USB-A-S-F-B-VU
USB-A-S-F-B-VU
    SAMTEC(申泰)
    插件
    USB连接器 Type-A 4P 弯插 端口数:1 额定电压:30V 工作温度:-50℃~+85℃
USB-A-S-F-B-VU 数据手册
REVISION Y USB-A-S-X-X-VU-XX NOTES: DO NOT SCALE FROM THIS PRINT TYPE -A 1. C REPRESENTS A CRITICAL DIMENSION. 2. VERIFY -S PLATING, VISUALLY CHECK -F ONLY. 3. ALL PARTS RoHS COMPLIANT WITH OR WITHOUT -RC. EI OPTION -RC: RoHS COMPLIANT LEAD FREE WITH HIGH TEMP INSULATOR CONFIGURATION -S: SINGLE PLATING -F: 1 µ'' SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (SEE NOTE 3 FOR -RC OPTION) -S: 30 µ'' SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (SEE NOTE 3 FOR -RC OPTION) RA TERMINATION -VU: VERTICAL UPRIGHT COLOR -B: BLACK -W: WHITE .031±.004 0.80±0.10 .101±.004 2.56±0.10 .073±.002 1.85±0.05 .756±.008 19.20±0.20 C6 .236 6.00 .687±.012 17.46±0.30 .571±.005 14.50±0.13 .202±.004 5.12±0.10 .492±.004 12.50±0.10 POS 4 .433±.004 11.00±0.10 POS 1 C7 'A' .049±.004 1.25±0.10 C1 .079±.005 2.00±0.13 C10 .456 11.58 .276±.005 7.00±0.13 C8 .114±.008 2.90±0.20 .280±.008 7.10±0.20 C9 .214 5.44 .010±.002 0.25±0.05 .283±.010 7.20±0.25 .079 2.00 .079 2.00 .020 0.50 .276 7.00 .214 5.44 C2 SPACER 01 .079 2.00 04 .036 PTH 0.92 .070 PTH 1.78 RECOMMENDED PCB LAYOUT C3 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS .X: .01 [.3] .XX: .005 [.13] .XXX: .004 [.10] MATERIAL: ANGLES 2 .079±.005 2.00±0.13 DETAIL 'A' SCALE 4 : 1 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: NYLON 9T, UL 94V-0 CONTACT OR TERMINAL: PHOS BRONZE BACK SHIELD: NICKEL PLATED PHOS BRONZE FRONT SHIELD: TIN PLATED PHOS BRONZE MAX FLASH ALLOWED: .051 MAX GATE VESTIGE: .051 F:\DWG\MISC\MKTG\USB-A-S-X-X-VU-XX-MKT.SLDDRW .020±.005 C5 0.50±0.13 .079±.005 2.00±0.13 C4 .020±.005 0.50±0.13 SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: USB A, SINGLE, VERTICAL UPRIGHT THOUGH HOLE DWG. NO. USB-A-S-X-X-VU-XX BY: LENNY K 10/19/06 SHEET 1 OF 1
USB-A-S-F-B-VU
1. 物料型号:通常指的是连接器的具体型号,例如USB-A-S-F-B-VU可能是一个特定的型号标识。
2. 器件简介:会介绍连接器的基本功能和用途,比如USB-A连接器用于实现USB接口的连接,支持数据传输和电源供应。
3. 引脚分配:详细说明连接器的每个引脚的功能,如VCC(电源)、D-(数据线负)、D+(数据线正)、GND(地线)等。
4. 参数特性:包括电气参数、机械参数和环境参数等,如工作电压、电流承受能力、插拔次数、工作温度范围等。
5. 功能详解:深入解释连接器的工作原理和功能,如USB协议支持、数据传输速率等。
6. 应用信息:介绍连接器在实际产品中的应用场景,如电脑、手机、USB设备等。
7. 封装信息:描述连接器的物理尺寸、形状和安装方式,如直插式、贴片式等。
USB-A-S-F-B-VU 价格&库存
很抱歉,暂时无法提供与“USB-A-S-F-B-VU”相匹配的价格&库存,您可以联系我们找货
USB-A-S-F-B-VU
    • 1+6.43680
    • 10+6.27480
    • 30+6.17760
    库存:12
    USB-A-S-F-B-VU
    • 1+6.43147
    • 10+5.93674
    • 30+5.83779
    • 100+5.54095
    USB-A-S-F-B-VU
    • 50+13.7803950+1.78620
    • 250+9.22180250+1.19532
    • 500+7.86818500+1.01987
    • 1000+5.825191000+0.75506
    • 2500+5.541672500+0.71831
    库存:10825
