PCB.SMAFRA.HT
PCB.SMAFRA.HT
    TAOGLASLIMITED
    插件
    射频和同轴连接器 弯插 SMA 连接器 插孔 母形插口 50Ω
PCB.SMAFRA.HT 数据手册
SPECIFICATION Part No. : PCB. SMAFRA.HT Product Name : SMA(F)RA Through Hole PCB Mount Jack Feature : SMA(F) Jack Through Hole PCB Jack Frequency Range: DC up to 6GHz Finish: Gold Dimensions: 13.75mm*15.1mm RoHS Compliant SPE-14-8-100/C/AD Page 1 of 3 1. Introduction The PCB. SMAFRA.HT connector was designed to be mounted on a PCB. The maximum thickness of PCB that the connector can be used with is 0.4mm. The connector pin is directly soldered onto pads on the PCB. The connector is a standard SMA(F)RA Jack. Taoglas connectors are all RoHS compliant. 2. Specification ELECTRICAL Impedance 50Ω Frequency Range DC~6 GHz Working Voltage Max. ≤170 Vrms Dielectric withstanding Voltage 500 Vrms Insulation Resistance ≥1000M MΩ MECHANICAL Connector Dimension 13.75mm*15.1mm Connector Pin Diameter 1.25 mm Connector Type SMA(F)RA Jack ENVIRONMENTAL RoHS compliant Operating Temperature -40°C to +85°C SPE-14-8-100/C/AD Page 2 of 3 3. Connector Drawing Name Material Finish QTY 1 Body Brass Gold 1 2 Insulator Teflon White 1 3 Female Contact Brass Gold 1 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © 2014, Taoglas Ltd. SPE-14-8-100/C/AD Page 3 of 3
PCB.SMAFRA.HT 价格&库存
很抱歉,暂时无法提供与“PCB.SMAFRA.HT”相匹配的价格&库存,您可以联系我们找货
PCB.SMAFRA.HT
  • 3+19.826993+2.56515
库存:1287
PCB.SMAFRA.HT
  • 20+42.4263520+5.48898
  • 50+27.4672450+3.55362
  • 100+25.35550100+3.28041
  • 300+24.29800300+3.14360
  • 500+21.93711500+2.83815
库存:1060
PCB.SMAFRA.HT
    • 4+23.104634+2.98920
    库存:6
    PCB.SMAFRA.HT
      • 1+60.91200
      • 200+23.57640
      • 500+22.74480
      • 1000+22.33440
      PCB.SMAFRA.HT
      • 1+42.628991+5.51520
      • 10+36.2421210+4.68889
      • 25+33.9712725+4.39509
      • 50+32.3474450+4.18501
      • 100+30.80185100+3.98505
      • 250+28.87364250+3.73558
      • 500+27.49583500+3.55732
      • 1000+26.184391000+3.38765
      • 2500+24.546822500+3.17579
      库存:13463
