PSG03463
PSG03463
    AIRBORN
    音频和视频连接器 5Pin
PSG03463 数据手册
PCB DIN Socket 5 way Specifications Connector Type No. of Contacts Gender Connector Colour Contact Termination Contact Plating Pin Size Connector Mounting Current Rating : Audio, DIN :5 : Receptacle : Black : Solder : Silver : 3.5mm : PCB : AC : 100V 1A DC : 12V 2A Max. Contact Resistance : 100MΩ (after 1,000 cycles insertion/extraction) Dielectric Withstanding Voltage : 500V AC for 1 minute Min. Insulation Resistance : 100MΩ at 500V AC. Applied for 1 minute Max. Insertion Force : 3kg Extraction Force : 2kg to 2.5kg Dimensions : Millimetres www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 25/02/13 V1.0 PCB DIN Socket 5 way Schematic Item Designation 1 Housing Material Finish 2 Cover PBT + 30%G Black Colour 3 Earth Terminal 0.2T Phosphor Bronze 4 Terminal 0.7T Brass Silver Plating Part Number Table Description Part Number DIN Socket, PCB, 5P 180° PSG03463 Important Notice : This data sheet and its contents (the “Information”) belong to the members of the Premier Farnell group of companies (the “Group”) or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Group assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Group was aware of the possibility of such loss or damage arising) is excluded. This will not operate to limit or restrict the Group’s liability for death or personal injury resulting from its negligence. pro - SIGNAL is the registered trademark of the Group. © Premier Farnell plc 2012. www.element14.com www.farnell.com www.newark.com www.cpc.co.uk Page 25/02/13 V1.0
PSG03463 价格&库存
很抱歉,暂时无法提供与“PSG03463”相匹配的价格&库存,您可以联系我们找货
PSG03463
    • 1+2.92745
    库存:20
