #22
0.13 to 0.33 mm2
Insulation O.D./ 1.4 to 1.7 mm
• Waterproof grade: Grade 7 ingress protection of JIS C 0920
(IPX7 of IEC 60529 )
This JWPF connector can be used for the
place of which especially waterproof is
required.
This is the wire-to-wire connector that is
grade 7 ingress protection of JIS C 0920
(IPX7 of IEC 60529).
*Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
*Compliant with RoHS.
• Waterproof performance
• Contained seal ring
• Solid rubber seal
• Double-spring construction
• Housing-to-terminal locks
• Inner-housing lock
Standards ––––––––––––––––––––––
Recognized E60389
2 R50326661
Assembly layout
30.2
4
4
JST
Contact
Applicable wire
Model No.
Receptacle
contact
Tab contact
mm2
Tab contact
AWG #
Insulation
O.D.
(mm)
Q’ty/
reel
26∼22
1.4∼1.7
8,200
SWPT-001T-P025 SWPR-001T-P025 0.13∼0.33
15.2
4.5
2
Material and Finish
7.5
Tab contact: Phosphor bronze, tin-plated (reflow treatment)
Receptacle contact: Copper alloy, tin-plated (reflow treatment)
RoHS compliance
Note: Contact JST for brass products.
Receptacle contact
Contact
SWPT-001T-P025
1
AP-K2N
MKS-L
Applicator
Dies
4.5
Crimp applicator with dies
MK/SWPR/T-001-025 APLMK SWPR/T001-025
SWPR-001T-P025
Note: Contact JST tor fully automatic crimping applicator.
11.7
6
Crimping
machine Crimp applicator
JWPF CONNECTOR
Housing
Material: PBT, UL94V-0, natural (white)
Tab housing (for Tab contact)
Circuits
Receptacle housing (for Receptacle contact)
02T-JWPF-VSLE-S
25.8
Q’ty/
bag
02R-JWPF-VSLE-S
7
5.5
8.1
Q’ty/
bag
16.5
2
2
2
03T-JWPF-VSLE-S
25.8
Q’ty/
bag
1,000
6.7
7
1,000
03R-JWPF-VSLE-S
7
5.5
8.4
Q’ty/
bag
16.5
Q’ty/
bag
8.4
1,000
8.7
9
1,000
04T-JWPF-VSLE-S
25.8
2
2
3
04R-JWPF-VSLE-S
7
5.5
16.5
Q’ty/
bag
06T-JWPF-VSLE-D
25.8
Q’ty/
bag
12.8
1,000
10.7
2
1,000
11
2
4
06R-JWPF-VSLE-D
11
9.5
4
4
16.5
Q’ty/
bag
08T-JWPF-VSLE-D
25.8
Q’ty/
bag
12.1
4
1,000
2
1,000
8.7
9.8
2
6
08R-JWPF-VSLE-D
11
9.5
4
16.5
Q’ty/
bag
2
1,000
10.7
11
2
8
1,000
RoHS compliance
Note: 1. Receptacle housing comes with seal rubber plate.
2. Tab housing comes with seal rubber plate, seal ring and seal ring holder.
2
很抱歉,暂时无法提供与“SWPT-001T-P025”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25493
- 820+0.20414
- 3280+0.17592
- 8200+0.15899
