MT3608
High Efficiency
1.2MHz Current Mode Step-Up Converter
FEATURES
GENERAL DESCRIPTION
Integrated 80mΩ Power MOSFET
2.5V to 24V Input Voltage
1.2MHz Fixed Switching Frequency
Internal 4A Switch Current Limit
Adjustable Output Voltage
Internal Compensation
Up to 28V Output Voltage
Automatic Pulse Frequency Modulation
Mode at Light Loads
up to 93% Efficiency
Available in a 6-Pin SOT23-6 Package
APPLICATIONS
Battery-Powered Equipment
Set-Top Boxed
LCD Bais Supply
DSL and Cable Modems and Routers
Networking cards powered from PCI or
PCI express slots
The MT3608 is a constant frequency, 6-pin
SOT23 current mode step-up converter
intended for small, low power applications. The
MT3608 switches at 1.2MHz and allows the use
of tiny, low cost capacitors and inductors 2mm
or less in height. Internal soft-start results in
small inrush current and extends battery life.
The MT3608 features automatic shifting to
pulse frequency modulation mode at light loads.
The MT3608 includes under-voltage lockout,
current limiting, and thermal overload protection
to prevent damage in the event of an output
overload. The MT3608 is available in a small 6pin SOT-23 package.
TYPICAL APPLICATION
VIN
CIN
22μF
SW
MT3608
EN
GND
FB
D
100
VOUT=5V
VOUT=5V
95
R1
110k
1%
R2
15k
1%
COUT
22μF
90
Efficiency(%)
L 4.7μH
VIN
85
80
VIN=3V
VIN=3.7V
75
VIN=4.2V
70
Figure 1. Basic Application Circuit
MT3608 Rev 3.1
400
600
800
1000
Load Current(mA)
www.aerosemi.com
Aerosemi Proprietary Information.Unauthorized Photocopy and Duplication Prohibited.
All Rights Reserved.
1
MT3608
ABSOLUTE MAXIMUM RATINGS
(Note 1)
VIN,EN voltages……………………-0.3V to 26V
FB Voltages………………................-0.3V to 6V
SW Voltage…………………….…...-0.3V to 30V
Power Dissipation…………………………...0.6W
Thermal Resistance θJC………………..130°C/W
Thermal Resistance θJA………………..250°C/W
Junction Temperature(Note2)…….............160°C
Operating Temperature Range…..-40°C to 85°C
Lead Temperature(Soldering,10s)……......260°C
Storage Temperature Range…...-65°C to 150°C
ESD HBM(Human Body Mode)……………...2kV
ESD MM(Machine Mode)……………..…….200V
PACKAGE/ORDER INFORMATION
Order Part
Number
Package
Top Marking
MT3608
SOT23-6
A28YNN
TOP VIEW
SW
1
6
NC
GND
2
5
VIN
FB
3
4
EN
6-LEAD PLASTIC SOT-23
TJMAX = 160°C, θJA = 250°C/ W, θJC = 130°C/W
Y:Year, NN: Internal Code
PIN DESCRIPTION
Pin Name
Pin Number
SW
1
GND
2
FB
3
EN
4
VIN
NC
5
6
MT3608 Rev 3.1
Description
Power Switch Output. SW is the drain of the internal MOSFET
switch. Connect the power inductor and output rectifier to SW.
Ground Pin
Feedback Input. The FB voltage is 0.6V. Connect a resistor
divider to FB.
Regulator On/Off Control Input. A high input at EN turns on the
converter, and a low input turns it off. When not used, connect
EN to the input supply for automatic startup.
Input Supply Pin. Must be locally bypassed.
No Connect
www.aerosemi.com
2
MT3608
ELECTRICAL CHARACTERISTICS (Note 3)
(VIN=VEN=5V,TA = 25°C, unless otherwise noted.)
PARAMETER
CONDITIONS
Operating Input Voltage
Under Voltage Lockout
Hysteresis
Current (Shutdown)
VEN= 0V
Quiescent Current
VFB=0.7V,No switch
(PFM)
Quiescent Current
VFB=0.5V,switch
(PWM)
Switching Frequency
Maximum Duty Cycle
VFB = 0V
EN Input High Voltage
EN Input Low Voltage
FB Voltage
SW On Resistance
SW Current Limit
VIN= 5V, Duty cycle=50%
SW Leakage
VSW = 20V
Thermal Shutdown
MIN
2.5
TYP
MAX
24
2.4
100
mV
0.1
1
µA
70
150
µA
1.0
2.0
mA
0.4
0.612
150
MHz
V
V
V
mΩ
A
μA
1.2
90
1.5
0.588
UNIT
V
V
0.6
80
4
1
155
Note 1: Absolute Maximum Ratings are those values beyond which the life of a device may be impaired.
Note 2: TJ is calculated from the ambient temperature TA and power dissipation PD according to the following
formula: TJ = TA + (PD) x (250°C/W).
Note 3: 100% production test at 25°C. Specifications over the temperature range are guaranteed by design
and characterization.
MT3608 Rev 3.1
www.aerosemi.com
3
MT3608
TYPICAL PERFORMANCE CHARACTERISTICS
Efficiency vs. Load Current
VOUT=5V
100
95
95
90
90
Efficiency(%)
Efficiency(%)
100
85
VIN=3V
80
85
70
200
400
VIN=12V
75
VIN=4.2V
VIN=5V
80
VIN=3.7V
75
VOUT=18V
600
800
VIN=16V
70
1000
Load Current(mA)
Line/Load Regulation
VOUT=5V
5
400
500
VIN=3V
18
VIN=5V
VIN=3.7V
VIN=12V
VIN=4.2V
VIN=16V
4.5
17
400
600
800
1000
Load Current(mA)
200
300
400
500
Load Current(mA)
Operation Frequency vs. Input Voltage
VOUT=5V
1.3
VOUT=18V
1.3
1.2
Frequency(MHz)
1.2
Frequency(MHz)
300
VOUT=18V
19
Output Voltage(V)
Output Voltage(V)
5.5
200
Load Current(mA)
1.1
1
1.1
1
0.9
0.9
3
3.2
3.4
3.6
3.8
Input Voltage(V)
MT3608 Rev 3.1
4
4.2
4
6
8
10
12
14
16
Input Voltage(V)
www.aerosemi.com
4
MT3608
FUNCTIONAL BLOCK DIAGRAM
EN
SW
Shutdown
Circuitry
FB
Error
Amplifier
PWM
Compartor
M1
Control Logic
VREF
Current Sense
Compartor
VIN
UVLO
OSC
GND
Figure 2. MT3608 Block Diagram
FUNCTIONAL DESCRIPTION
The MT3608 uses a fixed frequency, peak
current mode boost regulator architecture to
regulate voltage at the feedback pin. The
operation of the MT3608 can be understood
by referring to the block diagram of Figure 2.
At the start of each oscillator cycle the
MOSFET is turned on through the control
circuitry. To prevent sub-harmonic oscillations
at duty cycles greater than 50 percent, a
stabilizing ramp is added to the output of the
current sense amplifier and the result is fed
into the negative input of the PWM comparator.
When this voltage equals The output voltage
of the error amplifier the power MOSFET is
MT3608 Rev 3.1
turned off. The voltage at the output of the
error amplifier is an amplified version of the
difference between the 0.6V bandgap
reference voltage and the feedback voltage. In
this way the peak current level keeps the
output in regulation. If the feedback voltage
starts to drop, the output of the error amplifier
increases. These results in more current to
flow through the power MOSFET, thus
increasing the power delivered to the output.
The MT3608 has internal soft start to limit the
amount of input current at startup and to also
limit the amount of overshoot on the output.
www.aerosemi.com
5
MT3608
APPLICATIONS INFORMATION
Setting the Output Voltage
The internal reference VREF is 0.6V
(Typical).The output voltage is divided by a
resistor divider,R1 and R2 to the FB pin. The
output voltage is given by
R
VOUT = VREF 1 + 1
R2
Inductor Selection
The recommended values of inductor are 4.7
to 22μH. Small size and better efficiency are
the major concerns for portable device, such
as MT3608 used for mobile phone. The
inductor should have low core loss at 1.2MHz
and low DCR for better efficiency. To avoid
inductor saturation current rating should be
considered.
Capacitor Selection
Input and output ceramic capacitors of 22μF
are recommended for MT3608 applications.
For better voltage filtering, ceramic capacitors
with low ESR are recommended. X5R and
X7R types are suitable because of their wider
voltage and temperature ranges.
Layout Consideration
For best performance of the MT3608, the
following guidelines must be strictly followed.
➢ Input and Output capacitors should be
placed close to the IC and connected to
ground plane to reduce noise coupling.
➢ The GND should be connected to a strong
ground plane for heat sinking and noise
protection.
➢ Keep the main current traces as possible
as short and wide.
➢ SW node of DC-DC converter is with high
frequency voltage swing. It should be kept
at a small area.
➢ Place the feedback components as close
as possible to the IC and keep away from
the noisy devices.
VOUT
D
VIN
L
COUT
PIN1
GND
MT3608(K)
R2
VIA TO VOUT
CIN
R1
Diode Selection
Schottky diode is a good choice for MT3608
because of its low forward voltage drop and
fast reverses recovery. Using Schottky diode
can get better efficiency. The high speed
rectification is also a good characteristic of
Schottky diode for high switching frequency.
Current rating of the diode must meet the root
mean square of the peak current and output
average current multiplication as following
Red Trace should be as short as possible
Figure 3. MT3608 Suggested Layout
ID (RMS) IOUT IPEAK
The diode’ s reverse breakdown voltage
should be larger than the output voltage.
MT3608 Rev 3.1
www.aerosemi.com
6
MT3608
PACKAGE DESCRIPTION
SOT23-6
2.80
3.00
0.95
BSC
0.60
TYP
1.20
TYP
EXAMPLE
TOP MARK
AAAA
1.50
1.70
2.60
TYP
2.60
3.00
PIN 1
TOP VIEW
RECOMMENDED SOLDER PAD LAYOUT
GAUGE PLANE
0.25 BSC
0.90
1.30
1.45 MAX
SEATING PLANE
0.30
0.50
0.95 BSC
0.00
0.15
FRONT VIEW
0°~8°
0.30
0.55
0.09
0.20
SIDE VIEW
NOTE:
1.DIMENSIONS ARE IN MILLIMETERS.
2.DRAWING NOT TO SCALE.
3.DIMENSIONS ARE INCLUSIVE OF PLATING.
4.DIMENSIONS ARE EXCLUSIVE OF MOLD FLASH AND METAL BURR.
MT3608 Rev 3.1
www.aerosemi.com
7
MT3608
IMPORTANT NOTICE
Xi’an Aerosemi Technology Co.,Ltd reserve the right to make corrections, enhancements,
improvements and other changes to its semiconductor products and services.
Xi’an Aerosemi Technology Co.,Ltd is not responsible or liable for such altered documentation.
Information of third parties may be subject to additional restrictions.
Xi’an Aerosemi Technology Co.,Ltd does not assume any responsibility for use of any its products
for any particular purpose, nor does Xi’an Aerosemi Technology Co.,Ltd assume any liability
arising out of the application or use of any its products or circuits.
Copyright © 2011, Xi’an Aerosemi Technology Co.,Ltd
Http://www.aerosemi.com
MT3608 Rev 3.1
www.aerosemi.com
8
很抱歉,暂时无法提供与“MT3608”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.37890
- 100+0.36000
- 1000+0.31260
- 3000+0.26530
- 国内价格
- 1+0.46970
- 200+0.30360
- 1500+0.26400
- 3000+0.23320
- 国内价格
- 1+0.75849
- 10+0.71356
- 30+0.69045
- 100+0.67144
- 500+0.66474
- 1000+0.66021
- 国内价格
- 1+0.25360
- 3000+0.24230
- 6000+0.22540
- 国内价格
- 10+0.60830
- 30+0.58710
- 100+0.57090
- 500+0.56510
- 1000+0.56120
- 国内价格
- 100+0.30192
- 500+0.29596
